265A67-12
265A67-12
    CURTISINDUSTRIES
    CONNTERMBLKHINGEDCVR12POS
265A67-12 数据手册
Type CDM 35/64" (13.86mm) Center-to-Center Spacing BARRIER STYLE High Voltage/Current 6SeFL¿FatLRQs: Features: ‡ Versatile Medium Power Terminal Blocks – Designed for surface mount; power and control applications requiring a wide range of terminal variations. ‡ Sectional Thru-Bolt Construction – Available in one thru 50 terminals on 35/64" center-to-center spacing. Rated 30A/600V for Type CDM. ‡ Durable Break-Resistant Thermoplastic Moldings ‡ Wire Sizes – Type CDM features brass terminal bar with two No. 10-32 washer-head screws. UL recognized for No. 22AWG to No. 10AWG. ‡ Easy Crcuit Identification Design – Barrer-type terminals are furnished with a white fiber marking strip. ‡ Recognition and Listing – Various terminal types are UL recognized and CSA certified Recognized under the Components Program of Underwriters Laboratories, Inc. Standard 1059, Guide No. XCFR2, File No. E62557. Guide No. 184-N-90, Report No. LR39186-1. Type CDM Terminal Designation CDM brass terminal bar with two No. 10-32 washer-head screws acceptig wire up to No. 10AWG. Rated 30A. Type CDM Dimensions NOTE: mm dim. are shown in parentheses O.D. Marking Strip M.D. .468 (11.90) .421 (10.71) 1.25 (31.75) 1.00 (25.4) .547 (13.90) 42 Center-to-Center Spacing: 35/64" (13.86mm) Wire Range: CDM: UL Recognized for 22AWG to No. 10AWG No. of Terminals: 1 thru 50 Voltage Rating: CSA & UL: 600V Tightening Torque: 35 in.-lb. Current Rating: CDM: 30 amps, UL and CSA. Housing: Material Thermoplastic-polyester Continuous Use Temp. (UL Index) 130°C (266°F) Flammability Rating 94V-0 Water Absorption (24 hrs. % wt. gain) 0.7% Chemical Resistance Excellent in most environments Breakdown Voltage: CDM Terminal - Terminal 9,600V Typ. Terminal - Ground 10,800V Typ. Note: Speci¿cations contained herein are subMect to change without notice. www.curtisind.com 2.00 (50.8) Number of Terminals Mounting Dimensions Inches Metric (mm) Overall Dimensions Inches Metric (mm) 1 1.625 42.48 2.346 59.59 2 2.220 56.38 2.896 73.56 3 2.767 70.28 3.441 87.40 4 3.314 84.18 3.988 101.30 5 3.861 98.08 4.535 115.19 6 4.409 111.98 5.083 129.11 7 4.956 125.88 5.630 143.00 8 5.503 139.78 6.177 156.90 9 6.050 153.68 6.724 170.79 10 6.598 167.58 7.272 184.71 Dimensions shown are ± 0.030" .218 x .375 Lg. Mtg. Holes (5.53) x (9.52) Curtis Industries A Division of Powers Holdings, Inc. 6SHci¿cDtionssuEMHcttocKDnJH. Dimensions are shown for reference purposes only. Number of Terminals Mounting Dimensions Inches Metric (mm) Overall Dimensions Inches Metric (mm) 7.145 181.48 7.819 198.60 12 7.692 195.38 8.366 212.50 13 8.239 209.28 8.913 226.39 14 8.787 233.18 9.461 240.31 15 9.334 237.08 10.008 254.20 16 9.881 250.98 10.555 268.10 17 10.428 264.88 11.102 281.99 18 10.976 278.78 11.650 295.91 19 11.523 292.68 12.197 309.80 20 12.070 306.58 12.744 323.70 21 12.617 320.48 13.291 337.59 22 13.165 334.38 13.839 351.51 23 13.712 348.28 14.386 365.40 24 14.259 362.18 14.933 379.30 25 14.806 376.08 15.480 393.19 26 15.354 389.98 16.028 27 15.901 403.88 16.575 421.01 28 16.448 417.78 17.122 434.90 29 16.995 431.68 17.669 448.79 30 17.543 445.58 18.217 462.71 31 18.090 459.48 18.764 476.61 32 18.637 473.38 33 19.184 487.28 19.858 504.39 34 19.732 501.18 20.406 518.31 35 20.279 515.08 20.953 532.21 36 20.826 528.98 21.500 546.10 37 21.373 542.88 22.047 559.99 38 21.921 556.78 22.595 573.91 39 22.468 570.68 23.142 587.81 40 23.015 584.58 23.689 601.70 41 23.562 598.48 24.236 615.59 Type CDM terminal blocks are ordered by listing a composite number made up of the model designation followed by the number of poles required for the application. Example: 10-pole terminal block becomes stock number CDM-10. Series CDM Accessories MARKING STRIPS Two cover styles. Hinged cover of 3/16" thick black bakelite pivoting from special end brackets provide ready access to block. Factory-assembled and available only with original terminal block order. Plain cover of 1/16" thick black bakelite is permanently positioned to block with two screws. Factoryassembled or customer-installed. To order, specify: CDM (Plain) – Part No. 265A61 – 1 thru 50 terminals CDM (Hinged) – Part No. 265A67 – 1 thru 50 terminals JUMPERS Cooper Mumper rated 30A. Designed to fold over barrier to connect adMacent terminals. To order, specify: Part No. 523-A91 High Voltage/Current 11 How to Order 407.11 BARRIER STYLE 19.311 490.50 42 24.110 612.38 24.784 629.51 43 24.657 626.28 25.331 643.41 44 25.204 640.18 25.878 657.30 45 25.751 654.08 26.425 671.20 46 26.299 667.98 26.973 47 26.846 681.88 27.520 699.01 48 27.393 695.78 28.067 712.90 49 27.940 709.68 28.614 726.80 50 28.488 723.50 29.162 740.71 685.11 Dimensions shown are ± 0.030" Dimensions are in inches and millimeters unless otherwise speci¿ed. Values in parentheses are metric equivalents. Curtis Industries A Division of Powers Holdings, Inc. 1-800-657-0853 43
265A67-12
物料型号:CDM
器件简介:Curtis Industries生产的CDM系列是多功能的中功率端子排,设计用于表面安装;适用于需要广泛端子变体的功率和控制应用。
引脚分配:CDM端子排在35/64英寸中心到中心的间距上,可提供1至50个端子。
参数特性: - 额定电流:CDM:30安培 - 额定电压:600伏特 - 接线范围:CDM:UL认可的22AWG至10号AWG - 材料:热塑性聚酯 - 连续使用温度:130°C (266°F) - 阻燃等级:94V-0 - 水吸收率:0.7% - 化学抗性:在大多数环境中表现出色
功能详解:CDM端子排采用隔板式端子,配有白色纤维标记条,易于电路识别。端子类型多样,包括UL认可和CSA认证的类型。
应用信息:适用于高电压/电流的应用,可接线至10号AWG,额定30A。
封装信息:端子排的尺寸从1个端子到50个端子不等,具体尺寸根据端子数量而变化。所有尺寸公差为±0.030英寸,除非另有规定。
订购信息:通过列出型号标识符和所需极数的复合编号来订购CDM端子排。例如,10极端子排的库存编号为CDM-10。还提供了配件,如标记条和跳线。
265A67-12 价格&库存
很抱歉,暂时无法提供与“265A67-12”相匹配的价格&库存,您可以联系我们找货
