HDM12FA1K00
HDM12FA1K00
    SEI
    插件电阻 - 1KΩ ±1% 1/2W -500~+350ppm/℃
HDM12FA1K00 数据手册
HDM Series Stackpole Electronics, Inc. Moisture Resistant Carbon Film Resistor Resistive Product Solutions Features: • • • • • • • Specialized materials, processes and controls ensure a part that is impervious to moisture Small size with high power density Auto sequencing / insertion capable Low cost replacement in many applications using metal glaze resistors 100% RoHS compliant and lead free without exemption Halogen free REACH compliant Electrical Specifications Type / Code Power Rating (W) @ 70ºC HDM14 HDM12 0.25 0.5 (1) Lesser of √ P*R Maximum Working Voltage (V) (1) 300 350 Maximum Overload Voltage (V) 600 700 Ohmic Range (Ω) and Tolerance 1%, 2%, 5% 1 - 2.2M or maximum working voltage. Mechanical Specifications A Body Length 0.126 +0.008 / -0 3.20 +0.20 / -0 0.236 ± 0.012 6.00 ± 0.30 Type / Code HDM14 HDM12 B Body Diameter 0.071 ± 0.008 1.80 ± 0.20 0.094 ± 0.008 2.40 ± 0.20 C Lead Length (Bulk) 1.102 ± 0.118 28.00 ± 3.00 1.102 ± 0.118 28.00 ± 3.00 D Lead Diameter 0.018 ± 0.002 0.45 ± 0.05 0.024 ± 0.001 0.60 ± 0.02 Unit inches mm inches mm Performance Characteristics Test Performance or Quality Acceptance TCR - Temperature Coefficient of Resistance R < 100K Ω: -500 ~ +350 ppm/ºC 100K Ω ≤ R < 1 M Ω: -700 ~ 0 ppm/ºC R ≥ 1 M Ω: -1500 ~ 0 ppm/ºC Test Condition and Method Measure resistance (R0) at room temperature (t), after that, measure again the resistance (R) at 100ºC higher than room temperature. TCR = R - R0 R0 Overload (Short Time) Damp heat (Steady State) Load Life Pressure Cooker Bias Test Change of resistance ≤ ± (0.75% + 0.05 Ω) Change of resistance R < 100K Ω: ≤ ± (3% + 0.05 Ω) R ≥ 100K Ω: ≤ ± (5% + 0.05 Ω) Change of resistance R < 100K Ω: ≤ ± (2% + 0.05 Ω) R ≥ 100K Ω: ≤ ± (3% + 0.05 Ω) Change of resistance ≤ ± (20% + 0.05 Ω) x 106 (ppm/ºC) (t + 100) - t Apply the 2.5 times rated voltage or max overload voltage whichever is lower for 5 seconds and leave in room temperature for one hour after test. In the chamber having temperature 40 ± 2ºC and relative humidity 93 ± 3%, apply one percent of the power rating, 1.5 hour ON, 0.5 hour OFF for 1000 hours and leave in room temperature for one hour after test. At 70 ± 2ºC, apply rated DC voltage 1.5 hour ON, 0.5 hour OFF for 1000 hours and leave in room temperature for one hour after test. 121ºC, 2 atm, 98 - 100% R.H. Apply the rated DC voltage for 100 hours. Reference standards: JIS C5201-1, IEC60115-1 Operating temperature range is -55ºC to +155ºC Rev Date: 10/22/2020 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 1 www.seielect.com marketing@seielect.com HDM Series Stackpole Electronics, Inc. Moisture Resistant Carbon Film Resistor Resistive Product Solutions Power Derating Curve: Pressure Cooker Test Performance Recommended Solder Profiles This information is intended as a reference for solder profiles for Stackpole resistive components. These profiles should be compatible with most soldering processes. These are only recommendations. Actual numbers will depend on board density, geometry, packages used, etc., especially those cells labeled with “*”. 100% Matte Tin / RoHS Compliant Terminations Soldering iron recommended temperatures: 330°C to 350°C with minimum duration. Maximum number of reflow cycles: 3. Rev Date: 10/22/2020 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 2 www.seielect.com marketing@seielect.com HDM Series Stackpole Electronics, Inc. Moisture Resistant Carbon Film Resistor Resistive Product Solutions Wave Soldering Description Maximum Recommended Preheat Time 80 seconds 70 seconds Temperature Diff. 140°C 120°C Solder Temp. 260°C 250°C Dwell Time at Max. 10 seconds 5 seconds Ramp DN (°C/sec) N/A N/A Temperature Diff. = Defference between final preheat stage and soldering stage. Minimum 60 seconds 100°C 240°C * N/A Convection IR Reflow Description Maximum Recommended Minimum Ramp Up (°C/sec) Dwell Time > 217°C Solder Temp. Dwell Time at Max. Ramp DN (°C/sec) 3°C/sec 150 seconds 260°C 30 seconds 6°C/sec 2°C/sec 90 seconds 245°C 15 seconds 3°C/sec * 60 seconds * 10 seconds * Recommended Lead Free Resistor Reflow Profile Rev Date: 10/22/2020 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 3 www.seielect.com marketing@seielect.com HDM Series Stackpole Electronics, Inc. Moisture Resistant Carbon Film Resistor Resistive Product Solutions Repetitive Pulse Information: If repetitive pulses