ICM-MA50H-SS52-1151(LF)(SN)
    JST
    Through Hole
ICM-MA50H-SS52-1151(LF)(SN) 数据手册
Emboss Tape CF CARD CONNECTOR MA Type 1.27mm pitch/50-circuit CF card connector • Socket / Dual-row straddle type, SMT type • Card frame / for type I cards • Adapter / for type I, II cards • Header / for type I, II cards • Ejector / for type I, II cards Specifications ––––––––––––––––––– In addition to the connectors applicable to CF type I cards, those for CF type II cards are also available. • Pitch: 1.27mm • Type: Dual-row at mating section • Current rating: 0.5A AC, DC/line • Temperature range: -20˚C to +60˚C (including temperature rise in applying electrical current) • Contact resistance: Initial value/40m Ω max. After environmental testing/20m Ωmax. (variation from initial value) • Insulation resistance: 1,000M Ωmin. 500V DC (Except for Adapter cards) • Withstanding voltage: 500V AC/minute (Except for Adapter cards) • Mating/unmating life: 10,000 cycles • Conforms to CFA. * Compliant with RoHS. * Refer to "General Instruction and Notice when using Terminals and Connectors" at the end of this catalog. * Contact JST for details. PC board layout (viewed from component side) For Type I cards / Stand off 0mm Normal type / Reverse type For Type I cards / Stand off 1.64mm Normal type / Reverse type 46.0±0.05 46.0±0.05 43.2±0.05 43.2±0.05 40.16±0.05 40.16 31.115±0.05 31.115±0.05 0.4±0.035 (Pattern width) 0.635±0.05 (Pattern pitch) 0.4±0.035 (Pattern width) 6.35±0.05 2.3 0.635±0.05 (Pattern pitch) 1 3.0 14.5±0.05 2-φ1.7+0.1 0 5.0±0.05 5.0±0.05 14.5±0.05 6.35±0.05 2.3 ±0.05 2-φ1.7+0.1 0 2-φ2.2+0.1 0 CF CARD CONNECTOR MA Type For Type II cards / Stand off 0mm Normal type Reverse type 40.9±0.05 43.2±0.05 40.16±0.05 39.2±0.05 0.4±0.035 (Pattarn width) 45.0±0.05 30.0 48.0±0.05 43.6±0.05 ±0.05 22.4±0.05 43.17±0.05 28.5±0.05 6.0±0.05 47.75±0.05 0.05 3-φ1.1+  0 25.5±0.05 0.05 φ1.6+  0 0.05 3-φ1.1+  0 5.8±0.05 1.8 0.05 φ1.6+  0 0.635±0.05 (Pattarn pitch) 2.3±0.05 (Pattern width) 2.7±0.05 0.4±0.035 (Pattern pitch) 5.5±0.05 0.1 2-φ2.2+  0 0.635±0.05 6.3 0.05 2-φ2.2+  0 6.35±0.05 31.115±0.05 ±0.05 31.115 44.2±0.05 Ejector mounted header with shutter For Type II cards Reverse type (Stand off 0mm) Space-saving type For Type I cards / Stand off 0mm Normal type/Reverse type 49.0±0.03 ±0.03 31.115±0.05  0 50-φ0.45+0.1 31.7±0.03 1.9 ±0.05 1.15±0.05 1.55 ±0.05 0.4±0.03 0.635 2-φ2.2+0.05  0 0.9 ±0.05 ±0.05 49.8 ±0.03 41.3±0.03 31.115 ±0.05 2-φ1.25+0.05  0 1.27 ±0.03 0.635 ±0.03 0.78 36.4±0.05 0.85 ±0.05 33.95±0.05 4-φ1.6+0.1  0 4.35±0.03 41.4±0.05 45.0 ±0.03 49.8 ±0.03 Space-saving type For Type II cards / Stand off 0mm Normal type Reverse type ±0.05 39.2 45.13±0.05 ±0.05 