Type CDM 35/64" (13.86mm) Center-to-Center Spacing
BARRIER STYLE
High Voltage/Current
6SeFL¿FatLRQs:
Features:
Versatile Medium Power Terminal Blocks – Designed for
surface mount; power and control applications requiring a
wide range of terminal variations.
Sectional Thru-Bolt Construction – Available in one thru
50 terminals on 35/64" center-to-center spacing. Rated
30A/600V for Type CDM.
Durable Break-Resistant Thermoplastic Moldings
Wire Sizes – Type CDM features brass terminal bar with
two No. 10-32 washer-head screws. UL recognized for No.
22AWG to No. 10AWG.
Easy Crcuit Identification Design – Barrer-type terminals
are furnished with a white fiber marking strip.
Recognition and Listing – Various terminal types are UL
recognized and CSA certified
Recognized under the Components Program of
Underwriters Laboratories, Inc. Standard 1059,
Guide No. XCFR2, File No. E62557.
Guide No. 184-N-90, Report No. LR39186-1.
Type CDM Terminal Designation
CDM brass terminal bar with two No.
10-32 washer-head screws acceptig
wire up to No. 10AWG. Rated 30A.
Type CDM Dimensions
NOTE: mm dim. are shown in parentheses
O.D.
Marking Strip
M.D.
.468
(11.90)
.421
(10.71)
1.25
(31.75)
1.00
(25.4)
.547
(13.90)
42
Center-to-Center Spacing: 35/64" (13.86mm)
Wire Range:
CDM: UL Recognized for 22AWG to No. 10AWG
No. of Terminals: 1 thru 50
Voltage Rating: CSA & UL: 600V
Tightening Torque: 35 in.-lb.
Current Rating: CDM: 30 amps, UL and CSA.
Housing:
Material
Thermoplastic-polyester
Continuous Use
Temp. (UL Index)
130°C (266°F)
Flammability Rating
94V-0
Water Absorption
(24 hrs. % wt. gain) 0.7%
Chemical Resistance
Excellent in most environments
Breakdown Voltage:
CDM
Terminal - Terminal
9,600V Typ.
Terminal - Ground
10,800V Typ.
Note: Speci¿cations contained herein are subMect to change
without notice.
www.curtisind.com
2.00
(50.8)
Number of
Terminals
Mounting
Dimensions
Inches
Metric
(mm)
Overall
Dimensions
Inches
Metric
(mm)
1
1.625
42.48
2.346
59.59
2
2.220
56.38
2.896
73.56
3
2.767
70.28
3.441
87.40
4
3.314
84.18
3.988 101.30
5
3.861
98.08
4.535
115.19
6
4.409
111.98
5.083
129.11
7
4.956 125.88
5.630 143.00
8
5.503 139.78
6.177 156.90
9
6.050 153.68
6.724 170.79
10
6.598 167.58
7.272 184.71
Dimensions shown are ± 0.030"
.218 x .375 Lg. Mtg. Holes
(5.53) x (9.52)
Curtis Industries
A Division of Powers Holdings, Inc.
6SHci¿cDtionssuEMHcttocKDnJH.
Dimensions are shown for
reference purposes only.
Number of
Terminals
Mounting
Dimensions
Inches
Metric
(mm)
Overall
Dimensions
Inches
Metric
(mm)
7.145 181.48
7.819 198.60
12
7.692 195.38
8.366 212.50
13
8.239 209.28
8.913 226.39
14
8.787 233.18
9.461 240.31
15
9.334 237.08 10.008 254.20
16
9.881 250.98 10.555 268.10
17
10.428 264.88
11.102 281.99
18
10.976 278.78
11.650 295.91
19
11.523 292.68 12.197 309.80
12.070 306.58 12.744 323.70
21
12.617 320.48 13.291 337.59
22
13.165 334.38 13.839 351.51
23
13.712 348.28 14.386 365.40
24
14.259 362.18 14.933 379.30
25
14.806 376.08 15.480 393.19
26
15.354 389.98 16.028
27
15.901 403.88 16.575 421.01
28
16.448 417.78 17.122 434.90
29
16.995 431.68 17.669 448.79
30
17.543 445.58 18.217 462.71
31
18.090 459.48 18.764 476.61
32
18.637 473.38
33
19.184 487.28 19.858 504.39
34
19.732 501.18 20.406 518.31
35
20.279 515.08 20.953 532.21
36
20.826 528.98 21.500 546.10
37
21.373 542.88 22.047 559.99
38
21.921 556.78 22.595 573.91
39
22.468 570.68 23.142 587.81
40
23.015 584.58 23.689 601.70
41
23.562 598.48 24.236 615.59
Type CDM terminal blocks are ordered by listing a composite
number made up of the model designation followed by the
number of poles required for the application. Example:
10-pole terminal block becomes stock number CDM-10.
Series CDM Accessories
MARKING STRIPS
Two cover styles. Hinged cover of 3/16" thick black bakelite
pivoting from special end brackets provide ready access to
block. Factory-assembled and available only with original
terminal block order. Plain cover of 1/16" thick black bakelite
is permanently positioned to block with two screws. Factoryassembled or customer-installed.
To order, specify:
CDM (Plain) – Part No. 265A61 – 1 thru 50 terminals
CDM (Hinged) – Part No. 265A67 – 1 thru 50 terminals
JUMPERS
Cooper Mumper rated 30A. Designed to fold over barrier to
connect adMacent terminals. To order, specify:
Part No. 523-A91
11
How to Order
407.11
BARRIER STYLE
19.311 490.50
42
24.110 612.38 24.784 629.51
43
24.657 626.28 25.331 643.41
44
25.204 640.18 25.878 657.30
45
25.751 654.08 26.425 671.20
46
26.299 667.98 26.973
47
26.846 681.88 27.520 699.01
48
27.393 695.78 28.067 712.90
49
27.940 709.68 28.614 726.80
50
28.488 723.50 29.162 740.71
685.11
Dimensions are in inches and millimeters
unless otherwise speci¿ed.
Values in parentheses are metric equivalents.
Curtis Industries
1-800-657-0853
43
很抱歉,暂时无法提供与“265A61-50”相匹配的价格&库存,您可以联系我们找货
