LEUWS2W-PXQX-6P6R
LEUWS2W-PXQX-6P6R
    AMSOSRAM(艾迈斯半导体)
    SMD
    LEDOSTARSMD
LEUWS2W-PXQX-6P6R 数据手册
2015-11-27 OSRAM OSTAR Stage Datasheet Version 2.2 (not for new design) LE UW S2W Outstanding brightness and luminance due to surface emission and low Rth Extrem hohe Helligkeit und Leuchtdichte dank Oberflächenemission und niedrigem Rth Features: • Package: compact lightsource in multi chip SMT technology with glass window on top • Technology: ThinGaN • Viewing angle at 50 % IV: 120° • Color: Cx = 0.31, Cy = 0.32 acc. to CIE 1931 (ultra white) • Corrosion Robustness: Improved corrosion robustness Besondere Merkmale: • Gehäusetyp: Kompakte Lichtquelle in Multi-Chip SMT Technologie mit Glasabdeckung • Technologie: ThinGaN • Abstrahlwinkel bei 50 % IV: 120° • Farbe: Cx = 0.31, Cy = 0.32 acc. to CIE 1931 (ultra weiß) • Korrosionsstabilität: Verbesserte Korrosionsstabilität Applications Stage and Entertainment Lighting • • Mood Lighting • Architectural Lighting indoor and outdoor Anwendungen • Bühnen- und Effektbeleuchtung • Stimmungsbeleuchtung • Architekturbeleuchtung innen und außen 2015-11-27 1 Version 2.2 (not for new design) LE UW S2W Ordering Information Bestellinformation Type: Luminous Flux 1) page 25 Ordering Code Typ: Lichtstrom 1) Seite 25 Bestellnummer IF = 700 mA ΦV [lm] LE UW S2W-PXQX-4P7R Note: 450 ... 820 Q65111A0205 The above Type Numbers represent the order groups which include only a few brightness groups (see page 5). Only one group will be shipped on each packing unit (there will be no mixing of two groups on each packing unit). E. g. LE UW S2W-PXQX-4P7R means that only one group PX, PY, PZ, QX will be shippable for any packing unit. In a similar manner for colors where color chromaticity coordinate groups are measured and binned, single groups will be shipped on any one packing unit. LE UW S2W-PXQX-4P7R means that the device will be shipped within the specified limits. Anm.: Die oben genannten Typbezeichnungen umfassen die bestellbaren Selektionen. Diese bestehen aus wenigen Helligkeitsgruppen (siehe Seite 5). Es wird nur eine einzige Helligkeitsgruppe pro Verpackungseinheit geliefert. Z. B. LE UW S2W-PXQX-4P7R bedeutet, dass in einer Verpackungseinheit nur eine der Helligkeitsgruppen PX, PY, PZ, QX enhalten ist. Gleiches gilt für die Farben, bei denen Farbortgruppen gemessen und gruppiert werden. Pro Verpackungseinheit wird nur eine Farbortgruppe geliefert. Z.B. LE UW S2W-PXQX-4P7R bedeutet, dass in einer Verpackungseinheit nur eine der Farbortgruppen enthalten ist. LE UW S2W-PXQX-4P7R bedeutet, dass das Bauteil innerhalb der spezifizierten Grenzen geliefert wird. 2015-11-27 2 Version 2.2 (not for new design) LE UW S2W Maximum Ratings Grenzwerte Parameter Symbol Values Unit Bezeichnung Symbol Werte Einheit Operating temperature range Betriebstemperatur Top -40 ... 85 °C Storage temperature range Lagertemperatur Tstg -40 ... 85 °C Junction temperature Sperrschichttemperatur Tj 125 °C Forward current Durchlassstrom (TS = 25 °C; per Chip) IF 100 ... 1000 mA Forward current pulsed Durchlassstrom gepulst (D = 0.5; f = 120 Hz; TS = 25°C; per Chip) IF pulse 100 ... 