Single Slot SMT Connectors for Card-Bus Based PC Cards
IC14 Series
PC Card Standard Compliant
Board Space-Saving
SMT Unit
Guide Unit
Secure board retention
Two anchoring
pins
■Features
Four metal fittings
1. Space-Saving design facilitates pattern routing
Responding to the need for the equipment miniaturization,
the board mounting area has been further reduced by
relocation of the mounting screws away from the possible
routing of the conductive traces.
2. Card insertion shock protection
SMT Unit
Total of 6 board retention points assures that there is no
transfer of card insertion forces to the solder terminations.
3. New “Pop-Up” button card ejection mechanism
The button does not protrude without the card being
inserted, preventing it’s damage when carrying the
notebook computer.
Three-stage “Pop-Up” card ejection mechanism
Existing products
When the eject button is mistakenly pressed without a PC card inserted
4. Customized ejection buttons
Equipment
outline
The configuration, color or length can be designed for
customer’s specific applications.
5. Reliable and balanced card ejection mechanism
Hirose’s unique ejection mechanism will apply force equally
at each edge of the inserted card. In addition, large distance
of the ejection allows easy hold on the card.
IC14
Protruding button is
vulnerable to damage.
Board mounting
Standoff
Eject button
Left
■Applications
Notebook PCs, audio/video equipment and other devices
utilizing PC cards.
Standard
1.5mm
2.2mm
Right
Left
Right
Left
Right
Reverse
2.2mm
Left
Right
A2
Pop-up
Folding
Rigid
Pop-up
Pop-up
Pop-up
Pop-up
Folding
Rigid
Pop-up
Pop-up
Folding
Rigid
Pop-up
■Product Specifications
Current
rating
Ratings
Voltage
rating
Item
Operating temperature
0.5A
range
125V AC
-55ç to +85ç (Note 1)
Storage temperature
range
Operating humidity
Relative humidity 95% max.
Storage humidity
range
(No condensation)
range
Specifications
-40ç to +70ç (Note 2)
40% to 70% (Note 2)
Conditions
1. Insulation resistance
2. Withstanding voltage
3. Contact resistance
4. Vibration
1000 Mø min.
No flashover or insulation breakdown.
60 mø max. (Initial value)
No electrical discontinuity of 100 ns or more.
5. Humidity
Insulation resistance: 100 Mø min.
6. Temperature cycle
7. Durability
(mating/unmating)
8. Resistance to
soldering heat
Contact resistance: 20mø max. from initial value
500 V DC
500 V AC / one minute
1mA DC
Frequency: 10 to 2000 Hz, single amplitude of 1.52 mm or
acceleration of 147m/s2 (peak), 4 hours / 3 axis
96 hours at temperature of 40ç±2ç and humidity of 90% to
95%
Temperature: -55ç / +5ç to +35ç / +85ç / +5ç to +35ç
Duration:
30 / +5 max.
/ 30
/ +5 max. (Minutes)
5 cycles
10000 cycles at 400 to 600 cycles per hour
No deformation of any component. No affect on
contacts.
Reflow: At the recommended temperature profile
Manual soldering: 300ç for 3 seconds
Note 1: Includes temperature rise caused by current flow.
Note 2: The term ”storage” refers to products stored for long period of time prior to mounting and use. Operating Temperature Range
and Humidity range covers non- conducting condition of installed connectors in storage, shipment or during transportation.
■Materials/Finish
SMT unit
Component
Material
Insulator
Heat resistant thermoplastic compound
Contacts
Brass
Ground/eject metal fittings
Positioning pin
Stainless
Brass
Finish
Color: Black
Contact area: Gold plated
Termination area: Tin-lead plated (Note)
---------Tin-lead plated (Note)
Remarks
UL94V-0
Guide unit
Component
Material
Finish
Remarks
Insulator
Cover/Eject metal fittings
Spring
PBT
Stainless
Steel
Color: Black
UL94V-0
Note: Lead-free specified connectors are tin plated.
