35HDLBAU
35HDLBAU
    SWITCHCRAFT
    35HDLBAU
35HDLBAU 数据手册
1.97 1.09 0.43 0.41 0.139 REF "A" REF CABLE HOLE SEE TABLE A A 0.30 CABLE CLAMP (SLEEVE TERMINAL) 0.56 0.34 0.047 REF THRU HOLE HANDLE & TUBULAR INSLUATOR SHIPPED UNASSEMBLED 0.22 RING TERMINAL 0.06 PART NUMBER NOTES: 1. SPECIFICATIONS: CONTACT RESISTANCE: 20 MILIOHMS MAX. DIELECTRIC WITHSTANDING VOLTAGE - 250 VAC MIN INSULATION RESISTANCE @ 500 VDC - 2,000 MEGAOHMS MIN MAX WORKING VOLTAGE - 250 VAC, 140VDC CURRENT CARRY @ WORKING VOLTAGE - 4 AMPS INSERT / WITHDRAWAL FORCE - TYPICAL 2.5/2 LBS TEMPERATURE RANGE: -20°C TO 85°C (OPERATING) THERMAL SHOCK - MIL-STD-202, METHOD 107G VIBRATION - MIL-STD-202, METHOD 201 LIFE - 5,000 CYCLES 2. MATERIALS: PLUG BODY, TIP ROD & RING - COPPER ALLOY, TIN OR GOLD PLATED PLUG INSULATION - THERMOPLASTIC, BLACK RING TERMINAL - COPPER ALLOY, TIN PLATED CABLE CLAMP - STEEL, TIN PLATED COUPLING RING - COPPER ALLOY, NICKEL PLATED HANDLE - COPPER ALLOY, NICKEL PLATED OR BLACK EPOXY TUBULAR INSULATOR - MYLAR 3. THESE PRODUCTS ARE RoHS COMPLIANT. M6 X 0.5 THREAD 0.19 0.13 FLAT LENGTH ON TIP TERMINAL 0.08 SECTION A-A 3/8-32 UNEF-2A THREAD 1.09 "A" REF CABLE HOLE HANDLE FINISH PLUG FINISH 35HDLBAU BLACK MATTE GOLD PLATED 0.290 35HDLBAUS BLACK MATTE GOLD PLATED 0.175 35HDLBN BLACK MATTE TIN PLATED 0.290 35HDLBNS BLACK MATTE TIN PLATED 0.175 35HDLNAU NICKEL PLATED GOLD PLATED 0.290 35HDLNAUS NICKEL PLATED GOLD PLATED 0.175 35HDLNN NICKEL PLATED TIN PLATED 0.290 35HDLNNS NICKEL PLATED TIN PLATED 0.175 CUSTOMER DRAWING 1.94 THIS DRAWING DESCRIBES A DESIGN CONSIDERED PROPRIETARY IN NATURE, DEVELOPED AND MANUFACTURED BY SWITCHCRAFT INC. AND IS RELEASED ON A CONFIDENTIAL BASIS FOR IDENTIFICATION PURPOSES ONLY. UNLESS OTHERWISE SPECIFIED 1. ALL DIMENSIONS IN INCHES SIZE WIDTH FINISH - TWO PLACE DECIMALS 0.02 - THREE PLACE DECIMALS 0.005 REV 26681 ECO NUMBER 1-7-11 DATE REVISIONS TO SPEC No. FIRST USED ON BY 4-26-11 TJK APVD DO NOT SCALE DRAWING SolidWorks CAD File NAME B LBS/M TEMPER MATERIAL DATE DRAWN A MULT BY JEB SPEC No. SCALE 3:1 CHKD JEB 4-26-11 APVD TJK 10-16-13 3.5 MM LOCKING STEREO PLUG, RoHS SHEET PART No. 1 OF 35HDL_SERIES 1 REV A
35HDLBAU 价格&库存
很抱歉,暂时无法提供与“35HDLBAU”相匹配的价格&库存,您可以联系我们找货
35HDLBAU
  • 1+269.058921+34.80688
  • 10+228.6872610+29.58419
  • 25+214.3645125+27.73133
  • 50+204.1374550+26.40830
  • 100+194.40148100+25.14880
  • 300+179.91745300+23.27507
  • 500+173.55774500+22.45235
库存:586
