1507-3/4ST
1507-3/4ST
    CURTISINDUSTRIES
    7 电路 0.375"(9.53mm) 阻隔块 连接器, 螺钉,带焊片,单
1507-3/4ST 数据手册
Series 1500 .375" (9.52mm) Center-to-Center Spacing Features: ‡ Flexible Hi-Temp Thermoplastic Terminal Blocks – Self-extinguishing types which resist breakage and other damage (conform to UL 94V-0). ‡ Terminal Flexibility – Ideal for surface mount, sub-panel or chassis connections in electronic/electrical circuit applications. One thru 22 terminals. 1500 Series is .375" on centers. ‡ Economical Closed-Back Design – No need for costly insulation strip. ‡ Broad Wire Range – No. 6-32 external twin screws, UL recognized for No. 22AWG to No. 10AWG. Variations include double solder lug, single solder lug, wire wrap, solder pin and printed circuit pin. ‡ UL/CSA Electrical Ratings – UL 30A/1100V RMS (1/3 breakdown voltage), CSA rating 15A/300V. ‡ Recognition and Listing – Various terminal types are UL recognized and CSA certified. Dual Row Series 1500 Variations YWY wire-wrap terminal INTERNAL TERMINAL DESIGNATIONS W wire clamp .652 (15,87) 1500-Y 1500-YWY .062 (1,57) EXTERNAL TERMINAL DESIGNATIONS BARRIER STYLE 1500 .062 (1,57) Recognized under the Components Program of Underwriters Laboratories, Inc. Standard 1059, Guide No. XCFR2, File No. E62557. Guide No. 22.2 No. 158, Report No. LR39186-1. COMPLIES WITH IEC 947-7-1 ST double solder lug .093 Dia. Holes (2) (2,36) 6-32 Terminal Screw O.D. M.D. .375 Typ. (9,52) .312 (7,93) 1.270 (32,28) .875 (22,22) .687 (17,45) .180 (4,57) www.curtisind.com screw terminal with No. 6-32 plated steel* screw accepting up to No. 10AWG wire solderable tin-plated double solder tab solderable tin-plated single solder tab wire clamp captivated to a No. 6-32 plated steel screw * Other materials available – contact factory or your local representative for additional information. Y printer circuit terminal Series 1500 Dimensions 28 1500-ST 1500-3/4ST 1500-W 3/4 ST single solder lug .234 (5,94) printed circuit board design with .062" x .031" solderable tin-plated pin feed-thru wire wrap .320 Max. Lug Access (8,12) .170 Dia. Mtfg. Holes (4) .433 (4,31) (11,0) Curtis Industries A Division of Powers Holdings, Inc. .031 (.787) .278 (7,06) 6SHci¿cDtionssuEMHcttocKDnJH. Dimensions are shown for reference purposes only. How to Order Center-to-Center Spacing: .375" (9.52mm) Wire Range: Up to No. 12AWG (CSA requires use of lugs on wire larger than No. 16AWG.) No. of Terminals: 1 thru 22 Voltage Rating: CSA – 300V UL – 150V – General Industrial 250V – Commercial Appliance 300V – Limited Energy Industrial Tightening Torque: Wire Clamp and Wire Binding Screw 12 in.-lbs. Current Rating: UL: 20 amps CSA: 15 amps Housing: Material Polyphenylene Oxide Continuous Use Temp. (UL Index) 110°C (230°F) Flammability Rating 94V-0 Water Absorption (24 hrs. % wt. gain) .06% Chemical Resistance Resistant to inorganic bases and acids. For organic substances contact factory for speci¿c resistance. Breakdown Voltage: Terminal - Terminal 3,400V Typ. Terminal - Ground 7,300V Typ. Note: Speci¿cations contained herein are subMect to change without notice. 1500 Series terminal blocks are ordered by listing a composite number made up of the model designation in which the last two digits indicate the number of poles required for the application. Example: A 1500 10-terminal block (3/8" centers) becomes stock number 1510. Suffixes are used as follows: ST denotes double solder lug 3/4ST denotes single solder lug Y denotes printed circuit pin YWY feed-thru wire wrap W wire clamp The 1510 described above, with double solder lug mounting on 3/8" centers thus converts to stock number 1510-ST. To specify quick-connect terminals, simply add the style number required. (See accessories.) May be purchased factory-assembled or as customer-installed accessory. Number of Terminals Mounting Dimensions Metric (mm) Overall Dimensions Inches Metric (mm) 1 .750 19.05 1.030 26.16 2 1.125 28.57 1.405 35.68 3 1.500 38.10 1.780 45.21 4 1.875 47.62 2.155 54.73 5 2.250 57.15 2.530 64.26 2-11 Terminals .079 Dia. (No. 47 Drill) 6 2.625 66.67 2.905 73.78 12 T Terminals and Over .093 Dia. (No. 42 Drill) 7 3.000 76.20 3.280 83.31 8 3.375 85.72 3.655 92.83 9 3.750 95.25 4.030 102.36 10 4.125 104.77 4.405 11 4.500 114.30 4.780 121.41 12 4.875 123.82 5.155 130.93 13 5.250 133.35 5.530 140.46 14 5.625 142.87 5.905 149.98 15 6.000 152.40 6.280 159.51 16 6.375 161.92 6.655 169.03 17 6.750 171.45 7.030 178.56 18 7.125 180.97 7.405 188.08 19 7.500 190.05 7.780 197.61 20 7.875 200.02 8.155 207.13 21 8.250 209.55 8.530 216.66 22 8.625 219.07 8.905 226.18 PC BOARD DRILLING DIMENSIONS .375 Typ. (9,55) BARRIER STYLE Inches Dual