1.05
MAX
0.75
0.375
REF
0.25
3/8-32 UNEF-2A
THREAD
30°
0.56
MAX
30°
TIP
TERMINAL
SLEEVE
TERMINAL
HARDWARE
SEE NOTE 1
1.015 REF
TIP SHUNT
TERMINAL
NOTES:
1. HARDWARE SHIPPED UNASSEMBLED.
K178 WASHER AND K180 HEX NUT.
0.375
+0.020
-0.000
2. MATERIALS:
BUSHING - BRASS, NICKEL PLATED
INSULATING WASHERS - PHENOLIC
SLEEVE TERMINAL - BRASS, HOT TIN COATED
C TIP & SHUNT SPRINGS - COPPER ALLOY, SILVER PLATED
METAL WASHERS - STEEL, NICKEL PLATED
HEX NUT - BRASS, NICKEL PLATED
MOUNTING HOLE
CUSTOMER DRAWING
3. THIS PRODUCT IS RoHS COMPLIANT.
STAR SYMBOL DENOTES CRITICAL DIMENSION
UNLESS OTHERWISE SPECIFIED
1. ALL DIMENSIONS IN INCHES
-TWO PLACE DECIMALS
0.01
-THREE PLACE DECIMALS
0.005
-ANGLES
1
-ALL DIA. CONCENTRIC WITHIN 0.005 T.I.R.
2. FEATURES ON THE SAME CENTERLINE
MUST BE ALIGNED WITHIN 0.002
C
REDRAWN - 26696
1-20-11
TJK
TJK
REV
ECO NUMBER
DATE
BY
APVD
REVISIONS
3. REMOVE ALL BURRS
THIS DRAWING DESCRIBES A DESIGN CONSIDERED PROPRIETARY IN NATURE, DEVELOPED AND MANUFACTURED
BY SWITCHCRAFT INC. AND IS RELEASED ON A CONFIDENTIAL BASIS FOR IDENTIFICATION PURPOSES ONLY.
SIZE
MULT
FINISH
SCALE
DATE DRAWN
BY
CHKD
5-30-20
TJK
TJK
5-30-20
A
TEMPER
SPEC No.
FIRST USED ON
DO NOT SCALE DRAWING
LBS/M
MATERIAL
SPEC No.
NAME
Pro/Engineer CAD File
WIDTH
2:1
APVD
TJK
5-30-20
2 CONDUCTOR
1/4" LITTEL JAX, RoHS
SHEET
PART No.
1
L12A
OF
1
REV
C
很抱歉,暂时无法提供与“L12A”相匹配的价格&库存,您可以联系我们找货
