WME10007A
WME10007A
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    CONN HSG RCPT PIN PNL MNT 11POS
WME10007A 数据手册
100 Maxi 42 (For information) 74,6±0,2 8 G Spring 65,35±0,4 6 47,1 Mating seal Mating seal (cap) PANEL CUT OUT FOR INFORMATION (FOR REAR MOUNTING) Panel thickness Maxi :3 mm G 85° (for information) LOCKED POSITION (IP69k) 50 Mini OPENED CAP 5 2 Holes 8,4 for screw M8 tightening torque : 4.5Nm Mini / 5.5Nm Maxi 25 5 UNLOCKED POSITION 74,6 66,5 Mini O'ring 7 NOTES : -Contact are delivered separately -The cap is defined according to EN 16330 and Compliance Matrix N°13113 6 -The cap can be assembled with the backshell : WME10010A 8,4 41,5 2 Holes 8 PERFORMANCE CHARACTERISTICS: -Operating temperature : -30° up to +85° -Test potential: 800 V -Insulation resistance : 5 Gohms under 500V -Operating voltage : 28V (for #8) and 24V (for #16) -Rated current : 26A (for #8) et 13A (for #16) -Contact resistance :
WME10007A 价格&库存
很抱歉,暂时无法提供与“WME10007A”相匹配的价格&库存,您可以联系我们找货