A3
■Ordering information
●SMT unit
IC14 A - PLR - SF - EJR -(71)
1
1 Series name
2 Standoff type
2
3
5
6
4 SF : SMT unit
5 Eject button position
: IC14
EJR : Right-side eject
EJL : Left-side eject Number of ground contacts
6 Product specification code
Blank : Tin-lead plated
(71): Lead-free plated
Blank
: 0 mm
A
: 2.2 mm
B
: 1.5 mm
3 Board mounting type
PL: Standard type
PLR: Reverse type
●Guide unit
4
IC14 A - G - P EJR
7
7 Series name
8 Standoff type
: IC14
Blank
A
B
9 G: Guide unite
: 0 mm
: 2.2 mm
: 1.5 mm (Note 1)
8
9
10
11
10 Eject button type
Blank : Rigid button
P
: Pop-up button
F
: Folding button
11 Eject button position
EJR: Right-side eject
EJL: Left-side eject
Note 1: In the IC14B type, the screw attachment holes in the Guide unit are not threaded.
Note 2: In this series the SMT unit and the Guide unit must be used in combinations shown below.
Note 2: Other combinations cannot be used.
* Series name
* Standoffs
* Ejection button position
A4
( 1⇔7 )
( 2⇔8 )
( 5 ⇔ 11 )
■Standard
Right Pop-up button
SMT unit(1)
No.1
32MAX
No.34
No.35
No.2
No.36
Eject metal components movable range
No.68
GND
C
6
GND
57.4
7.5MAX 5.5MAX
3
●IC14, IC14A
SAR
GND
3.3
74.5
85.8(Card fully inserted)
30.55
27.45
84.55(Ejector button pushed-in for withdrawal)
62.55
GND
3 58.9
#2-M2(2X)
3 61.8
PRA
32.6
Button position for card ejection
63.5
Guide unit(2)
No.34
No.2
3.5
A
(7.4)
B
4.8
No.1
No.35
No.36
No.68
●IC14B
5
5
62.6
SBR
PRBM3
2.5
2.5
22.8
43.8
Stand off height
SMT unit 1
Guide unit 2
Part Number
CL No.
Part Number
CL No.
A
(mm)
B
(mm)
C
(mm)
Weight (g)
IC14-PL-SF-EJR
CL640-1301-0
IC14-G-PEJR
CL640-1409-7
2.7
5.5
0.3
13.1
2.2mm
IC14A-PL-SF-EJR
CL640-1303-6
IC14A-G-PEJR
CL640-1411-9
4.9
7.7
2.5
13.5
1.5mm
IC14B-PL-SF-EJR
CL640-1309-2
IC14B-G-PEJR
CL640-1413-4
4.2
7
1.8
13.3
1
: All illustrations show the SMT unit (1) and Guide unit (2) assemblied.
2
: Dimensions for card insertion are in accordance with “PC card standard”.
3
: Indicated dimensions are symmetrical to the center of the card insertion slot.
A5
■Standard
Left Pop-up button
●IC14, IC14A
3 57.4
No.1
C
No.34
SMT unit(1)
No.68
GND
6
7.5MAX 5.5MAX
GND
32MAX
No.35
No.2
No.36
SAL
GND
62.55
27.45
74.5
30.55
3.3
85.8 (Card fully inserted)
GND
3 58.9
#2-M2(2X)
3 61.8
PLA
32.6
(7.4)
Guide unit(2)
63.5
No.1
No.34
No.2
A
B
4.8
3.5
No.35
No.36
No.68
●IC14B
5
62.6
SBL
PLBM9
2.5
2.5
22.8
43.8
Stand off height
A6
SMT unit 1
Guide unit 2
Part Number
CL No.
Part Number
CL No.
A
(mm)
B
(mm)
C
(mm)
Weight (g)
IC14-PL-SF-EJL
CL640-1302-3
IC14-G-PEJL
CL640-1410-6
2.7
5.5
0.3
13.1
2.2mm
IC14A-PL-SF-EJL
CL640-1304-9
IC14A-G-PEJL
CL640-1412-1
4.9
7.7
2.5
13.5
1.5mm
IC14B-PL-SF-EJL
CL640-1310-1
IC14B-G-PEJL
CL640-1414-7
4.2
7
1.8
13.3
1
2
3
■Reverse
Right Pop-up button
3
57.4
32MAX
SMT unit(1)
No.68
No.34
No.35
No.2
GND
No.1
GND
C
7.5MAX
6
5.5MAX
No.36
GND
RA
3.3
3
58.9
3
61.8
30.55
74.5
27.45
62.55
GND
PRA
32.6
63.5
No.35
No.36
3.5
A
B
4.8
No.68
( 7.4)
Guide unit(2)
No.34
Stand off height
2.2mm
No.1
No.2
SMT unit 1
Guide unit 2
Part Number
CL No.
