3/4W-140
3/4W-140
    CINCH
    TERMINAL 3/4 W SOLDER 140 SERIES
3/4W-140 数据手册
COMMERCIAL Barrier Blocks Circular Mini DIN BNC Jones Plugs Edge Connectors Commercial [.050” (1.27mm) Density Solder Introduction Cup/Wire D-Microminiature] Cinch Commercial Products, consisting of Jones Plugs and Sockets, Barrier Blocks, Edge Cards, Two-Piece Commercial Dins, Mini Din Plugs, and their newest addition the 75Ω Press-Fit BNC Receptacle, provide a wide variety of connectors for the purchaser and designer to chose from. The Jones Plugs and Sockets have been utilized for decades and provide a quick, reliable, and economical means of solving your higher current-carrying capacity needs. Available in two series (300 and 2,400), these connectors can be found in data processing controls; amusement and vending machines; medical, communication, and test equipment; as well as industrial controls and heavy-duty, battery-powered equipment. Both series are available in a variety of cable and panel mounting options. Cinch Barrier Blocks are designed to simplify wiring work by reducing splicing, preventing current leaks and short circuits, and increasing insulation. Available in a variety of densities, these barrier blocks can be found in applications ranging from industrial controls to switching systems. Designed specially for applications where space is at a premium, the Cinch Mini Din family is ideal for personal computers, keyboard-mouse interface, hand-held electronic equipment, office-automation equipment, and audio and video equipment. Available in sizes 3 through 8 contact, the Cinch Mini Din family includes a fully shielded cable mounted plug in various cable lengths or cable mounted plug components for customers with high-volume assembly and overmold capabilities. Cinch Edge Card Connectors are available in a variety of styles on both .100 or .156 center spacing. The newest addition to the commercial family, the 75Ω Press-Fit BNC Receptacle is designed around a unique patented press-fit design that allows for multiple insertion into a backplane without loss of mechanical retention or electrical performance. When looking for time reliability to solve your commercial interconnect needs, look no further than Cinch Connectors. Whether it's a Jones Plug and Socket, Barrier Block, Edge Card, Mini Din plug, or our newest addition, the 75Ω BNC Press-Fit connector, you will always know years of customer satisfaction stand behind the product you chose. 2-1 Call Toll Free: 1 (800) 323-9612 2 Barrier Blocks ■ A wide variety of barrier blocks makes it possible to select the combination of mechanical and electrical characteristics that best meet the exact requirements of your application. MATERIALS ■ A wide selection of optional terminals and fanning strips permits the equipment designer to choose the method of termination most suitable for his environmental specifications and manufacturing requirements. Insulation Material: Molded monoblock, general purpose phenolic, black, UL Rated 94V-1 Eyelets: Material - Brass Plating - Nickel Screws: Material - Steel Plating - Nickel over copper flash Solder Terminals: Material - Brass Plating - Electro-Tin Marker Strip Material: Nema Grade XPC, UL Rated 94V-O ENVIRONMENTAL FEATURES ■ Interposing barriers between terminals yield higher electrical ratings and provide additional protection against frayed wire shorting. Operating Temperature: -55° to +300°F Certifications: UL Recognized - File E61245 CSA - LR 31996 Marketed exclusively through distribution. Call Toll Free: 1 (800) 323-9612 2-2 Barrier Blocks TERMINAL BLOCK QUICK REFERENCE Center-to- Number Single or Center of Double Screw Series Spacing Terminals Row Size Operating Voltage Current Rating Max. Wire Size Max. Watts/ Terminal Voltage Voltage Rating Rating w/Marker w/o Marker Marker Strip Mounting 140 .375 1-25 Double 5-40 250 Volts 15 Amps #16 3750 2000 1100 Bottom 141 .438 1-20 Double 6-32 250 Volts 20 Amps #14 5000 2400 1100 Bottom 142 .563 1-17 Double 8-32 250 Volts 30 Amps #10 7500 2600 1600 Bottom 150 .688 1-10 Double 10-32 250 Volts 40 Amps #10 10,000 2400 1500 Bottom 151 .875 1-8 Double 12-32 250 Volts 50 Amps #8 12,500 3400 1800 Bottom 152 1.125 1-6 Double 1/4-28 250 Volts 70 Amps #6 54,000 3800 2100 Bottom 164 .375 1-21 Double 6-32 250 Volts 15 Amps #14 3750 2000 1100 Bottom 540 .375 2-31 Double 5-40 600 Volts 15 Amps #16 3750 2300 2300 Top 541 .438 2-30 Double 6-32 600 Volts 20 Amps #14 5000 2800 2800 Top 542 .563 2-26 Double 8-32 600 Volts 30 Amps #10 7500 4000 4000 Top 176 .375 2-10 Single 5-40 250 Volts 15 Amps #16 3750 N/A 1100 N/A Marketed exclusively through distribution. 2-3 Call Toll Free: 1 (800) 323-9612 .375 Density, 5-40 x 3/16" BH Screw, Open Bottom, Double Row Barrier Blocks Series 140 Electrical Characteristics Voltage Rating: 250 VAC RMS maximum Current Rating: 15 Amps maximum Maximum Watts Per Terminal: 3750 Mechanical Characteristics Maximum Wire Size: #16 AWG Recommended Tightening Torque: 9 lb.-in. Dimensions Ordering Information No. of Standard Screw Terminals Catalog No. 1 1-140 2 2-140 3 3-140 4 4-140 5 5-140 6 6-140 7 7-140 8 8-140 9 9-140 10 10-140 11 11-140 12 12-140 13 13-140 14 14-140 15 15-140 16 16-140 17 17-140 18 18-140 19 19-140 20 20-140 21 21-140 22 22-140 23 23-140 24 24-140 25 25-140 Call Toll Free: 1 (800) 323-9612 2-4 “M” Dim. .750 1.125 1.500 1.875 2.250 2.625 3.000 3.375 3.750 4.125 4.500 4.875 5.250 5.625 6.000 6.375 6.750 7.125 7.500 7.875 8.250 8.625 9.000 9.375 9.750 “L” Dim. 1.032 1.407 1.782 2.157 2.532 2.907 3.282 3.657 4.032 4.407 4.782 5.157 5.532 5.907 6.282 6.657 7.032 7.407 7.782 8.157 8.532 8.907 9.282 9.657 10.032 Marketed exclusively through distribution. Barrier Blocks Series 140 .375 Density, 5-40 x 3/16" BH Screw, Open Bottom, Double Row Solder Terminal Options Dimensions “Y” Terminals “3/4W” Terminals “W” Terminals Ordering Information No. of Terminals 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 Catalog No. 1-140-Y 2-140-Y 3-140-Y 4-140-Y 5-140-Y 6-140-Y 7-140-Y 8-140-Y 9-140-Y 10-140-Y 11-140-Y 12-140-Y 13-140-Y 14-140-Y 15-140-Y 16-140-Y 17-140-Y 18-140-Y 19-140-Y 20-140-Y 21-140-Y 22-140-Y 23-140-Y 24-140-Y 25-140-Y Catalog No. 1-140-3/4W 2-140-3/4W 3-140-3/4W 4-140-3/4W 5-140-3/4W 6-140-3/4W 7-140-3/4W 8-140-3/4W 9-140-3/4W 10-140-3/4W 11-140-3/4W 12-140-3/4W 13-140-3/4W 14-140-3/4W 15-140-3/4W 16-140-3/4W 17-140-3/4W 18-140-3/4W 19-140-3/4W 20-140-3/4W 21-140-3/4W 22-140-3/4W 23-140-3/4W 24-140-3/4W 25-140-3/4W Catalog No. 1-140-W 2-140-W 3-140-W 4-140-W 5-140-W 6-140-W 7-140-W 8-140-W 9-140-W 10-140-W 11-140-W 12-140-W 13-140-W 14-140-W 15-140-W 16-140-W 17-140-W 18-140-W 19-140-W 20-140-W 21-140-W 22-140-W 23-140-W 24-140-W 25-140-W Solder Terminals can be ordered separately. Terminal Type “Y” “3/4W” “W” Catalog No. Y-140 3/4W-140 W-140 Marketed exclusively through distribution. 2-5 Call Toll Free: 1 (800) 323-9612 .375 Density, 5-40 x 3/16" BH Screw, Open Bottom, Double Row Barrier Blocks Series 140 Marker Strips Dimensions Standard “Y” Terminal 2 Ordering Information No. of Terminals 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 Catalog No. MS-1-140 MS-2-140 MS-3-140 MS-4-140 MS-5-140 MS-6-140 MS-7-140 MS-8-140 MS-9-140 MS-10-140 MS-11-140 MS-12-140 MS-13-140 MS-14-140 MS-15-140 MS-16-140 MS-17-140 MS-18-140 MS-19-140 MS-20-140 MS-21-140 MS-22-140 MS-23-140 MS-24-140 MS-25-140 Catalog No. MS-1-140-Y MS-2-140-Y MS-3-140-Y MS-4-140-Y MS-5-140-Y MS-6-140-Y MS-7-140-Y MS-8-140-Y MS-9-140-Y MS-10-140-Y MS-11-140-Y MS-12-140-Y MS-13-140-Y MS-14-140-Y MS-15-140-Y MS-16-140-Y MS-17-140-Y MS-18-140-Y MS-19-140-Y MS-20-140-Y MS-21-140-Y MS-22-140-Y MS-23-140-Y MS-24-140-Y MS-25-140-Y Use Standard Marker Strips for “3/4W” and “W” Solder Terminals. Accessories • Jumpers • Fanning Strips Marketed exclusively through distribution. Call Toll Free: 1 (800) 323-9612 2-6 .438 Density, 6-32 x 1/4" BH Screw, Open Bottom, Double Row Barrier Blocks Series 141 Electrical Characteristics Voltage Rating: 250 VAC RMS maximum Current Rating: 20 Amps maximum Maximum Watts Per Terminal: 5000 Mechanical Characteristics Maximum Wire Size: #14 AWG Recommended Tightening Torque: 12 lb.-in. Dimensions Ordering Information No. of Terminals 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 Standard Screw Catalog No. 1-141 2-141 3-141 4-141 5-141 6-141 7-141 8-141 9-141 10-141 11-141 12-141 13-141 14-141 15-141 16-141 17-141 18-141 19-141 20-141 “M” Dim. .875 1.312 1.750 2.187 2.625 3.062 3.500 3.938 4.375 4.813 5.250 5.687 6.125 6.562 7.000 7.437 7.875 8.312 8.750 9.187 “L” Dim. 1.187 1.625 2.062 2.500 2.938 3.375 3.812 4.250 4.687 5.125 5.562 6.000 6.437 6.875 7.312 7.750 8.187 8.625 9.062 9.500 Marketed exclusively through distribution. Call Toll Free: 1 (800) 323-9612 2-8 .438 Density, 6-32 x 1/4" BH Screw, Open Bottom, Double Row Barrier Blocks Series 141 Solder Terminal Options Dimensions “Y” Terminals “3/4W” Terminals “W” Terminals Ordering Information No. of Terminals 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 Catalog No. 1-141-Y 2-141-Y 3-141-Y 4-141-Y 5-141-Y 6-141-Y 7-141-Y 8-141-Y 9-141-Y 10-141-Y 11-141-Y 12-141-Y 13-141-Y 14-141-Y 15-141-Y 16-141-Y 17-141-Y 18-141-Y 19-141-Y 20-141-Y Catalog No. 1-141-3/4W 2-141-3/4W 3-141-3/4W 4-141-3/4W 5-141-3/4W 6-141-3/4W 7-141-3/4W 8-141-3/4W 9-141-3/4W 10-141-3/4W 11-141-3/4W 12-141-3/4W 13-141-3/4W 14-141-3/4W 15-141-3/4W 16-141-3/4W 17-141-3/4W 18-141-3/4W 19-141-3/4W 20-141-3/4W Catalog No. 1-141-W 2-141-W 3-141-W 4-141-W 5-141-W 6-141-W 7-141-W 8-141-W 9-141-W 10-141-W 11-141-W 12-141-W 13-141-W 14-141-W 15-141-W 16-141-W 17-141-W 18-141-W 19-141-W 20-141-W Solder Terminals can be ordered separately. Terminal Type “Y” “3/4W” “W” Catalog No. Y-141 3/4W-141 W-141 Marketed exclusively through distribution. 