MDF6-8DP-3.5DSA(05)
MDF6-8DP-3.5DSA(05)
    HRS(广濑)
    CONN HEADER 8POS 3.5MM DIP
MDF6-8DP-3.5DSA(05) 数据手册
MDF6 Series Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 3.5mm Pitch, Double Row, Compact Internal Power Connector (UL/CSA Standard Certified Product) Feb. 2021 ② MDF6 Series/3.5mm Pitch, Double Row, Compact Internal Power Connector (UL/CSA Standard Certified Product) Features 1. 3. 5mm pitch compact connector MDF6 Series is a compact, space- saving power connector with a 3. 5mm × 5mm pitch set in a double row alignment configuration. Inner Positive Lock Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 2. 7A Current Capacity Compact power connector that maintains a current capacity of 7A when using 16 AWG ( UL/ CSA standard is 6A) . 3. Box Type Header The box type header is highly resistant to prying and is polarized to prevent mis- insertion. Mis-insertion Prevention Design 4. Internal Positive Lock Secure mating with enhanced safety is secured by the internal positive lock. Applications Internal power supply for various devices 2 MDF6 Series/3.5mm Pitch, Double Row, Compact Internal Power Connector (UL/CSA Standard Certified Product) Product Specifications Rated Current (Note 1) 16 AWG 18 AWG 20AWG 22 AWG 7A/pin 6A/pin 5A/pin 4A/pin Rated Voltage 300V AC/DC Rated Current -30 to 85℃ Operating Humidity Range (Note 3) 40 to 80% Storage Temperature Range -10 to 60℃ Storage Humidity Range 40 to 70% 16 AWG 18 AWG 20 AWG 22 AWG 6A/pin 6A/pin 4A/pin 4A/pin UL/CSA UL : 250V AC Rated Voltage Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Operating Temperature (Note 2) CSA : 30V AC ■ UL CSA Safety Standard File No. UL : E52653 CSA : LR95109 Item Specifications Conditions Insulation Resistance 1000M Ω Min. 500V DC Withstanding Voltage No flashover or insulation breakdown. 1,500V AC per min. Contact Resistance 30m Ω Max. 1mA Vibration Resistance No electrical discontinuity of 1μ s or more Frequency : 10 to 55Hz, single amplitude of 0.75mm, 10 cycles in each of the 3 directions. Humidity (Steady state) Contact Resistance : 30m Ω Max. Insulation Resistance : 1000M Ω Min. 96 hours at temperature of 40 ± 2℃ and humidity of 90% to 95% Temperature Cycle Contact Resistance : 30m Ω Max. Insulation Resistance : 1000M Ω Min. (-55℃ : 30 minutes → 5 to 35℃ : 10 minutes → 85℃ : 30 minutes → 5 to 35℃ : 10 minutes) 5 cycles Mating Durability Contact Resistance : 30m Ω Max. Tin Plated : 30 cycles Soldering Heat Resistance No deformation of components affecting performance. Flow : 250℃ for 10 seconds Manual soldering : 300℃ for 3 seconds Note Note Note Note 1 2 3 4 : : : : The rated current changes depending on the cable used. Only the rated current of the header is 7A. Includes temperature rise due to current flow. No condensing. Information contained in this catalog represents general requirements for this Series. Contact us for the drawings and specifications for a specific part number shown. Material / Finish Product Part Material Finish Remarks Crimp Socket Insulator Polyamide Resin Natural (White) UL94V-0 Socket Crimp Contact Contact Phosphor Bronze Tin Plating - Insulator Polyamide Resin Natural (White) UL94V-0 Contact Brass Tin Plating - Pin Header 3 RoHS2 〇 MDF6 Series/3.5mm Pitch, Double Row, Compact Internal Power Connector (UL/CSA Standard Certified Product) Product Number Structure ■ Connector MDF6 - # DS - 3.5 C Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ❶ ❷ ❸ ❹ ❺ ❶ Series Name MDF6 ❹ Contact Pitch 3.5mm ❷ No. of Pos. 4 to 20 ❺ Contact Type ❸ Connector Type DS : Double Row Socket DP : Double Row Pin Header C : Crimp Socket DSA : Straight Pin Header DS : Right Angle Pin Header ❷ Packaging Type SCF : Socket Contact, Reel SC : Socket Contact, Pack ■ Contact MDF6 - 1618 SCF ❶ ❶ Applicable Cable Size ❷ 1618 : 16-18 AWG 2022 : 20-22 AWG 4 MDF6 Series/3.5mm Pitch, Double Row, Compact Internal Power Connector (UL/CSA Standard Certified Product) Double Row Socket A B C P=3.5 CAV No. Mark 5 8.2 14.2 Shown with crimp contacts assembled. Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 5.5 4.2 10.4 A Polarity Mark 1 3 * * 2 4 * * Contact No. Mark Part No. HRS No. No. of Pos. A B C MDF6-4DS-3.5C CL0547-0074-1-00 4 10.5 8.1 3.5 MDF6-6DS-3.5C CL0547-0075-4-00 6 14.0 11.6 7.0 MDF6-8DS-3.5C CL0547-0076-7-00 8 17.5 15.1 10.5 MDF6-10DS-3.5C CL0547-0077-0-00 10 21.0 18.6 14.0 MDF6-12DS-3.5C CL0547-0078-2-00 12 24.5 22.1 17.5 MDF6-14DS-3.5C CL0547-0079-5-00 14 28.0 25.6 21.0 MDF6-16DS-3.5C CL0547-0080-4-00 16 31.5 29.1 24.5 MDF6-18DS-3.5C CL0547-0081-7-00 18 35.0 32.6 28.0 MDF6-20DS-3.5C CL0547-0082-0-00 20 38.5 36.1 31.5 5 Purchase Unit 100pcs per bag MDF6 Series/3.5mm Pitch, Double Row, Compact Internal Power Connector (UL/CSA Standard Certified Product) Socket Crimp Contact 16.3 11.5 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 2.4 2.6 1.4 4.9 2.3 Applicable Cable Indicator Part No. HRS No. MDF6-1618SCF CL0547-0070-0-00 MDF6-1618SC CL0547-0071-3-00 MDF6-2022SCF CL0547-0072-6-00 MDF6-2022SC CL0547-0073-9-00 ● Applicable Cable Applicable Cable AWG Size Jacket Diameter 16-18 AWG φ 2.5 to 2.0 20-22 AWG φ 1.9 to 1.5 Type Purchase Unit Reel Contact 5000pcs per reel Loose Contact 100pcs per bag Reel Contact 5000pcs per reel Loose Contact 100pcs per bag Applicable Cable (Tin Plated Annealed Copper Wire) Conductor Size (Wire Construction) 16 AWG(26/0.254mm) 18 AWG(34/0.18mm) 20 AWG(21/0.18mm) 22 AWG(17/0.16mm) Jacket Diameter Recommended Cable Strip Length UL1061, UL1007 2.7 to 4.4mm φ 2.5 to 2.0 φ 1.9 to 1.5 Note : Please contact a Hirose sales representative when using cables other than those specified. 6 MDF6 Series/3.5mm Pitch, Double Row, Compact Internal Power Connector (UL/CSA Standard Certified Product) Double Row Pin Header : Straight Type 5 5.8 Polarity Mark □ 0.76 10.5 5.6 13 0.76×1.52 3.5 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ●Applicable Through Hole Diameter of PCB : φ1.3+0.1  0 ●Applicable PCB Thickness : 1.6±0.2 2.3 10.9 A B P=3.5 2.7 CAV No. Mark 1 * A * 2 Contact No. mark Part No. HRS No. No. of Pos. A B MDF6-4DP-3.5DSA(23) CL0547-0083-2-23 4 10.5 3.5 MDF6-6DP-3.5DSA(23) CL0547-0084-5-23 6 14.0 7.0 MDF6-8DP-3.5DSA(23) CL0547-0085-8-23 8 17.5 10.5 MDF6-10DP-3.5DSA(23) CL0547-0086-0-23 10 21.0 14.0 MDF6-12DP-3.5DSA(23) CL0547-0087-3-23 12 24.5 17.5 