TMPC1004HV-R15YG-D
TMPC1004HV-R15YG-D
    TAI-TECH(台庆)
    SMD,11x10mm
    功率电感 150nH ±30% IND_11X10MM_SM 4.00mm 11.00 x 10.00mm 0.6mΩ 43A
TMPC1004HV-R15YG-D 数据手册
TAI-TECH P1 SMD Power Inductor TMPC1004HV-Series(G)-D 1. Features 1. Carbonyl Powder. 2. Compact design. Halogen 3. High current,low DCR,high efficiency. 4. Very low acoustic noise and very low leakage flux noise. Halogen-free 5. High reliability. 6. 100% Lead(Pb)-Free and RoHS compliant. 7. High reliability -Reliability test complied to AEC-Q200. 8. Operating temperature -55~+125℃(Including self - temperature rise) 9. 2. Applications Note PC power system,incl. IMVP-6 DC/DC converter . 3. Dimensions C  100 2019 D E B A leadframe A Recommend PC Board Pattern R47 2019 L E H B D C non-leadframe G Series A(mm) B(mm) C(mm) D(mm) E(mm) L(mm) TMPC1004HV 11.0±0.5 10.0±0.3 3.8±0.2 2.3±0.3 3.0±0.3 13.6 5.4 3.5 Note: 1. The above PCB layout reference only. 2. Recommend solder paste thickness at 0.15mm and above. 4. Part Numbering TMPC 1004 HV A B C A: Series B: Dimension C: Type D: Inductance E: Inductance Tolerance F: Code - 100 MG D E - D F BxC Carbonyl Powder.vehicle. 100=10.0uH K=±10%,L=±15%,M=±20%,N=±25%,Y=±30% Marking: BlackR47 and 2019(20YY,19 WW,follow production date). G(mm) H(mm) TAI-TECH P2 5. Specification Part Number Inductance L0 (uH)±20% I rms ( A ) I sat ( A ) DCR(mΩ) Typ.@25℃ DCR(mΩ) Max.@25℃ Type TMPC1004HV-R15YG-D 0.15±30% 43.0 75.0 0.50 0.60 non-leadframe TMPC1004HV-R22MG-D 0.22 35.0 60.0 0.80 1.00 non-leadframe TMPC1004HV-R33MG-D 0.33 31.0 60.0 1.00 1.20 non-leadframe TMPC1004HV-R36MG-D 0.36 31.0 60.0 1.05 1.20 non-leadframe TMPC1004HV-R47MG-D 0.47 28.0 43.0 1.30 1.50 non-leadframe TMPC1004HV-R56MG-D 0.56 25.0 40.0 1.60 1.80 non-leadframe TMPC1004HV-R68MG-D 0.68 22.0 39.0 2.40 2.70 non-leadframe TMPC1004HV-1R0MG-D 1.00 18.0 36.0 3.00 3.30 non-leadframe TMPC1004HV-1R5MG-D 1.50 16.0 33.0 4.00 4.60 non-leadframe TMPC1004HV-2R2MG-D 2.20 12.0 27.0 6.50 7.00 leadframe TMPC1004HV-3R3MG-D 3.30 11.0 20.0 10.8 11.8 leadframe TMPC1004HV-4R7MG-D 4.70 10.0 17.0 15.0 15.5 leadframe TMPC1004HV-5R6MG-D 5.60 9.00 14.0 17.0 19.3 Leadframe TMPC1004HV-6R8MG-D 6.80 8.50 13.5 17.5 23.3 leadframe TMPC1004HV-8R2MG-D 8.20 8.00 12.5 20.0 22.5 leadframe TMPC1004HV-100MG-D 10.0 7.50 12.0 27.0 30.0 leadframe TMPC1004HV-150MG-D 15.0 6.25 10.0 40.0 45.0 leadframe TMPC1004HV-220MG-D 22.0 5.00 7.00 64.0 74.0 leadframe TMPC1004HV-330MG-D 33.0 3.50 5.00 92.0 112 leadframe TMPC1004HV-470MG-D 47.0 3.00 4.50 145 167 leadframe Note: 1. Test frequency : Ls : 100KHz /1.0V. 2. All test data referenced to 25℃ ambient. 3. Testing Instrument(or equ) : L: HP4284A,CH11025,CH3302,CH1320,CH1320S LCR METER / Rdc:CH16502,Agilent33420A MICRO OHMMETER. 4. Heat Rated Current (Irms) will cause the coil temperature rise approximately ΔT of 40℃ 5. Saturation Current (Isat) will cause L0 to drop approximately 30%. 6. The part temperature (ambient + temp rise) should not exceed 125℃under worst case operating conditions.Circuit design,component,PCB trace size and thickness,airflow and other cooling provisions all affect the part temperature. Part temperature should be verified in the end application. 7. Special inquiries besides the above common used types can be met on your requirement. TAI-TECH 6. Typical Performance Curves P3 TAI-TECH P4
TMPC1004HV-R15YG-D
物料型号: TMPC1004HV系列
器件简介: - 采用碳基粉末 - 紧凑设计 - 高电流、低直流电阻、高效率 - 极低的声学噪声和漏磁噪声 - 无卤素 - 符合RoHS标准 - 高可靠性,符合AEC-Q200可靠性测试 - 工作温度范围为-55℃至+125℃
引脚分配: 根据表格,有两种引脚分配,一种是基于铅框架的,另一种不是。
参数特性: - 提供了不同型号的电感值、额定电流、饱和电流、典型和最大直流电阻等参数。
功能详解: - 适用于PC电源系统,包括IMVP-6 DC/DC转换器。
应用信息: 适用于PC电源系统,包括IMVP-6 DC/DC转换器。
封装信息: 提供了详细的尺寸数据和推荐PCB布局参考。
TMPC1004HV-R15YG-D 价格&库存
很抱歉,暂时无法提供与“TMPC1004HV-R15YG-D”相匹配的价格&库存,您可以联系我们找货