2-9 Call Toll Free: 1 (800) 323-9612 DURA-CON® Barrier Blocks High Reliability Series 141 All-Plastic .438 Density, 6-32 x 1/4" BH Screw, Open Bottom, Double Row Marker Strips Dimensions Standard “Y” Terminal 2 Ordering Information No. of Terminals 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 Catalog No. MS-1-141 MS-2-141 MS-3-141 MS-4-141 MS-5-141 MS-6-141 MS-7-141 MS-8-141 MS-9-141 MS-10-141 MS-11-141 MS-12-141 MS-13-141 MS-14-141 MS-15-141 MS-16-141 MS-17-141 MS-18-141 MS-19-141 MS-20-141 Catalog No. MS-1-141-Y MS-2-141-Y MS-3-141-Y MS-4-141-Y MS-5-141-Y MS-6-141-Y MS-7-141-Y MS-8-141-Y MS-9-141-Y MS-10-141-Y MS-11-141-Y MS-12-141-Y MS-13-141-Y MS-14-141-Y MS-15-141-Y MS-16-141-Y MS-17-141-Y MS-18-141-Y MS-19-141-Y MS-20-141-Y Use Standard Marker Strip for “3/4W” and “W” Solder Terminals. Accessories • Jumpers • Fanning Strips Marketed exclusively through distribution. Call Toll Free: 1 (800) 323-9612 2-10 Barrier Blocks Series 142 .563 Density, 8-32 x 5/16" BH Screw, Open Bottom, Double Row Electrical Characteristics Voltage Rating: 250 VAC RMS maximum Current Rating: 30 Amps maximum Maximum Watts Per Terminal: 7500 Mechanical Characteristics Maximum Wire Size: #10 AWG Recommended Tightening Torque: 16 lb.-in. Dimensions Ordering Information No. of Terminals 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 Standard Screw Catalog No. 1-142 2-142 3-142 4-142 5-142 6-142 7-142 8-142 9-142 10-142 11-142 12-142 13-142 14-142 15-142 16-142 17-142 “M” Dim. 1.125 1.687 2.250 2.812 3.375 3.937 4.500 5.062 5.625 6.187 6.750 7.312 7.875 8.437 9.000 9.562 10.125 “L” Dim. 1.531 2.094 2.656 3.219 3.781 4.344 4.906 5.468 6.031 6.594 7.156 7.719 8.281 8.844 9.406 9.969 10.531 Marketed exclusively through distribution. Call Toll Free: 1 (800) 323-9612 2-12 Barrier Blocks Series 142 .563 Density, 8-32 x 5/16" BH Screw, Open Bottom, Double Row Solder Terminal Options Dimensions “Y” Terminals “3/4W” Terminals “W” Terminals Ordering Information No. of Terminals 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 Catalog No. 1-142-Y 2-142-Y 3-142-Y 4-142-Y 5-142-Y 6-142-Y 7-142-Y 8-142-Y 9-142-Y 10-142-Y 11-142-Y 12-142-Y 13-142-Y 14-142-Y 15-142-Y 16-142-Y 17-142-Y Catalog No. 1-142-3/4W 2-142-3/4W 3-142-3/4W 4-142-3/4W 5-142-3/4W 6-142-3/4W 7-142-3/4W 8-142-3/4W 9-142-3/4W 10-142-3/4W 11-142-3/4W 12-142-3/4W 13-142-3/4W 14-142-3/4W 15-142-3/4W 16-142-3/4W 17-142-3/4W Catalog No. 1-142-W 2-142-W 3-142-W 4-142-W 5-142-W 6-142-W 7-142-W 8-142-W 9-142-W 10-142-W 11-142-W 12-142-W 13-142-W 14-142-W 15-142-W 16-142-W 17-142-W Solder Terminals can be ordered separately. Terminal Type “Y” “3/4W” “W” Catalog No. Y-142 3/4W-142 W-142 Marketed exclusively through distribution. 2-13 Call Toll Free: 1 (800) 323-9612 DURA-CON® Barrier Blocks High Reliability Series 142 All-Plastic .563 Density, 8-32 x 5/16" BH Screw, Open Bottom, Double Row Marker Strips Dimensions Standard “Y” Terminal 2 Ordering Information No. of Terminals 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 Catalog No. MS-1-142 MS-2-142 MS-3-142 MS-4-142 MS-5-142 MS-6-142 MS-7-142 MS-8-142 MS-9-142 MS-10-142 MS-11-142 MS-12-142 MS-13-142 MS-14-142 MS-15-142 MS-16-142 MS-17-142 Catalog No. MS-1-142-Y MS-2-142-Y MS-3-142-Y MS-4-142-Y MS-5-142-Y MS-6-142-Y MS-7-142-Y MS-8-142-Y MS-9-142-Y MS-10-142-Y MS-11-142-Y MS-12-142-Y MS-13-142-Y MS-14-142-Y MS-15-142-Y MS-16-142-Y MS-17-142-Y Use Standard Marker Strips for “3/4W” and “W” Solder Terminals. Accessories • • Jumpers Fanning Strips Marketed exclusively through distribution. Call Toll Free: 1 (800) 323-9612 2-14 .688 Density, 10-32 x 5/16" BH Screw, Open Bottom, Double Row Barrier Blocks Series 150 Electrical Characteristics Voltage Rating: 250 VAC RMS maximum Current Rating: 40 Amps maximum Maximum Watts Per Terminal: 10,000 Mechanical Characteristics Maximum Wire Size: #10 AWG Recommended Tightening Torque: 20 lb.-in. Dimensions Ordering Information No. of Terminals 1 2 3 4 5 6 7 8 9 10 Standard Screw Catalog No. 1-150 2-150 3-150 4-150 5-150 6-150 7-150 8-150 9-150 10-150 Y-Terminals Catalog No. 1-150-Y 2-150-Y 3-150-Y 4-150-Y 5-150-Y 6-150-Y 7-150-Y 8-150-Y 9-150-Y 10-150-Y “M” Dim. 1.375 2.062 2.750 3.437 4.125 4.812 5.500 6.187 6.875 7.562 “L” Dim. 1.812 2.500 3.187 3.875 4.562 5.250 5.938 6.625 7.312 8.000 Marketed exclusively through distribution. Call Toll Free: 1 (800) 323-9612 2-16 Barrier Blocks Series 150 .688 Density, 10-32 x 5/16" BH Screw, Open Bottom, Double Row Marker Strips Dimensions Standard “Y” Terminal .688 TYP (17.46) Ordering Information No. of Terminals 1 2 3 4 5 6 7 8 9 10 Catalog No. MS-1-150 MS-2-150 MS-3-150 MS-4-150 MS-5-150 MS-6-150 MS-7-150 MS-8-150 MS-9-150 MS-10-150 Catalog No. MS-1-150-Y MS-2-150-Y MS-3-150-Y MS-4-150-Y MS-5-150-Y MS-6-150-Y MS-7-150-Y MS-8-150-Y MS-9-150-Y MS-10-150-Y Accessories None Available for 150 Series. Marketed exclusively through distribution. 2-17 Call Toll Free: 1 (800) 323-9612 .875 Density, 12-32 x 3/8" BH Screw, Open Bottom, Double Row Barrier Blocks Series 151 Electrical Characteristics Voltage Rating: 250 Volts maximum Current Rating: 50 Amps maximum Maximum Watts Per Terminal: 12,500 Mechanical Characteristics Maximum Wire Size: #8 Recommended Tightening Torque: 40 lb.-in. Dimensions Ordering Information No. of Terminals 1 2 3 4 5 6 7 8 Catalog No. 1-151 2-151 3-151 4-151 5-151 6-151 7-151 8-151 “M” Dim. (in) 1.750 2.625 3.500 4.375 5.250 6.125 7.000 7.875 “L” Dim. (in) 2.282 3.157 4.032 4.907 5.782 6.657 7.532 8.407 Marker Strip Catalog No. N/A MS-2-151 MS-3-151 MS-4-151 MS-5-151 MS-6-151 MS-7-151 MS-8-151 Solder Terminals can be ordered separately. Terminal Type “W” Catalog No. W-151 Marketed exclusively through distribution. Call Toll Free: 1 (800) 323-9612 2-18 1.25 Density, 1/4-28 x 1/2" BH Screw, Open Bottom, Double Row Barrier Blocks Series 152 Electrical Characteristics Voltage Rating: 250 Volts maximum Current Rating: 70 Amps maximum Maximum Watts Per Terminal: 54,000 Mechanical Characteristics Maximum Wire Size: #6 Recommended Tightening Torque: 75 lb.-in. Dimensions Ordering Information No. of Terminals 1 2 3 4 5 6 Catalog No. 1-152 2-152 3-152 4-152 5-152 6-152 “M” Dim. (in) 2.250 3.375 4.500 5.625 6.750 7.875 “L” Dim. (in) 2.876 4.001 5.126 6.251 7.376 8.501 Marker Strip Catalog No. N/A MS-2-152 MS-3-152 MS-4-152 MS-5-152 MS-6-152 Accessories None Available for 152 Series. Marketed exclusively through distribution. 2-19 Call Toll Free: 1 (800) 323-9612 Barrier Blocks Series 164 .375 Density, 6-32 x 5/16" BH Screw, Open Bottom, Double Row Electrical Characteristics Voltage Rating: 250 Volts maximum Current Rating: 15 Amps maximum Maximum Watts Per Terminal: 3750 Mechanical Characteristics Maximum Wire Size: #14 Recommended Tightening Torque: 12 lb.-in. Dimensions Ordering Information No. of Terminals 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 “M” Dim. (in) 0.750 1.125 1.500 1.875 2.250 2.625 3.000 3.375 3.750 4.125 4.500 4.875 5.250 5.625 6.000 6.375 6.750 7.125 7.500 7.875 8.250 Catalog No. 1-164 2-164 3-164 4-164 5-164 6-164 7-164 8-164 9-164 10-164 11-164 12-164 13-164 14-164 15-164 16-164 17-164 18-164 19-164 20-164 21-164 “L” Dim. (in) 1.032 1.407 1.782 2.157 2.532 2.907 3.282 3.657 4.032 4.407 4.782 5.157 5.532 5.907 6.282 6.657 7.032 7.407 7.782 8.157 8.532 Marketed exclusively through distribution. Call Toll Free: 1 (800) 323-9612 2-20 Barrier Blocks Series 164 .375 Density, 6-32 x 1/4" BH Screw, Open Bottom, Double Row Solder Terminal Options Dimensions “Y” Terminals “3/4W” Terminals “W” Terminals Ordering Information No. of Terminals 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 Catalog No. 1-164-Y 2-164-Y 3-164-Y 4-164-Y 5-164-Y 6-164-Y 7-164-Y 8-164-Y 9-164-Y 10-164-Y 11-164-Y 12-164-Y 13-164-Y 14-164-Y 15-164-Y 16-164-Y 17-164-Y 18-164-Y 19-164-Y 20-164-Y 21-164-Y Catalog No. 1-164-3/4W 2-164-3/4W 3-164-3/4W 4-164-3/4W 5-164-3/4W 6-164-3/4W 7-164-3/4W 8-164-3/4W 9-164-3/4W 10-164-3/4W 11-164-3/4W 12-164-3/4W 13-164-3/4W 14-164-3/4W 15-164-3/4W 16-164-3/4W 17-164-3/4W 18-164-3/4W 19-164-3/4W 20-164-3/4W 21-164-3/4W Catalog No. 1-164-W 2-164-W 3-164-W 4-164-W 5-164-W 6-164-W 7-164-W 8-164-W 9-164-W 10-164-W 11-164-W 12-164-W 13-164-W 14-164-W 15-164-W 16-164-W 17-164-W 18-164-W 19-164-W 20-164-W 21-164-W Marketed exclusively through distribution. 2-21 Call Toll Free: 1 (800) 323-9612 DURA-CON® Barrier Blocks High Reliability Series 164 All-Plastic [.050” .375 (1.27mm) Density, 6-32 Density x 1/4" Solder BH Screw, Cup/Wire Open Bottom, D-Microminiature] Double Row Marker Strips Dimensions Standard “Y” Terminal 2 Ordering Information No. of Terminals 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 Catalog No. N/A MS-2-140 MS-3-140 MS-4-140 MS-5-140 MS-6-140 MS-7-140 MS-8-140 MS-9-140 MS-10-140 MS-11-140 MS-12-140 MS-13-140 MS-14-140 MS-15-140 MS-16-140 MS-17-140 MS-18-140 MS-19-140 MS-20-140 MS-21-140 Catalog No. N/A MS-2-140-Y MS-3-140-Y MS-4-140-Y MS-5-140-Y MS-6-140-Y MS-7-140-Y MS-8-140-Y MS-9-140-Y MS-10-140-Y MS-11-140-Y MS-12-140-Y MS-13-140-Y MS-14-140-Y MS-15-140-Y MS-16-140-Y MS-17-140-Y MS-18-140-Y MS-19-140-Y MS-20-140-Y MS-21-140-Y Use Standard Marker Strips for “3/4W” and “W” Solder Terminals. Marketed exclusively through distribution. Call Toll Free: 1 (800) 323-9612 2-22 .375 Density, 5-40 x 1/4" BH Screw, Closed Bottom, Double Row Barrier Blocks Series 540 Electrical Characteristics Voltage Rating: 600 Volts maximum Current Rating: 15 Amps Maximum Watts Per Terminal: 3750 Mechanical Characteristics Maximum Wire Size: #16 Recommended Tightening Torque: 9 lb.-in. Dimensions Ordering Information No. of Terminals 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 Catalog No. 2-540 3-540 4-540 5-540 6-540 7-540 8-540 9-540 10-540 11-540 12-540 13-540 14-540 15-540 16-540 17-540 18-540 19-540 20-540 21-540 22-540 23-540 24-540 25-540 26-540 27-540 28-540 29-540 30-540 31-540 “M” Dim. (in) 1.125 1.500 1.875 2.250 2.625 3.000 3.375 3.750 4.125 4.500 4.875 5.250 5.625 6.000 6.375 6.750 7.125 7.500 7.875 8.250 8.625 9.000 9.375 9.750 10.125 10.500 10.875 11.250 11.625 12.000 “L” Dim. (in) 1.407 1.782 2.157 2.532 2.907 3.282 3.657 4.032 4.407 4.782 5.157 5.532 5.907 6.282 6.657 7.032 7.407 7.782 8.157 8.532 8.907 9.282 9.657 10.032 10.407 10.782 11.157 11.532 11.907 12.282 Marker Strip Catalog No. MSX-2-540 MSX-3-540 MSX-4-540 MSX-5-540 MSX-6-540 MSX-7-540 MSX-8-540 MSX-9-540 MSX-10-540 MSX-11-540 MSX-12-540 MSX-13-540 MSX-14-540 MSX-15-540 MSX-16-540 MSX-17-540 MSX-18-540 MSX-19-540 MSX-20-540 MSX-21-540 MSX-22-540 MSX-23-540 MSX-24-540 MSX-25-540 MSX-26-540 MSX-27-540 MSX-28-540 MSX-29-540 MSX-30-540 MSX-31-540 Marketed exclusively through distribution. Call Toll Free: 1 (800) 323-9612 2-24 .438 Density, 6-32 x 1/4" BH Screw, Closed Bottom, Double Row Barrier Blocks Series 541 Electrical Characteristics Voltage Rating: 600 Volts maximum Current Rating: 20 Amps Maximum Watts Per Terminal: 5000 Mechanical Characteristics Maximum Wire Size: #14 Recommended Tightening Torque: 12 lb.