325102-10-0
    CURTISINDUSTRIES
    10 电路 0.325"(8.26mm) 阻隔块 连接器, 螺钉
325102-10-0 数据手册
Series 32500 .325" Center-to-Center Spacing Features: ‡ Complete Line of .325" Offset Blocks – Including base mount, P.C. Pin, wire wrap, turret, and right angle terminals ‡ Open or Tri Barrier Designs – To meet your wiring requirements ‡ UL & CSA Recognized – With a 94 V-O flammability rating ‡ Molded in Standoffs – To aid in the board cleaning process ‡ A Multitude of Screw and Wire Terminals Available – Including wire clamps, wire ready screws, and combo head screws Recognized under the Components Program of Underwriters Laboratories, Inc. Standard 1059, Guide No. XCFR2, File No. E62557. Single Row Guide No. 22.2 No. 158, Report No. LR39186-1. 32500 Surface Mount With or Without Mounting Ends 32500 Tri-Barrier Surface Mount With or Without Mounting Ends “A” Overall Dimensions “B” Mounting Dimensions “C” Less End Mountings Ø .172 (4,37) Mounting Holes (2) .672 (17,07) BARRIER STYLE “A” Overall Dimensions “B” Mounting Dimensions “C” Less End Mountings .187 (4,75) .325 (8,26) Ø .172 (4,37) Mounting Holes (2) .572 (14,53) .325 (8,26) .325 (8,26) .656 (16,66) .656 (16,66) .341 .310 (8,66) (7,87) .036 (,91) .341 .310 (8,66) (7,87) INSERT OR BOTTOM TERMINATION DESIGN ] 0 = Base Mount Insert 1 = Printed Circuit Pin 2 = Wire Wrap Pin 3 = Turret Type Pin 4 = Right Angle Printed Circuit Pin www.curtisind.com .036 (,91) 325 X X X XX X [ SPECIALS OR OPTIONAL DESIGNS 0 = None A-= = Custom Con¿guration MOLDING DESIGN ] 0 = Open Back w/ Mounting Ends 1 = Open Back w/o Mounting Ends 2 = Tri Barrier w/ Mounting Ends 3 = Tri Barrier w/o Mounting Ends 8 .325 (8,26) .285 (7,24) .285 (7,24) How to Order .187 (4,75) [ NUMBER OF POSITIONS 1 thru 26, Available in One to Twenty-Six Positions [ HARDWARE OR TOP TERMINATION DESIGN 0 = Steel Combo Head Screw 1 = Wire Clamp Head Screw 2 = Brass Combo 3 = Stainless Steel Screw 5 = Supplied w/o Screws 6 = Quick Connects 8 = Captivated Steel Combo Head 9 = Captivated Wire Clamp Curtis Industries A Division of Powers Holdings, Inc. 6SHci¿cDtionssuEMHcttocKDnJH. Dimensions are shown for reference purposes only. SSeFi¿Fations: Dimensions Number of Terminals .310 (7,87) 2 – Wire Wrap .032 (8,13) 3 – Turret Type 34.24 .975 42.49 1.300 .373 9.47 24.77 .698 17.73 33.02 1.023 25.98 4 1.998 50.75 1.625 41.30 1.348 34.24 5 2.323 59.00 1.950 49.53 1.673 42.49 6 2.648 67.26 2.275 57.79 1.998 50.75 7 2.973 75.51 2.600 66.04 2.323 59.00 8 3.298 83.77 2.925 74.30 2.648 67.25 9 3.623 92.02 3.250 82.55 2.973 75.51 3.948 100.28 3.575 90.81 3.298 83.77 3.900 99.06 3.623 92.02 