2000 mA Reverse voltage Sperrspannung (TS = 25 °C) VR VESD ESD withstand voltage ESD Festigkeit (acc. to ANSI/ESDA/JEDEC JS-001 - HBM, Class 2) 2015-11-27 3 not designed for reverse operation V 2 kV Version 2.2 (not for new design) LE UW S2W Characteristics (TS = 25 °C; IF = 700 mA; per Chip) Kennwerte Parameter Symbol Values Unit Bezeichnung Symbol Werte Einheit Chromaticity coordinates acc. to CIE 1931 2) page 25 Farbkoordinaten nach CIE 1931 2) Seite 25 (typ.) (typ.) Cx Cy 0.31 0.32 - Viewing angle at 50 % IV Abstrahlwinkel bei 50 % IV (typ.) 2ϕ 120 ° Forward voltage 3) page 25 Durchlassspannung 3) Seite 25 (per Chip) (min.) (typ.) (max.) VF VF VF 2.90 3.45 4.00 V V V IR not designed for reverse operation Reverse current Sperrstrom Partial Flux acc. CIE 127:2007 Partieller Fluss (typ.) ΦE/V, 120° Radiating surface Abstrahlende Fläche (typ.) Acolor Real thermal resistance junction / solder point (typ.) (max.) 4) page 25 0.82 2.1 x 2.1 mm² Rth JS real Rth JS real 1.8 2.3 K/W K/W Rth JS el Rth JS el 1.4 1.8 K/W K/W Realer Wärmewiderstand Sperrschicht / Lötpad 4) Seite 25 "Electrical" thermal resistance junction / solder point (typ.) 4) page 25 (max.) "Elektrischer" Wärmewiderstand Sperrschicht / Lötpad 4) Seite 25 (with efficiency ηe = 21 %) 2015-11-27 4 Version 2.2 (not for new design) LE UW S2W Brightness Groups Helligkeitsgruppen Group Luminous Flux 1) page 25 Luminous Flux 1) page 25 Luminous Intensity 5) page 25 Lichtstrom 1) Seite 25 Lichtstrom 1) Seite 25 Lichtstärke 5) Seite 25 (min.) ΦV [lm] (max.) ΦV [lm] (typ.) IV [cd] PX 450 520 160 PY 520 610 185 PZ 610 710 220 QX 710 820 250 Gruppe 2015-11-27 5 Version 2.2 (not for new design) LE UW S2W Chromaticity Coordinate Groups 2) page 25 Farbortgruppen 2) Seite 25 520 Cy 0.8 530 540 510 550 0.7 560 0.6 570 500 0.5 580 590 600 610 620 630 0.4 + 0.3 490 0.2 0.1 0 E 480 470 460 450 0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 Cx 7R 7Q 7P 6Q 6R + 6P 5P 5Q 5R 4Q 4P 4R 0.25 0.26 0.27 0.28 0.29 0.30 0.31 0.32 0.33 0.34 0.35 0.36 0.37 0.9 0.42 Cy 0.41 0.40 0.39 0.38 0.37 0.36 0.35 0.34 0.33 0.32 0.31 0.30 0.29 0.28 0.27 0.26 0.25 0.24 0.23 0.22 0.21 0.20 Cx OHA03435 Color Chromaticity Groups 2) page 25 Farbortgruppen 2) Seite 25 Group Gruppe 4P 5P 6P 2015-11-27 Cx Cy 0.2787 0.2538 0.2828 Group Gruppe Cx Cy Cx Cy 0.2734 0.2607 0.2705 0.2647 0.2483 0.2787 0.2538 0.2734 0.2607 0.2930 0.2824 0.2889 0.2910 0.2865 0.2960 0.2962 0.2756 0.2930 0.2824 0.2889 0.2910 0.2930 0.2824 0.2889 0.2910 0.2865 0.2960 0.2962 0.2756 0.2930 0.2824 0.2889 0.2910 0.3072 0.3111 0.3049 0.3223 0.3035 0.3293 0.3090 0.3019 0.3072 0.3111 0.3049 0.3223 0.3072 0.3111 0.3049 0.3223 0.3035 0.3293 0.3090 0.3019 0.3072 0.3111 0.3049 0.3223 0.3170 0.3182 0.3170 0.3309 0.3170 0.3459 0.3170 0.3309 0.3170 0.3459 0.3170 0.3556 4Q 5Q 6Q 6 Group Gruppe 4R 5R 6R Version 2.2 (not for new design) Group Gruppe 7P 2015-11-27 Cx Cy 0.3170 0.3182 0.3170 Group Gruppe LE UW S2W Cx Cy 0.3170 0.3309 0.3309 0.3170 0.3341 0.3652 0.3375 0.3601 7Q Cx Cy 0.3170 0.3556 0.3459 0.3220 0.3653 0.3240 0.3595 0.3300 0.3728 0.3341 0.3652 0.3341 0.3652 7 Group Gruppe 7R Version 2.2 (not for new design) LE UW S2W Group Name on Label Gruppenbezeichnung auf Etikett Example: PX-4P Beispiel: PX-4P Brightness Helligkeit Chromaticity Coordinate Farbort PX 4P Note: No packing unit / tape ever contains more than one group for each selection. Anm.: In einer Verpackungseinheit / Gurt ist immer nur eine Gruppe für jede Selektion enthalten. 