PJRAS2X1S01X
PJRAS2X1S01X
    SWITCHCRAFT
    PJRAS2X1S01X
PJRAS2X1S01X 数据手册
1.102 [28,0] NOTES: 1. ALL DIMENSIONS ARE REFERENCE. INSERT (A) COLOR INSERT (B) COLOR SHELL AND SLEEVE TERMINAL FINISH PJRAS2X1S01X RED WHITE NICKEL PLATED PJRAS2X1S01AUX RED WHITE GOLD PLATED PJRAS2X1S02X WHITE RED NICKEL PLATED PJRAS2X1S02AUX WHITE RED GOLD PLATED PART NUMBER 2. MATERIALS: B HOUSING: ABS OR PBT, UL-94HB, BLACK B COLOR INSERT: POM OR PBT, UL-94HB SHELL & SLEEVE TERMINALS: COPPER ALLOY, NICKEL OR GOLD PLATED TIP TERMINALS: COPPER ALLOY, TIN PLATED 0.051 [1,3] 0.969 [24,6] 0.118 [3,0] 0.345 [8,75] R0.008 [0,2] TYP (8) T T S S 0.492 [12,5] 0.207 [5,25] FRONT PLATE: COPPER ALLOY, NICKEL PLATED 3. THIS PART IS RoHS COMPLIANT FRONT PLATE 0.323 [8,2] 0.094 HOUSING [2,4] 0.0126 PLATE [3,2] 0.551 [14,0] 0.276 [7,0] 0.413 [10,5] INSERT (B) 0.148 [3,75] TYP (2) 0.532 [13,5] 0.128 [3,25] P.C. BOARD LAYOUT HOUSING COMPONENT SIDE 0.472 [12,0] 0.256 [6,5] 0.158 [4,0] 0.423 [10,75] 0.059 [1,5] SHELL INSERT (A) 0.059 [1,5] 0.512 [13,0] 0.327 [8,3] TIP (T) TERMINALS T INSULATOR SLEEVE (S) TERMINALS 0.197 [5,0] S 0.039 [1,0] TYP (2) 0.345 [8,75] TYP (2) JACKS 0.148 [3,75] TYP (2) 0.492 [12,5] 0.968 [24,6] SCHEMATIC CUSTOMER DRAWING 1.062 [27,0] THIS DRAWING DESCRIBES A DESIGN CONSIDERED PROPRIETARY IN NATURE, DEVELOPED AND MANUFACTURED BY SWITCHCRAFT INC. AND IS RELEASED ON A CONFIDENTIAL BASIS FOR IDENTIFICATION PURPOSES ONLY. STAR SYMBOL DENOTES CRITICAL DIMENSION 1.122 [28,5] UNLESS OTHERWISE SPECIFIED 1. ALL DIMENSIONS IN INCHES -TWO PLACE DECIMALS 0.01 -THREE PLACE DECIMALS 0.005 -ANGLES 1 -ALL DIA. CONCENTRIC WITHIN 0.005 T.I.R. B 27929 08-17-17 PC TJK 2. FEATURES ON THE SAME CENTERLINE MUST BE ALIGNED WITHIN 0.002 A 25181 1-13-06 JL TJK 3. REMOVE ALL BURRS REV ECO NUMBER DATE BY APVD REVISIONS SIZE WIDTH FINISH SCALE DATE DRAWN BY CHKD 13-Jan-06 JL TJK 1-13-06 2:1 APVD TJK 1-13-06 PHONO JACK, RIGHT ANGLE, 2 POS. SCREW MOUNT, SHIELDED, RoHS B TEMPER SPEC No. FIRST USED ON DO NOT SCALE DRAWING LBS/M MATERIAL SPEC No. NAME Pro/Engineer CAD File MULT SHEET 1 OF 1 PART No. PJRAS2X1S__X SERIES REV B
PJRAS2X1S01X 价格&库存
很抱歉,暂时无法提供与“PJRAS2X1S01X”相匹配的价格&库存,您可以联系我们找货
PJRAS2X1S01X
  • 1+23.763741+3.07421
  • 10+20.1644710+2.60859
  • 25+18.8943725+2.44428
  • 50+17.9914550+2.32747
  • 162+16.55907162+2.14217
  • 324+15.76823324+2.03987
  • 648+15.01571648+1.94251
  • 1134+14.434451134+1.86732
  • 2592+13.617212592+1.76160
库存:1127