12 4.598 4.225 107.32 3.948 100.28 13 4.923 125.04 4.550 14 5.248 133.30 4.875 123.83 4.598 15 5.573 141.55 5.200 132.08 4.923 125.04 16 5.898 149.81 5.525 140.34 5.248 133.30 17 6.223 158.06 5.850 148.59 5.573 141.55 18 6.548 166.32 6.175 156.85 5.898 149.81 19 6.873 174.57 6.500 20 7.198 182.83 6.825 173.36 6.548 166.32 21 7.523 191.08 7.150 181.61 6.873 174.57 22 7.848 199.34 7.475 189.87 7.198 182.83 23 8.173 207.59 7.800 198.12 7.523 191.08 24 8.498 215.85 8.125 206.38 7.848 199.34 25 8.823 224.10 8.450 214.63 8.173 207.60 26 9.148 232.36 8.775 222.89 8.498 215.85 .032 (8,13) 4 – Right Angle PC Pin 116.79 115.57 4.273 108.53 116.79 165.1 6.223 158.06 27 8.823 224.10 28 9.148 232.36 Dimensions shown are ± 0.030" .411 (10,44) Series 32500 Tri-Barrier 1.348 1.673 16.51 4.273 108.53 .093 (2,36) .032 (8,13) 2 3 Metric (mm) Inches 11 .691 (17,55) .672 (17,07) .650 Metric (mm) 10 1.41 (3,58) .155 (3,94) Inches C ± .031 Less Mounting Ends BARRIER STYLE Series 32500 Open Back 25.98 B ± .031 Mounting Dimensions (M.D.) Single Row 2-11 Terminals Ø.079 (No. 47 Drill) 12 T Terminals and Over Ø.093 (No. 42 Drill) .656 (16,66) Metric (mm) 1.023 1 .325 Typ. 1 – PC Pin A ± .031 Overall Dimensions (O.D.) Inches PC BOARD DRILLING DIMENSIONS 0 – Flush Mount Without Mounting Ends Series 32500 With Mounting Ends Center-to-Center Spacing: .325" (.825mm) Wire Range: No. 22AWG to 14AWG No. of Terminals: 1 thru 26 (28 without mounting holes) Voltage Rating: 300V Tightening Torque: 9 in. lb. Current Rating: 15 amps UL (20 Amps with 12AWG & Lugs) Housing: Material Polypropylene Continuous Use Temp. (UL Index) 105°C (221°F) Flammability Rating 94V-0 Water Absorption (24 hrs. % wt. gain) .03% .032 (8,13) .530 (13,46) 0 – Flush Mount .656 (16,66) 1 – PC Pin .032 (8,13) .672 (17,07) Dimensions are in inches and millimeters unless otherwise speci¿ed. Values in parentheses are metric equivalents. 3 – Turret Type 4 – Right Angle PC Pin .093 (2,36) .310 (7,87) .155 (3,94) 2 – Wire Wrap .141 (3,58) .691 (17,55) .032 (8,13) .411 (10,44) .032 (8,13) .430 (10,92) .032 (8,13) Curtis Industries A Division of Powers Holdings, Inc. 1-800-657-0853 9
325102-10-0
- 物料型号: Series 32500 - 器件简介: 提供了.325"中心到中心间距的偏移块,包括基座安装、PC引脚、绕线、炮塔和直角端子等多种形式。 - 引脚分配: 单排隔板样式,有带或不带安装端的表面安装型号。 - 参数特性: - 中心到中心间距: .325" (.825mm) - 线规范围: No. 22AWG 至 14AWG - 端子数量: 1 至 26 (无安装孔为28) - 电压等级: 300V - 紧固扭矩: 9 in. lb. - 电流等级: 15安培UL (使用12AWG和端子时为20安培) - 功能详解: 提供了多种硬件或顶部端子设计选项,如钢组合头螺钉、线夹头螺钉等。 - 应用信息: 适用于多种安装和布线要求,包括UL和CSA认证。 - 封装信息: 材料为聚丙烯,连续使用温度指数为105°C(221°F),阻燃等级为94V-0。
325102-10-0 价格&库存
很抱歉,暂时无法提供与“325102-10-0”相匹配的价格&库存,您可以联系我们找货
