AF164-FR-07154RL
AF164-FR-07154RL
    YAGEO(国巨)
    RA_0603X4
    排阻/电阻网络 0603x4 154Ω ±1% 62.5mW ±200ppm/℃
AF164-FR-07154RL 数据手册
DATA SHEET ANTI-SULFURATED ARRAY CHIP RESISTORS AUTOMOTIVE GRADE AF122 (4Pin/2R) / AF124 (8Pin/4R) / AF162 (4Pin/ 2R)/ AF164 (8Pin/ 4R) 5%, 1% sizes 2 × 0402, 4 x 0402, 2 x 0603, 4 x 0603 Product specification – April 21, 2021 V.6 RoHS compliant Product specification Chip Resistor Surface Mount AF 2 8 122/124/162/164 (RoHS Compliant) SERIES SCOPE ORDERING INFORMATION - GLOBAL PART NUMBER & 12NC This specification describes AF122/AF124/AF162/AF164 (convex)series chip resistor arrays with lead-free terminations made by thick film process. Both part numbers are identified by the series, size, tolerance, packing type, temperature coefficient, taping reel and resistance value. YAGEO BRAND ordering code GLOBAL PART NUMBER (PREFERRED ) AF XX X - X X X XX XXXX L APPLICATIONS  Terminal for SDRAM and DDRAM (1) (2) (7) (1) SIZE 12 = 0402 x 2 (0404)  High-end Computer & Multimedia Electronics in high sulfur environment  Consume electronic equipments: PDAs, PNDs (3) (4) (5) (6) 12 = 0402 x 4 (0408) 16 = 0603 x 2 (0606) 16 = 0603 x 4 (0612) (2) NUMBER OF RESISTORS 2 = 2 resistors  Mobile phone, telecom… 4 = 4 resistors FEATURES  AEC-Q200 qualified (3) TOLERANCE F = ± 1% J = ± 5% (for Jumper ordering, use code of J)  RoHS compliant  Reducing environmentally hazardous wastes  High component and equipment reliability (4) PACKAGING TYPE R = Paper taping reel (5) TEMPERATURE COEFFICIENT OF RESISTANCE – = Base on spec  Saving of PCB space  None forbidden-materials used in products/production (6) TAPING REEL 07 = 7 inch dia. Reel 13 = 13 inch dia. Reel  Halogen Free Epoxy  Moisture sensitivity level: MSL 1 (7) RESISTANCE VALUE There are 2~4 digits indicated the resistor value. Letter R/K/M is decimal point, no need to mention the last zero after R/K/M, e.g.1K2, not 1K20. Detailed resistance rules show in table of “Resistance rule of global part number”. (8) DEFAULT Resistance CODE rule of global part ORDERING EXAMPLE (Note) number Letter L is the system default code for ordering Theonly. ordering code of a AF122 Resistance code rule Example 0R 0R = Jumper XRXX (1 to 9.76 Ω) 1R = 1 Ω 1R5 = 1.5 Ω 9R76 = 9.76 Ω XXRX (10 to 97.6 Ω) 10R = 10 Ω 97R6 = 97.6 Ω XXXR (100 to 976 Ω) 100R = 100 Ω XKXX (1 to 9.76 KΩ) 1K = 1,000 Ω 9K76 = 9760 Ω XM (1 MΩ) convex chip resistor array, value 1,000Ω with ± 5% tolerance, supplied in 7-inch tape reel is: AF122-JR-071KL. NOTE 1. All our R-Chip products meet RoHS compliant. "LFP" of the internal 2D reel label mentions "Lead Free Process" 2. On customized label, "LFP" or specific symbol printed and