RAVF Series
Stackpole Electronics, Inc.
Resistive Product Solutions
Convex Termination Chip Resistor Array
Features:
Thick film resistor element
Multiple circuit types available
Ideal SMD substitute for leaded networks
RoHS compliant and halogen free
Auto-placement capability
Square corner construction standard
Zero-ohm jumper available
RAVF 324D is standard with scalloped corner
Styles 102D, 104D and 164D are qualified to AEC-Q200
Electrical Specifications
Type / Code,
# of Elements,
Circuit Type
Power Rating (W)
(per element)
@ 70ºC
0.031
RAVF052D
Maximum
Working Voltage
(V)(1)
Maximum
Overload
Voltage (V)
12.5
25
25
50
Jumper: 0.5A
0.063
RAVF102D
TCR (ppm/ºC)
Ohmic Range (Ω) and Tolerance
± 500
± 300
± 200
± 400
± 200
Jumper: 1A
0.063
RAVF104D
Jumper: 1A
0.063
Jumper: 1A
25
50
50
100
0.063
Jumper: 1A
50
100
0.063
25
50
Jumper: 1A
RAVF324D
0.125
200
RAVF328N
0.063
25
RAVF328R
0.063
25
(1) Lesser of √ P*R or maximum working voltage.
400
50
50
RAVF162D
RAVF164D
RAVF168D
± 400
± 200
± 200
± 400
± 200
± 250
± 200
± 200
± 200
± 200
1%
2%, 5%
3 - 9.1
10 - 910
1 K - 1M
0.05 max
1 - 9.1
10 - 1M
0.025 max
0.05 max
1 - 9.1
10 - 1M
0.025 max
10 - 1M
10 - 1M
0.025 max
10 - 1M
22 - 1M
0.05 max
1 - 1M
0.05 max
1. - 9.1
10 - 1M
0.05 max
1 - 1M
0.05 max
10 - 1M
22 - 1M
22 - 1M
Schematics
Isolated Circuit - 2D
Isolated Circuit - 4D
Isolated Circuit - 8D
Rev Date: 11/18/2020
This specification may be changed at any time without prior notice
Please confirm technical specifications before you order and/or use.
1
Bussed Circuit - N
Bussed Circuit - R
www.seielect.com
marketing@seielect.com
RAVF Series
Terminations
RAVF - 2 Resistors / 4 Terminations (D)
Type / Code
# of Elements
Circuit Type
RAVF052D
RAVF102D
RAVF104D
RAVF162D
RAVF164D
RAVF168D
RAVF324D
RAVF328N
RAVF328R
L
Body Length
0.031
0.80
0.039
1.00
0.079
2.00
0.063
1.60
0.126
3.20
0.157
4.00
0.201
5.10
0.126
3.20
0.126
3.20
0.004
0.10
0.004
0.10
0.008
0.20
0.006
0.15
0.008
0.20
0.008
0.20
0.009
0.22
0.006
0.15
0.006
0.15
W
Body Width
0.024
0.60
0.039
1.00
0.039
1.00
0.063
1.60
0.063
1.60
0.063
1.60
0.122
3.10
0.063
1.60
0.063
1.60
0.004
0.10
0.004
0.10
0.006
0.15
0.006
0.15
0.008
0.20
0.006
0.15
0.008
0.20
0.006
0.15
0.006
0.15
RAVF - 4 Resistors / 8 Terminations (D)
H
Body Height
0.012
0.30
0.014
0.35
0.014
0.35
0.020
0.50
0.020
0.50
0.016
0.40
0.022
0.55
0.022
0.55
0.022
0.55
0.002
0.05
0.004
0.10
0.006
0.15
0.006
0.15
0.004
0.10
0.004
0.10
0.006
0.15
0.004
0.10
0.004
0.10
P
Element
Spacing
0.020 ± 0.006
0.50 ± 0.15
0.026 ± 0.039
0.67 ± 1.00
0.020 ± 0.006
0.50 ± 0.15