2015-11-27 8 Version 2.2 (not for new design) LE UW S2W Relative Spectral Emission - V(λ) = Standard eye response curve 5) page 25 Relative spektrale Emission - V(λ) = spektrale Augenempfindlichkeit 5) Seite 25 Φrel = f (λ); TJ = 25 °C; IF = 700 mA; per Chip LE UW S2W Φrel 1.0 : ultra white : Vλ 0.8 0.6 0.4 0.2 0.0 350 400 450 500 550 600 650 700 750 800 λ [nm] Radiation Characteristics 5) page 25 Abstrahlcharakteristik 5) Seite 25 Irel = f (ϕ); TJ = 25 °C 40˚ 30˚ 20˚ 10˚ ϕ 0˚ OHL03736 1.0 50˚ 0.8 60˚ 0.6 70˚ 0.4 80˚ 0.2 0 90˚ 100˚ 2015-11-27 1.0 0.8 0.6 0.4 0˚ 9 20˚ 40˚ 60˚ 80˚ 100˚ 120˚ Version 2.2 (not for new design) LE UW S2W Relative partial flux 5) page 25 Relativer zonaler Lichtstromanteil 5) Seite 25 ΦV(2ϕ)/ΦV(180°) = f (ϕ); T J = 25 °C ΦV(2ϕ) 1.0 ΦV(180°) 0.9 0.8 0.7 0.6 0.5 0.4 0.3 0.2 0.1 0.0 0 2015-11-27 10 20 30 40 50 60 70 80 10 90 100 110 120 130 140 150 160 170 180 2*ϕ [°] Version 2.2 (not for new design) LE UW S2W Relative Luminous Flux 5) page 25 , 6) page 25 Relativer Lichtstrom 5) Seite 25 , 6) Seite 25 ΦV/ΦV(700 mA) = f(IF); TJ = 25 °C; per Chip Forward Current 5) page 25 , 6) page 25 Durchlassstrom 5) Seite 25 , 6) Seite 25 IF = f (VF); TJ = 25 °C; per Chip IF [mA] ΦV LE UW S2W 1000 LE UW S2W 1,4 ΦV(700mA) 1,2 800 1,0 0,8 600 0,6 400 0,4 0,2 200 0,0 2,8 3,0 3,2 3,4 0 0 10 20 3,6 Chromaticity Coordinate Shift 5) page 25 Farbortverschiebung 5) Seite 25 Cx, Cy = f(IF); TJ = 25 °C LE UW S2W 0,03 : ∆Cx : ∆Cy 0,02 0,01 0,00 -0,01 -0,02 -0,03 0 20 0 40 0 60 0 80 00 10 IF [mA] 2015-11-27 0 60 0 80 00 10 IF [mA] VF [V] ∆Cx ∆Cy 0 40 11 Version 2.2 (not for new design) LE UW S2W Relative Forward Voltage 5) page 25 Relative Vorwärtsspannung 5) Seite 25 ΔVF = VF - VF(25 °C) = f(Tj); IF = 700 mA; per Chip ∆VF [V] Relative Luminous Flux 5) page 25 Relativer Lichtstrom 5) Seite 25 ΦV/ΦV(25 °C) = f(Tj); IF = 700 mA; per Chip Φv LE UW S2W 0,3 weiß 125-2 1,2 Φv(25°C) 0,2 1,0 0,1 0,8 0,0 0,6 -0,1 0,4 -0,2 0,2 -0,3 -40 -20 0 20 40 60 0,0 -40 -20 80 100 120 Chromaticity Coordinate Shift 5) page 25 Farbortverschiebung 5) Seite 25 Cx, Cy = f(Tj); IF = 700 mA; per Chip LE UW S2W 0,03 : ∆ Cx : ∆ Cy 0,02 0,01 0,00 -0,01 -0,02 -0,03 -40 -20 0 20 40 60 80 100 120 Tj [°C] 2015-11-27 20 40 60 80 100 120 Tj [°C] Tj [°C] ∆Cx ∆Cy 0 12 Version 2.2 (not for new design) LE UW S2W Max. Permissible Forward Current Max. zulässiger Durchlassstrom IF = f (T); for 4 chips operated LECWUW S2W IF [mA] 1100 1000 900 800 700 600 500 400 300 200 100 Donot usebelow100mA 0 0 20 40 60 80 100 TS [°C] 2015-11-27 13 Version 2.2 (not for new design) LE UW S2W Package Outline 7) page 25 Maßzeichnung 7) Seite 25 Approximate Weight: 66 mg Gewicht: 66 mg Corrosion robustness: Test conditions: 40 °C / 90 % rh / 15 ppm H2S / 336 h = Stricter than IEC 60068-2-43 (H2S) [25°C / 75 % rh / 10 ppm H2S / 21 days] = Regarding relevant gas (H2S) stricter than EN 60068-2-60 (method 4) [25 °C / 75 % rh / 200 ppb SO2, 200 ppb NO2,10 ppb Cl2 / 21 days] Korrosionsfestigkeit: Test Kondition: 40°C / 90 % rh / 15 ppm H2S / 336 h = Besser als IEC 60068-2-43 (H2S) [25°C / 75 % rh / 10 ppm H2S / 21 Tage] = Bezogen auf das Gas (H2S) besser als EN 60068-2-60 (method 4) [25°C / 75 % rh / 200ppb SO2, 200ppb NO2,10ppb Cl2 / 21 Tage] 2015-11-27 14 Version 2.2 (not for new design) LE UW S2W Electrical Internal Circuit Internes Elektrisches Schaltbild Recommended Solder Pad 7) page 25 Empfohlenes Lötpaddesign 7) Seite 25 2015-11-27 Reflow soldering Reflow-Löten 15 Version 2.2 (not for new design) LE UW S2W Note: For superior solder joint connectivity results we recommend soldering under standard nitrogen atmosphere. Package not suitable for any kind of wet cleaning or ultrasonic cleaning. Anm.: Um eine verbesserte Lötstellenkontaktierung zu erreichen, empfehlen wir, unter StandardStickstoffatmosphäre zu löten. Das Gehäuse ist für alle Arten einer nasschemischen Reinigung und Ultraschallreinigung nicht geeignet. 