YC324-FK-0710K7L
YC324-FK-0710K7L
    YAGEO(国巨)
    SMD-8P,3.2x5.1mm
    排阻/电阻网络 SMD-8P,3.2x5.1mm 10.7kΩ ±1% 125mW ±200ppm/℃
YC324-FK-0710K7L 数据手册
120 DATA SHEET ARRAY CHIP RESISTORS YC/TC 5%, 1% sizes YC:102/104/122/124/162/164/248/324/158T/358L/358T TC: 122/124/164 Product Specification – February 21, 2019 V.9 RoHS compliant 2 Product specification Chip Resistor Surface Mount YC/TC 12 102 to 358 SERIES SCOPE ORDERING INFORMATION - GLOBAL PART NUMBER & 12NC This specification describes YC (convex, flat) and TC (concave) series chip resistor arrays with leadfree terminations made by thick film process. Both part numbers are identified by the series, size, tolerance, packing type, temperature coefficient, taping reel and resistance value. YAGEO BRAND ordering code GLOBAL PART NUMBER (PREFERSRED ) APPLICATIONS  Terminal for SDRAM and DDRAM  Computer applications: laptop computer, desktop computer  Consume electronic equipments: PDAs, PNDs  Mobile phone, telecom… YC TC XXXX X X X X XX XXXX L/T (1) (2) (3) (4) (5) (6) (7) (8) (1) SIZE YC:102/104/122/124/162/164/248/324/158T/358L/358T TC: 122/124/164 (2) ARRAYS OR NETWORKS Array YC102/104/122/124/162/164/248/324: Network YC158T/YC358L/YC358T: NA (3) TOLERANCE FEATURES  AEC-Q200 qualified  More efficient in pick & place application  Low assembly costs  RoHS compliant  Products with lead free terminations meet RoHS requirements  Pb-glass contained in electrodes  Resistor element and glass are exempted by RoHS  Reducing environmentally hazardous wastes  High component and equipment reliability  Saving of PCB space  None forbidden-materials used in products/production  Halogen Free Epoxy F = ± 1% J = ± 5% (for Jumper ordering, use code of J) (4) PACKAGING TYPE R = Paper taping reel K = Embossed plastic tape reel (5) TEMPERATURE COEFFICIENT OF RESISTANCE – = Base on spec (6) TAPING REEL 07 = 7 inch dia. Reel 13 = 13 inch dia. Reel (7) RESISTANCE VALUE There are 2~4 digits indicated the resistor value. Letter R/K/M is decimal point. Detailed resistance rules show in table of “Resistance rule of global part number”. (8) DEFAULT CODE Letter L is the system default code for ordering only. (Note) Letter T is the only default code for YC102. O RDERING EXAMPLE The ordering code of a YC122 convex chip resistor array, value 1,000 Ω with ± 5% tolerance, supplied in 7-inch tape reel is: YC122-JR-071KL. YC158T network, value 100,000Ω with 5% tolerance, supplied in 7-inch tape reel is: YC158TJR-07100KL NOTE 1. All our RSMD products meet RoHS compliant. "LFP" of the internal 2D reel label mentions "Lead Free Process" 2. On customized