Additional Resources:
Product Page
PCB Footprint
date
10/09/2019
page
1 of 4
SERIES: SJ-4361X-SMT │ DESCRIPTION: MID MOUNT AUDIO JACK
FEATURES
• mid mount for low profile applications
• 4 conductor
• multiple switch configurations
PART NUMBER KEY
SJ-4361 X-SMT-TR
Base Number
Switch Options
Packaging:
4 = no switch
TR = Tape & Reel
5RS = ring switch
5TS = tip switch
6 = tip and ring switch
7 = tip, ring 1, and ring 2 switch
SPECIFICATIONS
parameter
conditions/description
min
rated input voltage
typ
12
rated input current
contact resistance1
between terminal and mating plug
between terminal in a closed circuit
insulation resistance
at 500 Vdc
voltage withstand
for 1 minute
1
A
50
30
mΩ
mΩ
MΩ
0.3
operating temperature
-25
life
at a rate of 24 cycles/minute
flammability rating
UL94V-0
RoHS
yes
500
Vac
3
kg
85
5,000
1. When measured at a current of less than 100 mA/1 kHz
2. All specifications measured at 10~35°C, humidity at 45~85%, under standard atmospheric pressure, unless otherwise noted.
cuidevices.com
units
Vdc
100
insertion/withdrawal force
Note:
max
°C
cycles
Product Page
PCB Footprint
CUI Devices │ SERIES: SJ-4361X-SMT │ DESCRIPTION: MID MOUNT AUDIO JACK
date 10/09/2019 │ page 2 of 4
MECHANICAL DRAWING
units: mm[inches]
TOLERANCE:
X.X ±0.2mm
X.XX ±0.1mm
X.XXX ±0.05mm
PCB: ±0.05 mm
0.90 0.035
(4 PLCS)
0.80 0.031
(7 PLCS)
4.40 0.173
PLATING
copper alloy
gold flash
terminal (10~12)
copper alloy
gold flash
plastic
PA6T or
equivalent
12.1 0.476
3.00 0.118
1.90 0.075
A
5.4 0.213
5.3 0.209
8.10 0.319
(2 PLCS)
MATERIAL
terminal (1~4)
5.00 0.197
1.000 0.039
(2 PLCS)
2.20 0.087
3.600 0.142
COPLANARITY
0.1
10.2 0.402
DETAIL A
SCALE 12 : 1
6.0 0.236
1.00 0.039
(6 PLCS)
3.0 0.118
2
3
4
8.6 0.339
0.3
10
11
12
1
0.60 0.024
(2 PLCS)
14
0.80 0.031
1.0 0.039
Ø 3.5 MATING PLUG
3.0 0.118
6.0 0.236
10.2 0.402
Model No.
Recommended PCB Layout
Top View
SJ-43614-SMT
SJ-43615RS-SMT
SJ-43615TS-SMT
1
4
3
11
2
1
4
3
10
2
1
4
3
2
Schematic
SJ-43616-SMT
SJ-43617-SMT
1
4
12
3
11
10
2
1
4
3
11
10
2
PIN
1
sleeve
sleeve
sleeve
sleeve
sleeve
2
tip
tip
tip
tip
tip
3
ring 1
ring 1
ring 1
ring 1
ring 1
4
ring 2
ring 2
ring 2
ring 2
ring 2
10
NP
NP
tip switch
tip switch
tip switch
11
NP
ring 1 switch
NP
ring 1 switch
ring 1 switch
12
NP
NP
NP
NP
ring 2 switch
cuidevices.com
Product Page
PCB Footprint
date 10/09/2019 │ page 3 of 4
SOLDERABILITY
parameter
reel storage
at relative humidity
很抱歉,暂时无法提供与“SJ-43615RS-SMT-TR”相匹配的价格&库存,您可以联系我们找货