2015-11-27 16 Version 2.2 (not for new design) LE UW S2W Reflow Soldering Profile Reflow-Lötprofil Product complies to MSL Level 2 acc. to JEDEC J-STD-020D.01 OHA04525 300 ˚C T 250 Tp 245 ˚C 240 ˚C tP 217 ˚C 200 tL 150 tS 100 50 25 ˚C 0 0 50 100 150 200 s 300 250 t OHA04612 Symbol Symbol Profile Feature Profil-Charakteristik Pb-Free (SnAgCu) Assembly Minimum ) Ramp-up rate to preheat* 25 °C to 150 °C Time tS TSmin to TSmax tS 60 Ramp-up rate to peak*) TSmax to TP Recommendation Maximum 2 3 100 120 2 3 Unit Einheit K/s s K/s Liquidus temperature TL 217 Time above liquidus temperature tL 80 100 s Peak temperature TP 245 260 °C Time within 5 °C of the specified peak temperature TP - 5 K tP 20 30 s 3 6 K/s 10 Ramp-down rate* TP to 100 °C 480 Time 25 °C to TP All temperatures refer to the center of the package, measured on the top of the component * slope calculation DT/Dt: Dt max. 5 s; fulfillment for the whole T-range 2015-11-27 °C 17 s Version 2.2 (not for new design) LE UW S2W Taping 7) page 25 Gurtung 7) Seite 25 2015-11-27 18 Version 2.2 (not for new design) LE UW S2W Tape and Reel Gurtverpackung 12 mm tape with 500 pcs. on 180 mm reel W1 D0 P0 A N F W E 13.0 ±0.25 P2 Label P1 Direction of unreeling Direction of unreeling W2 Leader: min. 400 mm * Trailer: min. 160 mm * *) Dimensions acc. to IEC 60286-3; EIA 481-D OHAY0324 2015-11-27 19 Version 2.2 (not for new design) LE UW S2W Pin - Asignment Anschlussbelegung Pin / Anschluss Description / Function / Beschreibung / Funktion 1 Cathode; Chip 1 2 Anode; Chip 1 3 Cathode; Chip 2 4 Anode; Chip 2 5 Cathode; Chip 3 6 Anode; Chip 3 7 Cathode; Chip 4 8 Anode; Chip 4 Tape dimensions [mm] Gurtmaße [mm] Tape dim ensions in m m W P0 12 + 0.3 / - 0.1 4 ± 0.1 P1 P2 D0 E F 4 ± 0.1 or 8 ± 0.1 2 ± 0.05 1.5 ± 0.1 1.75 ± 0.1 5.5 ± 0.05 Reel dimensions [mm] Rollenmaße [mm] Reel dim ensions in m m A W Nmin W1 W2max 180 12 60 12.4 + 2 18.4 2015-11-27 20 Version 2.2 (not for new design) LE UW S2W Barcode-Tray-Label (BTL) Barcode-Tray-Etikett (BTL) Data Matrix Code BIN BIn Nr. EXA M Group: xxxx-xxxx-xxxx LE xxx xxx MATERIAL: P LE Batch Material Number DC: Date Code Batch Number Dry Packing Process and Materials Trockenverpackung und Materialien Moisture-sensitive label or print Barcode label L VE el LE . see lab e If ve ati nk, bla cod bar y H) (R . dit mi hu e ed ag RH % /60 ˚C rar ck rel 30 N s VE RS inf pa % ainITI TO of to ak 90 d ntNSUC < ns (pe TIO or d , cte itio U g coSEND an bje ing ˚C nd 5 ˚C su ss CO Ais baRE co ± ce y 40 be TU MI CThIS ˚C < tor ll pro SE _ < ). urs urs Ho de urs Ho co 72 Ho urs te 48 e Ho 24 6 da e tim e th tim or ). 