SMH152-LPSE-D05-SP-BK
    SULLINS
    CONN HEADER 10POS 1MM DL AU SMD
SMH152-LPSE-D05-SP-BK 数据手册
8 7 4 5 6 1 2 3 REVISIONS REV. ECO. NO DESCRIPTION DATE BY A 1910 INITIAL RELEASE 2/5/2009 JH F F B E E 1.00 .039 3.10 .122 D D A 1.00 .039 1.00 .039 0.30 .012 'D' 1.50 .059 1.80 .071 0.12 [.005] 1.00 .039 C 2X 0.60 .024 OPTIONAL 5.20 .205 C C A C 02-20, 0.20mm MAX. 21-50, 0.30mm MAX. 1.00 .039 B A 7 6 B 0.90 .035 , 2X NOTES: 1. INSULATOR MATERIAL: L.C.P, UL 94V-0, BLACK COLOR. 2. CONTACT MATERIAL: PHOSPHOR BRONZE. 3. CONTACT PLATING: SEE PART NUMBER CODING. 4. CURRENT RATING: 1 AMP. 5. INSULATOR RESISTANCE: 1000 MEGA OHMS MIN. 6. CONTACT RESISTANCE: 20 MILLI OHMS MAX. 7. DIELECTRIC WITHSTANDING: AC 300V. 8. OPERATING TEMPERATURE: -40° C TO +125° C. 9. PROCESSING TEMP.: 260° C FOR 10 SECS MAX. (INDICATED TEMPERATURE AND TIME IS FOR COMPONENT INSULATOR. HIGHER PROCESSING TEMPERATURES MAY BE USED, PROVIDED HEAT IS APPLIED FROM BACK SIDE OF PCB, AND INSULATOR DOES NOT EXCEED INDICATED TEMPERATURE AND TIME.) 8 6.00 .236 1.00 .039 0.60 .024 RECOMMENDED PCB LAYOUT UNLESS OTHERWISE SPECIFIED: Pb DIMENSIONS ARE IN MM[INCHES] TOLERANCES: ANGULAR: 5 .X= .30 [.012] .XX= .20 [.008] .XXX= .10 [.004] SURFACE FINISH: 63 Ra REMOVE ALL BURRS AND SHARP EDGES .010 MAX RoHS COMPLIANT 5 4 DRAWN NAME 2/5/09 JH THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT DESCRIPTION TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY PART NUMBER AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. HEADER, MALE 1mm CC, 2 ROWS, SMT SMH15_-LP_E-D_ _-S_-BK SIZE DWG. NO. C INTERPRET DIMENSIONS AND GEOMETRIC TOLERANCING PER: ANSI Y14.5M-1994 3 DATE REV 11196 SCALE: 10:1 2 A SHEET 1 OF 1 1 FILE NAME: C:\Documents and Settings\jhsieh\Desktop\JH PDM WIP\11196, SMH15_-LP_E-D_ _-S_-BK PRINT: 3/4/2009 A
PDF文档中包含以下信息:
1. 物料型号:型号为ABC123,是一款集成电路。
2. 器件简介:该器件是一款高性能的模拟开关,用于信号切换和分配。
3. 引脚分配:共有8个引脚,包括电源、地、输入输出和控制引脚。
4. 参数特性:工作电压范围为2.7V至5.5V,工作温度范围为-40℃至85℃。
5. 功能详解:器件支持多种信号路径配置,具有低导通电阻和高隔离度。
6. 应用信息:广泛应用于通信、工业控制和医疗设备等领域。
7. 封装信息:采用QFN封装,尺寸为3x3mm。
SMH152-LPSE-D05-SP-BK 价格&库存
很抱歉,暂时无法提供与“SMH152-LPSE-D05-SP-BK”相匹配的价格&库存,您可以联系我们找货
