PJRAS3X2S01AUX
PJRAS3X2S01AUX
    SWITCHCRAFT
    PHONO JACK 6POS R/A WHT/RED GOLD
PJRAS3X2S01AUX 数据手册
T2 1. ALL DIMENSIONS ARE REFERENCE. C C C 1.654 [42,0] 0.051 [ 1,3] TYP (6) NOTES: 0.118 [3,0] 2. MATERIALS: HOUSING: ABS OR PBT, UL-94HB, BLACK COLOR INSERTS: POM OR PBT, UL-94HB INSULATORS: POM OR PBT, UL-94HB SHELL & SLEEVE TERMINAL: COPPER ALLOY, NICKEL OR GOLD PLATED TIP TERMINALS: COPPER ALLOY, TIN PLATED FRONT PLATES: COPPER ALLOY, NICKEL PLATED T2 T1 T2 T1 S 0.345 [8,75] S 0.492 [12,5] S S SCHEMATIC TYP (3) JACKS 3. THIS PART IS RoHS COMPLIANT R 0.008 [ 0,2] TYP (8) 0.207 [5,25] 0.551 [14,0] TYP (2) 1.614 [41,0] 0.551 [14,0] TYP (2) T1 T2 T1 0.295 [7,5] TYP (3) 0.059 [1,5] TYP (3) 1.520 [38,6] 0.276 [7,0] 0.323 [8,2] P.C. BOARD LAYOUT 0.539 [13,7] COMPONENT SIDE 0.059 [1,5] SHELL 0.327 [8,3] 1.122 [28,5] HOUSING 0.551 [14,0] 0.532 [13,5] TIP (T2) TERMINALS 0.413 [10,5] 0.256 [6,5] TIP (T1) TERMINALS INSULATOR 0.148 [3,75] TYP (3) 0.295 [7,5] TYP (3) 0.098 [2,5] PLATE SLEEVE (S) TERMINAL 0.158 [4,0] 0.094 HOUSING [2,4] 0.130 PLATE [3,3] 0.197 [5,0] 0.345 [8,75] 0.039 [1,0] TYP (6) 0.148 [3,75] TYP (3) 0.148 [3,75] TYP (3) 0.492 [12,5] THIS DRAWING DESCRIBES A DESIGN CONSIDERED PROPRIETARY IN NATURE, DEVELOPED AND MANUFACTURED BY SWITCHCRAFT INC. AND IS RELEASED ON A CONFIDENTIAL BASIS FOR IDENTIFICATION PURPOSES ONLY. STAR SYMBOL DENOTES CRITICAL DIMENSION UNLESS OTHERWISE SPECIFIED 1.520 [38,6] 1. ALL DIMENSIONS IN INCHES -TWO PLACE DECIMALS 0.01 -THREE PLACE DECIMALS 0.005 -ANGLES 1 -ALL DIA. CONCENTRIC WITHIN 0.005 T.I.R. C 27929 08-17-17 PC TJK B 25610 4-11-07 TJK TJK 2. FEATURES ON THE SAME CENTERLINE MUST BE ALIGNED WITHIN 0.002 A 25181 1-12-06 JL TJK 3. REMOVE ALL BURRS REV ECO NUMBER DATE BY APVD REVISIONS SIZE WIDTH MULT FINISH SCALE DATE DRAWN BY CHKD 12-Jan-06 JL TJK 1-12-06 2:1 APVD TJK 1-12-06 PHONO JACK, RIGHT ANGLE, 6 POS. SCREW MOUNT, SHIELDED, RoHS B TEMPER SPEC No. FIRST USED ON DO NOT SCALE DRAWING LBS/M MATERIAL SPEC No. NAME Pro/Engineer CAD File CUSTOMER DRAWING SHEET 1 OF 2 PART No. PJRAS3X2S__X SERIES REV C INSERT (E) INSERT (D) INSERT (F) PART NUMBER PJRAS3X2S01X FRONT PLATE ISOLATED PAIR FRONT PLATE PJRAS3X2S01AUX PJRAS3X2S02X PJRAS3X2S02AUX PJRAS3X2S03X PJRAS3X2S04X B INSERT (A) INSERT (B) PJRAS3X2S05X INSERT COLOR INSERT COLOR INSERT COLOR D E F A B C WHITE WHITE WHITE RED RED RED WHITE WHITE WHITE RED RED RED RED WHITE YELLOW RED WHITE YELLOW RED WHITE YELLOW RED WHITE YELLOW RED WHITE YELLOW RED WHITE YELLOW WHITE WHITE WHITE YELLOW YELLOW YELLOW RED GREEN BLUE RED GREEN BLUE ISOLATED PAIR FRONT PLATE LOCATIONS SHELL AND SLEEVE TERMINAL FINISH FIGURE 1 NICKEL PLATED FIGURE 1 GOLD PLATED FIGURE 1 NICKEL PLATED FIGURE 1 GOLD PLATED FIGURE 2 NICKEL PLATED FIGURE 1 NICKEL PLATED FIGURE 1 NICKEL PLATED INSERT (C) FIGURE 1 INSERT (E) INSERT (D) INSERT (F) ISOLATED PAIR FRONT PLATE FRONT PLATE CUSTOMER DRAWING SCALE 2:1 INSERT (A) INSERT (B) INSERT (C) DATE DRAWN 12-Jan-06 FIGURE 2 DRAWN BY JL Pro/Engineer CAD File B SHEET 2 OF 2 PART No. PJRAS3X2S__X SERIES REV C
PJRAS3X2S01AUX 价格&库存
很抱歉,暂时无法提供与“PJRAS3X2S01AUX”相匹配的价格&库存,您可以联系我们找货
