16220-1
16220-1
    EATON(伊顿)
    接线端子
16220-1 数据手册
Bussmann® Power Distribution & Terminal Blocks PDB Power Distribution Blocks 600 Volt AC or DC Catalog Symbol: Power Distribution Blocks Voltage Rating: 600 Volts AC or DC maximum Agency Information: UL Recognized, Guide XCFR2, File E221592 CSA Certified, Class 6228-01, File 15364 Example: A 3-pole, 16023 series is 16023-3. The line side of the device has (1) conductor opening per pole that accepts 350kcmil - #6 CU/AL. The load side of the device has (6) conductor openings per pole that each accepts #4 - #14 CU or #4 - #12 AL. Power Distribution Blocks (600V) Catalog Data 2-Pole -2 -2 -2 -2 -2 -2 -2 -2 3-Pole -3 -3 -3 -3 -3 -3 -3 -3 4-Pole -4 -4 NA NA NA NA NA NA 16335 -1 -2 -3 NA 500kcmil - #6CU-AL 16370 16371 -1 -1 -2 -2 -3 -3 NA NA 350kcmil - #6CU-AL 350kcmil - #6CU-AL 16372 16373 -1 -1 -2 -2 -3 -3 NA NA 350kcmil - #6CU-AL 350kcmil - #6CU-AL 16375 16376 -1 -1 -2 -2 -3 -3 NA NA 600kcmil - #2CU-AL 600kcmil - #2CU-AL 16377 16528 -1 -1 -2 -2 -3 -3 NA NA (2)300kcmil - #4CU-AL (2) 600kcmil - #2CU-AL 16530 16541 -1 –1 -2 -2 -3 –3 NA NA (2) 500kcmil - #6CU-AL 500kcmil - #6CU-AL Load (6) #4 - #14CU, #4 - #8AL (6) #4 - #14CU, #4 - #12AL (4) #4 - #14CU, #4 - #8AL (6) #4 - #14CU, #4 - #8AL (6) #4 - #14CU, #4 - #12AL (6) #4 - #14CU, #4 - #8AL (6 )#2 - #14CU, #2 - #12AL (3) #2 - #14CU, #2 - #8AL (2) 1/0 - #14CU, 1/0 - #8AL (3) #2 - #14 CU, #2 - #8AL (2) 1/0 - #14CU, 1/0 - #8AL (12) #4 - #14CU, #4 - #12AL (6) #2 - #14CU, #2 - #8AL (3) 1/0 - #14CU, 1/0 - #8AL (21) #10 - #14CU, #10AL (3) 1/0 - #14CU-AL (14) #10 - #14CU, #10AL (12) #4 - #14CU, #4 - #12AL (6) #2 - #14CU, #2 -8AL (3) 1/0 - #14CU, 1/0 - #8AL (12) #4 - #14CU, #4 - #12AL (4) 3/0 - #6CU-AL (4) #4 - #14CU-AL (12) #4 - #14CU-AL (21) #6 - #14CU-AL Connector Material and Ampacity AL-175A AL-310A AL-175A AL-175A AL-310A AL-350A AL-380A AL-310A CSA 1-Pole NA NA -1 -1 -1 -1 -1 -1 Connection Line 2/0 - #14CU, 2/0 - #8AL 350kcmil - #6CU-AL 2/0 - #14CU, 2/0 - #8AL 2/0 - #14CU, 2/0 - #8AL 350kcmil - #6CU-AL (2) 2/0 - #14CU, 2/0 - #8AL 500kcmil - #6CU-AL 350kcmil - #6CU-AL UL Catalog Number 16021 16023 16220 16321 16323 16325 16330 16332 • • • • • • • • • • • • • • • • AL-380A • • AL-310A AL-310A • • • • AL-310A AL-310A • • • • AL-420A AL-420A • • • • AL-570A AL-840A • • • • AL-760A AL-380A • • • • How To Order: Catalog Number + # of Poles Example: 16021-3 (complete part number) Dimensional information on page 3 Optional covers: 3-12-04 SB04093 160 162 163 165 Series: Series: Series: Series: CPB160 - (pole) CPB162 - (pole) CPDB - (pole) CPDB165 (1 for each pole) CE logo denotes compliance with European Union Low Voltage Directive (50-1000Vac, 75-1500Vdc). Refer to Data Sheet: 8002 or contact Bussmann Application Engineering at 636-527-1270 for more information. Form No. PDB Page 1 of 3 Data Sheet: 1117 Bussmann® Power Distribution & Terminal Blocks PDB Splicer Terminal Blocks 600 Volt AC or DC Catalog Symbol: Splicer Terminal Blocks Voltage Rating: 600Vac or DC maximum Agency Information: UL Recognized, Guide XCFR2, File E221592 CSA Certified, Class 6228-01, File 15364 Picture shown: 3-Pole - 1 opening on line per phase 1 opening on load per phase Connection 1-Pole 2-Pole 3-Pole 4-Pole Line 16000 16003 16005 16200 16201 16204 16301 16303 16306 16500 16504 NA NA NA -1 -1 -1 -1 -1 -1 -1 -1 -2 -2 -2 -2 -2 -2 -2 -2 -2 -2 -2 -3 -3 -3 -3 -3 -3 -3 -3 -3 -3 -3 -4 -4 -4 NA NA NA NA NA NA NA NA 2/0 - #8CU-AL 250kcmil - #6CU Only 350kcmil - #6CU-AL #2 - #14CU, #2 - #8AL 1/0 - #14CU Only 2/0 - #8CU-AL 250kcmil - #6CU Only 350kcmil - #6CU-AL (1)500kcmil - #6CU-AL (2) 350kcmil - #4CU-AL (2) 500kcmil - #6CU-AL Load Connector Material and Ampacity