0.031 ± 0.002
0.80 ± 0.05
0.031 ± 0.008
0.80 ± 0.20
0.020 ± 0.006
0.50 ± 0.15
0.051 ± 0.008
1.30 ± 0.20
0.025 ± 0.002
0.64 ± 0.05
0.025 ± 0.002
0.64 ± 0.05
RAVF - 8 Resistors / 10 Terminations (N/R)
Q
Termination
Width
0.012 ± 0.004
0.30 ± 0.10
0.020 ± 0.006
0.50 ± 0.15
0.010 ± 0.004
0.25 ± 0.10
0.031 ± 0.008
0.80 ± 0.20
0.013 ± 0.006
0.34 ± 0.15
0.013 ± 0.006
0.34 ± 0.15
R
Termination
Width
0.014 ± 0.004
0.35 ± 0.10
0.013 ± 0.004
0.34 ± 0.10
0.017 ± 0.004
0.43 ± 0.10
0.024 ± 0.006
0.60 ± 0.15
0.024 ± 0.006
0.61 ± 0.15
0.015 ± 0.004
0.38 ± 0.10
0.031 ± 0.008
0.80 ± 0.20
0.019 ± 0.006
0.49 ± 0.15
0.019 ± 0.006
0.49 ± 0.15
D
Bottom
Termination
0.006 ± 0.002
0.15 ± 0.05
0.010 ± 0.039
0.25 ± 1.00
0.008 +0.006/-0.004
0.20 +0.15/-0.10
0.012 ± 0.006
0.30 ± 0.15
0.012 ± 0.008
0.30 ± 0.20
0.012 ± 0.008
0.30 ± 0.20
0.022 ± 0.012
0.55 ± 0.30
0.010 ± 0.006
0.25 ± 0.15
0.010 ± 0.006
0.25 ± 0.15
A
Top
Termination
0.006 ± 0.004
0.15 ± 0.10
0.006 ± 0.004
0.15 ± 0.10
0.008 ± 0.004
0.20 ± 0.10
0.012 ± 0.006
0.30 ± 0.15
0.012 ± 0.008
0.30 ± 0.20
0.012 ± 0.008
0.30 ± 0.20
0.020 ± 0.008
0.50 ± 0.20
0.012 ± 0.008
0.30 ± 0.20
0.012 ± 0.008
0.30 ± 0.20
Unit
Inches
mm
Inches
mm
Inches
mm
Inches
mm
Inches
mm
Inches
mm
Inches
mm
Inches
mm
Inches
mm
Performance Characteristics
Test
Test Result (JIS C 5202)
Load Life in Moisture
Temperature cycle
Load Life
Resistance to Soldering heat
Terminal Adhesion
Short Time Overload
Operating temperature range is -55°C to +155°C, except for RAVF328N and RAVF328R
Operating temperature range for RAVF328N and RAVF328R is -55°C to +125°C
±3%
±1%
±3%
±1%
±1%
±2%
Power Derating Curve:
Percent Rated Power (%)
100
-55ºC
70ºC
RAVF052D, RAVF102D, RAVF104D
RAVF162D, RAVF164D, RAVF168D
RAVF324D
80
60
RAVF328N
RAVF328R
40
125ºC
60
80
100
120
155ºC
140
160
180
Ambient Temperature (ºC)
2
www.seielect.com
RAVF Series
Recommended Pad Layout
Type / Code
RAVF052D
RAVF102D
RAVF162D
Type / Code
RAVF104D
Type / Code
RAVF164D
RAVF324D
Type / Code
RAVF168D
A
B
P
Q1
Q2
Unit
0.012
0.30
0.020
0.50
0.039
1.00
0.035
0.90
0.079
2.00
0.102
2.60
0.020
0.50
0.026
0.67
0.031
0.80
0.012
0.30
0.013
0.33
0.016
0.40
0.008
0.20
0.013
0.34
0.016
0.40
Inches
mm
Inches
mm
Inches
mm
A
0.020
0.50
B
0.079
2.00
P
0.020
0.50
Q
0.012
0.30
Q1
0.011
0.28
Q2
0.009
0.22
Unit
Inches
mm
A
B
P
Q1
Q2
Unit
0.039
1.00
0.079
2.00
0.102
2.60
0.187
4.75
0.031
0.80
0.051
1.30
0.016
0.40
0.035
0.90
0.016
0.40
0.015
0.38
Inches
mm
Inches
mm
A
0.039
1.00
B
0.110
2.80
3
P
0.020
0.50
Q1
0.012
0.30
Unit
Inches
mm
www.seielect.com
RAVF Series
Recommended Pad Layout (cont.)