label, "LFP" or specific symbol printed and the optional "L" at the end of GLOBAL PART NUMBER / 12NC can be added (both are on customer request) Resistance rule of global part number Resistance code rule Example 0R 0R = Jumper XRXX (1 to 9.76 Ω) 1R = 1 Ω 1R5 = 1.5 Ω 9R76 = 9.76 Ω XXRX (10 to 97.6 Ω) 10R = 10 Ω 97R6 = 97.6 Ω XXXR (100 to 976 Ω) 100R = 100 Ω XKXX (1 to 9.76 KΩ) 1K = 1,000 Ω 9K76 = 9760 Ω XM (1 MΩ) 1M = 1,000,000 Ω www.yageo.com Feb. 21, 2019 V.9 Product specification Chip Resistor Surface Mount YC/TC SERIES 3 12 102 to 358 PHYCOMP BRAND ordering codes Both GLOBAL PART NUMBER (preferred) and 12NC (traditional) codes are acceptable to order Phycomp brand products. GLOBAL PART NUMBER (PREFERRED ) For detailed information of GLOBAL PART NUMBER and ordering example, please refer to page 2. TC122 series is supplied and ordered by global part number only. 12NC CODE 2350 XXX XXXXX L (1) (2) (3) Last digit of 12NC Resistance decade (3) (4) PAPER / PE TAPE ON REEL (units) (2) TYPE/ START TOL. RESISTANCE 2×0402 IN (1) (%) RANGE 10,000 ARV321 2350 ± 5% 1 to 1 MΩ 013 11xxx 013 12xxx ARV322 2350 ± 1% 10 to 1 MΩ 013 2xxxx 013 3xxxx Jumper 2350 - 0Ω 013 91001 - 50,000 (1) The resistors have a 12-digit ordering code starting with 2350. (2) The subsequent 4 or 5 digits indicate the resistor tolerance and packaging. (3) The remaining 4 or 3 digits represent the resistance value with the last digit indicating the multiplier as shown in the table of “Last digit of 12NC”. (4) "L" is optional symbol (Note) . Last digit 0.01 to 0.0976 Ω 0.1 to 0.976 Ω 0 1 to 9.76 Ω 8 10 to 97.6 Ω 9 100 to 976 Ω 1 1 to 9.76 KΩ 2 10 to 97.6 KΩ 3 100 to 976 KΩ 4 1 to 9.76 MΩ 5 10 to 97.6 MΩ 6 Example: 7 0.02 Ω = 0200 or 200 0.3 Ω = 3007 or 307 O RDERING EXAMPLE 1Ω = 1008 or 108 The ordering code of a ARV321 resistor, value 1,000Ω with ± 5% tolerance, supplied in tape of 10,000 units per reel is: 235001311102(L) or YC122-JR-071KL. 33 KΩ = 3303 or 333 10 MΩ = 1006 or 106 NOTE 1. All our RSMD products are RoHS compliant. "LFP" of the internal 2D reel label mentions "Lead Free Process" 2. On customized label, "LFP" or specific symbol printed and the optional "L" at the end of GLOBAL PAR T NUMBER / 12NC can be added (both are on customer request) www.yageo.com Feb. 21, 2019 V.9 Product specification Chip Resistor Surface Mount YC/TC SERIES 4 12 102 to 358 MARKING YC102 No marking Fig. 1 YC122 No marking Fig. 2 YC104 No marking Fig. 3 YC124 / 162 / 164 / 324 0 1-Digit marking Fig. 4 Jumper=0Ω E-24 series: 3 digits, 5% 2 Fig. 4-1 Value=240KΩ First two digits for significant figure and 3rd digit for number