MDF6-14DP-3.5DSA(23) CL0547-0088-6-23 14 28.0 21.0 MDF6-16DP-3.5DSA(23) CL0547-0089-9-23 16 31.5 24.5 MDF6-18DP-3.5DSA(23) CL0547-0090-8-23 18 35.0 28.0 MDF6-20DP-3.5DSA(23) CL0547-0091-0-23 20 38.5 31.5 7 Purchase Unit 100pcs per bag MDF6 Series/3.5mm Pitch, Double Row, Compact Internal Power Connector (UL/CSA Standard Certified Product) Double Row Pin Header : Right Angle Type A B 2.3 5.8 Polarity Mark 19.95 10.5 5 22 5.6 0.76×1.52 Contact No. Mark 1 A * CAV No. Mark □ 0.76 Part No. HRS No. No. of Pos. A B MDF6-4DP-3.5DS(23) CL0547-0270-0-23 4 10.5 3.5 MDF6-6DP-3.5DS(23) CL0547-0271-2-23 6 14.0 7.0 MDF6-8DP-3.5DS(23) CL0547-0272-5-23 8 17.5 10.5 MDF6-10DP-3.5DS(23) CL0547-0273-8-23 10 21.0 14.0 Application Pattern Cable 25.7 5.5 5 2.7 3.5 13.6 16.7 Cable 3.5 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ●Applicable Board Hole Diameter of PCB : φ1.3+0.1  0 ●Applicable PCB Thickness : 1.6±0.2 5 11.3 3.5 P=3.5 2.05 5 14.95 8 Purchase Unit 100pcs per bag MDF6 Series/3.5mm Pitch, Double Row, Compact Internal Power Connector (UL/CSA Standard Certified Product) Applicable Crimping Tool Type Part No. Main Press Unit Applicator Manual Crimping Tool Extraction Tool HRS No. Applicable Contact CM-105C CL0901-0001-0-00 - AP105-MDF6-1618S CL0901-4512-4-00 MDF6-1618SCF AP105-MDF6-2022S CL0901-4513-7-00 MDF6-2022SCF MDF6-TA1618HC CL0550-0203-5-00 MDF6-1618SC MDF6-TA-2022HC CL0550-0204-8-00 MDF6-2022SC DF-C-PO(A) CL0550-0170-8-00 MDF6-####SC(F) Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Note 1 : Issues caused by tools other than those specified by Hirose are outside the scope of warranty. Note 2 : Please conduct crimping work according to the "Crimp Quality Standard (ETAD-H0792-00)" and "Crimp Condition Table". Note 3 : When non-authorized tools are used, please consult with Hirose sales representative about provision of the drawing of the crimping tool. Precautions When Crimping ■ Required Documents Prior to Crimping The work- related documents listed below are required before beginning cable assembly ( The ● mark indicates required documents) . Please contact a Hirose sales representative if you do not have these documents. Description Automatic Crimping Machine Hand Crimping Tool 1. Crimping Machine Main Unit Instruction Manual Explanation of main press machine unit ● - 2. Applicator Instruction Manual Crimping Method ● - 3. Applicator Spare Parts List Explanation for Applicator Installation ● - 4. Crimp Conditions Standard crimp height and tensile strength values ● - 5. Crimp Quality Standards Various standards for crimping conditions ● - 6. Operating Instructions for Hand Tool Crimping method, standard crimp height and tensile strength values - ● Document Title Reference Bundled with purchase of main press machine unit. Bundled with purchase of applicator. Bundled with purchase of hand tool. ■ Tools Use the tools designated by Hirose when performing crimping. Crimping performed with tools other than those designated is outside the scope of warrantly. The operating instruction manual for the crimping machine and applicator are provided. Be sure to carefully read the operating instructions