are applied to resistors, pulse wave form must be less than “pulse limiting voltage”, “pulse limiting current” or “pulse limiting wattage” calculated by the formula below. Vp = K√P x R x T/t lp = K√P/P x T/t Pp = K2 x P x T/t Where: Vp: lp: Pp: P: R: T: t: K: [Vr: Note 1: Note 2: Note 3: Note 4: Note 5: Note 6: Pulse limiting voltage (V) Pulse limiting current (A) Pulse limiting wattage (W) Power rating (W) Nominal resistance (ohm) Repetitive period (sec) Pulse duration (sec) Coefficient: 0.8 Rated Voltage (V), Ir: Rated Current (A)] If T > 10 → T = 10 (sec), T / t > 1000 → T / t = 1000 If T > 10 and T / t > 1000, “Pulse Limiting power (Single pulse) is applied If Vp < Vr (lp < lr or Pp < P), Vr (lr, P) is Vp (lp, Pp) Pulse limiting voltage (current, wattage) is applied at less than rated ambient temperature. If ambient temperature is more than the rated temperature (70 °C), decrease power rating according to “Power Derating Curve” Assure sufficient margin for use period and conditions for “pulse limiting voltage” If the pulse waveform is not square wave, judge after transform the waveform into square wave according to the “Waveform Transformation to Square Wave”. Rev Date: 10/22/2020 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 4 www.seielect.com marketing@seielect.com HDM Series Stackpole Electronics, Inc. Moisture Resistant Carbon Film Resistor Resistive Product Solutions Waveform Transformation to Square Wave 1. Discharge curve wave with time constant “t” → Square wave 2. Damping oscillation wave with time constant of envelope “t” → Square wave 3. Half-wave rectification wave → Square wave 4. Triangular wave → Square wave 5. Special wave → Square wave Rev Date: 10/22/2020 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 5 www.seielect.com marketing@seielect.com HDM Series Stackpole Electronics, Inc. Moisture Resistant Carbon Film Resistor Resistive Product Solutions RoHS Compliance Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances” (RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as amended by Directive (EU) 2015/863/EU as regards the list of restricted substances. RoHS Compliance Status Standard Product Series HDM Description Package / Termination Type Standard Series RoHS Compliant Lead-Free Termination Composition Lead-Free Mfg. Effective Date (Std Product Series) Lead-Free Effective Date Code (YY/WW) Moisture Resistant Carbon Film Leaded Resistor Axial YES 100% Matte Sn Always Always “Conflict Metals” Commitment We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the eastern Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the electronics industry is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and products we supply do not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of Dodd-Frank Act regarding Conflict Minerals. Compliance to “REACH” We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free and compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List. Environmental Policy It is the policy of Stackpole Electronics, Inc. (SEI) to protect the environment in all localities in which we operate. We continually strive to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our environment and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms of pollution. How to Order H D Product Series Description Moisture Resistant HDM Carbon Film Code M Power Rating Code W 14 0.25 12 0.5 1 Code F G J 2 J Tolerance Tol Value 1% E24 2% 5% T Code T A Description Tape and Reel Ammo B Bulk 4 K Size All Sizes All Sizes 14 12 7 Quantity 5000 5000 2000 1000 0 Resistance Value Four characters with the multiplier used as the decimal holder. 1 ohm = 1R00 10 Kohm = 10K0 2.2 Mohm = 2M20 Rev Date: 10/22/2020 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 6 www.seielect.com marketing@seielect.com
HDM12FA1K00
物料型号:HDM系列,包括HDM14和HDM12两种型号。
器件简介: - 这些电阻器采用特殊的材料、工艺和控制,确保对湿气的防护。 - 尺寸小,功率密度高。 - 适合自动排序/插入。 - 成本低廉,可替代许多使用金属釉电阻器的应用。 - 符合100% RoHS标准,无铅且无豁免。 - 无卤素。 - 符合REACH标准。
引脚分配:文档中未明确提供引脚分配信息,但通常轴向电阻器的引脚分配是两端引出。
参数特性: - HDM14:功率额定0.25W,最大工作电压300V,最大过载电压600V,欧姆范围和公差1-2.2M,1%、2%、5%。 - HDM12:功率额定0.5W,最大工作电压350V,最大过载电压700V。
功能详解: - 电阻的温度系数(TCR)在不同电阻值下有不同的表现。 - 湿热(稳态)测试后,电阻值变化有具体限制。 - 负载寿命测试规定了在特定条件下电阻值的变化范围。 - 高压锅偏置测试规定了在极端条件下电阻值的最大变化。
应用信息:适用于需要防潮、高功率密度和成本效益的应用场合。
封装信息: - HDM14:体长0.126英寸,体径0.071英寸,引脚长度1.102英寸,引脚直径0.018英寸。 - HDM12:体长0.236英寸,体径0.094英寸,引脚长度1.102英寸,引脚直径0.024英寸。
HDM12FA1K00 价格&库存
很抱歉,暂时无法提供与“HDM12FA1K00”相匹配的价格&库存,您可以联系我们找货