Part Number
CL No.
A
(mm)
B
(mm)
C
(mm)
Weight (g)
IC14A-PLR-SF-EJR
CL640-1307-7
IC14A-G-PEJR
CL640-1411-9
4.9
7.7
2.3
14.3
1
2
3
A7
■Reverse
Left Pop-up button type
3
57.4
32 MAX
No.68
No.35
No.2
No.36
No.34
GND
SMT unit(1)
No.1
GND
7.5MAX
6
5.5MAX
C
GND
LA
62.55
27.45
74.5
30.55
3.3
GND
3
58.9
3
61.8
PLA
32.6
(7.4)
Guide unit(2)
63.5
No.35
No.36
No.68
A
B
4.8
3.5
No.34
Stand off height
2.2mm
A8
No.1
No.2
SMT unit 1
Guide unit 2
Part Number
CL No.
Part Number
CL No.
A
(mm)
B
(mm)
C
(mm)
Weight (g)
IC14A-PLR-SF-EJL
CL640-1308-0
IC14A-G-PEJL
CL640-1412-1
4.9
7.7
2.3
14.3
1
2
3
■Standard
Left folding button
3
57.4
SMT unit(1)
32MAX
No.35
No.1
No.34
No.2
No.36
GND
GND
6
7.5MAX 5.5MAX
C
No.68
SAL
GND
62.55
GND
3
61.8
3
58.9
(93.6)
3.3
Card fully inserted:85.6
74.5
27.45
8
5
Ejector pushed-in for withdrawal:(9.5)
LA
34.55
42.05
(65.45)
Guide unit(2)
No.34
No.2
A
B
4.8
No.1
No.35
Stand off height
2.2mm
No.36
No.68
SMT unit 1
Guide unit 2
Part Number
CL No.
IC14-PL-SF-EJL
CL640-1302-3
IC14A-PL-SF-EJL
CL640-1304-9
CL No.
A
(mm)
B
(mm)
C
(mm)
Weight (g)
IC14-G-FEJL
CL640-1406-9
2.7
5.5
0.3
13.9
IC14A-G-FEJL
CL640-1408-4
4.9
7.7
2.5
14.1
Part Number
1
2
3
A9
■Reverse
Left folding button
3
57.4
32 MAX
No.68
No.35
No.2
No.36
No.34
GND
GND
7.5MAX
6
5.5MAX
C
SMT unit(1)
No.1
GND
LA
62.55
GND
74.5
3
61.8
3
58.9
3.3
(93.6)
27.45
8
5
LA
34.55
42.05
Guide unit(2)
(65.45 )
No.68
No.36
A
B
4.8
No.35
No.34
Stand off height
2.2mm
A10
No.1
No.2
SMT unit 1
Guide unit 2
Part Number
CL No.
Part Number
CL No.
A
(mm)
B
(mm)
C
(mm)
Weight (g)
IC14A-PLR-SF-EJL
CL640-1308-0
IC14A-G-FEJL
CL640-1408-4
4.9
7.7
2.3
14.9
1
2
3
■Standard
Left rigid button
3
57.4
32MAX
No.35
No.1
No.2
No.36
GND
6
5.5MAX
C
SMT unit(1)
No.68
GND
No.34
7.5MAX
SAL
GND
3
61.8
3
58.9
3.3
74.5
85.6(Card fully inserted)
27.45
62.55
GND
8
LA
32.6
63.5
Guide unit(2)
3.5
No.34
No.2
A
B
4.8
No.1
No.35
Stand off height
2.2mm
No.36
No.68
SMT unit 1
Guide unit 2
Part Number
CL No.
Part Number
CL No.