of zeros YC248 0 1-Digit marking Fig. 5 Jumper=0Ω 2 Fig. 5-1 Value=240KΩ E-24 series: 3 digits, 5% First two digits for significant figure and 3rd digit for number of zeros YC158T/358L/358T E-24 series: 3 digits 2 Fig. 6 Value=24Ω Fig. 6-1 Value=240KΩ First two digits for significant figure and 3rd digit for number of zeros TC122 No marking Fig. 7 TC124 No marking Fig. 8 www.yageo.com Feb. 21, 2019 V.9 Product specification Chip Resistor Surface Mount YC/TC SERIES 5 12 102 to 358 TC164 0 1-Digit marking Fig. 9 Jumper=0Ω 2 E-24 series: 3 digits, 5% First two digits for significant figure and 3rd digit for number of zeros Fig. 9-1 Value=240KΩ For further marking information, please refer to data sheet “Chip resistors marking”. CONSTRUCTION The resistor is constructed on top of a high-grade ceramic body. Internal metal electrodes are added on each end to make the contacts to the thick film resistive element. The composition of the resistive element is a noble metal imbedded into a glass and covered by a second glass to prevent environment influences. The resistor is laser trimmed to the rated resistance value. The resistor is covered with a protective epoxy coat, finally the two external terminations (matte tin on Nibarrier) are added as shown in Fig.9. OUTLINES Fig. 10 Chip resistor outlines www.yageo.com Feb. 21, 2019 V.9 Product specification Chip Resistor Surface Mount YC/TC SERIES 102 to 358 6 12 SCHEMATIC Fig. 11 Equivalent circuit diagram Note: 1. YC102/104 is flat type For dimension, please refer to Table 1 Side view for all types YC102_ T YC 122/162 TC 122 YC 104/124/164/324 158/358/248 TC 124/164 unit: mm Fig. 12 YC/TC122 series chip resistors dimension Note: (1) YC102/104 is flat type www.yageo.com Feb. 21, 2019 V.9 Product specification Chip Resistor Surface Mount YC/TC SERIES 7 12 102 to 358 DIMENSIONS Table 1 TYPE YC102 H / H1 / HW YC104 YC122 YC124 YC162 YC164 YC248 YC324 B P L T W1 W2 H : 0.25 ± 0.10 0.15 ± 0.10 0.55 ± 0.10 0.80 ± 0.10 0.35 ± 0.10 0.15 ± 0.10 0.60 ± 0.10 H : 0.20 ± 0.10 0.15 ±0.05 0.40 ±0.10 1.40 ±0.10 0.35 ±0.10 0.15 ±0.10 0.60 ±0.10 H : 0.21+0.10 / -0.05 HW : 0.35 ± 0.10 H: 0.40 ± 0.15 H1: 0.30 ± 0.05 0.20 ±0.10 0.67 ±0.05 1.00 ±0.10 0.30 ±0.10 0.25 ±0.10 1.00 ±0.10 0.20 ±0.15 0.50 ±0.05 2.00 ±0.10 0.45 ±0.10 0.30 ±0.15 1.00 ±0.10 H : 0.30 ± 0.10 HW : 0.65 ± 0.15 0.30 ±0.10 0.80 ±0.05 1.60 ±0.10 0.40 ±0.10 0.30 ±0.10 1.60 ±0.10 0.30 ±0.15 0.80 ±0.05 3.20 ±0.15 0.60 ±0.10 0.30 ±0.15 1.60 ±0.15 0.30 ±0.15 0.50 ±0.05 4.00 ±0.20 0.45 ±0.10 0.40 ±0.15 1.60 ±0.15 0.50 ±0.20 1.27 ±0.05 5.08 ±0.20 0.60 ±0.10 0.50 ±0.15 3.20 ±0.20 H : 0.65 ±0.05 