MT334BX
MT334BX
    SWITCHCRAFT
    MT334BX
MT334BX 数据手册
2.953 MAX [75.01] FRAME AND BUSHING ASSEMBLY SOLDER TERMINAL 0.375 [9,53] SCREWS C 1.015 0.015 [25.78 0.38] SCALE 1:1 0.750 [19.05 REF 0.276 [7,01] 0.010 0.25] REF 0.253 [6,43] C REF 0.448 [11,38] 0.563 MAX [14.30] REF D 0.562 [14,27] 0.156 [3,96] REF 0.802 [20,37] REF SPACER INSULATING C REF SECTION C-C 0.040 MAX [1.02] 0.250 MIN [6.35] NOTES: 1. MATES WITH PJ-051 PLUG. 2. MATERIALS: FRAME - STEEL, NICKEL PLATED BUSHING - BRASS, NICKEL PLATED SPRINGS - NICKEL SILVER, SPRING TEMPERED CONTACTS - WELDED CROSS BAR, PALLADIUM SPACERS - PHENOLIC D LIFTER & TUBING - THERMOPLASTIC TERMINALS - HOT TIN DIPPED, LEAD FREE SOLDER SCREWS - STEEL, NICKEL PLATED 3. THIS PRODUCT IS RoHS COMPLIANT. (NOT MILITARY APPROVED) CUSTOMER DRAWING THIS DRAWING DESCRIBES A DESIGN CONSIDERED PROPRIETARY IN NATURE, DEVELOPED AND MANUFACTURED BY SWITCHCRAFT INC. AND IS RELEASED ON A CONFIDENTIAL BASIS FOR IDENTIFICATION PURPOSES ONLY. STAR SYMBOL DENOTES CRITICAL DIMENSION UNLESS OTHERWISE SPECIFIED 1. ALL DIMENSIONS IN INCHES -TWO PLACE DECIMALS 0.01 -THREE PLACE DECIMALS 0.005 -ANGLES 1 -ALL DIA. CONCENTRIC WITHIN 0.005 T.I.R. D 28156 4/10/19 TJK TJK C 27161 05-30-13 PC TJK B 26449 9-16-09 TO TJK 2. FEATURES ON THE SAME CENTERLINE MUST BE ALIGNED WITHIN 0.002 A 25269 1-26-06 TO TJK 3. REMOVE ALL BURRS REV ECO NUMBER DATE BY APVD REVISIONS SIZE MULT FINISH SCALE DATE DRAWN BY CHKD 30-Aug-10 TO TO 8-30-10 B TEMPER SPEC No. FIRST USED ON DO NOT SCALE DRAWING LBS/M MATERIAL SPEC No. NAME Pro/Engineer CAD File WIDTH 2:1 APVD TJK 9-5-10 TELEPHONE JACK SOLDER TERMINAL, RoHS SHEET PART No. 1 OF MT334BX 1 REV D
MT334BX 价格&库存
很抱歉,暂时无法提供与“MT334BX”相匹配的价格&库存,您可以联系我们找货