-in. Dimensions Ordering Information No. of Terminals 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 Catalog No. 2-541 3-541 4-541 5-541 6-541 7-541 8-541 9-541 10-541 11-541 12-541 13-541 14-541 15-541 16-541 17-541 18-541 19-541 20-541 21-541 22-541 23-541 24-541 25-541 26-541 27-541 28-541 29-541 30-541 “M” Dim. (in) 1.314 1.752 2.190 2.628 3.066 3.504 3.942 4.380 4.818 5.256 5.694 6.132 6.570 7.008 7.446 7.884 8.322 8.760 9.198 9.636 10.074 10.512 10.950 11.388 11.826 12.264 12.702 13.140 13.578 “L” Dim. (in) 1.626 2.064 2.502 2.940 3.378 3.816 4.254 4.692 5.130 5.568 6.006 6.444 6.882 7.320 7.758 8.196 8.634 9.072 9.510 9.948 10.386 10.824 11.262 11.700 12.138 12.576 13.014 13.452 13.890 Marker Strip Catalog No. MSX-2-541 MSX-3-541 MSX-4-541 MSX-5-541 MSX-6-541 MSX-7-541 MSX-8-541 MSX-9-541 MSX-10-541 MSX-11-541 MSX-12-541 MSX-13-541 MSX-14-541 MSX-15-541 MSX-16-541 MSX-17-541 MSX-18-541 MSX-19-541 MSX-20-541 MSX-21-541 MSX-22-541 MSX-23-541 MSX-24-541 MSX-25-541 MSX-26-541 MSX-27-541 MSX-28-541 MSX-29-541 MSX-30-541 Marketed exclusively through distribution. 2-25 Call Toll Free: 1 (800) 323-9612 .563 Density, 8-32 x 5/16" BH Screw, Closed Bottom, Double Row Barrier Blocks Series 542 Electrical Characteristics Voltage Rating: 600 Volts maximum Current Rating: 30 Amps Maximum Watts Per Terminal: 7500 Mechanical Characteristics Maximum Wire Size: #10 Recommended Tightening Torque: 16 lb.-in. Dimensions Ordering Information No. of Terminals 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 Catalog No. 2-542 3-542 4-542 5-542 6-542 7-542 8-542 9-542 10-542 11-542 12-542 13-542 14-542 15-542 16-542 17-542 18-542 19-542 20-542 21-542 22-542 23-542 24-542 25-542 26-542 “M” Dim. (in) 1.689 2.252 2.815 3.378 3.941 4.504 5.067 5.630 6.193 6.756 7.319 7.882 8.445 9.008 9.571 10.134 10.697 11.260 11.823 12.386 12.949 13.512 14.075 14.638 15.201 “L” Dim. (in) 2.095 2.658 3.221 3.784 4.347 4.910 5.473 6.036 6.599 7.162 7.725 8.288 8.851 9.414 9.977 10.540 11.103 11.666 12.229 12.792 13.355 13.918 14.481 15.044 15.607 Marker Strip Catalog No. MSX-2-542 MSX-3-542 MSX-4-542 MSX-5-542 MSX-6-542 MSX-7-542 MSX-8-542 MSX-9-542 MSX-10-542 MSX-11-542 MSX-12-542 MSX-13-542 MSX-14-542 MSX-15-542 MSX-16-542 MSX-17-542 MSX-18-542 MSX-19-542 MSX-20-542 MSX-21-542 MSX-22-542 MSX-23-542 MSX-24-542 MSX-25-542 MSX-26-542 Marketed exclusively through distribution. Call Toll Free: 1 (800) 323-9612 2-26 .375 Density, 5-40 x 3/16" BH Screw, Dip Solder, Single Row Barrier Blocks Series 176 Electrical Characteristics Voltage Rating: 250 Volts maximum Current Rating: 15 Amps maximum Maximum Watts Per Terminal: 3750 Mechanical Characteristics Maximum Wire Size: 16 AWG Recommended Tightening Torque: 16 lb.-in. Dimensions L M Ordering Information No. of Terminals 2 3 4 5 6 7 8 9 10 No. of Terminals 2 3 4 5 6 7 8 9 10 11 12 With Mounting Ears Catalog No. Catalog No. .125 Tail Lgth .184 Tail Lgth 2-176-2 2-176-3 3-176-2 3-176-3 4-176-2 4-176-3 5-176-2 5-176-3 6-176-2 6-176-3 7-176-2 7-176-3 8-176-2 8-176-3 9-176-2 9-176-3 10-176-2 10-176-3 “M” Dimension 1.125 1.500 1.875 2.250 2.625 3.000 3.375 3.375 4.125 Without Mounting Ears Catalog No. Catalog No. .125 Tail Lgth .184 Tail Lgth 2-176-2A 2-176-3A 3-176-2A 3-176-3A 4-176-2A 4-176-3A 5-176-2A 5-176-3A 6-176-2A 6-176-3A 7-176-2A 7-176-3A 8-176-2A 8-176-3A 9-176-2A 9-176-3A 10-176-2A 10-176-3A 11-176-2A 11-176-3A 12-176-2A 12-176-3A “L” Dimension 1.469 1.844 2.219 2.594 2.969 3.344 3.719 4.094 4.469 “L” Dimension .719 1.094 1.469 1.844 2.219 2.594 2.969 3.344 3.719 4.094 4.469 Marketed exclusively through distribution. 2-27 Call Toll Free: 1 (800) 323-9612 DURA-CON® Barrier Blocks High Reliability Accessories All-Plastic Solder Terminals 3/4W, Y, and W Optional Terminals for use with Cinch terminal blocks. See chart for type and dimensions. (Below) 2 Ordering Information "3/4 W" Terminals - Dimensions Catalog A Number in mm 3/4W-140 .953 24.21 3/4W-141 1.156 29.36 3/4W-142 1.422 36.11 B in .719 .680 .797 C mm 18.20 17.27 20.24 in .312 .422 .500 mm 12.70 15.88 18.64 in .136 .152 .177 mm 19.05 23.83 27.79 in .312 .422 .500 D mm 7.92 10.72 12.70 in .062 .078 .094 E mm 1.57 1.98 2.39 in .146 .152 .177 D in mm .593 15.06 .781 19.83 .906 23.01 in .093 .125 .125 F mm 3.71 3.86 4.50 in .094 .125 .125 mm 2.36 3.18 3.18 in .091 .103 .126 mm 3.71 3.86 4.50 in .094 .125 .125 mm 2.39 3.18 3.18 "Y" Terminals - Dimensions Catalog Number Y-140 Y-141 Y-142 A in .281 .312 .421 B mm 7.14 7.92 10.69 in .500 .625 .734 C mm 3.45 3.86 4.50 E F mm 2.31 2.62 3.20 "W" Terminals - Dimensions Catalog Number W-140 W-141 W-142 A in 1.219 1.563 1.875 B mm 30.96 39.70 47.63 in .750 .938 1.094 C D mm 7.92 10.72 12.70 in .063 .078 .094 E mm 1.60 1.98 2.39 in .146 .152 .177 F mm 2.39 3.18 3.18 Marketed exclusively through distribution. Call Toll Free: 1 (800) 323-9612 2-28 Barrier Blocks Accessories Quick Clamp Terminals Simplifies engaging of wires to barrier blocks. Wire is inserted into flared opening and screw is tightened. Screws are brass binder head type with nickel plating. Terminals are brass with tin plating. Includes two mating clamps and one screw. QC-1 Shown Ordering Information Barrier Block Series 141, 541 142, 542 Catalog No. QC-1 QC-2 Screw Size 6-32x5/16" 8-32x3/8" Wire Gauge Range AWG 12 thru 22 10 thru 16 Jumpers For connecting between adjacent terminals or alternate terminals. All jumpers are brass with nickel plating. Ordering Information Barrier Block Series 140 141 141 142 142, 542 142, 542 540 541 542 Type A B F F D E C C C Catalog No. 140J-1 141J-1 141J 95B 142J-1* 142J-2 540J 541J 542J Type A Type B Type C Type E Type F * Connects two alternate terminals Type D Marketed exclusively through distribution. 2-29 Call Toll Free: 1 (800) 323-9612 2 Barrier Block Accessories Fanning Strips MATERIALS FEATURES ■ Minimize wiring errors. ■ Available in straight and right-angle styles. ■ Available with cable clamp hole on right or left side, designated by “L” or “R” at end of catalog number. ■ Cable clamp hole for securing cable/wires with lacing twine or ty-wrap. Insulation Material: UL 94HB rated XPC, chocolate Contact Material: Brass Contact Plating: Cadmium Marketed exclusively through distribution. Call Toll Free: 1 (800) 323-9612 2-30 Barrier Block Accessories Fanning Strips Catalog Numbers and Dimensions for Fanning Strips for 140 Series Terminal Blocks Straight Type Dimensions Catalog No. 6-160B-R Catalog No. 6-160-R Ordering Information No. of Terminals 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 Catalog No. 2-160-R 3-160-R 4-160-R 5-160-R 6-160-R 7-160-R 8-160-R 9-160-R 10-160-R 11-160-R 12-160-R 13-160-R 14-160-R 15-160-R 16-160-R 17-160-R 18-160-R 19-160-R 20-160-R 21-160-R Catalog No. 2-160-L 3-160-L 4-160-L 5-160-L 6-160-L 7-160-L 8-160-L 9-160-L 10-160-L 11-160-L 12-160-L 13-160-L 14-160-L 15-160-L 16-160-L 17-160-L 18-160-L 19-160-L 20-160-L 21-160-L Catalog No. 2-160B-R 3-160B-R 4-160B-R 5-160B-R 6-160B-R 7-160B-R 8-160B-R 9-160B-R 10-160B-R 11-160B-R 12-160B-R 13-160B-R 14-160B-R 15-160B-R 16-160B-R 17-160B-R 18-160B-R 19-160B-R 20-160B-R 21-160B-R Catalog No. 2-160B-L 3-160B-L 4-160B-L 5-160B-L 6-160B-L 7-160B-L 8-160B-L 9-160B-L 10-160B-L 11-160B-L 12-160B-L 13-160B-L 14-160B-L 15-160B-L 16-160B-L 17-160B-L 18-160B-L 19-160B-L 20-160B-L 21-160B-L Marketed exclusively through distribution. 2-31 Call Toll Free: 1 (800) 323-9612 DURA-CON® Barrier Block High Reliability Accessories All-Plastic Fanning Fanning Strips Strips Catalog Numbers and Dimensions for Fanning Strips for 140 Series Terminal Blocks, Continued Right-Angle Type Dimensions 2 Catalog No. 6-160A-R Ordering Information No. of Terminals 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 Catalog No. 2-160A-R 3-160A-R 4-160A-R 5-160A-R 6-160A-R 7-160A-R 8-160A-R 9-160A-R 10-160A-R 11-160A-R 12-160A-R 13-160A-R 14-160A-R 15-160A-R 16-160A-R 17-160A-R 18-160A-R 19-160A-R 20-160A-R 21-160A-R Catalog No. 2-160A-L 3-160A-L 4-160A-L 5-160A-L 6-160A-L 7-160A-L 8-160A-L 9-160A-L 10-160A-L 11-160A-L 12-160A-L 13-160A-L 14-160A-L 15-160A-L 16-160A-L 17-160A-L 18-160A-L 19-160A-L 20-160A-L 21-160A-L Marketed exclusively through distribution. Call Toll Free: 1 (800) 323-9612 2-32 Barrier Block Accessories Fanning Strips Catalog Numbers and Dimensions for Fanning Strips for 141 Series Terminal Blocks Straight Type Dimensions No. of Terminals 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 Catalog No. 2-161-R 3-161-R 4-161-R 5-161-R 6-161-R 7-161-R 8-161-R 9-161-R 10-161-R 11-161-R 12-161-R 13-161-R 14-161-R 15-161-R 16-161-R 17-161-R 18-161-R 19-161-R 20-161-R Catalog No. 2-161-L 3-161-L 4-161-L 5-161-L 6-161-L 7-161-L 8-161-L 9-161-L 10-161-L 11-161-L 12-161-L 13-161-L 14-161-L 15-161-L 16-161-L 17-161-L 18-161-L 19-161-L 20-161-L 2 Catalog No. 5-161-R Right-Angle Type Dimensions No. of Terminals 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 Catalog No. 2-161A-R 3-161A-R 4-161A-R 5-161A-R 6-161A-R 7-161A-R 8-161A-R 9-161A-R 10-161A-R 11-161A-R 12-161A-R 13-161A-R 14-161A-R 15-161A-R 16-161A-R 17-161A-R 18-161A-R 19-161A-R 20-161A-R Catalog No. 2-161A-L 3-161A-L 4-161A-L 5-161A-L 6-161A-L 7-161A-L 8-161A-L 9-161A-L 10-161A-L 11-161A-L 12-161A-L 13-161A-L 14-161A-L 15-161A-L 16-161A-L 17-161A-L 18-161A-L 19-161A-L 20-161A-L Catalog No. 5-161A-R Marketed exclusively through distribution. 