H1: 0.50 ±0.15 H : 0.45 ±0.05 H1: 0.30 ±0.05 H : 1.10 ±0.15 H1: 0.90 ±0.15 TC122 H : 0.30 ±0.05 0.25 ±0.15 0.50 ±0.05 1.00 ±0.10 0.30 ±0.10 0.25 ±0.15 1.00 ±0.10 TC124 H : 0.30 ±0.10 0.20 ±0.10 0.50 ±0.05 2.00 ±0.10 0.40 ±0.10 0.25 ±0.10 1.00 ±0.10 TC164 H : 0.50 ± 0.15 0.30 ±0.15 0.80 ±0.05 3.20 ±0.15 0.60 ±0.10 0.30 ±0.15 1.60 ±0.15 YC158T H : 0.45±0.05 H1: 0.32± 0.05 0.30 ±0.15 0.64 ±0.05 3.20 ±0.20 0.60 ±0.10 0.35 ±0.15 1.60 ±0.15 YC358L YC358T H : 1.10±0.15 0.50 ±0.15 1.27 ±0.05 6.40 ±0.20 0.60 ±0.10 0.50 ±0.15 3.20 ±0.20 H1: 0.90±0.15 www.yageo.com Feb. 21, 2019 V.9 Product specification Chip Resistor Surface Mount YC/TC SERIES 8 12 102 to 358 ELECTRICAL CHARACTERISTICS Table 2 TYPE POWER OPERATING P70 TEMP. RANGE YC102 1/32W -55°C to +125°C MWV RCOV DWV RESISTANCE RANGE & TOLERANCE T. C. R. 15V 30V 30V E24 ± 5% 10Ω ≤ R ≤ 1MΩ E24/E96 ± 1% 10Ω ≤ R ≤ 1MΩ Jumper < 0.05Ω Jumper criteria (unit: A) Rated current 0.5 Max. current 1.0 ± 200 ppm/°C YC104 1/32W -55°C to +125°C 12.5V 25V 25V E24 ± 5% 10Ω ≤ R ≤ 1MΩ E24/E96 ± 1% 10Ω ≤ R ≤ 1MΩ Jumper < 0.05Ω YC122 1/16W -55°C to +155°C 50V 100V 100V E24 ± 5% 1Ω ≤ R ≤ 1MΩ E24/E96 ± 1% 1Ω ≤ R ≤ 1MΩ Jumper < 0.05Ω YC124 1/16W -55°C to +155°C 25V 50V 100V E24 ± 5% 1Ω ≤ R ≤ 1MΩ E24/E96 ± 1% 1Ω ≤ R ≤ 1MΩ Jumper < 0.05Ω YC162 1/16W -55°C to +155°C 50V 100V 100V E24 ± 5% 1Ω ≤ R ≤ 1MΩ E/24/E96 ± 1% 1Ω ≤ R ≤ 1MΩ Jumper < 0.05Ω YC164 1/16W -55°C to +155°C 50V 100V 100V E24 ± 5% 1Ω ≤ R ≤ 1MΩ E24/E96 ± 1% 1Ω ≤ R ≤ 1MΩ Jumper < 0.05Ω Rated current 1.0 Max. current 2.0 YC248 1/16W -55°C to +155°C 50V 100V 100V E24 ± 5% 10Ω ≤ R ≤ 1MΩ E24/E96 ± 1% 10Ω ≤ R ≤ 1MΩ Jumper < 0.05Ω Rated current 2.0 Max. current 10.0 YC324 1/8W -55°C to +155°C 200V 500V 500V E24 ± 5% 10Ω ≤ R ≤ 1MΩ E24/E96 ± 1% 10Ω ≤ R ≤ 1MΩ TC122 1/16W -55°C to +125°C 50V 100V 100V E24 ± 5% 10Ω ≤ R ≤ 1MΩ E24/E96 ± 1% 10Ω ≤ R ≤ 1MΩ Jumper < 0.05Ω Rated current 0.5 Max. current 1.0 Rated current 0.5 Max. current 1.0 1Ω ≤ R ≤ 10Ω ± 250 ppm/°C Rated current 1.0 10Ω ≤ R ≤ 1MΩ Max. current 2.0 ± 200 ppm/°C Rated current 1.0 Max. current 2.0 --- ± 200 ppm/°C --- Rated current 1.0 Max. current 1.5 TC124 1/16W -55°C to +125°C 50V 100V 100V E24 ± 5% 10Ω ≤ R ≤ 1MΩ E24/E96 ± 1% 10Ω ≤ R ≤ 1MΩ Jumper < 0.05Ω TC164 1/16W -55°C to +155°C 50V 100V 100V E24 ± 5% 10Ω ≤ R ≤ 1MΩ E24/E96 ± 1% 10Ω ≤ R ≤ 1MΩ Jumper < 0.05Ω YC158T 1/16W -55°C to +155°C 25V 50V 50V E24 ± 5% 10Ω ≤ R ≤ 100KΩ --- --- YC358L YC358T 1/16W -55°C to +155°C 50V 100V 100V E24 ± 5% 10Ω ≤ R ≤ 330KΩ --- --- Rated current 1.0 Max. current 1.5 Rated current 1.0 Max. current 2.0 FOOTPRINT AND SOLDERING PROFILES For recommended footprint