35HDRANAU
35HDRANAU
    SWITCHCRAFT
    35HDRANAU
35HDRANAU 数据手册
PART NUMBER PLUG FINGER HANDLE HANDLE CABLE OPENING I.D. 35HDRABAU GOLD BLACK 0.29 35HDRABAUS GOLD BLACK 0.175 35HDRANAU GOLD NICKEL 0.29 35HDRANAUS GOLD NICKEL 0.175 35HDRANN NICKEL NICKEL 0.29 35HDRANNS NICKEL NICKEL 0.175 MATERIALS: 1.52 REF PLUG MOLDING COMPOUND - L.C.P. BLACK SLEEVE, PLUG BODY - BRASS, NICKEL OR GOLD PLATED RING SLEEVE - BRASS, NICKEL OR GOLD PLATED TIP ROD - BRASS, NICKEL OR GOLD PLATED HOUSING - ZINC, BLACK OR NICKEL PLATED TUBULAR INSULATOR - MYLAR, TRANSLUCENT .41 REF .51 REF HANDLE - BRASS, BLACK OR NICKEL PLATED CLAMP TERMINAL - CRS, TIN PLATED SOLDER LUGS (TIP & RING) - BRASS, TIN PLATED .14 REF [3.5mm] .51 REF SOLDER LUG (TIP) SOLDER LUG (RING) TUBULAR INSULATOR SHIPPED UNASSEMBLED HANDLE SHIPPED UNASSEMBLED CABLE OPENING I.D. SEE TABLE HOUSING CLAMP TERMINAL (SLEEVE) CUSTOMER DRAWING SLEEVE, PLUG BODY UNLESS OTHERWISE SPECIFIED 1. ALL DIMENSIONS IN INCHES - TWO PLACE DECIMALS 0.01 - THREE PLACE DECIMALS 0.005 - ANGLES 1 - ALL DIA. CONCENTRIC WITHIN 0.005 T.I.R. RING 2. FEATURES ON THE SAME CENTERLINE MUST BE ALIGNED WITHIN 0.002 TIP THIS DRAWING DESCRIBES A DESIGN CONSIDERED PROPRIETARY IN NATURE, DEVELOPED AND MANUFACTURED BY SWITCHCRAFT INC. AND IS RELEASED ON A CONFIDENTIAL BASIS FOR IDENTIFICATION PURPOSES ONLY. STAR SYMBOL DENOTES CRITICAL DIMENSION A REV 24662 ECO NUMBER 3-23-04 DATE REVISIONS JL BY AKE SIZE FINISH SPEC No. FIRST USED ON DATE DRAWN 6-27-00 NAME DO NOT SCALE DRAWING SolidWorks CAD File MULT * * * B LBS/M TEMPER * * * * * MATERIAL SPEC No. SCALE 3:1 * 3. REMOVE ALL BURRS APVD WIDTH * BY CHKD APVD AKE AKE 3-23-04 AKE 3-23-04 3.5mm RA STEREO PLUG SHEET PART No. 1 OF 1 35HDRA SERIES REV A
35HDRANAU 价格&库存
很抱歉,暂时无法提供与“35HDRANAU”相匹配的价格&库存,您可以联系我们找货