3.35±0.05 0.635±0.05 (Pattern pitch) 8.15±0.05 0.4±0.035 (Pattern width) 0.05 φ1.6+  0 0.05 φ1.1+  0 44.38±0.05 1.9±0.05 43.33±0.05 R0.5 2 through-holes 1.0 Components cannot be mounted inside of this area. 1.2±0.05 1.2 49.5 +0.05 2-φ2.1 0 0.2 ±0.05 (37.3) 1.8±0.05 33.95±0.05 26.5±0.05 28.55±0.05 38.9 23.55 ±0.05 44.38 Reinforcement pitch 1.55±0.05 3.85±0.05 4.35 ±0.05 3.85 ±0.05 3.0 ±0.05 φ1.1+0.05 0 3.0±0.05 ±0.05 1.8 1.55 φ1.6+0.05 0 39.5±0.05 31.115±0.05 ±0.05 ±0.05 0.4 (Pattern width) 6.65 ±0.05 0.635 (Pattern pitch) ±0.05 ±0.05 31.115 Components cannot be mounted inside of this area. 43.63±0.05 1.2±0.05 54.0 2 CF CARD CONNECTOR MA Type Socket Dual-row straddle type 30.48 1.27 1.27 33.0 3.3 35.9 1.27 0.4 0.5 6.0 Rib length 2.5 Circuit No.1 No.1 mark 3.0 (8.5) 0.7 30.48 Circuits 50 Solder tail Dual-row straddle type Tail length Grounding spring Off-set dimension Rib length (mm) Tail length (mm) With (Circuit No.1, No.26) 3.0mm Center 2.5mm Model No. ICM-MA50S-TS12-3032 Q'ty/box Material and Finish 600 Contact: Copper-alloy, nickel-undercoated, Mating part; gold-plated Solder tail; tin-plated (reflow treatment) Grounding spring: Copper alloy nickel-undercoated, gold-plated Housing: LCP, UL94V-0, black RoHS compliance This product displays (LF)(SN) on a label. SMT type ICM-MA50S-TS12-3021 30.48 1.27 3.3 2.7 Off-set amount 0.2 35.9 Circuit No.2 0.635 0.25 2.3925 Circuit No.50 Circuit No.25 6.0 1.0 Circuit No.1 Circuit No.26 2.0 No.1 mark 4.0 (8.0) Circuit No.1 0.5 33.0 Rib length Tail length 31.115 ICM-MA50S-TS12-3022 30.48 1.27 3.3 2.7 Off-set amount 0.75 35.9 2.3925 3 Circuit No.2 0.635 Circuit No.50 Circuit No.25 0.25 31.115 6.0 1.0 Circuit No.1 Circuit No.26 Rib length 2.0 No.1 mark 4.0 (8.0) Circuit No.1 0.5 33.0 Tail length CF CARD CONNECTOR MA Type Socket SMT type ICM-MA50S-TS12-3023 30.48 1.27 3.3 2.7 Off-set amount 0.2 35.9 1.0 Circuit No.2 0.25 0.635 2.3925 Circuit No.50 Circuit No.25 2.0 Circuit No.1 Circuit No.26 3.0 (8.0) Circuit No.1 No.1 mark 6.0 0.5 33.0 Rib length 31.115 Tail length ICM-MA50S-TS12-3024 30.48 1.27 3.3 2.7 Off-set amount 0.35 35.9 1.0 Circuit No.2 Circuit No.50 0.25 0.635 Circuit No.25 2.3925 2.0 Circuit No.1 Circuit No.26 4.0 (8.0) Circuit No.1 No.1 mark 6.0 0.5 33.0 Rib length Tail length 31.115 ICM-MA50S-TS12-3026 30.48 1.27 3.3 2.7 Off-set amount 0.95 35.9 Circuit No.2 0.25 0.635 6.0 1.0 Circuit No.1 Circuit No.26 Circuit No.25 Circuit No.50 Rib length 2.0 Circuit No.1 No.1 mark 4.0 (0.7) 0.5 33.0 Tail length 31.115 (32.4) Circuits 50 Solder tail SMT type Grounding spring Off-set dimension (mm) Rib length (mm) Tail length (mm) With (Circuit No.1, No.26) Model No. Q'ty/reel 0.2mm 4.0mm 2.0mm