and soldering profiles, please refer to data sheet “Chip resistors mounting”. PACKING STYLE AND PACKAGING QUANTITY Table 3 Packing style and packaging quantity YC102/ 104 YC/TC 122 YC/TC 124 YC162 7" (178mm) 10,000 10,000 10,000 13" (254mm) 50,000 50,000 40,000 --- --- --- PACKING STYLE PACKING STYLE Paper taping reel ( R ) Embossed taping reel ( K) 7" (178mm) YC/TC 164 YC248 YC324 YC158T YC358L YC358T 5,000 5,000 5,000 --- 5,000 --- --- 20,000 --- --- 20,000 --- --- --- 4,000 4,000 --- 4,000 NOTE 1. For tape and reel specification/dimensions, please refer to data sheet “Chip resistors packing”. www.yageo.com Feb. 21, 2019 V.9 Product specification Chip Resistor Surface Mount YC/TC SERIES 102 to 358 9 12 FUNCTIONAL DESCRIPTION OPERATING TEMPERATURE RANGE YC102/104/122/162, TC122/124 Range: -55℃ to +125℃ (Fig.13) YC124/164/248/324/158T/358L/358T, TC164 Range: -55℃ to +155℃(Fig.14) POWER RATING Each type rated power at 70℃ YC102/104 = 1/32 W YC122/124/162/164/248/158T/358L/358T = 1/16 W YC324 = 1/8 W TC122/124/164 = 1/16 W Fig. 13 Maximum dissipation (P) in percentage of rated power as a function of the operating ambient temperature (T amb ) R ATED VOLTAGE The DC or AC (rms) continuous working voltage corresponding to the rated power is determined by the following formula: V= (PxR) or max. working voltage whichever is less Where V=Continuous rated DC or AC (rms) working voltage (V) P=Rated power (W) R=Resistance value (Ω ) Fig. 14 Maximum dissipation (P) in percentage of rated power as a function of the operating ambient temperature (T amb ) www.yageo.com Feb. 21, 2019 V.9 Product specification Chip Resistor Surface Mount YC/TC SERIES 10 12 102 to 358 TESTS AND REQUIREMENTS Table 4 Test condition, procedure and requirements TEST TEST METHOD PROCEDURE Life/ Operational Life/ Endurance MIL-STD-202-method 108 1,000 hours at 70± 5 °C applied RCWV 1.5 hours on, 0.5 hour off, still air required High Temperature Exposure/ Endurance at Upper Category Temperature MIL-STD-202-method 108 IEC 60115-1 4.25.1 REQUIREMENTS ± (2%+0.05 Ω)
YC324-FK-0710K7L
物料型号:YAGEO Phicomp 系列贴片电阻,型号包括YC102/104/122/124/162/164/248/324/158T/358L/358T和TC122/124/164。
器件简介:这些是YAGEO公司生产的贴片电阻阵列,采用无铅端接技术,符合RoHS标准,适用于SDRAM和DDRAM的终端、计算机应用、消费电子设备、移动电话和电信设备等。
引脚分配:文档中提供了不同型号的贴片电阻的等效电路图,展示了各个引脚之间的连接关系。
参数特性:电阻阵列的公差为±1%或±5%,包装类型包括纸质胶带卷(R)和压花塑料胶带卷(K)。电阻的温度系数、胶带卷直径和电阻值都有详细的说明。
功能详解:文档详细描述了电阻的构造,包括高等级陶瓷基体、内部金属电极、厚膜电阻元件、覆盖的保护性环氧涂层以及外部端接。
应用信息:适用于SDRAM和DDRAM终端、计算机应用(如笔记本电脑、桌面电脑)、消费电子设备(如PDA、PND)、移动电话和电信设备。
封装信息:提供了不同型号的贴片电阻的尺寸信息,包括高度、宽度、引脚间距和长度。
YC324-FK-0710K7L 价格&库存
很抱歉,暂时无法提供与“YC324-FK-0710K7L”相匹配的价格&库存,您可以联系我们找货