Type / Code
RAVF328R
A
0.031
0.80
B
0.122
3.10
P
0.025
0.64
Q1
0.013
0.34
Q2
0.018
0.45
Unit
Inches
mm
Recommended Solder Profile
This information is intended as a reference for solder profiles for Stackpole resistive components. These profiles should
be compatible with most soldering processes. These are only recommendations. Actual numbers will depend on board
density, geometry, packages used, etc., especially those cells labeled with “*”.
100% Matte Tin / RoHS Compliant Terminations
Soldering iron recommended temperatures: 330°C to 350°C with minimum duration.
Maximum number of reflow cycles: 3.
Wave Soldering
Description
Maximum
Recommended
Preheat Time
80 seconds
70 seconds
Temperature Diff.
140°C
120°C
Solder Temp.
260°C
250°C
Dwell Time at Max.
10 seconds
5 seconds
Ramp DN (°C/sec)
N/A
N/A
Temperature Diff. = Defference between final preheat stage and soldering stage.
Minimum
60 seconds
100°C
240°C
N/A
Convection IR Reflow
Description
Maximum
Recommended
Minimum
Ramp Up (°C/sec)
Dwell Time > 217°C
Solder Temp.
Dwell Time at Max.
Ramp DN (°C/sec)
3°C/sec
150 seconds
260°C
30 seconds
6°C/sec
2°C/sec
90 seconds
245°C
15 seconds
3°C/sec
60 seconds
10 seconds
4
www.seielect.com
RAVF Series
Recommended Lead Free Resistor Reflow Profile
RoHS Compliance
Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various
regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances”
(RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our
compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as
amended by Directive (EU) 2015/863/EU as regards the list of restricted substances.
RoHS Compliance Status
Standard
Product
Series
Description
Package /
Termination
Type
Thick Film Surface Mount Chip Resistor
Array Convex Terminations
Note (1): RoHS Compliant by means of exemption 7c-I.
RAVF
SMD
Standard
Series
RoHS
Compliant
Lead-Free Termination
Composition
Lead-Free
Mfg. Effective Date
(Std Product Series)
YES(1)
100% Matte Sn over Ni
Jan-04 (Japan)
Jul-04 (Taiwan)
Lead-Free
Effective Date
Code
(YY/WW)
04/01
04/27
“Conflict Metals” Commitment
We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the eastern
Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the electronics industry
is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and products we supply do
not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of Dodd-Frank Act regarding
Conflict Minerals.
Compliance to “REACH”
We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free and
compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of
Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List.
5
www.seielect.com
RAVF Series
Environmental Policy
It is the policy of Stackpole Electronics, Inc. (SEI) to protect the environment in all localities in which we operate. We continually strive
to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our environment
and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms of pollution.
How to Order
1
2
3
4
5
6
7
8
9
10
11
12
13
14
R
A
V
F
1
6
4
D
J
T
1
K
Product Series
Code Description
Convex
RAVF
Termination
Size
Code
W
052D 0.031
102D 0.063
104D 0.063
162D 0.063
164D 0.063
168D 0.063
324D 0.125
328N 0.063
328R 0.063
Tolerance(1)
Code Tol Value
F
1%
E24
G
2%
J
5%
Z jumper
Code
T
Packaging
Size
052D, 102D, 104D
162D, 164D, 168D
Tape and Reel
328N, 328R
324D
Description
Resistance Value
Quantity
10000
5000
4000
Note (1): 1% tolerance is available in E24 values only.
E96 values are generally not available. Contact Stackpole for details.
Four characters with the
multiplier used as the
decimal holder.
10 ohm = 10R0
10.2 Kohm = 10K2
1 Mohm = 1M00
Zero ohm jumper = 0R00
D = Isolated
N = Bussed
R = Bussed
6
www.seielect.com
很抱歉,暂时无法提供与“RAVF164DFT68K0”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 50000+0.1347550000+0.01742
