35RM3L
35RM3L
    SWITCHCRAFT
    插件
35RM3L 数据手册
8 7 6 5 4 3 2 1 F F RING CONTACT 0.50 12.7 TIP CONTACT 0.50 12.7 SLEEVE E 0.50 12.7 0.41 10.3 0.44 11.2 0.28 7.1 0.31 7.7 E 0.07 1.8 0.06 1.5 RING CONTACT 0.47 11.8 0.15 3.8 0.50 12.7 SLEEVE 0.33 8.4 TIP CONTACT D 0.50 12.7 0.141 REF 3.58 3/8 - 32 THREAD 0.33 8.4 35RM3L & 35RM3AUL 35RM3 & 35RM3AU 0.51 12.9 D 3/8 - 32 THREAD LOCKING / NON-SEALED NON-LOCKING / NON-SEALED 0.50 12.7 0.141 REF 3.58 M6 x 0.5 - 6g THREAD 0.40 10.0 0.30 7.5 0.07 1.8 B A C C 0.50 12.7 0.33 8.4 A 0.141 REF 3.58 B PANEL O-RING 0.390 9.91 MATING O-RING B B SECTION A-A SECTION B-B 35RM3S & 35RM3AUS 35RM3LS & 35RM3AULS RECOMMENDED PANEL MOUNTING HOLE NON-LOCKING / SEALED LOCKING / SEALED NOTES: 1. MATES WITH SWITCHCRAFT'S 3.5MM LOCKING STEREO PLUG. DESCRIPTION CONTACTS 35RM3 REAR PANEL MOUNT, NON-LOCKING, NON-SEALED SILVER 3. MATERIAL: HOUSINGS, HEX NUT - COPPER ALLOY, NICKEL PLATED FLAT WASHERS - STEEL, NICKEL PLATED CONTACTS - BERYLLIUM COPPER, SILVER OR GOLD PLATED SLEEVE - STEEL, TIN PLATED O-RINGS - RUBBER 35RM3AU REAR PANEL MOUNT, NON-LOCKING, NON-SEALED GOLD 35RM3L REAR PANEL MOUNT, LOCKING, NON-SEALED SILVER 35RM3AUL REAR PANEL MOUNT, LOCKING, NON-SEALED GOLD 35RM3LS REAR PANEL MOUNT, LOCKING, SEALED SILVER 4. THIS PRODUCT IS RoHS COMPLIANT. 35RM3AULS REAR PANEL MOUNT, LOCKING, SEALED GOLD 35RM3S REAR PANEL MOUNT, NON-LOCKING, SEALED SILVER 35RM3AUS REAR PANEL MOUNT, NON-LOCKING, SEALED GOLD 2. HEX NUT, WASHER AND O-RINGS ARE PROVIDED ASSEMBLED TO THE HOUSING ASSEMBLY. NO O-RINGS SUPPLIED WITH NON-SEALED VERSIONS. A PART NUMBER 8 7 6 5 CUSTOMER DRAWING THIS DRAWING DESCRIBES A DESIGN CONSIDERED PROPRIETARY IN NATURE, DEVELOPED AND MANUFACTURED BY SWITCHCRAFT INC. AND IS RELEASED ON A CONFIDENTIAL BASIS FOR IDENTIFICATION PURPOSES ONLY. UNLESS OTHERWISE SPECIFIED REV 28206 ECO NUMBER 09/13/19 DATE REVISIONS 4 PC BY - TWO PLACE DECIMALS 0.02 MULT - THREE PLACE DECIMALS 0.005 [0.13] DATE DRAWN BY 02-10-17 AM DO NOT SCALE DRAWING SolidWorks CAD File NAME TEMPER A SPEC No. SCALE CHKD PC 11-06-19 3:1 APVD TJK 11-06-19 3.5MM JACK ASSEMBLY REAR PANEL MOUNT, RoHS C LBS/M MATERIAL SPEC No. FIRST USED ON [0.5] TJK APVD WIDTH FINISH 1. ALL DIMENSIONS IN INCHES [mm] A SIZE SHEET PART No. 1 OF 1 35RM3_SERIES REV A
35RM3L 价格&库存
很抱歉,暂时无法提供与“35RM3L”相匹配的价格&库存,您可以联系我们找货
