966
966
    ADAFRUIT
    1 X 60 YD TAPE
966 数据手册
Low-profile microSD card adapter for Raspberry Pi PRODUCT ID: 966 Description Make your Pi a little slimmer with this microSD card adapter board. It slides in where the SD card goes but  is half the length. Pop in a microSD card for a sleeker machine. The microSD card holder is a push‐push type  so you can push on the edge that sticks out to remove the card when necessary. MicroSD card and Raspberry Pi NOT INCLUDED. Depending on the case from various manufacturers, the  microSD card adapter may not easily slide in and out or may need modifications to the PCB or actual case.  The microSD card adapter is meant for a stand alone board or with use on our Pi Dish or VESA mount. It  does not fit in a PiBow case, for certain. You might  be able to build an Adafruit Pi Box around a Pi with the  adapter inserted but it isn't a good fit and the card can't be ejected while installed and it's not  recommended to be used with the Pi Box. Other cases may or may not work, so be aware before assuming  that this will work with your case! We also have a 'short' microSD ‐> SD card adapter that is 5mm longer than this adapter but isn't as thick, so  it will work in any Pi case. It will also work in MacBooks, where as this adapter will not! Technical Details Protrudes from edge of Raspberry Pi 3mm with microSD card installed Thickness (clearance required from bottom of Raspberry Pi): 5.5mm Engineered in NYC Adafruit ®
很抱歉,暂时无法提供与“966”相匹配的价格&库存,您可以联系我们找货