before beginning work. ■ Applicable Cables Check that the cables to be used are within the applicable range. If you intend to use a cable other than those recommended, contact a sales representative. [ Precautions] • Cables applicable to crimping connectors are tin- plated stranded soft- copper wire. • Avoid crimping solid wire, wires with polyester threads or tin coated wires. • Avoid crimping two cables together. • The crimp height setting values ( Note) may vary between tin- plated and gold- plated terminals even if the same electric wires are used. • The crimp height setting values ( Note) may vary depending on the difference in the core wire configuration even if the computed cross- sectional area is the same. Note : The crimp height is an important item that determines crimping quality. We execute crimping tests for each electric wire to ensure the optimal value for the crimp height with high precision, thereby ensuring optimal setup values. 9 MDF6 Series/3.5mm Pitch, Double Row, Compact Internal Power Connector (UL/CSA Standard Certified Product) Precautions Please refer to the "Wire-to-Board Connector Use Handbook". 2.Connection Conditions Please refer to the "Wire-to-Board Connector Use Handbook". 3.Precautions ■ The color of the plastic molding may differ slightly depending on product lot and future storage conditions but this does not affect the product performance. 4.Handling Please refer to the following documents when handling the product. ■ Crimp Quality Standard(ATAD-H0792-00) ■ Wire-to-Board Connector Use Handbook Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1.Cleaning Conditions While taking in consideration Specifications mentioned in this catalog are reference values. When considering to order or use this product, please confirm the " Drawing" and " Product Specifications" sheets. Use an appropriate cable when using the connector in combination with cables. If considering usage of a non- specified cable, please contact your sales representative. If assembly process is done by jigs & tools which are not identified by Hirose assurance will not be given. Please consult with your Hirose sales representative if you are planning to use the product for any of the following applications. ( Automotive, medical, public infrastructure, aerospace/ defense, etc. ) Hirose will consider the validity of the warranty depending on the conditions. 10 MDF6 Series/3.5mm Pitch, Double Row, Compact Internal Power Connector (UL/CSA Standard Certified Product) [ JAPAN ] [ GERMANY ] [ TAIWAN ] Headquarters GERMAN Branch / STUTTGART Office TAIWAN Office HIROSE ELECTRIC CO., LTD. HIROSE ELECTRIC EUROPE B.V. HIROSE ELECTRIC (TAIWAN) CO., LTD. Phone : +81-45-620-7410 http://www.hirose.com Phone : +49-711-456002-1 http://www.hirose.com/eu/ Phone : +886-2-2555-7377 http://www.hirose.com/tw/ NUREMBERG Office [ U.S.A ] US Headquarters / CHICAGO Office HIROSE ELECTRIC ( U.S.A.), INC. Phone : +1-630-282-6700 http://www.hirose.com/us/ SAN JOSE Office HIROSE ELECTRIC EUROPE B.V. Phone : +49-911-326889-63 http://www.hirose.com/eu/ HIROSE ELECTRIC EUROPE B.V. Phone : +49-511-978261-30 