PJRAN2X1U02X
PJRAN2X1U02X
    SWITCHCRAFT
    PJRAN2X1U02X
PJRAN2X1U02X 数据手册
NOTES: PART NUMBER INSERT (A) COLOR INSERT (B) COLOR SHELL AND SLEEVE TERMINAL FINISH PJRAN2X1U01X RED WHITE NICKEL PLATED PJRAN2X1U01AUX RED WHITE GOLD PLATED PJRAN2X1U02X WHITE RED NICKEL PLATED PJRAN2X1U02AUX WHITE RED GOLD PLATED 1. ALL DIMENSIONS ARE REFERENCE. 2. MATERIALS: B B HOUSING: ABS OR PBT, UL-94HB, BLACK COLOR INSERT: POM OR PBT, UL94-HB 0.295 TYP (2) [7,5] 0.039 X 0.098 [1.0] X [2.5] TYP (4) 0.146 [3,7] SHELL & SLEEVE TERMINAL: COPPER ALLOY,NICKEL OR GOLD PLATED TIP & SHUNT TERMINALS: COPPER ALLOY, TIN PLATED 0.158 [4,0] 3. THIS PART IS RoHS COMPLIANT 0.591 [15,0] 0.098 X 0.051 [2.5] X [1.3] TYP (2) 0.984 [25,0] INSERT (B) P.C. BOARD LAYOUT 0.768 [19,5] 0.591 [15,0] INSERT (A) 0.079 [2,0] SHELL COMPONENT SIDE HOUSING 0.374 [9,5] 0.217 [5,5] 2 0.327 [8,3] 3 0.314 [8,0] 1 0.158 [4,0] SCHEMATIC 0.059 [1,5] TYP (2) JACKS 0.532 [13,5] SHUNT (3) 0.295 [7,5] TYP (2) 0.082 [2,1] TYP (2) 0.158 [4,0] CUSTOMER DRAWING SLEEVE (1) TIP (2) THIS DRAWING DESCRIBES A DESIGN CONSIDERED PROPRIETARY IN NATURE, DEVELOPED AND MANUFACTURED BY SWITCHCRAFT INC. AND IS RELEASED ON A CONFIDENTIAL BASIS FOR IDENTIFICATION PURPOSES ONLY. STAR SYMBOL DENOTES CRITICAL DIMENSION UNLESS OTHERWISE SPECIFIED 1. ALL DIMENSIONS IN INCHES -TWO PLACE DECIMALS 0.01 -THREE PLACE DECIMALS 0.005 -ANGLES 1 -ALL DIA. CONCENTRIC WITHIN 0.005 T.I.R. B 27929 08-17-17 PC TJK 2. FEATURES ON THE SAME CENTERLINE MUST BE ALIGNED WITHIN 0.002 A 25181 1-13-06 JL TJK 3. REMOVE ALL BURRS REV ECO NUMBER DATE BY APVD REVISIONS SIZE MULT FINISH SCALE DATE DRAWN BY CHKD 13-Jan-06 JL TJK 1-13-06 2:1 APVD TJK 1-13-06 PHONO JACK, RIGHT ANGLE 2 POS, PC MOUNT, UNSHIELDED, RoHS B TEMPER SPEC No. FIRST USED ON DO NOT SCALE DRAWING LBS/M MATERIAL SPEC No. NAME Pro/Engineer CAD File WIDTH SHEET 1 OF 1 PART No. PJRAN2X1U__X SERIES REV B
PJRAN2X1U02X 价格&库存
很抱歉,暂时无法提供与“PJRAN2X1U02X”相匹配的价格&库存,您可以联系我们找货
