SJ2-3593A-SMT-TR
SJ2-3593A-SMT-TR
    CUIDEVICES
    AUDIOJACK,3.5MM,RT,3CONDUC
SJ2-3593A-SMT-TR 数据手册
Additional Resources: Product Page | 3D Model | PCB Footprint date 11/17/2022 page 1 of 4 SERIES: SJ2-359X-SMT | DESCRIPTION: AUDIO JACK FEATURES • multiple switch configurations • right angle • reflow solder compatible • surface mount PART NUMBER KEY SJ2 - 359 X X - SMT - TR Base Number # Conductors: 3=3 Switch Options: B = tip switch D = tip & ring switch Package Style: SMT = surface mount Packaging: TR = Tape & Reel SPECIFICATIONS parameter conditions/description min rated input voltage typ max 12 rated input current contact resistance between terminal and mating plug between terminal in a closed circuit insulation resistance at 500 Vdc voltage withstand for 1 minute Vdc 1 A 50 30 mΩ mΩ 500 Vac kg 100 MΩ insertion/withdrawal force 0.3 3 operating temperature -25 85 life 5,000 flammability rating UL94V-0 RoHS yes cuidevices.com units °C cycles Additional Resources: Product Page | 3D Model | PCB Footprint CUI DEVICES | SERIES: SJ2-359X-SMT | DESCRIPTION: AUDIO JACK date 11/17/2022 | page 2 of 4 MECHANICAL DRAWING units: mm tolerance: X.X ±0.30 mm X.XX ±0.25 mm X.XXX ±0.20 mm PCB: ±0.05 mm unless otherwise specified DESCRIPTION MATERIAL PLATING/COLOR terminal 1 copper alloy t=0.20 silver over nickel terminal 2 copper alloy t=0.20 silver over nickel terminal 3 copper alloy t=0.20 silver over nickel terminal 4 copper alloy t=0.20 silver over nickel terminal 10 copper alloy t=0.20 silver over nickel terminal 11 copper alloy t=0.20 silver over nickel housing PA9T (UL94V-0) black Recommended PCB Layout Top View Model No. SJ2-3593B-SMT SJ2-3593D-SMT 1 3 Schematic 1 3 11 10 2 10 2 Ø3.5 MATING PLUG PIN 1 sleeve sleeve 2 tip tip 3 ring ring 10 tip switch tip switch 11 NP ring switch cuidevices.com Additional Resources: Product Page | 3D Model | PCB Footprint CUI DEVICES | SERIES: SJ2-359X-SMT | DESCRIPTION: AUDIO JACK date 11/17/2022 | page 3 of 4 SOLDERABILITY parameter conditions/description reel storage 5~25°C, 20~75% humidity reflow soldering see reflow profile Note: min typ 255 260 1. CUI Devices recommends usage of the product within 24 hours after T&R is opened. After 24 hours, CUI Devices recommends drying the parts prior to use. PACKAGING units: mm Reel Size: Ø330 mm Reel QTY: 700 pcs per reel cuidevices.com max units °C Additional Resources: Product Page | 3D Model | PCB Footprint CUI DEVICES | SERIES: SJ2-359X-SMT | DESCRIPTION: AUDIO JACK date 11/17/2022 | page 4 of 4 REVISION HISTORY rev. description date 1.0 initial release 12/12/2016 1.01 added storage and drying conditions 06/09/2017 1.02 brand update 10/10/2019 1.03 discontinued models SJ2-3593C-SMT-TR, SJ2-3593A-SMT-TR & SJ2-3592BSMT-TR; logo, datasheet style update 08/18/2022 1.04 product reengineered for improved manufacturability and production yield, see PCN for details 11/17/2022 The revision history provided is for informational purposes only and is believed to be accurate. CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website. CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may result from its use. CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness. cuidevices.com
SJ2-3593A-SMT-TR 价格&库存
很抱歉,暂时无法提供与“SJ2-3593A-SMT-TR”相匹配的价格&库存,您可以联系我们找货