ICM-MA50S-TS12-3021T 1,500 0.75mm 4.0mm 2.0mm ICM-MA50S-TS12-3022T 1,500 0.2mm 3.0mm 2.0mm ICM-MA50S-TS12-3023T 1,500 0.35mm 4.0mm 2.0mm ICM-MA50S-TS12-3024T 1,500 0.95mm 4.0mm 2.0mm ICM-MA50S-TS12-3026T 1,500 Material and Finish Contact: Copper alloy, nickel-undercoated, Mating part; gold-plated Solder tail; tin-plated (reflow treatment) Grounding spring: Copper alloy, nickel-undercoated, gold-plated Housing: LCP, UL94V-0, black RoHS compliance This product displays (LF)(SN) on a label. 4 CF CARD CONNECTOR MA Type Header (for Type I cards) Normal type (Stand off 0mm) 46.6 34.8 31.115 0.635 0.3 (26.5) 7.5 19.0 L 5.2 0.5 43.03 1.27 30.48 Circuit No.25 4.25 0.89 3.55 1.4 1.27 0.79 Circuit No.1 40.16 Circuit No.50 Circuit No.26 Reverse type (Stand off 0mm) Dimension L Circuit No. Dimensions (mm) 1, 13, 38, 50 5.0 ±0.1 2∼12, 14∼24, 27∼37, 39∼49 4.25 ±0.1 25, 26 3.5 ±0.1 43.03 40.16 Circuit No.1 1.4 0.89 0.79 3.55 4.25 Circuit No.25 1.27 1.27 30.48 Circuit No.50 Circuit No.26 19.0 5.2 7.5 L (26.5) 46.6 0.5 0.3 0.635 31.115 34.8 Circuits Type Model No. Q'ty / box Normal ICM-MA50H-SS52-1151 180 Reverse ICM-MA50H-SS52-1171 180 50 RoHS compliance This product displays (LF)(SN) on a label. 5 Dimension L Circuit No. Dimensions (mm) 1, 13, 38, 50 5.0 ±0.1 2∼12, 14∼24, 27∼37, 39∼49 4.25 ±0.1 25, 26 3.5 ±0.1 Material and Finish Contact: Phosphor bronze, nickel-undercoated, Mating part; gold-plated Solder tail; tin-plated (reflow treatment) Housing: PPS, UL94V-0 Solder tab: Brass, copper-undercoated, tin-plated (reflow treatment) CF CARD CONNECTOR MA Type Header (for Type I cards) Normal type (Stand off 1.64mm) 46.6 34.8 31.115 0.635 0.3 7.5 (26.5) 19.0 L 5.2 0.5 43.03 1.27 30.48 Circuit No.25 Dimension L Circuit No. 3.55 1.4 0.89 Circuit No.26 Reverse type (Stand off 1.64mm) 6.62 1.27 0.79 Circuit No.1 Circuit No.50 Dimensions (mm) 1, 13, 38, 50 5.0 ±0.1 2∼12, 14∼24, 27∼37, 39∼49 4.25 ±0.1 25, 26 3.5 ±0.1 43.03 Circuit No.25 Circuit No.1 1.27 1.27 Circuit No.26 6.62 3.55 1.4 0.79 0.89 Circuit No.50 30.48 5.2 7.5 L (26.5) 19.0 46.6 0.5 0.3 0.635 31.115 Dimension L Circuit No. 5.0 ±0.1 2∼12, 14∼24, 27∼37, 39∼49 4.25 ±0.1 25, 26 3.5 ±0.1 34.8 Circuits Type Model No. Q'ty / box Normal ICM-MA50H-SS52-1141 140 Reverse ICM-MA50H-SS52-1161 140 50 Dimensions (mm) 1, 13, 38, 50 Material and Finish Contact: Phosphor bronze, nickel-undercoated, Mating part; gold-plated Solder tail; tin-plated (reflow treatment) Housing: PPS, UL94V-0 Solder tab: Brass, copper-undercoated, tin-plated (reflow treatment) RoHS compliance This product displays (LF)(SN) on a label. 