Additional Resources:
Product Page
date
10/10/2019
page
1 of 4
SERIES: SJ2-3504X-SMT │ DESCRIPTION: AUDIO JACK
gold flash terminal plating
reflow solder compatible
right angle
surface mount
N
U
ED
FEATURES
TI
PART NUMBER KEY
SJ2-3504 X X - SMT-TR
Switch Options:
A = no switch
C = ring switch
N
# Conductors:
3=3
O
Base Number
Package Style:
SMT = surface mount
Packaging:
TR = Tape & Reel
SPECIFICATIONS
parameter
min
typ
rated input current
contact resistance1
between terminal and mating plug
between terminal in a closed circuit
insulation resistance
at 500 Vdc
voltage withstand
for 1 minute
-25
life
at a rate of 24 cycles/minute
flammability rating
UL94V-0
RoHS
yes
D
1
A
50
30
mΩ
mΩ
MΩ
0.3
operating temperature
500
Vac
3
kg
85
5,000
1. When measured at a current of less than 100 mA/1 kHz
2. All specifications measured at 10~35°C, humidity at 45~85%, under standard atmospheric pressure, unless otherwise noted.
cuidevices.com
units
Vdc
100
insertion/withdrawal force
Note:
max
12
IS
C
rated input voltage
conditions/description
°C
cycles
Product Page
CUI Devices │ SERIES: SJ2-3504X-SMT │ DESCRIPTION: AUDIO JACK
date 10/10/2019│ page 2 of 4
MECHANICAL DRAWING
PLATING
terminal 1
copper alloy
gold flash
terminal 2
copper alloy
gold flash
terminal 3
copper alloy
gold flash
terminal 4
copper alloy
gold flash
terminal 11
copper alloy
gold flash
plastic
PA10T
ED
MATERIAL
N
TI
N
U
units: mm
tolerance:
X.X ±0.2 mm
X.XX ±0.10 mm
X.XXX ±0.050 mm
PCB: ±0.05 mm
IS
C
O
Recommended PCB Layout
Top View
Model No.
SJ2-35043A-SMT
SJ2-35043C-SMT
1
sleeve
sleeve
2
tip
tip
3
ring
ring
4
tip
tip
11
NP
ring switch
Schematic
D
Ø3.5 MATING PLUG
PIN
cuidevices.com
Product Page
date 10/10/2019│ page 3 of 4
SOLDERABILITY
parameter
reel storage
at relative humidity
很抱歉,暂时无法提供与“SJ2-35043A-SMT-TR”相匹配的价格&库存,您可以联系我们找货