2-33 Call Toll Free: 1 (800) 323-9612 Barrier Block Accessories Fanning Strips Catalog Numbers and Dimensions for Fanning Strips for 142 Series Barrier Blocks Straight Type Ordering Information No. of Terminals 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 Catalog No. 2-162-R 3-162-R 4-162-R 5-162-R 6-162-R 7-162-R 8-162-R 9-162-R 10-162-R 11-162-R 12-162-R 13-162-R 14-162-R 15-162-R 16-162-R 17-162-R Dimensions Catalog No. 2-162-L 3-162-L 4-162-L 5-162-L 6-162-L 7-162-L 8-162-L 9-162-L 10-162-L 11-162-L 12-162-L 13-162-L 14-162-L 15-162-L 16-162-L 17-162-L Catalog No. 5-162-R Right-Angle Type Dimensions Ordering Information No. of Terminals 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 Catalog No. 2-162A-R 3-162A-R 4-162A-R 5-162A-R 6-162A-R 7-162A-R 8-162A-R 9-162A-R 10-162A-R 11-162A-R 12-162A-R 13-162A-R 14-162A-R 15-162A-R 16-162A-R 17-162A-R Catalog No. 2-162A-L 3-162A-L 4-162A-L 5-162A-L 6-162A-L 7-162A-L 8-162A-L 9-162A-L 10-162A-L 11-162A-L 12-162A-L 13-162A-L 14-162A-L 15-162A-L 16-162A-L 17-162A-L Catalog No. 5-162A-R Marketed exclusively through distribution. Call Toll Free: 1 (800) 323-9612 2-34 Barrier Block Accessories Lug-Type Terminal Strips Materials Insulation Material: UL 94 HB rated XPC, chocolate Contact Material: Steel Contact Plating: Cadmium Mechanical Characteristics Mounting Hole: .140" (3.56mm) diameter Strip Dimension: .0625" (1.59mm) thick x .375" (9.53mm) wide Lug Density: .375" (9.53mm) Ordering Information Mounting Catalog No. Centers 51 51A 51B 51C 51F 51L 51R 52 52A 52B 52C 52R 53 1.500 (38.10) 53A 1.500 (38.10) 53B .750 (19.05) 53C .750 (19.05) 53E 53F 54 1.875 (47.63) 54A 1.875 (47.63) 54B 54C 55 2.250 (57.15) 55A 2.250 (57.15) 55B 1.500 (38.10) 55C 1.500 (38.10) 56 2.625 (66.68) 56A 2.625 (66.68) 56B 1.875 (47.63) 56C 1.875 (47.63) 1 1 1 2 4 1/2 3 1 1 1 2 4 1 2 4 1 1 1 1 2 4 1 1 2 4 1 1 2 4 1 1 Lug Type Used In Position 2 3 4 5 6 7 8 2 4 1 1 1 3 2 4 1 1 1 1 1 2 4 2 4 1 1 1 1 1 1 2 4 1 1 2 4 1 1 1 1 3 1 1 1 1 1 1 1 1 2 4 1 1 1 1 1 1 1 1 1 1 2 4 1 1 1 1 1 1 1 1 1 1 1 1 1 1 2 4 1 1 1 1 1 1 1 1 1 1 1 1 1 1 2 4 1 1 2 4 1 1 1 1 2 4 1 1 1 1 2 4 2 4 1 1 Dimensions Marketed exclusively through distribution. 2-35 Call Toll Free: 1 (800) 323-9612 Jones Plugs/Sockets Series 300 Multiple Density Solder Eyelet ■ Solder lug terminals with .093" x .062" (2.36mm x 1.57mm) wiring holes. ■ Two-contact "Jones" connector is round, all others are rectangular. ■ For use in cable-to-panel and cable-to-cable applications. FEATURES ■ Designed for light and medium duty. ■ Plug prongs are .156" (3.96mm) wide and .047" (1.19mm) thick. ■ Polarized to prevent wrong-way insertion. ■ Plugs have projecting flat blades, sockets have recessed twin bellows. ■ Cable clamps of zinc and clear irridite-plated steel used for strain relief. ■ UL Recognized-file E170218 (UL 1977), E130965 (UL1863). ■ CSA-LR31996. ■ See Panel Cutout dimension on page (2-38). MATERIALS Insulation Material: Molded monoblock, general purpose phenolic, black UL94V-1 Contact Material: Plug: Brass Socket: Phosphor bronze Contact Plating: Cadmium Operating Temperature: Up to +105°C ELECTRICAL Hood Material: UL 94V-0 rated thermoplastic Operating Voltage: Current Rating: Contact Resistance: 250 VAC RMS maximum 10 Amps 16 Milliohms maximum Marketed exclusively through distribution. Call Toll Free: 1 (800) 323-9612 2-36 Jones Plugs/Sockets Series 300 Multiple Density Solder Eyelet Polarizing Patterns - 300 Series Marketed exclusively through distribution. 2-37 Call Toll Free: 1 (800) 323-9612 Jones DURA-CON® Plugs/Sockets High Reliability Series 300 All-Plastic Multiple Density Solder Eyelet Mounting Dimensions A Reference 2 in B mm in C mm in D mm in mm 303 .453 11.51 1.016 25.81 .750 19.05 - - 304 .719 18.26 .781 19.84 1.000 25.40 - - 306 .719 18.26 1.031 26.19 1.000 25.40 - - 308 .719 18.26 1.281 32.54 1.000 25.40 - - 310 .719 18.26 1.578 40.08 1.000 25.40 - - 312 .953 24.21 1.266 32.16 1.250 31.75 - - 315-12 .953 24.21 1.516 38.51 1.250 31.75 - - 315 1.016 25.81 1.641 41.68 1.375 34.93 - - 318 1.016 25.81 1.953 49.61 1.375 34.93 .625 15.88 321 1.016 25.81 2.266 57.56 1.375 34.93 .469 11.91 324 1.016 25.81 2.578 65.48 1.375 34.93 .625 15.88 327 1.016 25.81 2.891 73.43 1.375 34.93 .781 19.84 330 1.016 25.81 3.203 81.36 1.375 34.93 .938 23.83 333 1.016 25.81 3.516 89.31 1.375 34.93 1.094 27.79 NOTE: For 300 Series 2 through 33 contact angle bracket connectors. All mounting holes are .156" (3.96mm) dia. Maximum chassis thickness is .063" (1.59mm) for bottom mounting. Mounting holes are located on center line unless otherwise shown. Marketed exclusively through distribution. Call Toll Free: 1 (800) 323-9612 2-38 Jones Plugs/Sockets Series 300 No. of Contacts 2 3 4 6 8 10 12 15* 15 18 21 24 27 30 33 [.050” Multiple (1.27mm) Density Density Solder SolderCup/Wire Eyelet With Angle D-Microminiature] Bracket/Less Angle Bracket With Angle Bracket Catalog No. Catalog No. Plug Socket P-302-AB S-302-AB P-303-AB S-303-AB P-304-AB S-304-AB P-306-AB S-306-AB N/A N/A P-310-AB N/A P-312-AB N/A N/A S-315-12-AB P-315-AB S-315-AB P-318-AB S-318-AB P-321-AB S-321-AB P-324-AB S-324-AB P-327-AB S-327-AB P-330-AB S-330-AB P-333-AB S-333-AB Less Angle Bracket Catalog No. Catalog No. Plug Socket P-302-LAB S-302-LAB P-303-LAB S-303-LAB P-304-LAB S-304-LAB P-306-LAB S-306-LAB N/A N/A P-310-LAB N/A P-312-LAB N/A N/A S-315-12-LAB P-315-LAB S-315-LAB P-318-LAB S-318-LAB P-321-LAB S-321-LAB P-324-LAB S-324-LAB P-327-LAB S-327-LAB P-330-LAB S-330-LAB P-333-LAB S-333-LAB No. of Contacts 2 3 4 6 8 10 12 15 15 18 21 24 27 30 33 X = length of plug contacts. This dimension does not apply to sockets. Y = length of plug or socket tails. No. of Contacts 2 3 4 6 8 10 12 15* A in B mm in 16.67 25.40 19.05 25.40 -39.69 31.75 38.10 .438 .688 .688 -.688 .938 .938 in mm in 1.625 1.938 2.250 2.563 2.875 3.188 3.500 41.28 49.23 57.15 65.10 73.03 80.98 88.90 .656 1.000 .750 1.000 -1.562 1.250 1.500 C mm 11.11 17.46 17.46 -17.46 23.81 23.81 *Special 15 contact arrangement to allow 12-position mating. L Reference 15 18 21 24 27 30 33 M See note 1.250 .938 1.250 1.562 1.875 2.188 D in mm in mm .969 .750 1.000 1.000 -1.000 1.250 1.250 24.61 19.05 25.40 25.40 -25.40 31.75 31.75 1.219 1.062 1.312 1.312 -1.312 1.562 1.562 30.96 26.99 33.34 33.34 -33.34 39.69 39.69 Polarizing Pin mm 31.75 23.81 31.75 39.69 47.63 55.58 NO NO NO 14 14 14 17 NOTE: 15-position plug and socket require only two mounting brackets, mounted on center of connector. Marketed exclusively through distribution. 2-39 Call Toll Free: 1 (800) 323-9612 2 Jones DURA-CON® Plugs/Sockets High Reliability Series 300 All-Plastic [.050” Multiple (1.27mm) Density Density Solder Solder Cup/Wire Eyelet D-Microminiature] Flush Plate 300 Series with Flush Plate (FP) 2 No. of Catalog No. Catalog No. Contacts Plug Socket 2 P-302-FP S-302-FP 3 P-303-FP S-303-FP 4 P-304-FP S-304-FP 6 P-306-FP S-306-FP 8 N/A N/A 10 P-310-FP N/A 12 P-312-FP N/A NOTE: Not available in contact sizes 15-33. X = length of plug contacts. This dimension does not apply to sockets. Y = length of plug or socket tails. Dimensions - Plug or Socket No. of Contacts 2 3 4 6 8 10 12 A in 2.063 2.063 2.063 2.063 -2.563 2.563 B mm 52.40 52.40 52.40 52.40 -65.10 65.10 in 1.250 1.250 1.250 1.250 -1.750 1.750 C mm 31.75 31.75 31.75 31.75 -44.45 44.45 in 1.750 1.750 1.750 1.750 -2.250 2.250 D mm 44.45 44.45 44.45 44.45 -57.15 57.15 in .938 .688 .938 -1.500 1.188 mm 23.81 17.46 23.81 -38.10 30.16 E Max. in mm .719 18.26 .500 12.70 .750 19.05 .750 19.05 --.750 19.05 1.000 25.40 Panel Cutout Dimensions A Reference 303-FP 304-FP 306-FP 308-FP 310-FP 312-FP in .953 .703 .953 -1.516 1.203 B mm 24.21 17.86 24.21 -38.51 30.56 in .516 .766 .766 -.766 1.016 C mm 13.11 19.46 19.46 -19.46 25.81 in 1.750 1.750 1.750 -2.250 2.250 mm 44.45 44.45 44.45 -57.15 57.15 Marketed exclusively through distribution. Call Toll Free: 1 (800) 323-9612 2-40 Jones Plugs/Sockets Series 300 [.050” Multiple (1.27mm) Density Density Solder Solder Cup/Wire Eyelet D-Microminiature] End Brackets 300 Series with End Brackets (EB) No. of Contacts 15 18 21 24 28 30 33 Catalog No. Plug P-315-EB P-318-EB P-321-EB P-324-EB P-328-EB P-330-EB P-333-EB Catalog No. Socket S-315-EB S-318-EB S-321-EB S-324-EB S-328-EB S-330-EB S-333-EB 2 NOTE: Not available in contact sizes 2-12. X = length of plug contacts. This dimension does not apply to sockets. Y = length of plug or socket tails. Dimensions No. of Contacts 15 18 21 24 27 30 33 L ± .031 (.79mm) 2.313 58.75 2.625 66.68 2.938 74.63 3.250 82.55 3.563 90.50 3.875 98.43 4.188 106.38 M ± .031 (.79mm) 2.000 50.80 2.313 58.75 2.625 66.68 2.938 74.63 3.250 82.55 3.563 90.50 3.875 98.43 P ± .063 (1.59mm) 1.625 41.28 1.938 49.23 2.250 57.15 2.563 65.10 2.875 73.03 3.188 80.98 3.500 88.90 Polarizing Pin NO NO NO 14 14 14 17 Panel Cutout Dimensions A Reference 315-EB 318-EB 321-EB 324-EB 327-EB 330-EB 333-EB in 1.641 1.953 2.266 2.578 2.891 3.203 3.516 B mm 41.68 49.61 57.56 65.48 73.43 81.36 89.31 in 1.016 1.016 1.016 1.016 1.016 1.016 1.016 C mm 25.81 25.81 25.81 25.81 25.81 25.81 25.81 in 2.000 2.313 2.625 2.938 3.250 3.563 3.875 mm 50.80 58.75 66.68 74.63 82.55 90.50 98.43 Marketed exclusively through distribution. 2-41 Call Toll Free: 1 (800) 323-9612 Jones DURA-CON® Plugs/Sockets High Reliability Series 300 All-Plastic Multiple Density Solder Eyelet Recessed Plate 300 Series with Recessed Plate (RP) 2 No. of Contacts 2 3 4 6 8 10 12 Catalog No. Plug P-302-RP P-303-RP P-304-RP P-306-RP N/A P-310-RP P-312-RP Catalog No. Socket S-302-RP S-303-RP S-304-RP S-306-RP N/A N/A N/A NOTE: Not available in contact sizes 15-33. Y = length of plug or socket tails. Dimensions No. of Contacts 2 3 4 6 8 10 12 A in 2.063 2.063 2.063 2.063 -2.563 2.563 B mm 52.40 52.40 52.40 52.40 -65.10 65.10 in 1.500 1.500 1.500 1.500 -2.000 2.000 C mm 38.10 38.10 38.10 38.10 -50.80 50.80 in 1.750 1.750 1.750 1.750 -2.250 2.250 mm 44.45 44.45 44.45 44.45 -57.15 57.15 D Max. in mm 1.350 34.29 1.350 34.29 1.350 34.29 1.350 34.29 --1.850 46.99 1.850 46.99 Marketed exclusively through distribution. Call Toll Free: 1 (800) 323-9612 2-42 Jones Plugs/Sockets Series 300 [.050” Multiple (1.27mm) Density Density Solder Solder Cup/Wire Eyelet D-Microminiature] Shallow Bracket 300 Series with Shallow Bracket (SB) No. of Contacts 15 18 21 24 27 30 33 Catalog No. Plug P-315-SB P-318-SB P-321-SB P-324-SB P-327-SB P-330-SB P-333-SB Catalog No. Socket S-315-SB S-318-SB S-321-SB S-324-SB S-327-SB S-330-SB S-333-SB 2 NOTE: Not available in contact sizes 2-12. X = length of plug contacts. This dimension does not apply to sockets. Y = length of plug or socket tails. Dimensions No. of Polarizing Contacts 15 18 21 24 27 30 33 A ± .031 (.79mm) in mm 1.688 42.86 2.000 50.80 2.313 58.75 2.625 66.68 2.938 74.63 3.250 82.55 3.563 90.50 M ± .031 (.79mm) in mm 2.125 53.98 2.438 61.93 2.750 69.85 2.063 52.40 3.375 85.73 3.688 93.68 4.000 101.60 L ± .063 (1.59mm) in mm 2.547 64.69 2.859 72.62 3.172 80.57 3.484 88.49 3.797 96.44 4.109 104.38 4.422 112.32 Polarizing Pin NO NO NO 14 14 14 17 Panel Cutout Dimensions A Reference 315-SB 318-SB 321-SB 324-SB 327-SB 330-SB 333-SB in 1.750 2.063 2.375 2.688 3.000 3.313 3.625 B mm 44.45 52.40 60.33 68.28 76.20 84.15 92.08 in 1.156 1.156 1.156 1.156 1.156 1.156 1.156 C mm 29.36 29.36 29.36 29.36 29.36 29.36 29.36 in 2.125 2.438 2.750 3.062 3.376 3.688 4.000 mm 53.98 61.93 69.85 77.77 85.75 93.68 101.60 Marketed exclusively through distribution. 