PJRAS1X3S02X
PJRAS1X3S02X
    SWITCHCRAFT
    PHONO JACK 3POS R/A GRN/BLU/RED
PJRAS1X3S02X 数据手册
0.512 [13,0] 0.323 [8,2] 0.276 [7,0] FRONT PLATE 0.059 [1,5] 0.413 [10,5] 0.394 [10,0] 0.327 [8,3] TIP (T3) TERMINAL 0.256 [6,5] T2 S 0.492 [12,5] 0.345 [8,75] 0.295 [7,5] TIP (T2) TERMINAL 0.417 [10,6] HOUSING 0.532 [13,5] T1 0.207 [5,25] 0.094 HOUSING [2,4] 0.130 PLATE [3,3] 0.551 [14,0] 0.051 [1,3] S3 0.630 [16,0] INSERT (B) 1.661 [42,2] 0.264 [6,7] T3 0.118 [3,0] 0.787 [20,0] INSERT (A) 0.551 [14,0] 0.179 [4,55] 0.059 TYP (2) [1,5] R0.008 [0,2] TYP (8) 0.866 [22,0] 0.551 [14,0] 0.177 [4,5] SHELL TIP (T1) TERMINAL P.C. BOARD LAYOUT COMPONENT SIDE INSULATOR SLEEVE (S) TERMINAL INSERT (C) 0.417 [10,6] 0.158 [4,0] 0.179 [4,55] 0.148 [3,75] 0.264 [6,7] 0.197 [5,0] T3 SLEEVE (S3) TERMINAL 0.345 [8,75] T1 0.787 [20,0] INSERT (A) COLOR INSERT (B) COLOR INSERT (C) COLOR SHELL AND SLEEVE TERMINAL FINISH PJRAS1X3S01X RED WHITE YELLOW NICKEL PLATED PJRAS1X3S01AUX RED WHITE YELLOW GOLD PLATED PJRAS1X3S02X GREEN BLUE RED NICKEL PLATED PJRAS1X3S02AUX GREEN BLUE RED GOLD PLATED PART NUMBER 2. MATERIALS: B COLOR INSERT: POM OR PBT, UL-94HB B INSULATOR: POM OR PBT, UL-94HB UNLESS OTHERWISE SPECIFIED 1. ALL DIMENSIONS IN INCHES -TWO PLACE DECIMALS 0.01 -THREE PLACE DECIMALS 0.005 -ANGLES 1 -ALL DIA. CONCENTRIC WITHIN 0.005 T.I.R. TIP TERMINALS: COPPER ALLOY, TIN PLATED 3. THIS PART IS RoHS COMPLIANT B 27929 08-17-17 PC TJK 2. FEATURES ON THE SAME CENTERLINE MUST BE ALIGNED WITHIN 0.002 A 25181 1-13-06 JL TJK 3. REMOVE ALL BURRS REV ECO NUMBER DATE BY APVD REVISIONS SIZE WIDTH SCHEMATIC CUSTOMER DRAWING MULT FINISH SCALE DATE DRAWN BY CHKD 13-Jan-06 JL TJK 1-13-06 2:1 APVD TJK 1-13-06 PHONO JACK, RIGHT ANGLE, 3 POS. SCREW MOUNT, SHIELDED, RoHS B TEMPER SPEC No. FIRST USED ON DO NOT SCALE DRAWING LBS/M MATERIAL SPEC No. NAME Pro/Engineer CAD File S THIS DRAWING DESCRIBES A DESIGN CONSIDERED PROPRIETARY IN NATURE, DEVELOPED AND MANUFACTURED BY SWITCHCRAFT INC. AND IS RELEASED ON A CONFIDENTIAL BASIS FOR IDENTIFICATION PURPOSES ONLY. STAR SYMBOL DENOTES CRITICAL DIMENSION SHELL & SLEEVE TERMINALS: COPPER ALLOY, NICKEL OR GOLD PLATED FRONT PLATE: COPPER ALLOY, NICKEL PLATED T2 0.640 [16,25] 1. ALL DIMENSIONS ARE REFERENCE. HOUSING: ABS OR PBT, UL-94HB, BLACK S3 0.148 [3,75] TYP (2) 0.492 [12,5] NOTES: B 0.039 [1,0] TYP (2) SHEET 1 OF 1 PART No. PJRAS1X3S__X SERIES REV B
PJRAS1X3S02X 价格&库存
很抱歉,暂时无法提供与“PJRAS1X3S02X”相匹配的价格&库存,您可以联系我们找货