23 tim e at t wi nt˚C or l wi fac Flo tim s at or ca at re. Flo d tha ale el or nth nti Flo uiv du if: rea es l 4 5 Flo lab mo ide ce eq low g, l ve vic is be or de 24 tin en l 5a6 pro ve Le de , e te co , g: ve l un wh Le ke r se da ure ba ed low ba Le ve mo % ba e al d ure Le ist en ref e e 10 tim ure se for ist ale op se for > , Mo se 3 ist ure is or . , is ha se Mo nk be ist nk g rd -03 Mo in n Flo r-p RH g, bla Mo ba TD po If blathi % kin Ca life s (if ar t. wi 10 ba tor J-S thi, va p. elf Ye ar ks _ < e icat me , C 1 Ye ee urs Sh terlow tem ted at ed uir > 1 W Ho un Af Indno uir DE 1. d e 4 8 ref dy reqy is 2. JE bo e Mo ore tim 16 req : C/ e es dit2b a) St tim or mi IP ed or g is tim e vic b) or e Hu Flo en tim or De 2a kin nc te Flo a) op or 3. b) baere Flo da e l 1 2 Flo If al ref tim ve l 4. se d l 2a3 ve Le g an ve l Le Ba te ure Le ve ure Le ist Da ure ist Mo ist ure Mo ist Mo Mo MO TO OP M RA OS Humidity indicator Barcode label Please check the HIC immidiately after bag opening. Discard if circles overrun. Avoid metal contact. Do not eat. Comparator check dot WET If wet, examine units, if necessary bake units 15% If wet, examine units, if necessary bake units 10% 5% If wet, parts still adequately dry. change desiccant Humidity Indicator MIL-I-8835 AM OSR Desiccant OHA00539 Barcode-Product-Label (BPL) Barcode-Produkt-Etikett (BPL) OSRAM Opto EX AM P RoHS Compliant (6P) BATCH NO: 1234567890 (1T) LOT NO: 1234567890 BIN1: XX-XX-X-XXX-X LX XXXX Semiconductors ML Temp ST X XXX °C X (9D) D/C: 1234 Pack: RXX LE DEMY XXX X_X123_1234.1234 X (X) PROD NO: 123456789(Q)QTY: 9999 (G) GROUP: XX-XX-X-X OHA04563 2015-11-27 21 OHA02684 Version 2.2 (not for new design) LE UW S2W Transportation Packing and Materials Kartonverpackung und Materialien Barcode label 8 Y M DE R 18 -1 Q P -1 + P: C: 99 D/ 21 00 (9 D) 21 : 20 00 : 14 2 5 (Q )Q TY O H 12 34 S S em R ic AM on du O p ct to or H NO s TC 3G BA (6 P) NO : 12 11 00 LO T (1 T) NO : OD PR ) (X 44 (G ) G RO UP : P -1 + Q -1 R 18 DE M Y Bi n2 : Pn3 : Q 1: -1 20 M -2 2 L 0 Te 2a 22 m 3 24 0 p ST Ad 26 0 C R C R0 ditio 0 C R PA 77 na RT l TE CK VA XT R: M u L lt S iT Y O T P 67 L 6 E Bi D Bi n1 D) (9 : 20 00 D/ C: 01 Muster TY )Q : 34 : NO O (X ) PR M RA OS D 5 14 2 110 0 (Q O S TC (1 T) LO T NO (6 P) : 12 BA S 8 3G em R ic AM o n O d u p ct to o H rs NO 2199 H 12 2100 01 44 el A C OU L GR E V LE see . lab e H) nk, cod (R bla r If ty ba . idi RH m hu 0% e /6 ive d ˚C re ag lat ra ck re 30 _ < inf pa % k s of to 90 ea ur s d ). < ns (p or ur s d Ho de , cteg itio ur s Ho an bje co ˚C 72 sin nd Ho ur 5 te 48 ˚C su es e Ho IC co ± is UR 24 6 da e M 40 be oc ry tim ˚C e Th STSE r th < ll pr tim cto ). r OI oo 23 wi nt tim e at l wi fa r M TO Fl oo tim s at at ale ˚C at e. ica Fl th oo r th ur el OP nt Fl oo on es uiv if: read ed l 4 5 Fl , lab m ide eq low l oc ve vic is ingen be or de 24 l 5a6 pr ve Le de nt wh e te co , w, g: ve l Le ke r re ou se da ba ed flo Le ve tu re m % ba e ba al d Le r en re tu re e re 10 ois tim se fo tu re ale op se fo > , M r se ois 3 is , is ha se M ois tu nk be oo . 03 nk rd g M ois in r-p bla in Fl RH g, DM ba po If blath % kin Ca life is (if . ar ST p. wi 10 baator et Jelf r th va Ye ar ks s m _ < m ed 1 Ye ee ur d, C iredic t Sh te w, te at nt > 1 W Ho Af flody qu In no ire DE 1. e 4 8 ou re ed re ty is qu JE 2. bo e M or tim 16 re C/ : e es idi 2b r a) St tim mor is IP ed r oo tim e vic b) g e r Hu Fl en oo tim De 2a kin nc te Fl oo r a) op 3. b) ba re Fl oo da e fe l 1 2 Fl If al re tim ve l 4. se d l 2a3 ve Le g an ve l Le re Ba te Le ve tu re Le tu Da ois re tu re M ois M ois tu M ois M Nns IVEORS ai IT CT nt TIO co NS DU g SE U ba E ON (G ) M u L lt S iT Y O T67 P L 6 Muster E Bi D Bi n1 Bi n2 : Pn3 : Q- 1: 1- 20 M 20 2 L Te 2a 22 m 3 24 0 p ST Ad 26 0 C R 0 C R0 dit ion C R PA 77 al RT CK TE VA XT R: Barcode label Packing Sealing label OHA02044 Note: Moisture-sensitive product is packed in a dry bag containing desiccant and a humidity card. Regarding dry pack you will find further information in the internet and in the Short Form Catalog in chapter “Tape and Reel” under the topic “Dry Pack”. Here you will also find the normative references like JEDEC. Anm.: Feuchteempfindliche Produkte sind verpackt in einem Trockenbeutel zusammen mit einem Trockenmittel und einer Feuchteindikatorkarte. Bezüglich Trockenverpackung finden Sie weitere Hinweise im Internet und in unserem Short Form Catalog im Kapitel “Gurtung und Verpackung” unter dem Punkt “Trockenverpackung”. Hier sind Normenbezüge, unter anderem ein Auszug der JEDEC-Norm, enthalten. Dimensions of transportation box in mm Width Length Height Breite Länge Höhe 195 ± 5 195 ± 5 30 ± 5 2015-11-27 22 Version 2.2 (not for new design) LE UW S2W Notes Hinweise The evaluation of eye safety occurs according to the standard IEC 62471:2008 ("photobiological safety of lamps and lamp systems"). Within the risk grouping system of this CIE standard, the LED specified in this data sheet fall into the class Moderate risk (exposure time 0.25 s). Under real circumstances (for exposure time, eye pupils, observation distance), it is assumed that no endangerment to the eye exists from these devices. As a matter of principle, however, it should be mentioned that intense light sources have a high secondary exposure potential due to their blinding effect. As is also true when viewing other bright light sources (e.g. headlights), temporary reduction in visual acuity and afterimages can occur, leading to irritation, annoyance, visual impairment, and even accidents, depending on the situation. Die Bewertung der Augensicherheit erfolgt nach dem Standard IEC 62471:2008 ("photobiological safety of lamps and lamp systems"). Im Risikogruppensystem dieser CIE- Norm erfüllen die in diesem Datenblatt angegebenen LEDs folgende Gruppenanforderung - Moderate risk (Expositionsdauer 0,25 s). Unter realen Umständen (für Expositionsdauer, Augenpupille, Betrachtungsabstand) geht damit von diesen Bauelementen keinerlei Augengefährdung aus. Grundsätzlich sollte jedoch erwähnt werden, dass intensive Lichtquellen durch ihre Blendwirkung ein hohes sekundäres Gefahrenpotenzial besitzen. Nach einem Blick in eine helle Lichtquelle (z.B. Autoscheinwerfer), kann ein temporär eingeschränktes Sehvermögen oder auch Nachbilder zu Irritationen, Belästigungen, Beeinträchtigungen oder sogar Unfällen führen. Subcomponents of this LED contain, among other substances, goldplated and Ag-filled materials. In spite of the improved corrosion stability of this LED, it can be affected by environments that contain very high concentrations of aggressive substances. Therefore, we recommend avoiding aggressive atmospheres during storage, production and use. Einzelkomponenten dieser LED enthalten u.a. goldbeschichtete und Ag-gefüllte Materialien. Trotz der verbesserten Korrosionsstabilität dieser LED können Einzelkomponenten durch sehr hohe Konzentration aggressiver Substanzen angegriffen werden. Aus diesem Grund wird empfohlen, aggressive Umgebungen während der Lagerung, Produktion und im Betrieb zu vermeiden. 