2-43 Call Toll Free: 1 (800) 323-9612 Jones DURA-CON® Plugs/Sockets High Reliability Series 300 All-Plastic [.050” Multiple (1.27mm) Density Density Solder Solder Cup/Wire Eyelet D-Microminiature] Deep Bracket 300 Series Deep Bracket (DB) 2 No. of Contacts 2 3 4 6 8 10 12 15 18 21 24 27 30 33 Catalog No. Plug P-302-DB P-303-DB P-304-DB P-306-DB N/A N/A P-312-DB P-315-DB P-318-DB P-321-DB P-324-DB P-327-DB P-330-DB P-333-DB Catalog No. Socket S-302-DB S-303-DB S-304-DB S-306-DB N/A N/A N/A S-315-DB S-318-DB S-321-DB S-324-DB S-327-DB S-330-DB S-333-DB Dimensions Y = length of plug or socket tails. L ± .063 (1.60mm) in mm 2.813 71.44 3.125 79.38 3.437 87.31 3.750 95.25 4.063 103.19 4.375 111.13 4.688 119.06 No. of Contacts 15 18 21 24 27 30 33 M ± .031 (.79mm) in mm 2.375 60.33 2.688 68.28 3.000 76.20 3.313 84.15 3.625 92.08 3.938 100.03 4.250 107.95 Polarizing Pin NO NO NO 14 14 14 17 Panel Cutout Dimensions A Reference 302-DB thru 312-DB 315-DB 318-DB 321-DB 324-DB 327-DB 330-DB 333-DB B C in mm in mm in mm 1.453 2.000 2.313 2.625 2.938 3.250 3.562 3.875 36.91 50.80 58.75 66.68 74.63 82.55 90.47 98.43 1.125 1.438 1.438 1.438 1.438 1.438 1.438 1.438 28.58 36.53 36.53 36.53 36.53 36.53 36.53 36.53 1.750 2.376 2.688 3.000 3.312 3.626 3.938 4.250 38.10 60.35 68.28 76.20 84.12 92.10 100.03 107.95 Marketed exclusively through distribution. Call Toll Free: 1 (800) 323-9612 2-44 Jones Plugs/Sockets Series 300 [.050” Multiple (1.27mm) Density Density Solder Solder Cup/Wire Eyelet With Hood & 90° Clamp D-Microminiature] 300 Series with Hood and 90° Cable Clamp (CCE) No. of Contacts 2 3 4 6 8 10 12 15 18 21 24 27 30 33 Catalog No. Plug P-302-CCE P-303-CCE P-304-CCE P-306-CCE N/A P-310-CCE P-312-CCE P-315-CCE P-318-CCE P-321-CCE P-324-CCE P-327-CCE P-330-CCE P-333-CCE Catalog No. Socket S-302-CCE S-303-CCE S-304-CCE S-306-CCE N/A N/A N/A S-315-CCE S-318-CCE S-321-CCE S-324-CCE S-327-CCE S-330-CCE S-333-CCE 2 Dimensions No. of Contacts 2 3 4 6 8 10 12 A +.016 (.41mm) in mm .691 17.55 1.034 26.26 .786 19.96 1.036 26.31 --1.592 40.44 1.286 32.66 No. of Contacts 15 18 21 24 27 30 33 B +.016 (.41mm) in mm .472 11.99 .724 18.39 .724 18.39 --.720 18.29 .974 24.74 C +.031 (.79mm) in mm .953 24.21 .953 24.21 .953 24.21 .078 27.38 --1.203 30.56 1.203 30.56 E in 2.514 2.826 3.139 3.451 3.764 4.076 4.389 L mm 63.85 71.78 79.73 87.66 95.61 103.53 111.48 in 1.795 2.107 2.420 2.732 3.045 3.357 3.670 mm 45.59 53.52 61.47 69.39 77.34 85.27 93.22 G in .313 .344 .453 .469 -.359 .422 mm 7.95 8.74 11.51 11.91 -9.12 10.72 Cable Opening in mm .563 14.30 .563 14.30 .625 15.88 .625 15.88 .625 15.88 .750 19.05 .750 19.05 Cable "D" Opening in mm .313 7.95 .250 6.35 .375 9.53 .438 11.13 --.500 12.70 .563 14.30 Polarizing Pin NO NO NO 14 14 14 17 Marketed exclusively through distribution. 2-45 Call Toll Free: 1 (800) 323-9612 Jones DURA-CON® Plugs/Sockets High Reliability Series 300 All-Plastic [.050” (1.27mm) Density Multiple Density Solder Eyelet Solder Cup/Wire With Hood & 180° Clamp D-Microminiature] 300 Series with Hood and 180° Cable Clamp (CCT) 2 No. of Contacts 2 3 4 6 8 10 12 15 18 21 24 27 30 33 Catalog No. Plug P-302-CCT P-303-CCT P-304-CCT P-306-CCT N/A P-310-CCT P-312-CCT P-315-CCT P-318-CCT P-321-CCT P-324-CCT P-327-CCT P-330-CCT P-333-CCT Catalog No. Socket S-302-CCT S-303-CCT S-304-CCT S-306-CCT N/A N/A N/A S-315-CCT S-318-CCT S-321-CCT S-324-CCT S-327-CCT S-330-CCT S-333-CCT Dimensions No. of Contacts 2 3 4 6 8 10 12 A ± .016 (.41mm) in mm .691 17.55 1.034 26.26 .786 19.96 1.036 26.31 --1.592 40.44 1.286 32.66 No. of Contacts 15 18 21 24 27 30 33 B ± .016 (.41mm) in mm .472 11.99 .724 18.39 .724 18.39 --.720 18.29 .974 24.74 L in 1.795 2.107 2.420 2.732 3.045 3.357 3.670 mm 45.59 53.52 61.47 69.39 77.34 85.27 93.22 C ± .031 (.79mm) in mm .953 24.21 .953 24.21 .953 24.21 1.078 27.38 --1.203 30.56 1.203 30.56 Cable Opening in mm .563 14.30 .563 14.30 .625 15.88 .625 15.88 .625 15.88 .750 19.05 .750 19.05 “D” Cable Opening in mm .375 9.53 .313 7.95 .375 9.53 .438 11.13 --.500 12.70 .563 14.30 E ± .031 (.79mm) in mm .359 9.12 .359 9.12 .469 11.91 .484 12.29 --.500 12.70 .469 11.91 Polarizing Pin NO NO NO 14 14 14 17 Marketed exclusively through distribution. Call Toll Free: 1 (800) 323-9612 2-46 Jones Plugs/Sockets Series 300 [.050” Multiple (1.27mm) Density Density Solder Solder Cup/Wire Eyelet D-Microminiature] 180° Clamp w/Locks 300 Series Plug with Hood and Lock (CCT-L) and Socket with Hood and Keeper (CCT-K) No. of Contacts 2 3 4 6 8 10 12 15 18 21 24 27 30 33 Catalog No. Catalog No. Plug w/ Lock Socket w/ Keeper P-302-CCT-L S-302-CCT-K P-303-CCT-L S-303-CCT-K P-304-CCT-L S-304-CCT-K P-306-CCT-L S-306-CCT-K N/A N/A P-310-CCT-L N/A P-312-CCT-L N/A P-315-CCT-L S-315-CCT-K P-318-CCT-L S-318-CCT-K P-321-CCT-L S-321-CCT-K P-324-CCT-L S-324-CCT-K P-327-CCT-L S-327-CCT-K P-330-CCT-L S-330-CCT-K P-333-CCT-L S-333-CCT-K Socket 2 Plug Dimensions No. of Contacts 2 3 4 6 8 10 12 15 18 21 24 27 30 33 A ± .016 (.41mm) in mm .691 17.5 1.034 26.26 .786 19.96 1.036 26.31 --1.592 40.44 1.286 32.66 1.795 45.59 2.107 53.52 2.420 61.47 2.732 69.39 3.045 77.34 3.357 85.27 3.670 93.22 B ± .016 (.41mm) in mm .472 11.99 .724 18.39 .724 18.39 --.720 18.29 .974 24.74 1.100 27.94 1.100 27.94 1.100 27.94 1.100 27.94 1.100 27.94 1.100 27.94 1.100 27.94 C ± .031 (.79mm) in mm .953 24.21 .953 24.21 .953 24.21 1.078 27.38 --1.203 30.56 1.203 30.56 1.850 46.99 1.850 46.99 1.850 46.99 1.850 46.99 1.850 46.99 1.850 46.99 1.850 46.99 F in .359 .359 .469 .484 -.500 .469 .712 .712 .712 .712 .712 .712 .712 mm 9.12 9.12 11.91 12.29 -12.70 11.91 18.08 18.08 18.08 18.08 18.08 18.08 18.08 “D” Cable Opening Polarizing in mm Pin .375 9.53 -.313 7.94 -.375 9.53 -.438 11.13 ----.500 12.70 -.563 14.30 -.563 14.30 NO .563 14.30 NO .625 15.88 NO .625 15.88 14 .625 15.88 14 .750 19.05 14 .750 19.05 17 Marketed exclusively through distribution. 2-47 Call Toll Free: 1 (800) 323-9612 DURA-CON® High Reliability Miscellaneous All-Plastic [.050” (1.27mm) Density Multiple Density Solder Cup/Wire Solder Eyelet D-Microminiature] JONES PLUGS AND SOCKETS 300 SERIES MATING CHART PLUGS MOUNTING CONFIG. AB 2 AB DB FP RP EB SB CCE CCT •* • •* • • • • • • • • • • • • • • • • •* •* •* •* •* •* •* •* • • •* •* •* • • DB FP SOCKETS RP EB SB CCE CCT • • • • • CCT-L CCT-K LAB • • • • • • • • • CCT-L • • CCT-K • LAB • • • • • • • • • • These are recommended configurations. •* These are possible configurations, but not normally recommended. NOTE: Cinch layout S315-12 is available only in “AB” or “LAB”. Replacement Drive Pins for Series 300 Plugs and Sockets with Cable Caps and Clamps Dimensions No. of Contacts 2 3 4,6,8,10* 12 15-33* Ordering Information Dim. L +.005 (.13mm) in mm .687 17.45 .468 11.89 .718 18.24 .953 28.58 1.125 28.58 No. of Contacts 2 3 4,6,8,10* 12 15-33* Catalog No. 302R 303R 304R 312R 333R *10 contact size and 15 through 33 contact sizes require two pins per unit; all other sizes require only one. Marketed exclusively through distribution. Call Toll Free: 1 (800) 323-9612 2-48 Jones Plugs/Sockets Series 2400 Multiple Density Solder Eyelet ■ For use in cable-to-cable and cable-to-panel applications. ■ Designed for medium duty. ■ Plug prongs are .250" (6.35mm) wide and .055" (1.40mm) thick. ■ Socket contacts have solder eyelet contacts of .093" diameters. ■ Polarized to prevent wrong-way insertion. FEATURES ■ Plugs have projecting flat blades, sockets have recessed twin bellows. ■ Cable clamps of zinc and clear irridite-plated steel are used for strain relief. ■ Bifurcated bellows socket contact provides four individual flexing surfaces for maximum contact with the blade. ■ Plugs and sockets have recessed pockets with barriers around the contacts. ■ A shoulder extends around the face (mating) side of both plug and socket presenting a finished appearance when mounted in bracket or cap. ■ Intermates with existing 400 Series Products on the market. ■ UL Recognized - file - E17021B (UL1977) E130965 (1863). ■ CSA - LR31996-2. ELECTRICAL MATERIALS ■ Panel cutout dimensions (See page 2-57). Insulation Material: Molded monoblock, general purpose phenolic, black Contact Material: Plug: Brass Socket: Phosphor bronze Contact Plating: Cadmium Operating Temperature: Up to +105°C Hood Material: Formed metal with dielectric liner in hood to prevent shorting Operating Voltage: Current Rating: Current Resistance: 250 VAC RMS 15 Amps 1.0 Milliohms maximum Marketed exclusively through distribution. Call Toll Free: 1 (800) 323-9612 2-50 Jones Plugs/Sockets Series 2400 Multiple Density Solder Eyelet Less Angle Bracket 2400 Series Less Angle Bracket No. of Contacts 2 4 6 8 10 12 Catalog No. Plug N/A P-2404-LAB P-2406-LAB P-2408-LAB P-2410-LAB P-2412-LAB Catalog No. Socket S-2402-LAB S-2404-LAB S-2406-LAB S-2408-LAB S-2410-LAB S-2412-LAB Plug Socket Dimensions - Plug or Socket No. of Contacts 2 4 6 8 10 12 M in .563 1.000 1.438 1.875 2.313 2.750 L mm 14.29 25.40 36.51 47.63 58.74 69.85 in .656 1.094 1.531 1.969 2.406 1.844 mm 16.67 27.78 38.89 50.01 61.12 46.83 Marketed exclusively through distribution. 