the optional "L" at the end of GLOBAL PART NUMBER 1M = 1,000,000 Ω www.yageo.com Apr. 21, 2021 V.6 Product specification Chip Resistor Surface Mount AF SERIES 3 8 122/124/162/164 (RoHS Compliant) MARKING AF122 No marking Fig. 1 ynsc008 AF124 / AF162 / AF164 0 I-Digit marking YNSC010 Fig. 2 Value = 0Ω 3 60 1% E-24/E-96: R≧ 100Ω 4digits First three digits for significant figure and 4th digit for number of zeros YNSC043 Fig. 3 Value = 316KΩ 5% E-24: R≧ 10Ω First two digits for significant figure and 3rd digit for number of zeros YNSC034 Fig. 3 Value = 240KΩ For further marking information, please refer to data sheet “Chip resistors marking”. CONSTRUCTION The resistor is constructed on top of a high-grade ceramic body. Internal metal electrodes are added on each end to make the contacts to the thick film resistive element. The composition of the resistive element is a noble metal embedded into a glass and covered by a glass. The resistor is laser trimmed to the rated resistance value. The resistor is covered with a protective epoxy coat, finally the external terminations (matte tin on Nibarrier) are added as shown in Fig.4. OUTLINES overcoat resistive layer inner electrode termination ceramic substrate YNSC069 Fig. 4 Chip resistor outlines DIMENSIONS Table 1 TYPE AF122 AF124 AF162 AF164 B (mm) 0.24± 0.10 0.25± 0.15 0.35± 0.10 0.35± 0.15 H (mm) 0.30+0.10/-0.05 0.45± 0.05 0.30± 0.10 0.65± 0.05 --- 0.30± 0.05 -- 0.50± 0.15 P (mm) 0.67± 0.05 0.50± 0.05 0.80±0.05 0.80± 0.05 L (mm) 1.00± 0.10 2.00± 0.10 1.60±0.10 3.20± 0.15 0.60± 0.10 H1 (mm) T (mm) 0.30± 0.10 0.45± 0.10 0.40±0.10 W1 (mm) 0.25± 0.10 0.30± 0.15 0.30±0.10 0.30± 0.15 W2 (mm) 1.00± 0.10 1.00± 0.10 1.60±0.10 1.60± 0.15 For dimension, please refer to Table 1 AF122 / 162 AF124 / 164 Fig. 5 AF122/124/162/164 series chip resistors dimension www.yageo.com Apr. 21, 2021 V.6 Product specification Chip Resistor Surface Mount AF SERIES 4 8 122/124/162/164 (RoHS Compliant) SCHEMATIC For dimension, please refer to Fig. 5 and Table 1 4 5 3 6 7 8 AF122 / 162 AF124 / 164 R1 1 Fig. 6 Equivalent circuit diagram R1 R2 R2 1 2 R3 2 R4 3 4 R1 = R2 = R3 = R4 R1 = R2 YNSC078-1 ELECTRICAL CHARACTERISTICS Table 2 AF122 AF124 AF162 AF164 –55 °C to +155 °C –55 °C to +155 °C –55 °C to +155 °C –55 °C to +155 °C 1/16 W 1/16 W 1/16W 1/16W Maximum Working Voltage 50 V 50 V 50V 50V Maximum Overload Voltage 100 V 100 V 100V 100V Dielectric Withstanding Voltage Resistance Range 100 V 100 V 100V 100V 5% (E24) 1 Ω to 1 MΩ 1% (E24/E96) 10 Ω to 1 MΩ Jumper < 50 mΩ 5% (E24) 1 Ω to 1 MΩ 1% (E24/E96) 1 Ω to 1 MΩ Jumper < 50 mΩ CHARACTERISTICS Operating Temperature Range Rated Power 1 Ω ≤ R ≤ 10 Ω ± 250 ppm/°C Temperature