ICC-8SS14-TN(LF)(SN)
    JST
    SMD
ICC-8SS14-TN(LF)(SN) 数据手册
ICC CONNECTOR Smart Card 2.54mm Emboss Tape 8-circuit smart card connectors (.100") pitch Features ––––––––––––––––––––––– • Compact The ICC connector has been specifically compactly designed to meet the restrictions involved with high-density mounting. • High durability The combination of the high technology used in the development of the material, and the contact design itself, guarantees the ICC connector for 100,000 mating cycles. (Model no. ICC-8SS80-316-TN) • Embossed tape for automatic mounting This connector can be supplied in embossed tape packaging, for mounting by automatic placement machines. JST The ICC connector is designed to be accommodated within IC card reading/writing devices. The market for IC cards is rapidly expanding and replacing magnetic cards. The ICC connector is compatible with IC cards which conform to ISO7816. B Specifications –––––––––––––––––– 392 • Current rating: 0.5A AC, DC • Voltage rating: 125V AC, DC • Temperature range: -55˚C to +85˚C (including temperature rise in applying electrical current) • Contact resistance: Initial value/30m Ω max.(40m Ω max. for low insertion force type) After environmental testing/50m Ω max. (60m Ω max. for low insertion force type) • Insulation resistance: 1,000M Ω min. • Withstanding voltage: 750V AC/minute * Contact JST for details. ICC CONNECTOR Connector ––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––– 1.5(.059) 13(.512) 10(.394) 9.3(.366) 0.3(.012) 2.54(.010) 0.7(.028) 7.62(.030) 12.1(.476) 11.5(453) A 1.5 (.059) 0.9(.035)dia. 0.4(.016) JST 0.7(.028) 4.5(.177) 6.8(.268) 5.08(.200) 2(.079) type Material and Finish Model No. Q'ty / reel Guaranteed mating / unmating life 800 100,000 80 type ICC-8SS80-316-TN Contact: Cladding Mating section...Gold-Cladding Solder tail...Tin/lead-plated Housing: PPS, UL94V-0, white Solder tab: Copper-alloy, copper-undercoated, tin/lead-plated 15 type (low insertion force type) ICC-8SS15-214L-TN Contact: Copper alloy, nickel-undercoated Mating section...Gold-plated Solder tail...Tin/lead-plated Housing: PPS, UL94V-0, brown Solder tab: Copper-alloy, copper-undercoated, tin/lead-plated 800 30,000 14 type ICC-8SS14-TN Contact: Copper alloy, nickel-undercoated Mating section...Gold-plated Solder tail...Tin/lead-plated Housing: PPS, UL94V-0, black Solder tab: Copper-alloy, copper-undercoated, tin/lead-plated 800 10,000 Note: The products listed above are supplied on embossed-tape. Taping specifications –––––––––––––––––––––––––––––––––––––––––––––––––––––– 380 ± 2(14.961 ± .079)dia. Feeding direction 2.5 25.5 -+ 1.0 (1.004 +- .098 .039 ) 1.55±0.05 (.061± .002)dia. 4.0±0.1 (.157± .004) 2.0±0.1 (.079± .004) Feeding direction Tail tape 40 (1.575) min. Cover tape leader area Connector loaded area Lead tape 20(.787) min. 2.0 ± 0.5 (.079 ± .020) 1.75 ± 0.1 (.069± .004) [13(.512)dia.] Carrier tape 400(15.748) min. 0.3±0.05 (.012± .002) 11.5±0.1 (.453± .004) 24±0.3(.945± .012) Cover tape Carrier tape 16±0.1 (.630± .004) Note: 1. Specifications conform to JIS C 0806. The tape width, connector loading recess square dimensions, etc.are determined by the number of circuits and external shape of the connector to be loaded. Note: 2. Specifications are subject to change without prior notice. 393 ICC CONNECTOR PC board layout (viewed from component side) –––––––––––––––––––––––––––––––––––– + 0.1 0 +.004 0 8.7± 0.1 2.2 ) (.343±.004) (.087 2± 0.5 (.079±.020)) 2.2 (.087 5.08± 0.05 (.020±.002) + 0.1 0 + .004 0 ) 1.7 (.067 + 0.1 0 +.004 0 1.0± 0.05 (.039±.002) 2.3 + 0.1 0 (.091 +.004 0 ) 1.7 + 0.1 0 ) 10.6 ± 0.1(.417±.004) (.067 + .004 0 ) (For reference) 0.8± 0.03(.031±.001) 2.54± 0.05(.010±.002) 7.62± 0.08(.030±.003) 394
ICC-8SS14-TN(LF)(SN) 价格&库存
很抱歉,暂时无法提供与“ICC-8SS14-TN(LF)(SN)”相匹配的价格&库存,您可以联系我们找货
    • 1+12.44160
    • 10+10.62720
    • 30+9.48240
    • 100+8.31600
    • 500+7.79760
    • 800+7.56000