6 CF CARD CONNECTOR MA Type Header (for Type I cards) / Space-saving type Normal , Reverse types (Stand off 0mm ) 44.8 0.3 0.3 33.4 31.115 0.3 0.635 L 2.3 5.0 1.3 3.4 2-φ2.2 + 0.1 0 30.48 Dimension L Circuit No. 1.27 Circuit No.25 Circuit No.1 Circuit No.26 Circuit No.50 5.0 ±0.1 2∼12, 14∼24, 27∼37, 39∼49 4.25 ±0.1 25, 26 3.5 ±0.1 33.95 Circuits Type Model No. Q'ty / box Material and Finish 1,850 Contact: Copper alloy, nickel-undercoated, Mating part; gold-plated Solder tail; tin-plated (reflow treatment) Housing: PPS, UL94V-0, black Solder tab: Copper alloy, nickel-undercoated, tin-plated (reflow treatment) Normal 50 ICM-MA50H-SS52-1184 Reverse Dimensions (mm) 1, 13, 38, 50 RoHS compliance This product displays (LF)(SN) on a label. Ejector mounted header with shutter (for Type II cards) 52.7 (8.25) 49.0 (3.8) 7.35 Shutter stroke 51.0 31.7 14.1 (4.4) 45.0 (3.6) 6.35 41.3 (3.3) Circuit No.50 Circuit No.25 Circuit No.26 Circuit No.1 Card stroke (5.5) Reverse type (Stand off 0mm) 5.0 49.8 7.5 Button stroke 43.03 30.48 1.27 0.9 Circuit No.25 Circuit No.1 3.6 3.47 Circuit No.50 Circuit No.26 0.9 0.635 31.115 Circuits 50 Type Reverse Model No. ICM-MA2SL-SD12-RL31 RoHS compliance This product displays (LF)(SN) on a label. 7 Q'ty / box Material and Finish 128 Contact: Copper alloy, nickel-undercoated, Mating part; gold-plated Solder tail; tin-plated (reflow treatment) Housing/ Guide bar/ Push button: PPS, UL94V-0, black Lock/ Rotation arm/ Push bar: Stainless Frame: Stainless, selective nickel-undercoated, tin/copper alloy-plated CF CARD CONNECTOR MA Type Header (for Type II cards) Normal type (Stand off 0mm ) 47.0 43.2 31.115 0.5 (41.6) 32.7 L 8.9 0.3 5.2 0.635 0.5 Circuit No.25 43.03 Dimension L Circuit No. 3.55 1.4 Circuit No.26 5.25 1.27 1.27 Circuit No.1 0.89 0.79 30.48 5.0 ±0.1 2∼12, 14∼24, 27∼37, 39∼49 4.25 ±0.1 25, 26 3.5 ±0.1 Circuit No.50 Reverse type (Stand off 0mm) Dimensions (mm) 1, 13, 38, 50 47.0 31.115 0.3 0.6 43.03 Circuit No.26 Dimension L Circuit No. 1.85 3.6 Circuit No.25 Circuit No.1 Dimensions (mm) 1, 13, 38, 50 5.0 ±0.1 2∼12, 14∼24, 27∼37, 39∼49 4.25 ±0.1 25, 26 3.5 ±0.1 3.5 1.27 1.27 Circuit No.50 0.79 0.89 30.48 1.4 0.89 Circuits (42.7) 32.7 L 5.2 0.635 10.0 0.6 Type Model No. Q'ty / box Material and Finish Normal ICM-MA2H-SS52-N11B 84 Contact: Phosphor bronze, nickel-undercoated, Mating part; gold-plated Solder tail; tin-plated (reflow treatment) Housing: PPS, UL94V-0, black Solder tab: Phosphor bronze, copper-undercoated, tin-plated (reflow treatment) Reverse ICM-MA2H-SS52-R21A 84 Contact: Phosphor bronze, nickel-undercoated, Mating part; gold-plated Solder tail; tin-plated (reflow treatment) Housing: LCP, UL94V-0, black Solder tab: Phosphor bronze, copper-undercoated, tin-plated (reflow treatment) 50 RoHS compliance This product displays (LF)(SN) on a label. 