SURFACE MOUNT AUDIO JACKS
• Mates with 2.5mm and 3.5mm plugs
• Designed for reliable interface with audio equipment
including computer speakers, headphones, sound
cards, cell phones, etc.
• Models available for mono and stereo applications
• Low profile, surface mount design
SPECIFICATIONS
Housing: Polyamide, UL Rated 94V-0
Ground Terminal: .012 (.30) Brass, Gold Flash ➀
Spring Contacts: .008 (.20) Phosphor Bronze,
Gold Flash ➁ ➄
Shunt Terminals: .012 (.30) Brass, Gold flash ➂ ➃
SUPPLIED ON TAPE AND REEL
FOR 2.5 mm PLUGS
.102 [2.6]
I. DIA.
.158 [4.0]
.079 [2.01]
.079 [2.01]
.067 [1.70]
.265 [6.8]
.180 [4.6]
.110 [2.8]
1
.217 .110 [2.8] 1
.473 [5.5]
3
[12.0]
4
2
5
.157
[4.0] .295
[7.5]
2
.532 .294
[13.5] [7.5]
1
2
3
4
5
.118 [3.0]
.063 [1.60]
DIA. (2) PLS
.197 [5.0]
4
.157 [4.0]
.472 [12.0]
.088 [2.24]
(3) PLS
.295
[7.5]
.354 [9.0]
.240 [6.1]
.118 [3.0]
.197 [5.0]
4
5
Tape Spec’s: 24mm wide; 16mm pitch
Reel Spec’s: 15 inch reel (1,000 pieces per reel)
.079 [2.01]
(3) PLS
.110 [2.8]
1
.240
.590 .354 [6.1]
[15.0] [9.0]
.110 [2.8] 1
4
.193
[4.9]
2
.063 [1.60]
DIA. (2) PLS
.314
.532
[8.0]
[13.5]
.366
[9.3]
.236 [6.0]
3
2
.039 [0.99]
(3) PLS
4
5
.472 [12.0]
.059
[1.50] (2) PLS
5
.118 [3.00]
.193 [4.9]
.100 [2.6]
(2) PLS
.366 [9.3]
1
CAT. NO. 980TR (Stereo)
CAT. NO. 982TR (Mono)
(TOP VIEW)
.059 [1.5]
.039 [1.0]
MONO
SCHEMATIC
5
Pad Layout
.142 [3.6]
I. DIA.
.197 [5.0]
STEREO
SCHEMATIC
(TOP VIEW)
.059 [1.50]
.020 [0.51]
.157 [4.0]
AUDIO JACKS & BINDING POSTS
.374 [9.5]
Pad Layout
.354 [9.0]
.039 [0.99]
(5) PLS
FOR 3.5 mm PLUGS
CAT. NO. 981TR (Stereo)
Reel Spec’s: 15 inch reel (800 pieces per reel)
CAT. NO. 983TR (Mono)
BINDING POSTS
All Keystone binding posts are designed to prevent accidental contact with current
carrying parts. They feature a “limited opening” captivated head to insure safety.
Ideal for audio circuitry, R.F. circuitry, oscilloscopes, power supplies and various
other applications.
These multi-purpose binding posts feature high current rating, captivated heads and
anti-rotation stud mounting.
Note: Binding Posts accept .175” (4.5) Banana Plugs, .080” (2.08) Tip Plugs, Spade
Lugs, Alligator Clips, Wires and EZ hooks.
STANDARD BINDING POST
.719 [18.3]
UNINSULATED BINDING POST
.423 [10.8]
DIA.
.086 [2.18]
DIA.
.423 [10.8]
DIA.
.719 [18.3]
.086 [2.18]
DIA.
.203 [5.2]
MAX.
.312-32 THREAD
Mounting Detail
.828 [21.1]
.203 [5.2]
MAX.
.437 [11.1]
4-40 THREAD
6-32 THREAD
.250 [6.4]
.234 [6.0]
.328 [8.4]
DIA.
MATERIAL:
For panels up
to .281 (7.1) thick
Stud: Brass per QQ-B-626
Plating: Silver Plate
Insulation: Nylon
Current Rating: 15 Amps
Stud to Panel Capacitance: 3.3 pF Nominal
CAT. NO.
7004
7005
COLOR
RED
BLACK
For panels up
to .313 (8.0) thick
MATERIAL:
Plating: Nickel Plate
Insulation: Nylon
Current Rating: 15 Amps, 1000V AC Working
COLOR
RED
BLACK
STANDARD HEX HEAD
STANDARD DUAL HEX HEAD
.480 [12.2]
HEX.
.625 [15.9]
CAT. NO.
7006
7007
.625 [15.9]
.093 [2.36]
DIA.
(2) PLS
.480 [12.2]
HEX.
.093 [2.36]
DIA.
.920 [23.4]
MAX.
Mounting Detail
.500 [12.7]
DIA.
.920 [23.4]
MAX.
THREAD
.468 [11.9]
.750 [19.1]
1.380 [35.1]
THREAD
Mounting Detail
.750 [19.1]
.656 [16.7]
.500 [12.7] DIA.
MATERIAL:
Stud: Brass per ASTM B-16.
Insulation: Nylon
Current Rating: 30 Amps,
1000V AC Working
112
GOLD PLATE
CAT.
NO. THREAD
4108 8-32
4109 10-32
Tel (718) 956-8900 • Fax (718) 956-9040
(800) 221-5510 • kec@keyelco.com
NICKEL PLATE
CAT.
NO. THREAD
7018 8-32
7019 10-32
MATERIAL:
Insulation: Nylon
1000V AC Working
RoHS COMPLIANT ~ ISO 9001 CERTIFIED
GOLD PLATE
CAT.
NO. THREAD COLOR
4096 8-32
RED
4097 8-32
BLACK
7016 10-32
RED
7017 10-32 BLACK
7023 10-32 WHITE
7024 10-32 YELLOW
NICKEL PLATE
CAT.
NO. THREAD COLOR
4091 8-32
RED
4092 8-32
BLACK
4093 10-32
RED
4094 10-32 BLACK
4198 10-32 WHITE
4199 10-32 YELLOW
www.keyelco.com
31-07 20th Road – Astoria, NY 11105-2017
很抱歉,暂时无法提供与“983TR”相匹配的价格&库存,您可以联系我们找货
