PJRAS1X1S03AU
PJRAS1X1S03AU
    SWITCHCRAFT
    PHONO JACK 1POS R/A RED GOLD
PJRAS1X1S03AU 数据手册
NOTES: 2. MATERIALS: C HOUSING: ABS OR PBT, UL-94HB, BLACK C COLOR INSERT: POM OR PBT, UL-94HB SHELL & SLEEVE TERMINAL: COPPER ALLOY, SEE TABLE FOR PLATING. SHELL AND SLEEVE TERMINAL FINISH TIP TERMINAL FRONT PLATE & GROUND TERMINAL PJRAS1X1S01X BLACK NICKEL PLATED MATTE TIN PLATED MATTE TIN PLATED PJRAS1X1S01AUX BLACK GOLD PLATED MATTE TIN PLATED MATTE TIN PLATED PJRAS1X1S01AUALLX BLACK GOLD PLATED GOLD PLATED GOLD PLATED PJRAS1X1S02X WHITE NICKEL PLATED MATTE TIN PLATED MATTE TIN PLATED PJRAS1X1S02AUX WHITE GOLD PLATED MATTE TIN PLATED MATTE TIN PLATED PJRAS1X1S03X RED NICKEL PLATED MATTE TIN PLATED MATTE TIN PLATED PJRAS1X1S03AUX RED GOLD PLATED MATTE TIN PLATED MATTE TIN PLATED PJRAS1X1S03AUALLX B TIP TERMINAL: COPPER ALLOY, SEE TABLE FOR PLATING B FRONT PLATE & GROUND TERMINAL: COPPER ALLOY, SEE TABLE FOR PLATING 3. THIS PART IS RoHS COMPLIANT RED GOLD PLATED GOLD PLATED GOLD PLATED PJRAS1X1S04X YELLOW NICKEL PLATED MATTE TIN PLATED MATTE TIN PLATED PJRAS1X1S04AUX YELLOW GOLD PLATED MATTE TIN PLATED MATTE TIN PLATED PJRAS1X1S05X BLUE NICKEL PLATED MATTE TIN PLATED MATTE TIN PLATED PJRAS1X1S05AUALLX BLUE GOLD PLATED GOLD PLATED GOLD PLATED PJRAS1X1S06X GREEN NICKEL PLATED MATTE TIN PLATED MATTE TIN PLATED PJRAS1X1S06AUALLX GREEN GOLD PLATED GOLD PLATED GOLD PLATED PJRASIXIS07X ORANGE NICKEL PLATED MATTE TIN PLATED MATTE TIN PLATED PJRAS1X1S07AUX ORANGE GOLD PLATED MATTE TIN PLATED MATTE TIN PLATED 0.394 [10,0] 0.094 HOUSING [2,4] 0.098 PLATE [2.5] 0.276 [7,0] 0.728 [18,5] 0.532 [13,5] B INSERT COLOR PART NUMBER 1. ALL DIMENSIONS ARE REFERENCE. B INSERT 0.256 [6,5] 0.394 [10,0] 0.417 [10,6] 0.148 [3,75] R0.008 [0,2] TYP (8) 0.051 [1,3] 0.118 [3,0] T G 0.492 [12,5] S 0.345 [8,75] 0.207 [5,25] 0.059 [1,5] 0.551 [14,0] 0.323 [8,2] 0.047 [1,2] SHELL 0.512 [13,0] P.C. BOARD LAYOUT COMPONENT SIDE T HOUSING 0.327 [8,3] S FRONT PLATE G INSULATOR 0.158 [4,0] 0.197 [5,0] 0.417 [10,6] 0.345 [8,75] TIP (T) TERMINAL 0.148 [3,75] UNLESS OTHERWISE SPECIFIED 1. ALL DIMENSIONS IN INCHES -TWO PLACE DECIMALS 0.01 -THREE PLACE DECIMALS 0.005 -ANGLES 1 -ALL DIA. CONCENTRIC WITHIN 0.005 T.I.R. C 27929 08-17-17 PC TJK B 25738 10-26-07 TJK TJK 2. FEATURES ON THE SAME CENTERLINE MUST BE ALIGNED WITHIN 0.002 A 25181 1-13-06 JL TJK 3. REMOVE ALL BURRS REV ECO NUMBER DATE BY APVD REVISIONS SIZE WIDTH CUSTOMER DRAWING MULT FINISH SCALE DATE DRAWN BY CHKD 13-Jan-06 JL TJK 1-13-06 2:1 APVD TJK 1-13-06 PHONO JACK, RIGHT ANGLE, 1 POS. SCREW MOUNT, SHIELDED, RoHS B TEMPER SPEC No. FIRST USED ON DO NOT SCALE DRAWING LBS/M MATERIAL SPEC No. NAME Pro/Engineer CAD File SCHEMATIC THIS DRAWING DESCRIBES A DESIGN CONSIDERED PROPRIETARY IN NATURE, DEVELOPED AND MANUFACTURED BY SWITCHCRAFT INC. AND IS RELEASED ON A CONFIDENTIAL BASIS FOR IDENTIFICATION PURPOSES ONLY. STAR SYMBOL DENOTES CRITICAL DIMENSION 0.276 [7,0] 0.039 [1,0] SLEEVE (S) TERMINAL 0.492 [12,5] 0.512 [13,0] 0.148 [3,75] GROUND (G) TERMINAL SHEET 1 OF 1 PART No. PJRAS1X1S__X SERIES REV C
PJRAS1X1S03AU 价格&库存
很抱歉,暂时无法提供与“PJRAS1X1S03AU”相匹配的价格&库存,您可以联系我们找货
