35RAPC7J
35RAPC7J
    SWITCHCRAFT
    35RAPC7J
35RAPC7J 数据手册
FRONT FACE OF JACK 0.148 3.76 2X 0.295 7.49 0.079 2.01 0.197 5.00 0.079 1.99 6 8 2X 4 3 RECOMMENDED PCB HOLE PATTERN COMPONENT SIDE 0.142 3.61 2X 1.00 25.5 0.492 12.50 0.591 15.01 0.295 7.49 2X 0.256 6.50 0.197 5.00 0.12 3.0 0.043 1.09 0.394 10.01 7 1 8X 0.50 12.7 0.55 14.0 2 5 CL 0.157 3.99 HOLE FOR THREAD CUTTING FASTENER 0.086 0.328 [2.18] [8.33] 0.110 0.040 [2.79] [1.02] 2X 0.02 0.5 8X 0.276 7.01 2X 0.11 2.8 0.10 2.4 6X P 0.148 3.76 8X 0.032 0.81 0.016 0.41 R PIN 3 T PIN 2 S PIN 1 TOP JACK SCHEMATIC PERFORMANCE SPECIFICATIONS: INSERTION/EXTRACTION FORCES: INITIAL 0.8 TO 6 POUNDS. DIELECTRIC WITHSTANDING VOLTAGE: 500 VAC INSULATION RESISTANCE: INITIAL 100 MEGOHMS MINIMUM CONTACT RESISTANCE PLUG TO JACK: 50 MILLIOHMS MAXIMUM CONTACT RESISTANCE SHUNTS TO SPRINGS: 30 MILLIOHMS MAXIMUM MECHANICAL LIFE: 5000 CYCLES MINIMUM R RS T TS S MATERIALS: SPRINGS AND TERMINALS: SILVER PLATED COPPER ALLOY HOUSING: LCP PIN 5 PIN 8 PIN 4 PIN 7 PIN 6 BOTTOM JACK SCHEMATIC CUSTOMER DRAWING NOTES: THIS DRAWING DESCRIBES A DESIGN CONSIDERED PROPRIETARY IN NATURE, DEVELOPED AND MANUFACTURED BY SWITCHCRAFT INC. AND IS RELEASED ON A CONFIDENTIAL BASIS FOR IDENTIFICATION PURPOSES ONLY. 1. THIS PRODUCT IS RoHS COMPLIANT. 2. ALL DIMENSIONS REFERENCE ONLY. UNLESS OTHERWISE SPECIFIED 1. ALL DIMENSIONS IN INCHES SIZE - TWO PLACE DECIMALS 0.02 - THREE PLACE DECIMALS 0.005 3-8-16 TO TJK P 26432 08-28-09 JEB TJK DATE DRAWN N ECO 21834 REDRAWN 05-28-97 BDS BDS 080709 DATE REVISIONS BY APVD DO NOT SCALE DRAWING SolidWorks CAD File NAME TEMPER BY BDS SPEC No. SCALE 2:1 CHKD BDS 080709 APVD BDS 080709 3.5 MM DUAL JACK, RoHS B LBS/M MATERIAL SPEC No. FIRST USED ON 27662 ECO NUMBER MULT FINISH R REV WIDTH SHEET PART No. 1 OF 35RAPC7J 1 REV R
35RAPC7J 价格&库存
很抱歉,暂时无法提供与“35RAPC7J”相匹配的价格&库存,您可以联系我们找货