2-51 Call Toll Free: 1 (800) 323-9612 ® Jones DURA-CON Plugs/Sockets High Reliability Series 2400 All-Plastic [.050” Multiple (1.27mm) Density Density Solder Solder Cup/Wire Eyelet D-Microminiature] With Angle Bracket 2400 Series with Angle Bracket 2 No. of Contacts 2 4 6 8 10 12 Catalog No. Plug N/A P-2404-AB P-2406-AB P-2408-AB P-2410-AB P-2412-AB Catalog No. Socket S-2402-AB S-2404-AB S-2406-AB S-2408-AB S-2410-AB S-2412-AB Plug Socket Dimensions - Plug or Socket No. of Contacts 2 4 6 8 10 12 M in .563 1.000 1.438 1.875 2.313 2.750 L mm 14.29 25.40 36.51 47.63 58.74 69.85 in .656 1.094 1.531 1.969 2.406 2.844 mm 16.67 27.78 38.89 50.01 61.12 72.24 Panel Cutout dimensions are on page 2-61. Call Toll Free: 1 (800) 323-9612 Marketed exclusively through distribution. 2-52 Jones Plugs/Sockets Series 2400 [.050” Multiple (1.27mm) DensityDensity Solder Solder Cup/Wire Eyelet D-Microminiature] Shallow Bracket 2400 Series with Shallow Bracket No. of Contacts 2 4 6 8 10 12 Catalog No. Plug N/A P-2404-SB P-2406-SB P-2408-SB P-2410-SB P-2412-SB Catalog No. Socket S-2402-SB S-2404-SB S-2406-SB S-2408-SB S-2410-SB S-2412-SB 2 Plug Socket Dimensions - Plug or Socket No. of Contacts 2 4 6 8 10 12 L in 1.500 1.937 2.375 2.813 3.250 3.688 M mm 38.10 49.21 60.33 71.45 82.55 93.68 in 1.062 1.500 1.938 2.375 2.813 3.250 mm 26.99 38.10 49.23 60.33 71.45 82.55 Panel Cutout dimensions are on page 2-61. R. Max. in mm 1.766 19.45 1.234 31.34 1.672 42.47 2.109 53.57 2.547 64.69 2.984 75.80 Marketed exclusively through distribution. 2-53 Call Toll Free: 1 (800) 323-9612 Jones DURA-CON® Plugs/Sockets High Reliability Series 2400 All-Plastic [.050” Multiple (1.27mm) Density Density Solder Solder Cup/Wire Eyelet D-Microminiature] Deep Bracket 2400 Series with Deep Bracket 2 No. of Contacts 2 4 6 8 10 12 Catalog No. Plug N/A P-2404-DB P-2406-DB P-2408-DB P-2410-DB P-2412-DB Catalog No. Socket S-2402-DB S-2404-DB S-2406-DB S-2408-DB S-2410-DB S-2412-DB Plug Socket Plug or Socket Dimensions - Plug or Socket No. of Contacts 2 4 6 8 10 12 B in .922 1.359 1.797 2.234 2.672 3.109 L mm 23.42 34.53 45.64 56.74 67.87 78.97 in 1.750 2.188 2.625 3.063 3.500 3.938 M mm 44.45 55.58 57.53 77.79 88.90 100.03 in 1.313 1.750 2.188 2.625 3.063 3.500 mm 33.35 44.45 55.58 66.68 77.80 88.90 Panel Cutout dimensions are on page 2-61. Marketed exclusively through distribution. Call Toll Free: 1 (800) 323-9612 2-54 Jones Plugs/Sockets Series 2400 [.050” Multiple (1.27mm) Density Density Solder Solder Cup/Wire Eyelet D-Microminiature] With Hood & 90° Clamp 2400 Series with Hood and 90° Clamp No. of Contacts 2 4 6 8 10 12 Catalog No. Plug N/A P-2404-CCE P-2406-CCE P-2408-CCE P-2410-CCE P-2412-CCE Catalog No. Socket S-2402-CCE S-2404-CCE S-2406-CCE S-2408-CCE S-2410-CCE S-2412-CCE 2 Dimensions - Plug or Socket No. of Contacts 2 4 6 8 10 12 L in .625 1.062 1.500 1.937 2.375 2.813 C mm 15.88 26.99 38.10 49.21 60.33 71.45 in 1.375 1.375 1.375 1.344 1.344 1.312 mm 34.93 34.93 34.93 34.13 34.13 33.34 Cable Opening in mm .375 9.53 .438 11.11 .438 11.11 .563 14.29 .563 14.29 .625 15.88 Marketed exclusively through distribution. 2-55 Call Toll Free: 1 (800) 323-9612 Jones DURA-CON® Plugs/Sockets High Reliability Series 2400 All-Plastic Multiple Density Solder Eyelet With Hood & 180° Clamp 2400 Series with Hood and 180° Clamp 2 No. of Contacts 2 4 6 8 10 12 Catalog No. Plug N/A P-2404-CCT P-2406-CCT P-2408-CCT P-2410-CCT P-2412-CCT Catalog No. Socket S-2402-CCT S-2404-CCT S-2406-CCT S-2408-CCT S-2410-CCT S-2412-CCT Plug Socket Dimensions - Plug or Socket No. of Contacts 2 4 6 8 10 12 L in .625 1.062 1.500 1.937 2.375 2.813 Cable Opening in mm .313 7.94 .438 11.11 .438 11.11 .563 14.29 .563 14.29 .625 15.88 mm 15.88 26.99 38.10 49.21 60.33 71.45 Marketed exclusively through distribution. Call Toll Free: 1 (800) 323-9612 2-56 Jones Plugs/Sockets Series 2400 Panel Cutout Dimensions Angle Bracket A Reference in mm P-2402-AB --S-2402-AB 1.188 30.16 P-2404-AB S-2404-AB 1.625 41.28 P-2406-AB S-2406-AB 2.063 52.40 P-2408-AB S-2408-AB 2.500 63.50 P-2410-AB S-2410-AB 2.938 74.63 P-2412-AB S-2412-AB 3.375 85.73 Panel Cutout Dimensions Shallow Bracket A Reference in mm P-2402-SB S-2402-SB 1.062 27.00 P-2404-SB S-2404-SB 1.500 38.10 P-2406-SB S-2406-SB 1.938 49.22 P-2408-SB S-2408-SB 2.376 60.34 P-2410-SB S-2410-SB 2.812 71.44 P-2412-SB S-2412-SB 3.250 82.56 Panel Cutout Dimensions Deep Bracket A Reference in mm P-2402-DB S-2402-DB 1.312 33.34 P-2404-DB S-2404-DB 1.750 44.46 P-2406-DB S-2406-DB 2.188 55.56 P-2408-DB S-2408-DB 2.624 66.68 P-2410-DB P-2410-DB 3.062 77.80 P-2412-DB S-2412-DB 3.500 88.90 [.050” (1.27mm) Density Solder Cup/Wire Panel Cutout Dimensions D-Microminiature] B C in -1.008 mm -25.60 in -1.015 mm -25.78 1.445 36.70 1.015 25.78 1.886 47.83 1.015 25.78 2.320 58.93 1.015 25.78 2.758 70.05 1.015 25.78 3.195 81.15 1.015 25.78 in mm in mm .813 20.64 1.156 29.37 1.250 31.75 1.156 29.37 1.688 42.86 1.156 29.37 2.125 53.98 1.156 29.37 2.563 65.10 1.156 29.37 3.000 76.20 1.156 29.37 in mm in mm .938 23.81 1.438 36.51 1.375 34.93 1.438 36.51 1.813 46.04 1.438 36.51 2.250 57.15 1.438 36.51 2.688 68.28 1.438 36.51 3.125 79.38 1.438 36.51 B 2 C B C Marketed exclusively through distribution. 2-57 Call Toll Free: 1 (800) 323-9612 Contact positions 3, 4, 5, 6, 7, and 8. Pre-assembled with standard shielded cable lengths; consult factory for other lengths. Molded-in strain relief. Cable and overmold available in standard colors: black or beige. Contacts available with gold over nickel. Shielding system designed to meet FCC requirements for EMI/RFI suppression. UL Recognized - file E170218 (UL1977). CSA Certified - file LR31996-6. Insulation Material: Plug Insulator: UL 94V-0 rated nylon Plug Overmold: PVC (black or beige) Cable Jacket: PVC (black or beige) Contact Material: Plug: Phosphor bronze Contact Plating: Option 1: Gold Flash over nickel underplate overall Option 2: Option 1 plus additional gold in mating area for total thickness of 30μin. Shield Material: Steel Shield Plating: Nickel Standard Cable Shielded cable with 0.197 inch OD Composition: jacket over 28 AWG stranded wire conductors. Contact factory for custom cable requirements. Shock: MIL-STD-202, Method 213, Condition C Operating Temperature: -40°C to +70°C Heat Resistance: 196 hrs. at 100°C Salt Spray: MIL-STD-202, Method 101D, Condition D Vibration: MIL-STD-202, Method 204, Condition B Humidity: MIL-STD-202, Method 103, 48 hrs. at 90-95% RH at 40°C MECHANICAL ELECTRICAL MATERIALS ■ ■ ■ ■ ■ ■ ■ ■ Single-Ended Cable Assembly ENVIRONMENTAL FEATURES Circular Mini DIN Plugs Voltage Rating: Current Rating: Contact Resistance: Insulation Resistance: 500 VAC RMS, 707 VDC 1 Amp at 100 VAC 2 Amps at 12 VDC Contact to contact: 30 milliohms maximum Shield to shield: 50 milliohms maximum 500 megohms minimum at 500 VDC 100 megohms minimum after humidity Durability: Withstands 500 mating/unmating cycles Mating Force: 10 lb. (4.5 kg) maximum Unmating Force: 1 lb. (0.9 kg) minimum Contact Retention: 3 lb. minimum Call Toll Free: 1 (800) 323-9612 PIN NO COLOR 1 2 3 BLACK GREEN RED 4 5 6 BROWN BLUE WHITE 7 YELLOW 8 GRAY Marketed exclusively through distribution. 2-58 Circular Mini DIN Plugs Single-Ended Cable Assembly Dimensions 3-Contact 4-Contact 5-Contact 7-Contact 6-Contact 8-Contact Ordering Information: (NOTE: One meter = 39.62 inches.) For cable assemblies with plug on one end. Plug features contacts with Option 1 plating (gold flash over nickel). No. of Contacts 3 4 4 4 5 6 6 6 7 7 7 8 8 8 Cable Length Meter Black Color Cable & Overmold Catalog No. Beige Color Cable & Overmold Catalog No. 1 1 2 3 1 1 2 3 1 2 3 1 2 3 MDC-3P05 MDC-4P05 MDC-4P13 MDC-4P15 MDC-5P05 MDC-6P05 MDC-6P13 MDC-6P15 MDC-7P05 MDC-7P13 MDC-7P15 MDC-8P05 MDC-8P13 MDC-8P15 MDC-3P08 MDC-4P08 MDC-4P53 MDC-4P55 MDC-5P08 MDC-6P08 MDC-6P53 MDC-6P55 MDC-7P08 MDC-7P53 MDC-7P55 MDC-8P08 MDC-8P53 MDC-8P55 The above cable assemblies are highly recommended for general commercial applications. Contact factory for other lengths or colors. For cable assemblies with plug on one end. Plug features contacts with Option 2 plating (Option 1 with additional gold in mating area). NOTE: Total gold thickness in mating area is 30 microinches. No. of Contacts 3 4 5 6 7 8 Cable Length Meter Black Color Cable & Overmold Catalog No. Beige Color Cable & Overmold Catalog No. 1 1 1 1 1 1 MDC-3P06 MDC-4P06 MDC-5P06 MDC-6P06 MDC-7P06 MDC-8P06 MDC-3P09 MDC-4P09 MDC-5P09 MDC-6P09 MDC-7P09 MDC-8P09 The above cable assemblies are recommended where greater contact durability is required. Additional Capabilities • Additional lengths or colors of the above cable assemblies can be produced. Consult factory for custom orders. • Custom-plated contacts can be provided. Consult factory for information. Marketed exclusively through distribution. 2-59 Call Toll Free: 1 (800) 323-9612 FEATURES Circular Mini DIN Plugs Plug Components for Cable Termination ■ Individual components available for cable assembly with overmolding. ■ Plug insulator available with contact positions 3, 4, 5, 6, 7, and 8. ■ Seamless shield case is crimped to cable shield; designed to meet FCC requirements for EMI/RFI suppression. ■ One-piece shield case - no extra ferrules or shields required with Cinch Shield Crimp Tools. ■ Contacts are crimp style and supplied on reels. ■ Contacts available with gold over nickel in several options. ■ Tools available to facilitate reliable, efficient termination. ■ Terminates 24 to 30 AWG wire. ■ UL Recognized - file E170218 (UL1977). Insulation Material: Plug Insulator: 94 V-0 rated nylon Contact Material: Plug: Phosphor bronze MATERIALS Contact Plating: Option 1: Gold flash over nickel underplate overall Option 2: Option 1 plus additional gold in mating area for total thickness of 30μin. Option 3: Option 1 plus additional gold in mating area for total thickness of 50μin. Shield Case Material: Steel Shield Case Plating: Nickel Dimensions 3-Contact 6-Contact 4-Contact 5-Contact 7-Contact 8-Contact Marketed exclusively through distribution. Call Toll Free: 1 (800) 323-9612 2-60 Circular Mini DIN Plugs Plug Components for Cable Termination Ordering Information For each Plug Assembly, the following components are needed: one plug insulator, one shield, and adequate contacts. Component Type Insulator Shield Case Contact Description 3 Position Insulator 4 Position Insulator 5 Position Insulator 6 Position Insulator 7 Position Insulator 8 Position Insulator Metal Shield Case Option 1 Plating Option 1 Plating Option 2 Plating Option 2 Plating Option 3 Plating Quantity 1 1 1 1 1 1 1 300 on Reel 15,000 on Reel 300 on Reel 15,000 on Reel 15,000 on Reel Catalog No. MDX-3PI MDX-4PI MDX-5PI MDX-6PI MDX-7PI MDX-8PI MDX-PZ MDX-P-3A MDX-P-15A MDX-P-3B MDX-P-15B MDX-P-15D Tool Ordering Information The following tools are recommended for Mini Din Cable Plug Assembly. One tool of each type is required. Tool Type Contact Crimp Contact Insertion Insulator Insertion Shield Crimp Description Stripper-Crimper Machine Complete, Includes Dies Contact Crimp Hand Tool Crimps using 300 Contact Reels Combination Contact Insertion and Insulator Insertion Tool Contact Insertion Hand Tool Fixture used with MDT-P28 Insulator Insertion Bench Mounted Tool Insulator Insertion Hand Tool Pneumatic Crimp Tool Catalog No. MDT-P25 MDT-P35 MDT-P41 MDT-P28 MDT-P29 MDT-P34 MDT-P30 MDT-P81 Overview of Assembly Steps • Prepare multi-conductor cable. • Crimp contacts onto individual conductors using tool MDT-P25 or tool MDT-P35. • Insert contact with conductor into insulator using tool MDT-P41 or have insertion tool MDT-P28 with insulator locating vice MDT-P29. • Insert insulator into the shield case using tool MDT-P34 or MDT-P30. • Crimp the shield case onto the cable shield using tool MDT-P81. • Overmold plastic to complete the assembly. Marketed exclusively through distribution. 