2015-11-27 23 Version 2.2 (not for new design) LE UW S2W Disclaimer Disclaimer Language english will prevail in case of any discrepancies or deviations between the two language wordings. Bei abweichenden Angaben im zweisprachigen Wortlaut haben die Angaben in englischer Sprache Vorrang. Attention please! The information describes the type of component and shall not be considered as assured characteristics. Terms of delivery and rights to change design reserved. Due to technical requirements components may contain dangerous substances. For information on the types in question please contact our Sales Organization. If printed or downloaded, please find the latest version in the Internet. Packing Please use the recycling operators known to you. We can also help you – get in touch with your nearest sales office. By agreement we will take packing material back, if it is sorted. You must bear the costs of transport. For packing material that is returned to us unsorted or which we are not obliged to accept, we shall have to invoice you for any costs incurred. Components used in life-support devices or systems must be expressly authorized for such purpose! Critical components* may only be used in life-support devices** or systems with the express written approval of OSRAM OS. Bitte beachten! Lieferbedingungen und Änderungen im Design vorbehalten. Aufgrund technischer Anforderungen können die Bauteile Gefahrstoffe enthalten. Für weitere Informationen zu gewünschten Bauteilen, wenden Sie sich bitte an unseren Vertrieb. Falls Sie dieses Datenblatt ausgedruckt oder heruntergeladen haben, finden Sie die aktuellste Version im Internet. Verpackung Benutzen Sie bitte die Ihnen bekannten Recyclingwege. Wenn diese nicht bekannt sein sollten, wenden Sie sich bitte an das nächstgelegene Vertriebsbüro. Wir nehmen das Verpackungsmaterial zurück, falls dies vereinbart wurde und das Material sortiert ist. Sie tragen die Transportkosten. Für Verpackungsmaterial, das unsortiert an uns zurückgeschickt wird oder das wir nicht annehmen müssen, stellen wir Ihnen die anfallenden Kosten in Rechnung. Bauteile, die in lebenserhaltenden Apparaten und Systemen eingesetzt werden, müssen für diese Zwecke ausdrücklich zugelassen sein! Kritische Bauteile* dürfen in lebenserhaltenden Apparaten und Systemen** nur dann eingesetzt werden, wenn ein schriftliches Einverständnis von OSRAM OS vorliegt. *) A critical component is a component used in a life-support device or system whose failure can reasonably be expected to cause the failure of that life-support device or system, or to affect its safety or the effectiveness of that device or system. **) Life support devices or systems are intended (a) to be implanted in the human body, or (b) to support and/or maintain and sustain human life. If they fail, it is reasonable to assume that the health and the life of the user may be endangered. 2015-11-27 *) Ein kritisches Bauteil ist ein Bauteil, das in lebenserhaltenden Apparaten oder Systemen eingesetzt wird und dessen Defekt voraussichtlich zu einer Fehlfunktion dieses lebenserhaltenden Apparates oder Systems führen wird oder die Sicherheit oder Effektivität dieses Apparates oder Systems beeinträchtigt. **) Lebenserhaltende Apparate oder Systeme sind für (a) die Implantierung in den menschlichen Körper oder (b) für die Lebenserhaltung bestimmt. Falls Sie versagen, kann davon ausgegangen werden, dass die Gesundheit und das Leben des Patienten in Gefahr ist. 24 Version 2.2 (not for new design) LE UW S2W Glossary Glossar 1) Brightness: Brightness values are measured during a current pulse of typically 25 ms, with an internal reproducibility of ± 8 % and an expanded uncertainty of ± 11 % (acc. to GUM with a coverage factor of k = 3). 