http://www.hirose.com/eu/ Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. [ FRANCE ] SINGAPORE Office HIROSE ELECTRIC SINGAPORE PTE. LTD. PARIS Office Phone : +1-734-542-9963 http://www.hirose.com/us/ Phone : +33-1-85764886 http://www.hirose.com/eu/ HIROSE ELECTRIC EUROPE B.V. DALLAS Office HIROSE ELECTRIC ( U.S.A.), INC. [ ITALY ] BANGKOK Liaison Office HIROSE ELECTRIC SINGAPORE PTE. LTD. MILAN Office HIROSE ELECTRIC EUROPE B.V. Phone : +39-02-36636350 http://www.hirose.com/eu/ Phone : +1-972-324-3370 http://www.hirose.com/us/ IRVINE Office [ CHINA ] PENANG Representative Office CHINA Headquarters / SHANGHAI Branch Phone : +1-949-930-3750 http://www.hirose.com/us/ HIROSE ELECTRIC ( CHINA ) CO., LTD. [ THE NETHERLANDS ] SHENZHEN Branch EU Headquarters / AMSTERDAM OFFICE Phone : +86-755-8207-0851 http://www.hirose.com/cn/ Phone : +31-20-6557460 http://www.hirose.com/eu/ [ UNITED KINGDOM ] UK Branch HIROSE ELECTRIC EUROPE B.V. Phone : +44-1908-202050 http://www.hirose.com/eu/ Phone : +66-2-686-1255 http://www.hirose.com/sg/ [ MALAYSIA ] HIROSE ELECTRIC ( U.S.A.), INC. HIROSE ELECTRIC EUROPE B.V. Phone : +65-6324-6113 http://www.hirose.com/sg/ [ THAILAND ] BOSTON Office Phone : +1-978-655-9850 http://www.hirose.com/us/ Phone : +82-31-496-7000 http://www.hirose.co.kr/ [ SINGAPORE ] DETROIT Office (AUTOMOTIVE) HIROSE ELECTRIC ( U.S.A.), INC. HIROSE ELECTRIC ( U.S.A.), INC. KOREA Office HIROSE KOREA CO.,LTD. HANOVER Office HIROSE ELECTRIC ( U.S.A.), INC. Phone : +1-408-253-9640 http://www.hirose.com/us/ [ KOREA ] Phone : +86-21-6391-3355 http://www.hirose.com/cn/ HIROSE ELECTRIC ( CHINA ) CO., LTD. HIROSE ELECTRIC SINGAPORE PTE. LTD. Phone : +60-4-648-5536 http://www.hirose.com/sg/ [ INDIA ] BANGALORE Office HIROSE ELECTRIC INDIA PVT. LTD. Phone : +91-80-4120-1907 http://www.hirose.com/sg/ BEIJING Branch HIROSE ELECTRIC ( CHINA ) CO.,LTD. Phone : +86-10-5165-9332 http://www.hirose.com/cn/ GUANGZHOU Branch HIROSE ELECTRIC ( CHINA ) CO.,LTD. DELHI Office HIROSE ELECTRIC INDIA PVT. LTD. Phone : +91-120-660-8018 http://www.hirose.com/sg/ Phone : +86-180-9895-1861 http://www.hirose.com/cn/ [ HONG KONG ] HONG KONG Office HIROSE ELECTRIC HONGKONG TRADING CO., LTD.    Phone : +852-2803-5338 http://www.hirose.com/hk/ 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN        https://www.hirose.com https://www.hirose-connectors.com ※ The contents of this catalog are current as of date of 2/ 2021. Contents are subject to change without notice for the purpose of improvements. 11 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. M E M O
MDF6-8DP-3.5DSA(05)
物料型号:MDF6系列,3.5mm间距,双排紧凑内部电源连接器(UL/CSA标准认证产品)
器件简介:MDF6系列是一种紧凑、节省空间的电源连接器,具有3.5mm x 5mm的间距,以双排对齐配置设置。
引脚分配:文档中提供了不同位数的连接器型号,从4到20位不等,例如MDF6-4DS-3.5C至MDF6-20DS-3.5C。
参数特性: - 额定电流:16AWG 7A/pin,18AWG 6A/pin,20AWG 5A/pin,22AWG 4A/pin - 额定电压:300V AC/DC - 操作温度范围:-30至85°C - 存储温度范围:-10至60°C - 存储湿度范围:40%至70%
功能详解: - 3.5mm间距紧凑连接器 - 7A电流容量,使用16 AWG电线时 - 防撬箱式插座,具有极性防止误插 - 内部正锁,确保安全配对
应用信息:适用于各种设备的内部电源供应。
封装信息: - 绝缘体材料:聚酰胺树脂,自然色(白色),UL94V-0 - 插座端子接触材料:磷青铜,锡镀层 - 针式插座绝缘体材料:聚酰胺树脂,自然色(白色),UL94V-0 - 接触材料:黄铜,锡镀层
MDF6-8DP-3.5DSA(05) 价格&库存
很抱歉,暂时无法提供与“MDF6-8DP-3.5DSA(05)”相匹配的价格&库存,您可以联系我们找货