2-61 Call Toll Free: 1 (800) 323-9612 FEATURES CARDCON ™ Edge Connector Commercial ■ ■ ■ ■ ■ ■ ■ ■ ■ ■ .100" (2.54mm) Density Dip Solder AT and XT versions available. Dip solder tails on .200" (5.08mm) row centers double readout. Bifurcated semi-bellows contacts for added contact reliability. Ideal for applications involving vibration or board irregularities. Contact positions: 12, 15, 18, 20, 22, 25, 28, 30, 31, 36, 37, 40, 43, 44, 49, 50, 52, 60, 70, AT, and XT. Accepts .062" (1.59mm) thick PC boards. Available less mounting ears, or with .128" (3.25mm) mounting holes or 4-40 threaded holes. Meets applicable performance criteria of MIL-C-21097. Tube packaging available. UL Recognized - file E170218 (UL1977) E130965 (UL1863). MECHANICAL ELECTRICAL ENVIRONMENTAL MATERIALS Insulation Material: UL 94V-0 rated glass-filled polyester, black Contact Material: Spring brass Standard Contact Plating: 10μin. selective gold over nickel, 50μin. nickel in contact area, tin on tails XT, AT Plating: 30μin. selective gold over 50μin. nickel in contact area, tin on tails Shock: Per MIL-STD-202E, Method 213, Condition C Operating Temperature: -65°C to +105°C Vibration: Per MIL-STD-202E, Method 204, Condition B Humidity: Per MIL-STD-202, Method 103, Condition B Accessories: Polarizing Key: Two types (order separately): a) for between-contact polarization and b) for in-contact polarization. See page 2-74 for more information. Card Guide Posts: (order separately) Attach to mounting ears and guide PC board into connector. See page 2-74 for more information. Withstanding Voltage: Current Rating: Contact Resistance: Insulation Resistance: 650 VAC RMS (@ sea level) 3 Amps 10 Milliohms maximum 5000 Megohms minimum Individual Contact Insertion and Separation Force: 12oz. maximum with .070" (1.78mm) blade; 1 oz. minimum with .054" (1.37mm) blade Marketed exclusively through distribution. Call Toll Free: 1 (800) 323-9612 2-62 CARDCON ™ Edge Connector Commercial .100" (2.54mm) Density Dip Solder Dimensions No. of Pos./Cont. 12/24 15/30 18/36 18/36+ 31/62IBM 20/40 22/24 25/50 28/56 30/60 31/62 31/62IBM 36/72 37/74 40/80 43/86 44/88 49/98 50/100 52/104 60/120 70/140 A B C D E F in 1.000 1.300 1.600 mm 25.40 33.02 40.64 in 1.100 1.400 1.700 mm 27.94 35.56 43.18 in 1.300 1.600 1.900 mm 33.02 40.64 48.26 in 1.460 1.760 2.060 mm 37.08 44.70 52.32 in 1.775 2.075 2.375 mm 45.09 52.71 60.33 in 2.035 2.335 2.635 mm 51.69 59.31 66.93 5.000 1.800 2.000 2.300 2.600 2.800 2.900 2.900 3.400 3.500 3.800 4.100 4.200 4.700 4.800 5.000 5.800 6.800 127.00 45.72 50.80 58.42 66.04 71.12 73.66 73.66 86.36 88.90 96.52 104.14 106.68 119.38 121.92 127.00 147.32 172.72 5.100 1.900 2.100 2.400 2.700 2.900 3.000 3.000 3.500 3.600 3.900 4.200 4.300 4.800 4.900 5.100 5.900 6.900 129.54 48.26 53.34 60.96 68.58 73.66 76.20 76.20 88.90 91.44 99.06 106.68 109.22 121.92 124.46 129.54 149.86 175.26 5.300 2.100 2.300 2.600 2.900 3.100 3.200 3.200 3.700 3.800 4.100 4.400 4.500 5.000 5.100 5.300 6.100 7.100 134.62 53.34 58.42 66.04 73.66 78.74 81.28 81.28 93.98 96.52 104.14 111.76 114.30 127.00 129.54 134.62 154.94 180.34 5.460 2.260 2.460 2.760 3.060 3.260 3.360 3.360 3.860 3.960 4.260 4.560 4.660 5.160 5.260 5.460 6.260 7.260 138.68 57.40 62.48 70.10 77.72 82.80 85.34 85.34 98.04 100.58 108.20 115.82 118.36 131.06 133.60 138.68 159.00 184.40 5.775 2.575 2.775 3.075 3.375 3.575 3.675 3.675 4.175 4.275 4.575 4.875 4.975 5.475 5.575 5.775 6.575 7.575 146.69 65.41 70.49 78.11 85.73 90.81 93.35 93.35 106.05 108.59 116.21 123.83 126.37 139.07 141.61 146.69 167.01 192.41 6.035 2.835 3.035 3.335 3.635 3.835 3.935 3.935 4.435 4.535 4.835 5.135 5.235 5.735 5.835 6.035 6.835 7.835 153.29 72.01 77.09 84.71 92.33 97.41 99.95 99.95 112.63 115.19 122.81 130.43 132.97 145.67 148.21 153.29 173.61 199.01 Ordering Information No. of Pos./Cont. 12/24 15/30 18/36 18/36+ 31/62 IBM 20/40 22/44 25/50 28/56 30/60 31/62 31/62 IBM 36/72 37/74 40/80 43/86 44/88 49/98 50/100 52/104 60/120 70/140 Less Mounting Ears Catalog No. 50-12SN-12 50-15SN-12 50-18SN-12 .128" (3.25mm) Mounting Holes Catalog No. 50-12SN-11 50-15SN-11 50-18SN-11 4-40 Threaded Holes Catalog No. 50-12SN-13 50-15SN-13 50-18SN-13 50-52SN-AT 50-20SN-12 50-22SN-12 50-25SN-12 50-28SN-12 50-30SN-12 50-31SN-12 50-31SN-XT 50-36SN-12 50-37SN-12 50-40SN-12 50-43SN-12 50-44SN-12 50-49SN-12 50-50SN-12 50-52SN-12 50-60SN-12 50-70SN-12 50-20SN-11 50-22SN-11 50-25SN-11 50-28SN-11 50-30SN-11 50-31SN-11 50-36SN-11 50-37SN-11 50-40SN-11 50-43SN-11 50-44SN-11 50-49SN-11 50-50SN-11 50-52SN-11 50-60SN-11 50-70SN-11 50-20SN-13 50-22SN-13 50-25SN-13 50-28SN-13 50-30SN-13 50-31SN-13 50-36SN-13 50-37SN-13 50-40SN-13 50-43SN-13 50-44SN-13 50-49SN-13 50-50SN-13 50-52SN-13 50-60SN-13 50-70SN-13 Marketed exclusively through distribution. 2-63 Call Toll Free: 1 (800) 323-9612 MATERIALS FEATURES CARDCON ™ Edge Connector Commercial .156" (3.96mm) Density Dip Solder/Solder Eyelet ■ Dip solder tails single readout and double readout on .140" (3.56mm) row centers or .200" (5.08mm) row centers. ■ Solder eyelet, single readout and double readout on .200" (5.08mm) row centers. ■ Available with unique tails for PC board retention; holds the connector firmly on the board during wave soldering operations. ■ Bifurcated semi-bellows contacts for added contact reliability. ■ Ideal for applications involving vibration or board irregularities. ■ Contact positions: 6, 10, 12, 15, 18, 22, 24, and 25. ■ Accepts single- or double-sided .062" (1.59mm) thick PC boards. ■ Available less mounting ears or with .128" (3.25mm) mounting hole. ■ Meets applicable performance criteria of MIL-C-21097. ■ UL Recognized - file E170218 (UL1977) E130965 (UL1863). Insulation Material: UL 94V-0 rated glass-filled polyester, black Contact Material: Spring brass Contact Plating: 10μ" selective gold over 30μ" nickel in contact area, tin on tails Shock: Per MIL-STD-202E, Method 213, Condition C ENVIRONMENTAL Operating Temperature: -65°C to +105°C Vibration: Per MIL-STD-202E, Method 204, Condition B Humidity: Per MIL-STD-202, Method 103, Condition B Accessories: Polarizing Key: Two types (order separately): a) for between-contact polarization and b) for in-contact polarization See page 2-72 for more information. MECHANICAL ELECTRICAL Card Guide Posts: (order separately): Attach to mounting ears and guide PC board into connector See page 2-72 for more information. Withstanding Voltage: Current Rating: Contact Resistance: Insulation Resistance: 1800 VAC RMS (@ sea level) 5 Amps 6 Milliohms maximum 5000 Megohms minimum Individual Contact Insertion and Separation Force: 16 oz. maximum with .070" (1.78mm) blade; 1 oz. minimum with .054" (1.37mm) blade Marketed exclusively through distribution. Call Toll Free: 1 (800) 323-9612 2-64 CARDCON ™ Edge Connector Commercial [.050” (1.27mm) Density .156" (3.96mm) Density Solder Cup/Wire Dip Solder/Solder Eyelet D-Microminiature] 2 Dimensions No. of Pos./Cont. 6/12 10/20 12/24 15/30 18/36 22/44 24/48 25/50 A In 1.785 2.410 2.723 3.191 3.660 4.285 4.598 4.754 mm 45.34 61.21 69.16 81.05 92.96 108.84 116.79 120.75 B in mm 1.531 38.89 2.156 54.76 2.469 62.71 2.937 74.60 3.406 86.51 4.031 102.39 4.344 110.34 4.500 114.30 C in 1.239 1.874 2.177 2.645 3.114 3.739 4.052 4.208 mm 31.47 47.34 55.30 67.18 79.10 94.94 102.92 106.88 D in 1.100 1.724 2.036 2.504 2.972 3.596 3.911 4.067 mm 27.94 43.79 51.71 63.60 75.49 91.34 99.34 103.30 Ordering Information No. of Less Mounting Ears .128 Mounting Hole Pos./Cont. Catalog No. Catalog No. Solder eyelet, single readout 6/6 10/10 12/12 15/15 18/18 22/22 24/24 25/25 50-6SN-8 50-10SN-8 50-12SN-8 50-15SN-8 50-18SN-8 50-22SN-8 50-24SN-8 50-25SN-8 50-6SN-7 50-10SN-7 50-12SN-7 50-15SN-7 50-18SN-7 50-22SN-7 50-24SN-7 50-25SN-7 No. of Less Mounting Ears .128 Mounting Hole Pos./Cont. Catalog No. Catalog No. Dip solder tails, single readout, .156" (3.96mm) long No. of Less Mounting Ears .128 Mounting Hole Pos./Cont. Catalog No. Catalog No. Dip solder tails, double readout, .140" (3.55mm) row spacing, .125" (3.18mm) long 6/6 10/10 12/12 15/15 18/18 22/22 24/24 25/25 6/12 10/20 12/24 15/30 18/36 22/24 24/48 25/50 50-6SN-6 50-10SN-6 50-12SN-6 50-15SN-6 50-18SN-6 50-22SN-6 50-24SN-6 50-25SN-6 50-6SN-5 50-10SN-5 50-12SN-5 50-15SN-5 50-18SN-5 50-22SN-5 20-24SN-5 50-25SN-5 50-12SN-4 50-20SN-4 50-24SN-4 50-30SN-4 50-36SN-4 50-44SN-4 50-48SN-4 50-50SN-4 50-12SN-2 50-20SN-2 50-24SN-2 50-30SN-2 50-36SN-2 50-44SN-2 50-48SN-2 50-50SN-2 Solder eyelet, double readout, .200" (5.08mm) row spacing Dip solder tails, double readout, .200" (5.08mm) row spacing, .156" (3.96mm) long Dip solder tails with unique board retention feature .200" (5.08mm) row spacing, .156" (3.96mm) long 6/12 10/20 12/24 15/30 18/36 22/24 24/28 25/50 6/12 10/20 12/24 15/30 18/36 22/44 24/48 25/50 6/12 10/20 12/24 15/30 18/36 22/44 24/48 25/50 50-12SN-10 50-20SN-10 50-24SN-10 50-30SN-10 50-36SN-10 50-44SN-10 50-48SN-10 50-50SN-10 50-12SN-9 50-20SN-9 50-24SN-9 50-30SN-9 50-36SN-9 50-44SN-9 50-48SN-9 50-50SN-9 50-12SN-3 50-20SN-3 50-24SN-3 50-30SN-3 50-36SN-3 50-44SN-3 50-48SN-3 50-50SN-3 50-12SN-1 50-20SN-1 50-24SN-1 50-30SN-1 50-36SN-1 50-44SN-1 50-48SN-1 50-50SN-1 50-12SN-3R 50-20SN-3R 50-24SN-3R 50-30SN-3R 50-36SN-3R 50-44SN-3R 50-48SN-3R 50-50SN-3R 50-12SN-1R 50-20SN-1R 50-24SN-1R 50-30SN-1R 50-36SN-1R 50-44SN-1R 50-48SN-1R 50-50SN-1R Marketed exclusively through distribution. 