NDN111-WH
NDN111-WH
    EATON(伊顿)
    3 电路 0.635"(16.13mm) 阻隔块 连接器, 螺钉
NDN111-WH 数据手册
Fuseblocks, Holders and Terminal Blocks CE logo denotes compliance with European Union Low Voltage Directive (50-1000Vac, 75-1500Vdc). Refer to Data Sheet: 8002 or contact Bussmann Application Engineering at 636-527-1270 for more information. Ratings: 90A, 600V; UL/CSA Center Spacing: .635∑ (16.13) Number of Poles: 3 Circuits per Foot: 18 Circuit Jumper: JN1, 2 circuits Wire Size: AWG #2-18 CU Screw Size: ⁄Ω¢-28 Mounting Options: 35mm DIN rail, C-rail, Base Mount. (Dove tail option is available for mounting side-by-side. Order part no. NDN111A-WH.) NDN111-__ __(color) Rail Mount Terminal Blocks NDN1-WH Ratings: 90A, 600V Center Spacing: .635∑ (16.13) Number of Poles: 1 Circuits per Foot: 18 Circuit Jumper: JN1, 2 circuits Wire Size: AWG #2-18 CU Screw Size: ⁄Ω¢-28 Mounting Options: 35mm DIN rail, C-rail (Dove-tail option is available for mounting side-by-side. Order part no. NDN1A-WH.) Marking Tape: MT12-⁄Ω™ Torque Rating: 32 in/lb max. NDN1Colors: WH -White CE logo denotes compliance with European Union Low Voltage Directive (50-1000Vac, 75-1500Vdc). Refer to Data Sheet: 8002 or contact Bussmann Application Engineering at 636-527-1270 for more information. NDNAS NRA37-1/2 72” long Stand-Off Channel for C-rail SOA72 Bussmann® See series specifications specifications MARKING JUMPERS TAPE See series Marking Tape: MT12-⁄Ω™ Torque Rating: 32 in/lb max. NDN111 NDN111A Colors: Colors: YE - Yellow YE - Yellow WH - White WH- White NFTA C-rail Low profile No flange Aluminum 37⁄Ω™∑ length For complete specification data, call Bussmann Information Fax ~ 636.527.1450 C-rail Aluminum NFTA36 36” long NFTA72 72” long Series NDN Terminal Block Accessories NDNA 35mm DIN rail 35mm DIN rail Aluminum End Stop NDNA 100 1 meter NDNA 200 2 meters 90
NDN111-WH 价格&库存
很抱歉,暂时无法提供与“NDN111-WH”相匹配的价格&库存,您可以联系我们找货
