35FM3
35FM3
    SWITCHCRAFT
    35FM3
35FM3 数据手册
8 7 6 5 4 3 2 1 RING CONTACT F F TIP CONTACT SLEEVE 0.82 20.8 0.50 12.7 E 0.68 17.4 0.50 12.7 0.09 2.2 0.22 5.6 0.38 9.7 0.52 13.2 E 0.07 1.8 RING CONTACT 0.50 12.7 0.50 12.7 SLEEVE TIP CONTACT D 0.33 8.4 0.141 REF 3.58 0.33 8.4 0.141 REF 3.58 M6 x 0.5 - 6g THREAD 3/8 - 32 THREAD D 3/8 - 32 THREAD 35FM3 & 35FM3AU 35FM3L & 35FM3AUL NON-LOCKING / NON-SEALED LOCKING / NON-SEALED A B C C A B PANEL O-RING 0.390 9.91 MATING O-RING B B SECTION A-A SECTION B-B 35FM3S & 35FM3AUS 35FM3LS & 35FM3AULS RECOMMENDED PANEL MOUNTING HOLE NON-LOCKING / SEALED LOCKING / SEALED NOTES: 1. MATES WITH SWITCHCRAFT'S 3.5MM LOCKING STEREO PLUG. 2. HEX NUT, WASHER AND O-RINGS ARE PROVIDED ASSEMBLED TO THE HOUSING ASSEMBLY. NO O-RINGS SUPPLIED WITH NON-SEALED VERSIONS. A 3. MATERIAL: HOUSINGS, HEX NUT - COPPER ALLOY, NICKEL PLATED FLAT WASHERS - STEEL, NICKEL PLATED CONTACTS - BERYLLIUM COPPER, SILVER OR GOLD PLATED SLEEVE - STEEL, TIN PLATED O-RINGS - RUBBER 4. THIS PRODUCT IS RoHS COMPLIANT. 8 7 PART NUMBER DESCRIPTION CONTACTS 35FM3 FRONT PANEL MOUNT, NON-LOCKING, NON-SEALED SILVER 35FM3AU FRONT PANEL MOUNT, NON-LOCKING, NON-SEALED GOLD 35FM3L FRONT PANEL MOUNT, LOCKING, NON-SEALED SILVER 35FM3AUL FRONT PANEL MOUNT, LOCKING, NON-SEALED GOLD 35FM3LS FRONT PANEL MOUNT, LOCKING, SEALED SILVER 35FM3AULS FRONT PANEL MOUNT, LOCKING, SEALED GOLD 35FM3S FRONT PANEL MOUNT, NON-LOCKING, SEALED SILVER 35FM3AUS FRONT PANEL MOUNT, NON-LOCKING, SEALED GOLD 6 5 CUSTOMER DRAWING THIS DRAWING DESCRIBES A DESIGN CONSIDERED PROPRIETARY IN NATURE, DEVELOPED AND MANUFACTURED BY SWITCHCRAFT INC. AND IS RELEASED ON A CONFIDENTIAL BASIS FOR IDENTIFICATION PURPOSES ONLY. UNLESS OTHERWISE SPECIFIED REV 28206 ECO NUMBER 09/13/19 DATE REVISIONS 4 PC BY - TWO PLACE DECIMALS 0.02 MULT - THREE PLACE DECIMALS 0.005 [0.13] DATE DRAWN BY 02-09-17 AM DO NOT SCALE DRAWING SolidWorks CAD File NAME TEMPER A SPEC No. SCALE CHKD PC 11-06-19 3:1 APVD TJK 11-06-19 3.5MM JACK ASSEMBLY FRONT PANEL MOUNT, RoHS C LBS/M MATERIAL SPEC No. FIRST USED ON [0.5] TJK APVD WIDTH FINISH 1. ALL DIMENSIONS IN INCHES [mm] A SIZE SHEET PART No. 1 OF 1 35FM3_SERIES REV A
35FM3 价格&库存
很抱歉,暂时无法提供与“35FM3”相匹配的价格&库存,您可以联系我们找货
35FM3
    • 1+123.844521+16.08060
    • 10+105.2209910+13.66243
    • 25+98.6305025+12.80668
    • 50+93.9246250+12.19565
    • 100+89.44141100+11.61353
    • 300+86.33475300+11.21014
    库存:1070