8 CF CARD CONNECTOR MA Type Header (for Type II cards) / Space-saving type Normal type (Stand off 0mm) 0.3 0.3 44.53 5.4 31.115 0.3 8.0 L 5.0 0.635 1.9 43.03 0.89 30.48 1.27 Circuit No.25 Circuit No.50 Dimension L Circuit No. 3.5 Circuit No.26 0.79 1.4 2.05 Circuit No.1 39.2 44.38 Dimensions (mm) 1, 13, 38, 50 5.0 ±0.1 2∼12, 14∼24, 27∼37, 39∼49 4.25 ±0.1 25, 26 3.5 ±0.1 Reverse type (Stand off 0mm) 0.3 0.3 44.53 31.115 5.35 4.88 0.3 8.0 L 5.0 0.635 45.18 43.03 Type Model No. Q'ty / reel Normal ICM-MA2H-SS52-N13LT 750 Reverse ICM-MA2H-SS52-R13HT 750 50 RoHS compliance This product displays (LF)(SN) on a label. This products listed above are supplied on embossed-tape. 9 1.85 Circuit No.25 Circuit No.1 Circuits 3.5 Circuit No.26 3.6 0.79 Circuit No.50 0.89 1.4 1.27 1.27 30.48 0.89 Dimension L Circuit No. Dimensions (mm) 1, 13, 38, 50 5.0 ±0.1 2∼12, 14∼24, 27∼37, 39∼49 4.25 ±0.1 25, 26 3.5 ±0.1 Material and Finish Contact: Phosphor bronze, nickel-undercoated, Mating part; gold-plated Solder tail; tin-plated (reflow treatment) Housing: PPS, UL94V-0 Solder tab: Brass, copper-undercoated, tin-plated (reflow treatment) CF CARD CONNECTOR MA Type Ejector (for Type I Header) Left button 23.6 (29.5) (29.5) (3.3) (3.3) 4.2 25.0 23.6 4.2 25.0 Right button Button stroke 5.6 Card stroke 6.6 17.4 6.6 Card stroke 17.4 Button stroke 2.8 2.8 5.6 26.5 26.5 Type Model No. Q'ty / box Right button ICM-MAE-R01 100 Left button ICM-MAE-L01 100 Material Applicable header Frame/ Rotation arm : Stainless Push button: PPS, UL94V-0, black ICM-MA50H-SS52-1141 ICM-MA50H-SS52-1151 ICM-MA50H-SS52-1161 ICM-MA50H-SS52-1171 RoHS compliance Applicable headers display (LF)(SN) on a label. Left button (3.53)Card stroke Ejector mounted header (for Type I Header) / Space-saving type 45.4 3.215 (25.88) 43.1 (6.3)Button stroke 2-φ2.2+0.1 0 4.65 38.63 2.425 1.4 4.0 23.87 39.53 Type Reverse (Left button) Model No. Q'ty / box Material and Finish Applicable header 252 Frame: Stainless, nickel-undercoated, tin/copper alloy-plated Rotation arm: Stainless Push button: Synthetic resin, UL94V-0, gray ICM-MA50H-SS52-1184 ICM-MAE-L91ND RoHS compliance This product displays (LF) on a label. An applicable header displays (LF)(SN) on a label. 10 CF CARD CONNECTOR MA Type Ejector (for Type II header) For Normal type header (Left button) For Normal type header (Right button) 51.6 4.95 37.5 39.6 2.6 Card stroke 1.3 (27.6) 5.0 5.0 27.07 6.3 Button stroke 0.5 (41.4) 1.3 39.6 (41.4) 36.4 0.5 37.5 6.3 Button stroke 4.7 51.6 (27.6) 2.6 Card stroke 4.95 4.7 For Reverse type header (Right button) (51.6) (6.05) (27.8) 10.0 3.7 (3.35)Card stroke 42.7 (23.8) (6.0) Button