2-65 Call Toll Free: 1 (800) 323-9612 .156" (3.96mm) Density Dip Solder/Solder Eyelet Edge Connector High Reliability ■ Dip solder tails, single readout, .156" (3.96mm) long or .234" (5.94mm) long. FEATURES ■ Dip solder tails, double readout, .156" (3.96mm) or .234" (5.94mm) long on .200" (5.08mm) row spacing, or .125" (3.18mm) long on .140" (3.56mm) row spacing. ■ Solder eyelet, single readout and double readout on .200" (5.08mm) row spacing. ■ Patented bifurcated bellows contacts for added contact reliability. ■ Ideal for applications involving vibration or board irregularities. ■ Contact positions: 6, 10, 12, 15, 18, 22, and 25. ■ Available with or without mounting ears. ■ Accepts single- or double-sided .062" (1.59mm) thick PC boards. MATERIALS Shock: Per MIL-STD-202E, Method 202 Operating Temperature: Dip solder: -65°C to +105°C Solder eyelet: -65°C to +125°C Vibration: Per MIL-STD-202E, Method 204, Condition B Humidity: Per MIL-STD-202E, Method 103, Condition B Accessories: Polarizing Key: Two types (order separately): a) for between-contact polarization and b) for in-contact polarization See page 2-74 for more information. Card Guide Posts: (order separately): Attach to mounting ears and guide PC board into connector See page 2-74 for more information. MECHANICAL ELECTRICAL Insulation Material: Diallyl phthalate, green Contact Material: Phosphor bronze Contact Plating: 30μ" selective gold over 50μ" copper in the contact areas, 5μ" gold on tails ENVIRONMENTAL ■ UL Recognized - file E170218 (UL1977) E130965 (UL1863). Withstanding Voltage: Current Rating: Contact Resistance: Insulation Resistance: 1800 VAC RMS (@ sea level) 5 Amps Dip solder: 6 Milliohms Solder eyelet: 10 Milliohms 5000 Megohms minimum Individual Contact Insertion and Separation Force: 16 oz. maximum with .070" (1.78mm) blade; 1 oz. minimum with .054" (1.37mm) blade Marketed exclusively through distribution. Call Toll Free: 1 (800) 323-9612 2-66 Edge Connector High Reliability .156" (3.96mm) Density Dip Solder/Solder Eyelet Single Readout Double Readout With Plain Mounting Holes Dimensions No. of Pos./Cont. 6 10 12 15 18 20 22 25 A in 1.100 1.724 2.036 2.504 2.972 3.286 3.596 4.067 mm 27.94 43.79 51.71 63.60 75.49 83.46 91.34 103.30 B in 1.239 1.864 2.177 2.645 3.114 3.427 3.739 4.208 C mm 31.47 47.35 55.30 67.18 79.10 87.05 94.97 106.88 in 1.531 2.156 2.469 2.937 3.406 3.719 4.031 4.500 mm 38.80 54.76 62.71 74.60 86.51 94.46 102.39 114.30 D in 1.785 2.410 2.723 3.191 3.660 3.973 4.285 4.754 mm 45.34 61.21 69.16 81.05 92.96 100.91 108.84 120.75 Marketed exclusively through distribution. 2-67 Call Toll Free: 1 (800) 323-9612 DURA-CON® Edge Connector High Reliability High Reliability All-Plastic [.050” (1.27mm) Density .156" (3.96mm) Density Dip Solder Cup/Wire Solder/Solder Eyelet D-Microminiature] Ordering Information Single Readout No. of Pos./Cont. 2 6/6 10/10 12/12 15/15 18/18 20/20 22/22 25/25 .128" (3.25mm) Mounting Hole Dip Solder Tails Dip Solder Tails .156" (3.96mm) Long .234" (5.94mm) Long Catalog No. Catalog No. 50-6H-10 50-6S-10 50-10H-10 50-10S-10 50-12R-10 50-12S-10 50-15H-10 50-15S-10 50-18H-10 50-18S-10 50-20C-10 50-20S-10 50-22H-10 50-22S-10 50-25H-10 50-25S-10 Solder Eyelet Catalog No. 50-6H-20 50-10H-20 50-12H-20 50-15H-20 50-18H-20 50-20A-20 50-22H-20 50-25H-20 Double Readout .128" (3.25mm) Mounting Hole Less Mounting Ears Solder Eyelet Dip Solder Tails Dip Solder Tails Dip Solder Tails Dip Solder Tails No. of .234" (5.94mm) Long .156" (3.96mm) Long .125" (3.18mm) Long .125" (3.18mm) Long Pos./Cont. .200" (5.08mm) Between .200" (5.08mm) Between .140" (3.56mm) Between .140" (3.56mm) Between Row Spacing Row Spacing Row Spacing Row Spacing Catalog No. Catalog No. Catalog No. Catalog No. Catalog No. 6/12 50-12H-30 50-12S-20 50-12H-10 50-12H-30-2 50-12H-30-1 10/20 50-20H-30 50-20S-20 50-20H-10 50-20H-30-2 50-20H-30-1 12/24 50-24H-30 50-24S-20 50-24H-10 50-24H-30-2 50-24H-30-1 15/30 50-30H-30 50-30S-20 50-30H-10 50-30H-30-2 50-30H-30-1 18/36 50-36H-30 50-36S-20 50-36H-10 50-36H-30-2 50-36H-30-1 20/40 50-40A-30 50-40S-20 50-40B-10 22/44 50-44H-30 50-44S-20 50-44H-10 50-44H-30-2 50-44H-30-1 25/50 50-50H-30 50-50S-20 50-50H-10 50-50H-30-2 50-50H-30-1 Call Toll Free: 1 (800) 323-9612 2-68 .156" (3.96mm) Density Card Extender Edge Connector High Reliability FEATURES ■ Solder terminations, double readout. ■ Bifurcated bellows type contacts. ■ Contact positions: 6, 10, 12, 15, 18, 22, and 25. MECHANICAL ELECTRICAL ENVIRONMENTAL MATERIALS ■ Accepts .062" (1.59mm) thick double-sided PC boards. Insulation Material: Diallyl phthalate, green Contact Material: Beryllium copper Contact Plating: 30μin. select gold over 50μin. nickel in the contact areas, 10μin. gold tails Shock: Per MIL-STD-202E, Method 213, Condition C Operating Temperature: -65°C to +125°C Vibration: Per MIL-STD-202E, Method 204, Condition B Humidity: Per MIL-STD-202E, Method 103, Condition B Withstanding Voltage: Current Rating: Contact Resistance: Insulation Resistance: 830 VAC RMS (@ sea level) 5 Amps 5 Milliohms maximum 5000 Megohms minimum Individual Contact Insertion and Separation Force: 16 oz. maximum with .070" (1.78mm) blade; 1 oz. minimum with .054" (1.37mm) blade Marketed exclusively through distribution. Call Toll Free: 1 (800) 323-9612 2-70 Edge Connector High Reliability .156" (3.96mm) Density Card Extender Dimensions Dimensions No. of Pos./Cont. 6/12 10/20 12/24 15/30 18/36 22/44 25/50 A in 1.100 1.724 2.036 2.504 2.972 3.596 4.067 B mm 27.94 43.79 51.71 63.60 75.48 91.33 103.30 in 1.239 1.864 2.177 2.645 3.114 3.739 4.208 C mm 31.47 47.34 55.29 67.18 79.09 94.97 106.88 in 1.531 2.156 2.469 2.937 3.406 4.031 4.500 mm 38.88 54.76 62.71 74.59 86.51 102.38 114.30 D in 1.785 2.410 2.723 3.191 3.660 4.285 4.754 mm 45.33 61.21 69.16 81.05 92.96 108.83 120.75 Ordering Information No. of Pos./Cont. 6/12 10/20 12/24 15/30 18/36 22/44 25/50 Catalog No. 50-12S-30 50-20S-30 50-24S-30 50-30S-30 50-36S-30 50-44S-30 50-50S-30 Marketed exclusively through distribution. 2-71 Call Toll Free: 1 (800) 323-9612 Card Guides Polarizing Keys Edge Connector Accessories Card Guides Card guide for .100" (2.54mm) and .156" (3.96mm) density edge connectors. Accepts .062" (1.59mm) thick PC boards. Card guides attach to mounting ears and guide printed circuit board into connector. Order separately. Material: Polypropylene Part No. 50-GP-1 (Green) Part No. 50-GP-1B (Black) Polarizing Keys Style A Description Between-contact In-contact type Between-contact Between-contact Between-contact In-contact type Style B type type type type Connector Family .156" .156" .156" .156" .100" .156" Style C Material Cellulose acetate Thermoset plastic Glass epoxy Glass epoxy Glass-filled nylon Thermoplastic Style D Style B B A D C B Catalog No. 50-PK 50-PK1 50-PK2 50-PK2M 50-PK3 50-PK4 Marketed exclusively through distribution. Call Toll Free: 1 (800) 323-9612 2-72 Socket Commercial Miscellaneous Plug Buttons Plug Buttons Nickel-plated steel. Spring tension prongs. 41V provides ventilation wherever required. Call Toll Free: 1 (800) 323-9612 Dimensions For Hole Diameter in mm .250 6.35 .375 9.53 .500 12.70 .625 15.88 .750 19.05 .875 22.23 1.000 25.40 1.250 31.75 1.000 25.40 2-74 Cup Diameter in mm .406 10.32 .500 12.70 .656 16.67 .797 20.24 .938 23.81 1.062 26.99 1.156 29.37 1.438 36.51 1.156 29.37 Catalog No. 41A 41B 41C 41D 41E 41F 41G 41H 41V Press-Fit BNC Coaxial Connector Board Mount Receptacle for 75 Ω Applications FEATURES ■ Solderless, Press-Fit Installation. ■ Strong, One-Piece Cast Body. ■ Standard BNC Interface. ■ 75Ω Impedance. MATERIALS ■ Meets Lucent Technologies (AT&T) Requirements. Body: One-piece diecast zinc per QQ-Z-363 Plating: Nickel, 150μin. min. per QQ-N-290 over copper, 200μin. min. per MIL-C-14550 Center Contact: Beryllium copper Plating: Gold, 30μin. minimum over nickel, 50μin. minimum Insulator: Teflon TFE per ASTM D1710 Compliant version, Pt. No. 299 99 00 134 is also available. For more information please contact us at 1-800-323-9612 Unique patented press-fit connector design allows for multiple insertions into a backplane without loss of mechanical retention or electrical ELECTRICAL Impedance: Frequency Range: RF Leakage: Insertion Loss: VSWR: performance. 75Ω 0 to 4 GHz The design requirements for nominal PC board > -55 dB mounting holes and thickness are as follows: .2dB maximum @ 2 GHz Insertion Forces: 1.024 Working Voltage: < 500 VAC RMS @ sea level Insulation Resistance: > 5000 MOhms @ 500 VDC .093 Board Thickness: 200 lb. max. .250 Board Thickness: 500 lb. max. MECHANICAL Withdraw Forces: .093 Board Thickness: 100 lb. max. .250 Board Thickness: 200 lb. max. Connector Insertion Force: 100 lb.* Center Contact Insertion Force: < 2.0 lb.* Center Contact Removal Force: > 2.0 oz.* *Requirements are for two connector insertions into the same PC board The Cinch Press-Fit BNC surpasses these mounting holes. PC board thickness can range from .093" to .300" thick. connector to be inserted, removed, rotated 180o, PC board hole requirements are as follows: Ground Legs: .059" Nom. Center Contact: .040" Nom. Call Toll Free: 1 (800) 323-9612 requirements with a unique, non-symmetrical ground leg design. This design allows the and reinserted into the same location on the board without loss of mechanical or electrical performance. 2-76 Press-Fit BNC Coaxial Connector Board Mount Receptacle for 75 Ω Applications Production Insertion Tool Design Press-Fit BNC Connector Dimensions Ordering Information Catalog Number: Standard Package: BNC-1-PF Anti-Static Tube, 48 Connectors Per Tube 2-77 Call Toll Free: 1 (800) 323-9612 CYLINDRICAL C48 Series/MIL-C-26500 Accessories & Application Tooling Boeing: BACC45 / BACC63 Series
3/4W-140 价格&库存
很抱歉,暂时无法提供与“3/4W-140”相匹配的价格&库存,您可以联系我们找货
3/4W-140
  • 10+4.2827110+0.55512