Coefficient Jumper Criteria 5% (E24) 1 Ω to 1 MΩ 5% (E24) 1 Ω to 1 MΩ 1% (E24/E96) 1 Ω to 1 MΩ 1% (E24/E96) 1 Ω to 1 MΩ Jumper < 50 mΩ Jumper < 50 mΩ 10 Ω < R ≤ 1 MΩ ± 200 ppm/°C Rated Current 0.5 A Rated Current 1.0 A Rated Current 1.0 A Rated Current 1.0A Maximum Current 1.0 A Maximum Current 2.0 A Maximum Current 2.0 A Maximum Current 2.0A FOOTPRINT AND SOLDERING PROFILES For recommended footprint and soldering profiles, please refer to data sheet “Chip resistors mounting”. PACKING STYLE AND PACKAGING QUANTITY Table 3 Packing style and packaging quantity PACKING STYLE Paper Taping Reel (R) REEL DIMENSION AF122 AF124 AF162 AF164 7" (178 mm) 10,000 units 10,000 units 5,000 units 5,000 units 13" (330 mm) 50,000 units 40,000 units --- 20,000 units NOTE 1. For paper tape and reel specification/dimensions, please refer to data sheet “Chip resistors packing”. www.yageo.com Apr. 21, 2021 V.6 Product specification Chip Resistor Surface Mount AF SERIES 5 8 122/124/162/164 (RoHS Compliant) FUNCTIONAL DESCRIPTION POWER RATING AF122 / AF124 / AF162 / AF164 rated power at 70 °C is 1/16 W RATED VOLTAGE The DC or AC (rms) continuous working voltage corresponding to the rated power is determined by the following formula: V= (P X R) or max. working voltage whichever is less Where V=Continuous rated DC or AC (rms) working voltage (V) handbook, halfpage MLB206_1 P (%Prated) 100 50 0 55 0 50 70 100 155 o Tamb ( C) Fig. 7 Maximum dissipation (P) in percentage of rated power as a function of the operating ambient temperature (T amb ) P=Rated power (W) R=Resistance value (Ω) www.yageo.com Apr. 21, 2021 V.6 Product specification Chip Resistor Surface Mount AF SERIES 6 8 122/124/162/164 (RoHS Compliant) TESTS AND REQUIREMENTS Table 4 Test condition, procedure and requirements TEST TEST METHOD PROCEDURE REQUIREMENTS High Temperature Exposure AEC-Q200 Test 3 1,000 hours at TA = 155 °C, unpowered ± (2.0%+0.05Ω) Moisture Resistance AEC-Q200 Test 6 Biased Humidity AEC-Q200 Test 7 MIL-STD-202 Method 108 MIL-STD-202 Method 106 MIL-STD-202 Method 103
AF164-FR-07154RL
物料型号:AF122 (4Pin/2R) / AF124 (8Pin/4R) / AF162 (4Pin/2R) / AF164 (8Pin/4R)
器件简介:这些是YAGEO生产的符合RoHS标准的表面贴装芯片电阻阵列,采用厚膜工艺制造,具有无铅端接。
引脚分配:AF122和AF162为4引脚/2电阻配置,AF124和AF164为8引脚/4电阻配置。
参数特性:电阻值范围为1Ω至1MΩ,公差为5%或1%,尺寸包括2×0402、4×0402、2×0603和4×0603。
功能详解:这些电阻阵列适用于SDRAM和DDRAM的终端、高端计算机和多媒体电子设备、消费电子设备如PDA、PND、手机和电信设备。它们通过了AEC-Q200认证,符合RoHS标准,减少了环境有害物质的排放,提高了组件和设备的可靠性,节省了PCB空间。
应用信息:适用于高硫环境中的高端计算机和多媒体电子设备,以及移动电话、电信等消费电子设备。
封装信息:封装类型包括纸带卷装,卷径有7英寸和13英寸两种规格。电阻阵列的物理尺寸在表格1中有详细说明。
电气特性包括工作温度范围为-55°C至+155°C,额定功率为1/16W,最大工作电压为50V,电阻温度系数等信息在表2中有详细描述。
AF164-FR-07154RL 价格&库存
很抱歉,暂时无法提供与“AF164-FR-07154RL”相匹配的价格&库存,您可以联系我们找货