stroke 7.0 23.315 43.03 Circuit No.26 Circuit No.25 Circuit No.1 3.6 Circuit No.50 Type Model No. (6.29) Q'ty / box Material Applicable header For Normal type header (Left button) ICM-MAE-L33 324 ICM-MAE-R32 324 Frame/ Rotation arm/ Push bar/ Push plate/ Button shaft: Stainless Push button: PBT, UL94-0, black(R32), gray(L33) ICM-MA2H-SS52-N11B For Normal type header (Right button) For Reverse type header (Right button) ICM-MAE-R21A Frame/ Rotation arm/ Push bar: Stainless Push button: PPS, UL94-0, black ICM-MA2H-SS52-R21A 48 RoHS compliance ICM-MAE-L33/ICM-MAE-R32 display (N) on a label. Applicable headers display (LF)(SN) on a label. 11 CF CARD CONNECTOR MA Type Ejector (for Type II header) / Space-saving type For Reverse type header (Stand off 0mm) Right button 25.03 22.57 22.57 23.58 (6.35) 14.8 (25.5) (4.5)Button stroke 4.7 (4.5)Button stroke 8.8 6.3 49.5 (32.5) (2.7)Card stroke 37.4 2-φ2.1 37.3 26.9 3.2 (35.1) 13.0 (2.7)Card stroke For Normal type header (Stand off 0mm) Left button 4.0 (24.9) Circuit No.1 Circuit No.25 Circuit 26 Circuit 50 4.0 3.6 39.2 For Normal type header (Stand off 0mm) Left button/Push-push type For Reverse type header (Stand off 0mm) Left button/Push-push type 4.65 45.13 45.13 (4.45) 7.5 (36.4) (2.9)Card stroke 37.4 (36.0) (3.0)Card stroke 13.0 (3.4) 38.73 20.0 43.03 32.0 43.03 Type Model No. Material and Finish Q'ty / box For Normal type header (Stand off 0mm) Left button ICM-MAE-L73FA 36 Rotation arm/Push bar/Push plate/ Frame: Stainless Button: PBT, UL94V-0, gray For Normal type header (Stand off 0mm) Left button, Push-push ICM-MA2EP-L520A 36 Rotation arm/Push plate: Stainless Button: PBT, UL94V-0, black Frame: Stainless, selective nickel-undercoated, tin/copper alloy-plated For Reverse type header (Stand off 0mm) Right button ICM-MAE-R66C3 36 Rotation arm/Push bar/Push plate/ Frame: Stainless Clinched button: Synthetic resin, black Frame: Stainless, selective nickel-undercoated, tin/copper alloy-plated For Reverse type header (Stand off 0mm) Left button, Push-push ICM-MA2EP-L810E 36 Arm: Stainless Push button: Synthetic resin, UL94V-0, black Frame: Stainless, selective nickel-undercoated, tin/copper alloy-plated Applicable header ICM-MA2H-SS52-N13L ICM-MA2H-SS52-N13LT ICM-MA2H-SS52-R13HT RoHS compliance ICM-MAE-R66C3 display (LF) on a label. ICM-MA2EP-L520A/ICM-MA2EP-L810E display (LF) on a label. Applicable headers display (LF)(SN) on a label. 