A
(mm)
B
(mm)
C
(mm)
Weight (g)
IC14-PL-SF-EJL
CL640-1302-3
IC14-G-EJR
CL640-1402-8
2.7
5.5
0.3
13.4
IC14A-PL-SF-EJL
CL640-1304-9
IC14A-G-EJR
CL640-1404-3
4.9
7.7
2.5
13.7
1
2
3
A11
■Reverse
Left rigid button
3
57.4
32MAX
No.68
GND
No.35
No.2
No.36
No.34
GND
7.5MAX
6
5.5MAX
C
SMT unit(1)
No.1
GND
LA
62.55
GND
74.5
3
61.8
3
58.9
3.3
FL
27.45
8
LA
32.6
63.5
No.68
Guide unit(2)
No.36
No.35
B
C
A
4.8
3.5
No.34
Stand off height
2.2mm
A12
No.2
SMT unit 1
No.1
Guide unit 2
Part Number
CL No.
Part Number
CL No.
A
(mm)
B
(mm)
C
(mm)
Weight (g)
IC14A-PLR-SF-EJL
CL640-1308-0
IC14A-G-EJL
CL640-1404-3
4.9
7.7
2.3
14.4
1
2
3
BPCB mounting pattern
●Standard
●Without Standoff
●Without Standoff
14.4MAX
54.425±0.05
50.4±0.05
54.425±0.05
Mounting area
(2.2)
(2.2)
50.4±0.05
2.5±0.1
4.025±0.05
3.5MIN
1.8MAX
4.3MIN
5.65MIN
1.95
MIN
32.5MIN
No conductive traces
2.95MIN
2 58.9±0.05
(Right button)
50.4±0.05
2
2
64.8±0.05
Card edge position
48±0.05
53.2MAX
59.2MIN
2.5±0.1
54.425±0.05
4.025±0.05
GND
GND
Card edge position
2
2
14.6MIN
Mounting area
11.5MAX
(2.2)
GND
12.225±0.05
3.55±0.1
11.5MAX
2.5±0.1
54.425±0.05
14.6MIN
Mounting area
46.2±0.05
53.2MAX
59.2MIN
2.4±0.05
4.2±0.05
C
2.6MAX
21±0.05
2
43.8±0.05
56.9MIN
3.5MIN
2.6 MAX
3.5MIN
4.4MAX
3.5 MIN
3.8 MIN
3.8 MIN
7.75 MIN
4.4MAX
2-Ø2.2
3.5 MIN
Shield plate mounting area
+0.1
+0
7MIN
7.75 MIN
3.5 MIN
2.6MAX
+0.1
2-Ø2.2 +0
7MIN
3.5MIN
3.5MIN
4.4MAX
3.5 MIN
4.3MIN
5.65MIN
●Standoff 1.5mm
50.4±0.05
(2.2)
53.9MIN
52.2MAX
(Left button)
12.225±0.05
3.55±0.1
2-Ø2.2
C
●Standoff 1.5mm
64.8±0.05
+0.1
+0
54.65±0.05
2.95MIN
2 58.9±0.05
GND
55.2MIN
52.2MAX
2-Ø2.2
C
1.95MIN
3.55±0.1
2-Ø2.2
+0.1
Card edge position
4.25±0.05
2-Ø2.2 +0
GND
59.1MAX
54.65±0.05
12.225±0.05
4.8MIN
64.75±0.05
Card edge position
1.8MAX
2.5±0.1
GND
59.1MAX
GND
4.25±0.05
Mounting area
4.025±0.05
32.5MIN
3.55±0.1
12.225±0.05
64.75±0.05
GND
4.025±0.05
14.4MAX
(Right button)
(Left button)
2.6MAX
C
22.8±0.05
2
4.4MAX
43.8±0.05
56.9MIN
●Standoff 2.2mm
(Common to both Right & left buttons)
11.5MAX
2.5±0.1
54.425±0.05
14.6MIN
Mounting area
GND
3.55±0.1
(2.2)
4.025±0.05
GND
Card edge position
4.3MIN
2.95MIN
1.5MAX
1.5MAX
1.95MIN
4.05MIN
7.25MIN
2-Ø2.2 +0.1
54.65±0.05
2 53.2MAX
2 59.2MIN
3.75MIN
4.25±0.05
5.65MIN
64.75±0.05
12.225±0.05
50.4±0.05
C
2 58.9±0.05
Note 1)
area show the conductive pattern prohibited area.
Note.2)
Indicated dimensions are symmerical to the center of the card insertion slot.