CSA Catalog Number U.R. Power Distribution Blocks (600V) Catalog Data 2/0 - #8CU-AL 250kcmil - #6CU Only 350kcmil - #6CU-AL #2 - #14CU, #2 - #8AL 1/0 - #14CU Only 2/0 - #8CU-AL 250kcmil - #6CU Only 350kcmil - #6CU-AL (1)500kcmil - #6CU-AL (2) 350kcmil - #4CU-AL (2) 500kcmil - #6CU-AL AL-175A CU-255A AL-310A AL-115A CU-150A AL-175A CU-255A AL-310A AL-380A AL-620A AL-760A • • • • • • • • • • • — — — — — — • • • • • Dimensional information on page 3 Optional covers: 3-12-04 SB04093 160 162 163 165 Series: Series: Series: Series: CPB160 - (pole) CPB162 - (pole) CPDB - (pole) CPDB165 (1 for each pole) CE logo denotes compliance with European Union Low Voltage Directive (50-1000Vac, 75-1500Vdc). Refer to Data Sheet: 8002 or contact Bussmann Application Engineering at 636-527-1270 for more information. Form No. PDB Page 2 of 3 Data Sheet: 1117 Bussmann® Power Distribution & Terminal Blocks PDB Connector-Stud and Stud-Stud Blocks 600 Volt AC or DC Catalog Symbol: Connector–Stud Block Voltage Rating: 600Vac or DC maximum Agency Information: UL Recognized, Guide XCFR2, File E221592 CSA Certified, Class 6228-01, File 15364 Series 162, 163, and 165 Dimensional Data (Available 1, 2, and 3 pole) H J Series 160 (Available 2, 3, and 4 pole) Dimensional Data LINE SIDE D 2.12" LINE SIDE C 0.5" 0.69" F E E 4.12" (2-Pole) 5.37" (3-Pole) 6.62" (4-Pole) A B 3.62" (2-Pole) 4.87" (3-Pole) 6.12" (4-Pole) .25" L C'Bore G K Dia. 2.8" 1" 2.0" 1.4" LOAD SIDE 0.38" 0.27" Dia. (2 Holes) Slot 0.22" x 0.38". (4 Places) Dimensions for Series 162, 163, and 165 LOAD SIDE 160 Series Bases have mounting holes outside the barriers. Other bases (162 through 165) have mounting holes within barriers–see dimensional drawings. Cat. No. A B 162 163 165 2.88 4.0 5.5 2.25 3.38 4.75 C1 C2 1.07 1.88 1.98 3.60 3.10” 5.79” C3 D E 2.70 1.75 5.21 3.32 8.48” 2.93” 0.81 1.62 2.69 F G H J K L 0.53 0.31 0.84 0.31 0.20 0.41 0.99 0.31 0.87 0.35 Slot .20” wide x .41” long Slot .42” wide x .62” long 1.55” 0.38 1.19” .44” Slot .20” wide x .33” long Slot .41” wide x .53” long Connection Line Load Connector Material and Ampacity CSA Catalog Number UL Connector-Stud Blocks (600V) Catalog Data 1-Pole 2-Pole 3-Pole 16280 -1 -2 -3 2/0 - #14CU-AL ⁄Ω¢ - 20 ≈ ‹Ω¢ Stud AL-175A • — 16281 -1 -2 -3 2/0 - #14CU-AL ⁄Ω¢ - 20 Tapped hole AL-175A • — 16378 -1 -2 -3 500kcmil - #6CU-AL (2) ⁄Ω¢ - 20 ≈ 1 Stud AL-380A • • 16383 -1 -2 -3 500kcmil - #6CU-AL (1) ‹Ω• - 16 ≈ 1 Stud AL-380A • • 16582 -1 -2 -3 (2) 500kcmil - #6CU-AL (2) ‹Ω• - 16 ≈ 1fiΩ• Stud AL-760A • • 16290 -1 -2 -3 ⁄Ω¢ - 20 ≈ ‹Ω¢ Stud ⁄Ω¢ - 20 ≈ ‹Ω¢ Stud CU-150A • — 16390 -1 -2 -3 ‹Ω• - 16 ≈ 1⁄Ω• Stud ‹Ω• - 16 ≈ 1⁄Ω• Stud CU-250A • • 16394 -1 -2 -3 ⁄Ω™ - 13 ≈ 1⁄Ω¡§ Stud ⁄Ω™ - 13 ≈ 1⁄Ω¡§ Stud CU-400A • • 16395 -1 -2 -3 ‹Ω• - 16 ≈ 1‡Ω¡§ Stud (2) ⁄Ω¢ - 20 ≈ ·Ω¡§ Stud CU-310A • • 16591 -1 -2 -3 ‹Ω• - 16 ≈ 1‡Ω¡§ Stud (2) ‹Ω• - 16 ≈ 1‡Ω¡§ Stud CU-400A • — 16593 -1 -2 -3 ⁄Ω™ - 13 ≈ 1 Stud ⁄Ω™ - 13 ≈ 1 Stud CU-600A • • Connector – Stud Stud – Stud The only controlled copy of this Data Sheet is the electronic read-only version located on the Bussmann Network Drive. All other copies of this document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Bussmann reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Bussmann also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications. 3-12-04 SB04093 CE logo denotes compliance with European Union Low Voltage Directive (50-1000Vac, 75-1500Vdc). Refer to Data Sheet: 8002 or contact Bussmann Application Engineering at 636-527-1270 for more information. Form No. PDB Page 3 of 3 Data Sheet: 1117
16220-1 价格&库存
很抱歉,暂时无法提供与“16220-1”相匹配的价格&库存,您可以联系我们找货
  • 3+476.68777
  • 6+454.04132
  • 23+433.40198
库存:42