12 CF CARD CONNECTOR MA Type Card frame (for Type I cards) ICM-MA50F-A/B-FB-C Frame A Frame B 42.8 36.4 Applicable socket 38.0(Component assembling area) Q'ty / box Material 150 Frame: Glass-filled PBT, UL94V-0 Cover: Stainless ICM-MA50S-TS12-3032 ICM-MA50F-A/B-FB-CA 30.9(Component assembling area) 38.0(Component assembling area) Model No. as a set (Frame A + Frame B) 50 (Glue position) 2.9 2.9 30.9(Component assembling area) 36.4 Circuits 42.8 (Glue position) ICM-MA50S-TS12-3023T RoHS compliance Adapter card 1.0 1.0 1.0 1.6 68-circuits side For CF Type I cards (PC card 5V key) 54.0 5.0max 42.0 22.0 85.6 43.3 3.3 50-circuits side Model No. ICM-MA50A-C441N Q'ty / box Material and Finish 50-circuits side Header Contact: Copper alloy, nickel-undercoated, Mating part; gold-plated Solder tail; tin-plated (reflow treatment) Housing: PPS, UL94V-0 68-circuits side Socket Contact: Copper alloy, nickel-undercoated, Mating part; gold-plated Solder tail; tin-plated (reflow treatment) Housing: LCP, UL94V-0 Grounding spring: Copper alloy, nickel-undercoated, gold-plated 48 RoHS compliance This product displays (LF)(SN) on a label. 13 Cover: Stainless Frame: PBT, UL94V-0 PC board: Glass-epoxy, UL94V-0 CF CARD CONNECTOR MA Type Adapter card For CF Type II cards (PC card 5V key with grounding clip spring) 1.0 1.0 1.6 1.0 68-circuits side 5.0max 54.0 3.3 85.6 33.35 42.0 50-circuits side Model No. Q'ty / box Material and Finish Contact: Copper alloy, nickel-undercoated, Mating part; gold-plated Solder tail; tin-plated (reflow treatment) Housing: PPS, UL94V-0 Contact: Copper alloy, nickel-undercoated, Mating part; gold-plated Solder tail; tin-plated (reflow treatment) Housing: LCP, UL94V-0 Grounding spring: Copper alloy, nickel-undercoated, gold-plated 50-circuits side Header ICM-MA2A-C454N 48 68-circuits side Socket Cover: Stainless Frame: PBT, UL94V-0 PC board: Glass-epoxy, UL94V-0 Contact spring: Copper alloy Shutter: PPS, UL94V-0 Spring: Stainless Lock: Stainless RoHS compliance This product displays (LF)(SN) on a label. For CF Type II cards (PC card 3.3V key with grounding clip spring) 1.0 1.0 1.6 2.1 68-circuits side 5.0max 54.0 3.3 85.6 33.35 42.0 50-circuits side Model No. ICM-MA2A-CL454N Q'ty / box Material and Finish 50-circuits side Header Contact: Copper alloy, nickel-undercoated, Mating part; gold-plated Solder tail; tin-plated (reflow treatment) Housing: PPS, UL94V-0 68-circuits side Socket Contact: Copper alloy, nickel-undercoated, Mating part; gold-plated Solder tail; tin-plated (reflow treatment) Housing: LCP, UL94V-0 Grounding spring: Copper alloy, nickel-undercoated, gold-plated 48 Cover: Stainless Frame: PBT, UL94V-0 PC board: Glass-epoxy, UL94V-0 Contact spring: Copper alloy Shutter: PPS, UL94V-0 Spring: Stainless Lock: Stainless RoHS compliance This product displays (LF)(SN) on a label. 14
ICM-MA50H-SS52-1151(LF)(SN) 价格&库存
很抱歉,暂时无法提供与“ICM-MA50H-SS52-1151(LF)(SN)”相匹配的价格&库存,您可以联系我们找货