2
A13
●Reverse
●Standoff 2.2mm
64.75±0.05
3.55±0.1
Mounting area
2.5±0.1
54.425±0.05
4.025±0.05
GND
11.5MAX
(2.2)
12.225±0.05
50.4±0.05
14.6MIN
GND
Card edge position
4.25±0.05
2
2
1.5MAX
1.5MAX
1.95MIN
4.05MIN
7.25MIN
5.65MIN
3.75MIN
+0.1
4.3MIN
2-Ø2.2
54.65±0.05
53.2MAX
59.2MIN
C
2 58.9±0.05
Note 1)
Note.2)
2
BPCB mounting area (Enlarged views)
●Standard
●Without Standoff
48.2±0.05
GND
Ø2
No.1
No.2
.3
No.68
GND
Ø2.3
No.34
No.35
Ø1.8±0.05(Plated through hole)
P=0.635±0.03
68-0.37±0.03
3±0.1
1.9±0.1
3±0.1
4.4±0.1
2.2±0.05
5
Ø1.85±0.05(Plated through hole)
C
48.2±0.05
●Standoff 1.5mm, 2.2mm
3±0.1
Ø2
2.7MIN
.3
4.2MIN
4.4±0.1
No.2
GND
No.34
No.68
GND
3±0.1
No.1
1.9±0.1
P=0.635±0.03
68-0.37±0.03
Ø2.3
No.35
5
1.05MIN
1.05MIN
C
2 58.4MIN
●Reverse
●Standoff 2.2mm
GND
Ø2
No.68
No.34
4.2MIN
2.7MIN
.3
P=0.635±0.03
68-0.37±0.03
No.2
No.1
GND
No.35
1.05MIN
1.05MIN
C
2 58.4MIN
3±0.1
1.9±0.1
3±0.1
4.4±0.1
2.2±0.05
Ø2.3
5
4.4±0.1
3.9275±0.05
2±0.1(Terminal mounting area)
4.2±0.1(Terminal mounting area)
48.2±0.05
46.4725±0.05
4.4±0.1
2.2±0.05
46.4725±0.05
3.9275±0.05
A14
4.4±0.1
3.9275±0.05
46.4725±0.05
BAssembly of units and board placement procedures
(1) Mount the SMT unit on the PCB board.
SMT unit
Guide unit
SBR
PRBM3
A
Push rod
Stroke arm
PCB
PAR
PBR
Fig. 1
Note 1: Verify and make sure that the position of the stroke arm of the SMT unit and the push rod of the Guide unit are at the positions indicated
in Fig. 1. (as delivered).
If needed, position them as shown.
Correct position of the push rod and the stroke arm is required for correct assembly of both units.
Note 2: Make sure that the SMT unit is positioned securely.
Note 3: Soldering will not be possible with the Guide unit attached first.
The Guide unit must be attached and secured to the PCB board AFTER the SMT unit is attached to the PCB.
SBR
SBR
Interference
Interference
Fig. 2
A15
(2) Align both arrow marks (stamped on the shield plate) on the Guide unit with the corresponding grooves on the (mounted on the
board) SMT unit (as illustrated of Fig. 3 and 3-1).
SBR
PRBM3
A
Fig. 3-1
PAR
PBR
Fig. 3-2
Fig. 3
Shield plate
Arrow mark
Insulator part
SBR
A
Position B
Position A
Groove
Fig. 3-1
Gide unit
SMT unit
Fig. 3-2
A16
PCB
Note 3: Place the Guide unit over the installed SMT unit, (exercising caution NOT to touch the spring, push rod or the stroke arm).Ref. Fig.4
PRBM3
Guide unit holding areas
PAR
PBR
Fig. 4
A17
(3) Slide the Guide unit forward until it is locked with the SMT unit.
Fully locked units should be as shown on Fig. 5.
Slide forward
Shiel plate
SMT unit
SBR
PRBM3
Spring portion
Slide forward
PAR
PBR
Fully locked
SBR
Visible insulator
Locking area
No space
Fig. 5
A18
Note 5: It is assumed that the Guide unit and the SMT unit will be mounted on the same PCB. However, in some applications the Guide unit may be
mounted directly on the device’s case/housing.
It is critical that the miss-alignment of the Guide unit must be kept within ± 0.15 mm.
