24BX
24BX
    SWITCHCRAFT
    CONN JACK 3A 125V 3COND SHIELD
24BX 数据手册
HEX NUT SCHEMATIC CIRCUIT 1.00 WASHER FRAME ASSEMBLY 0.53 PRESSURE PLATE 0.88 0.298 REF 0.25 I.D. 0.75 0.78 0.02 SPACERS (6) 3/8-32 UNEF-2A THREAD TWIN NUT CUSTOMER DRAWING NOTES: 1. MATERIALS: FRAME - STEEL, NICKEL PLATED BUSHING - BRASS, NICKEL PLATED SPRINGS - COPPER ALLOY CONTACTS - FINE SILVER SPACERS - PHENOLIC PRESSURE PLATE - STEEL, NICKEL PLATED SCREWS & TWIN NUT - STEEL, NICKEL PLATED HEX NUT - BRASS, NICKEL PLATED WASHER - STEEL, NICKEL PLATED 2. THIS PRODUCT IS RoHS COMPLIANT. THIS DRAWING DESCRIBES A DESIGN CONSIDERED PROPRIETARY IN NATURE, DEVELOPED AND MANUFACTURED BY SWITCHCRAFT INC. AND IS RELEASED ON A CONFIDENTIAL BASIS FOR IDENTIFICATION PURPOSES ONLY. STAR SYMBOL DENOTES CRITICAL DIMENSION UNLESS OTHERWISE SPECIFIED 1. ALL DIMENSIONS IN INCHES -TWO PLACE DECIMALS 0.01 -THREE PLACE DECIMALS 0.005 -ANGLES 1 -ALL DIA. CONCENTRIC WITHIN 0.005 T.I.R. SIZE 26226 2-6-07 TO TJK REV ECO NUMBER DATE BY APVD REVISIONS 3. REMOVE ALL BURRS DO NOT SCALE DRAWING Pro/Engineer CAD File MULT FINISH FIRST USED ON SCALE DATE DRAWN BY CHKD 02-Sep-10 TO TO 9-2-10 NAME TEMPER SPEC No. 2:1 APVD TJK 9-2-10 PHONE JACK SHORT FRAME, RoHS B LBS/M MATERIAL SPEC No. 2. FEATURES ON THE SAME CENTERLINE MUST BE ALIGNED WITHIN 0.002 A WIDTH PART No. SHEET 1 24BX OF 1 REV A
很抱歉,暂时无法提供与“24BX”相匹配的价格&库存,您可以联系我们找货