1) Helligkeit: Helligkeitswerte werden während eines Strompulses einer typischen Dauer von 25 ms, mit einer internen Reproduzierbarkeit von ± 8 % und einer erweiterten Messunsicherheit von ± 11 % gemessen (gemäß GUM mit Erweiterungsfaktor k = 3). 2) Chromaticity coordinate groups: Chromaticity coordinates are measured during a current pulse of typically 25 ms, with an internal reproducibility of ± 0.005 and an expanded uncertainty of ± 0.01 (acc. to GUM with a coverage factor of k = 3). 2) Farbortgruppen: Farbkoordinaten werden während eines Strompulses einer typischen Dauer von 25 ms, mit einer internen Reproduzierbarkeit von ± 0,005 und einer erweiterten Messunsicherheit von ± 0,01 gemessen (gemäß GUM mit Erweiterungsfaktor k = 3). 3) Forward Voltage: The forward voltage is measured during a current pulse of typically 8 ms, with an internal reproducibility of ± 0.05 V and an expanded uncertainty of ± 0.1 V (acc. to GUM with a coverage factor of k = 3). 3) Durchlassspannung: Vorwärtsspannungen werden während eines Strompulses einer typischen Dauer von 8 ms, mit einer internen Reproduzierbarkeit von ± 0,05 V und einer erweiterten Messunsicherheit von ± 0,1 V gemessen (gemäß GUM mit Erweiterungsfaktor k = 3). 4) Thermal Resistance: Rth max is based on statistic values (6σ). 4) Wärmewiderstand: Rth statistischen Werten (6σ). 5) Typical Values: Due to the special conditions of the manufacturing processes of LED, the typical data or calculated correlations of technical parameters can only reflect statistical figures. These do not necessarily correspond to the actual parameters of each single product, which could differ from the typical data and calculated correlations or the typical characteristic line. If requested, e.g. because of technical improvements, these typ. data will be changed without any further notice. 5) Typische Werte: Wegen der besonderen Prozessbedingungen bei der Herstellung von LED können typische oder abgeleitete technische Parameter nur aufgrund statistischer Werte wiedergegeben werden. Diese stimmen nicht notwendigerweise mit den Werten jedes einzelnen Produktes überein, dessen Werte sich von typischen und abgeleiteten Werten oder typischen Kennlinien unterscheiden können. Falls erforderlich, z.B. aufgrund technischer Verbesserungen, werden diese typischen Werte ohne weitere Ankündigung geändert. 6) Characteristic curve: In the range where the line of the graph is broken, you must expect higher differences between single LEDs within one packing unit. 6) Kennlinien: Im gestrichelten Bereich der Kennlinien muss mit erhöhten Abweichungen zwischen Leuchtdioden innerhalb einer Verpackungseinheit gerechnet werden. 7) Tolerance of Measure: Unless otherwise noted in drawing, tolerances are specified with ±0.1 and dimensions are specified in mm. 7) Maßtoleranz: Wenn in der Zeichnung nicht anders angegeben, gilt eine Toleranz von ±0,1. Maße werden in mm angegeben. 2015-11-27 25 max basiert auf Version 2.2 (not for new design) LE UW S2W Published by OSRAM Opto Semiconductors GmbH Leibnizstraße 4, D-93055 Regensburg www.osram-os.com © All Rights Reserved. 2015-11-27 26
LEUWS2W-PXQX-6P6R 价格&库存
很抱歉,暂时无法提供与“LEUWS2W-PXQX-6P6R”相匹配的价格&库存,您可以联系我们找货
