8
7
4
5
6
1
2
3
REVISIONS
REV.
ECO. NO
F
2024
H
2828
F
DESCRIPTION
DATE
HEAD HEIGHT 3.60mm WAS 4.00mm, UPDATE WARP 9/15/2009
TOLERANCE
UPDATE PROCESSING TEMPERATURE FOR NYLON 6T
MATERIAL, UPDATE DIM 'B' TOL TO .50mm )WAS
.35mm), UPDATE CURRENT RATING TO 2 AMPS 04/09/2015
(WAS 1 AMP)
BY
JH
LH
F
E
E
.157 4.00
B±.020 [ .50]
A±.010 [ .25]
D
D
.079±.002 2.00±0.05
.079±.002 2.00±0.05
.142±.008 3.60±0.20
.079 2.00
C
C
.110±.008 2.80±0.20
.020±.002 0.50±0.05
A±.004 [ .10]
.031±.002 0.80±0.05
02-20, 0.20mm MAX.
21-30, 0.30mm MAX.
31-40, 0.40mm MAX.
B
.079±.002 2.00±0.05
B
.079±.002 2.00±0.05
A
NOTES:
1. INSULATOR MATERIAL: SEE PART NUMBER CODING.
2. CONTACT MATERIAL: BRASS.
3. CONTACT PLATING: GOLD FLASH OVERALL.
4. CURRENT RATING: 2 AMPS
5. VOLTAGE RATING: 150V AC/DC.
6. INSULATOR RESISTANCE: 5000 MEGOHMS MIN.
7. CONTACT RESISTANCE: 20 MILLIOHMS MAX.
8. DIELECTRIC WITHSTANDING: 500V AC.
9. OPERATING TEMPERATURE: -40° C TO +105° C.
10. PROCESSING TEMP.: WAVE/MANUAL SOLDERING ONLY.
8
7
6
RECOMMENDED PCB LAYOUT
Pb
RoHS COMPLIANT
5
4
UNLESS OTHERWISE SPECIFIED:
DIMENSIONS ARE IN INCHES [MM]
TOLERANCES:
ANGULAR:
1
DECIMALS
.X= .012 [.30]
.XX= .008 [.20]
.XXX= .006 [.15]
DRAWN
DATE
NAME
12/12/2005 YCH
THE INFORMATION HEREIN CONTAINS
PROPIETARY INFORMATION OF
SULLINS ELECTRONICS AND IS NOT
TO BE REPRODUCED, USED OR
DISCLOSED TO OTHERS FOR ANY
PURPOSE EXCEPT AS SPECIFICALLY
AUTHORIZED IN WRITING BY AN
OFFICER OF SULLINS ELECTRONICS.
TITLE
HEADER, MALE 2mm CC, 2 ROWS, ST
PART NUMBER
SIZE
C
CAGE CODE
54453
SCALE: 12:1
3
2
NRPNxx2PAEN-RC
DWG. NO.
10637
SHEET 1 OF 1
1
REV
H
FILE NAME: 10637, NRPNxx2PAEN-RC
A
很抱歉,暂时无法提供与“NRPN082PAEN-RC”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 30+2.6241730+0.31664
- 125+2.61191125+0.31516
- 300+2.61185300+0.31515
- 1250+2.611791250+0.31514
- 3000+2.611743000+0.31514
