RAVS Series
Stackpole Electronics, Inc.
Convex Anti-Sulfur Chip Array
Resistive Product Solutions
Features:
Thick film resistor element
Multiple circuit types available
High palladium inner terminations
Square corner construction standard
Zero-ohm jumper available
RoHS compliant
Halogen free
REACH compliant
Electrical Specifications
Type / Code
Power Rating
(W) @ 70ºC
Maximum
Working
Voltage
(1)
Maximum
Overload
Voltage (V)
(V)
RAVS102D
0.063
25
50
RAVS162D
RAVS104D
RAVS164D
RAVS324D
0.063
0.063
0.063
0.125
50
25
50
200
100
50
100
400
Ohmic Range (Ω) and Tolerance
TCR (ppm/ºC)
1%
± 300
± 200
± 200
± 200
± 200
± 200
2%
5%
1 - 10
10 - 1M
1 - 10M
10 - 1M
22 - 1M
10 - 1M
22 - 1M
10 - 1M
(1) Lesser of √ P*R or maximum working voltage
Mechanical Specifications
Schematic:
Type / Code
Body Length
Body Width
Body Height
Element
Spacing
Termination
Width
L
W
H
P
0.039 ± 0.004 0.039 ± 0.004 0.014 ± 0.004 0.026 ± 0.002
RAVS102D
1.00 ± 0.10
1.00 ± 0.10
0.35 ± 0.10
0.65 ± 0.05
RAVS162D
0.063 ± 0.006 0.063 ± 0.006 0.020 ± 0.006 0.031 ± 0.002
1.60 ± 0.15
1.60 ± 0.15
0.50 ± 0.15
0.80 ± 0.05
0.079
2.00
0.126
RAVS164D
3.20
0.200
RAVS324D
5.08
RAVS104D
0.10
1.00 ± 0.10
0.35 ±
0.004 0.063 ± 0.004 0.020 ±
0.10
1.60 ± 0.10
0.50 ±
0.008 0.122 ± 0.008 0.022 ±
0.20
3.10 ± 0.20
0.55 ±
Q
0.002 0.020 ± 0.004 0.012 ±
0.05
0.50 ± 0.10
0.30 ±
0.004 0.031 ± 0.004 0.016 ±
0.10
0.80 ± 0.10
0.40 ±
0.004 0.050 ± 0.004 0.031 ±
0.10
1.27 ± 0.10
0.80 ±
End
Top
Bottom
Termination
Termination
Termination
Unit
Width
R
A
D
0.013 ± 0.002 0.006 ± 0.004 0.010 ± 0.002 inches
0.33 ± 0.05
0.15 ± 0.10
0.25 ± 0.05
mm
0.024 ± 0.006 0.012 ± 0.006 0.012 ± 0.006 inches
0.60 ± 0.15
0.30 ± 0.15
0.30 ± 0.15
mm
0.006 0.016 ± 0.006 0.006 ±
0.15
0.40 ± 0.15
0.15 ±
0.006 0.024 ± 0.006 0.012 ±
0.15
0.60 ± 0.15
0.30 ±
0.008
0.020 ±
0.20
0.50 ±
0.004 0.010 ± 0.004 inches
0.10
0.25 ± 0.10
mm
0.008 0.010 ± 0.006 inches
0.20
0.25 ± 0.15
mm
0.008 0.012 ± 0.008 inches
0.20
0.30 ± 0.20
mm
Performance Characteristics
Test
Load Life in Moisture
Temperature Cycle
Load Life
Resistance to Soldering Heat
Terminal Adhesion
Short Time Overload
Anti-sulfur (ASTM B 809-95) 60ºC, >90% R.H.
Operating Temperature Range: -55ºC to +155ºC (RAVS102D, RAVS162D)
Test Results (JIS C 5202)
±3%
±1%
±3%
±1%
±1%
±2%
±1%
-55ºC to +125ºC (RAVS104D, RAVS164D, RAVS324D)
Rev Date: 11/18/2020
This specification may be changed at any time without prior notice.
Please confirm technical specifications before you order and/or use.
1
www.seielect.com
marketing@seielect.com
RAVS Series
Power Derating Curve:
Recommended Solder Profile
This information is intended as a reference for solder profiles for Stackpole resistive components. These profiles should
be compatible with most soldering processes. These are only recommendations. Actual numbers will depend on board
density, geometry, packages used, etc., especially those cells labeled with “*”.
100% Matte Tin / RoHS Compliant Terminations
Soldering iron recommended temperatures: 330°C to 350°C with minimum duration.
Maximum number of reflow cycles: 3.
Wave Soldering
Description
Maximum
Recommended
Preheat Time
80 seconds
70 seconds
Temperature Diff.
140°C
120°C
Solder Temp.
260°C
250°C
Dwell Time at Max.
10 seconds
5 seconds
Ramp DN (°C/sec)
N/A
N/A
Temperature Diff. = Defference between final preheat stage and soldering stage.
Minimum
60 seconds
100°C
240°C
N/A
Convection IR Reflow
Description
Maximum
Recommended
Minimum
Ramp Up (°C/sec)
Dwell Time > 217°C
Solder Temp.
Dwell Time at Max.
Ramp DN (°C/sec)
3°C/sec
150 seconds
260°C
30 seconds
6°C/sec
2°C/sec
90 seconds
245°C
15 seconds
3°C/sec
60 seconds
10 seconds
2
www.seielect.com
RAVS Series
Recommended Lead Free Resistor Reflow Profile
RoHS Compliance
Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various
regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances”
(RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our
compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as
amended by Directive (EU) 2015/863/EU as regards the list of restricted substances.
RoHS Compliance Status
Standard
Product
Series
Description
Package /
Termination
Type
RAVS
Convex Anti-Sulfur Chip Resistor Array
SMD
Note (1): RoHS Compliant by means of exemption 7c-I.
Standard
Series
RoHS
Compliant
YES(1)
Lead-Free Termination
Composition
Lead-Free
Mfg. Effective Date
(Std Product Series)
100% Matte Sn over Ni
Always
Lead-Free
Effective Date
Code
(YY/WW)
Always
“Conflict Metals” Commitment
We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the eastern
Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the electronics industry
is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and products we supply do
not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of Dodd-Frank Act regarding
Conflict Minerals.
Compliance to “REACH”
We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free and
compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of
Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List.
3
www.seielect.com
RAVS Series
Environmental Policy
It is the policy of Stackpole Electronics, Inc. (SEI) to protect the environment in all localities in which we operate. We continually strive
to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our environment
and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms of pollution.
How to Order
1
2
3
4
5
6
7
8
9
10
11
12
13
14
R
A
V
S
3
2
4
D
J
T
1
K
Product Series
Convex
Anti-Sulfur
RAVS
Power
Code W
10 0.06
16 0.06
32 0.13
Elements
2
4
Circuit Type
Code Description
D
Isolated
Tolerance
Packaging
Code Tol
Code Description Size Quantity
F
1%
10 10000
T Tape and Reel 16
G
2%
5000
J
5%
32
4000
Z Jumper
4
Resistance Value
Four characters with the
multiplier used as the
decimal holder.
22 ohm = 22R0
10.2 Kohm = 10K2
1 Mohm = 1M00
Zero ohm jumper = 0R00
www.seielect.com
很抱歉,暂时无法提供与“RAVS164DJT470R”相匹配的价格&库存,您可以联系我们找货