The side clearance between the case/housing and the shield plate should be 0.15mm minimum. Ref. Fig. 6
Note 5. Clearance between body and shield: 0.15 mm minimum.
±0.15
PRBM3
SBR
±0.15
PAR
PBR
Device case/housing
Fig. 6
Note 6: DO NOT insert/eject the PC card before the SMT unit and the Guide unit are fully mounted and locked, with the push rod and stroke arm
connected.
A19
(4) The Guide unit should be securely attached with two screws.
(4-1) IC14 and IC14A Types ••• Fig. 7 (From the bottom of the PCB)
PAR
Fig. 7
(4-2) IC14B Type ••• Fig. 8 (From the top of the PCB)
PAR
PBR
Fig. 8
Note 7: The IC14 and IC14A assemblies do not require separate hex nuts.
Note 8: Hex nuts and screws are required for the IC14B assemblies. Max. length of the screw thread is 1.4mm.
Screw size
M2∞0.4
A20
Connector type
Recommended tightening torque (N•m)
IC14 type
0.12~0.16
IC14A and IC14B type
0.14~0.18
BRecommended procedure for removal of the Guide unit
(1) Remove the 2 screws attaching the Guide unit to the PCB.
(2) Make sure that the stroke arm of the SMT unit and the pushrod of the Guide unit are at the positions indicated in Fig. 1.
Guide unit
SMT unit
Remove screws
SBR
PRBM3
Push rode
Stroke arm
PAR
PBR
PCB
Fig. 1
(3) As illustrated in Fig. 2, the lock between the shield plate and the ribs of the insulated case can be released.
Press the insulator on both side of the installed assembly and carefully slide the Guide unit.
Press
Shield plate
Range of retaining position
Detail A
Pull guide unit in this direction
Left side
Right side
SBR
PRBM3
Press
Release pressure points
(each side)
PAR
PBR
Release pressure points (each side)
Fig. 2
A21
Note 1: As illustrated in the enlarged view of Fig. 3, the lock is released by deflecting the insulator approximately 0.5 mm.
Detail A lock release condition
Shield plate
Insulator (deflect)
Fig. 3 detail A - enlarged view
Note 2: Assure that the push rod remains in its original position. Moving it from this position may cause it to fall-out.
SBR
PRBM3
Original push rod position
Fig. 4
A22
Do not move in this position
BRecommended opening dimensions for the device housing
(Card Insertion Slot and Ejection button guide)
(55)
1 (6)
1
(28.5)
(33.2)
1 : PC Card center Line dimensions
BHandling Precautions
(1) Metal components of these connector assemblies have sharp edges. Use caution when handling, installing or dis-assembling.
(2) The design of the device’s case/housing should incorporate sufficient guide and support for the ejection button.
(3) Slight tool marks or cleaning liquid residue the surfaces of the Guide unit will not affect form, fit or function of the assemblies.
A23
BRecommended temperature profile
●Using Typical Solder Paste
Temperature (ç)
5S max
Recommended conditions
Reflow system
: IR reflow
Solder composition
: Paste, 63%Sn/37%Pb
(Flux content 9wt%)
Test board
: Glass epoxy
80mm∞125mm∞1.6mm
thick
Metal mask
60~90S
Preheating
30S
: 0.15mm thick
20~30S
Soldering
Start
Time (Seconds)
●Using Lead-free Solder Paste
250ç(PEAK)
250
220ç
Temperature (ç)
200
Reflow system
: IR reflow
Solder composition
: Paste, 96.5%Sn/3.0%Ag/0.5%Cu
(Flux content 10.5wt%)
170ç
150
Test board
: Glass epoxy
Metal mask
: 0.15mm thick
150ç
80mm∞125mm∞1.6mm thick
60s(MAX)
100
The temperature profiles are based on the above conditions.
60~120s
50
In individual applications the actual temperature may vary,
25ç
Preheating
Start
depending on solder paste type, volume/thickness and board
size/thickness. Consult your solder paste and equipment
manufacturer for specific recommendations.
Time (Seconds)
A24
Soldering
IC14A-PL-SF-EJL(71) 价格&库存
很抱歉,暂时无法提供与“IC14A-PL-SF-EJL(71)”相匹配的价格&库存,您可以联系我们找货