Row 6SeFL¿FatLoQs: 111.88 Dimensions Shown are ± 0.030" Dimensions are in inches and millimeters unless otherwise speci¿ed. Values in parentheses are metric equivalents. Curtis Industries A Division of Powers Holdings, Inc. 1-800-657-0853 29 Series 1500/2000 Accessories .806 (20,47) QUICK-CONNECT TERMINALS 1500/2000 – Available with .187" x .202" quick-connect tabs for 1500 series; .250" x .032" for 2000 series. Nine styles . . . tin-plated brass tabs held in place by terminal screws. Up to six terminations per pole. To order, specify: 1500 Series: Part No. TB11-19 2000 Series: Part No. TB31-39 TB13 (1500) .125 (3,18) 1.570 45% Dual Row TB34 (2000) .589 (14,96) .250 (6,35) .187 (4,75) See Table A, Dim. 2 .156 (0) Dia. Hole Part No. TB11 P tN 2X ÿ .062 .125 .031 1.318 90% .300±.003 .150 .184 TB16 (1500) TB36 (2000) + .005 .367 - .003 1.197 .250 .031 .156 TB35 (2000) 90° .625 .312 .156 TB15 .994 (25,25) .088 .088 90% 45% TB15 (1500) .422 90° 45° 1.672 .312 1.224 1.049 (26,64) TB11 (1500) BARRIER STYLE 45° TB14 (1500) .031 (,787) .399 TB33 (2000) 1.392 (35,36) See Table A, Dim 1 1.00 (25,4) 90% 90° Last digit of part number corresponds to previous style numbers. See Table A, Dim. 3 (2) .250 (6,35) .960 .150 TB31 (2000) See Table A Dim. 4 .150 (3,81 TB37 (2000) 1.307 (33,2) TB12 (1500) 45° .243 (6,17 Part No. TB17 TB17 (1500) .826 (20,98) 1.099 .955 (24,26) 45% 45° TB18 (1500) TB38 (2000) 1.481 45% .727 (18,47) .960 .268 90° .831 90% Part No. TB19 TB32 (2000) 32 www.curtisind.com TB19 (1500) Curtis Industries A Division of Powers Holdings, Inc. TB39 (2000) Speci¿cations subMect to change. Dimensions are shown for reference purposes only. MARKING STRIPS 1500/2000 Pre-punched black ¿ber . . . mounts under block. May be imprinted to customer speci¿cations. To order, specify: 1500 Series – Part No. 247A10-1 thru 22 2000 Series – Part No. 247A11-1 thru 22 Dual Row WIRE CLAMP 1500/2000 – Wire clamp captivated to No. 6-32 screw eliminates need for lugs. 1500 Series – Part No. 058525700 2000 Series – Part No. 058526700 Part No. 68240100 Part No. 68245100 TERMINAL BLOCK JUMPERS COVERS 1500/2000 – Rigid .030" thick self-extinguishing vinyl. Complete with spring clips for attaching to mounting positions. To order, specify: 1500 Series – Part No. 247B24-1 thru 26 terminals 2000 Series – Part No. 247B25-1 thru 26 terminals Dimensions are in inches and millimeters unless otherwise speci¿ed. Values in parentheses are metric equivalents. 2000 – Plated brass in two styles. Types 267A28 is designed to Mump two adMacent terminals as it is channeled to cross over the barrier top. “Rooster comb” design of Type 267A42 permits connections of two to 18 poles. To order, specify: Part No. 267A42 (plus no. of poles) Example: 267A42-18 Curtis Industries A Division of Powers Holdings, Inc. 1-800-657-0853 BARRIER STYLE 1500 – Jumper is constructed of plated brass. “Rooster comb” design permits connections of two to 10 poles. To order, specify: Part No. 278-A11 (plus no. of poles) Example: 278A11-10 Part No. 68240100 (Holes) or 68245100 (slots) (2-pole Mumper for 1500 only) 33 Series 2000 .4375" (11.11mm) Center-to-Center Spacing Features: ‡ Flexible Hi-Temp Thermoplastic Terminal Blocks – Self-extinguishing types which resist breakage and other damage (conform to UL94V-0). ‡ Terminal Flexibility – Ideal for surface mount, sub-panel or chassis connections in electronic/electrical circuit applications. One thru 26 terminals. ‡ Economical Closed-Back Design – No need for costly insulation strip. ‡ Broad Wire Range – No. 6-32 external twin screws, UL recognized for No. 22AWG to No. 10AWG. Variations include double solder lug, single solder lug, wire wrap, solder pin and printed circuit pin. ‡ UL/CSA Electrical Ratings – UL 30A/1100V RMS (1/3 breakdown voltage), CSA rating: 20A/300. ‡ Recognition and Listing – Various terminal types are UL recognized and CSA certified. BARRIER STYLE Dual Row Series 2000 Variations YWY wire-wrap terminal INTERNAL TERMINAL DESIGNATIONS 2000-Y W wire clamp .652 (15,87) EXTERNAL TERMINAL DESIGNATIONS .062 (1,57) 2000 2000-ST 2000-3/4ST 2000-W YSY solder terminal screw teminal with No. 6-32 plated steel* screw accepting up to No. 10AWG wire solderable tin-plated double solder tab solderable tin-plated single solder tab wire clamp captivated to a No. 6-32 plated steel screw * Other materials available – contact factory or your local representative for additional information. .652 (15,87) .062 (1,57) 2000-YSY 2000-YWY printed circuit board design with .062" x .031" solderable tin-plated pin solder pin wire wrap Recognized under the Components Program of Underwriters Laboratories, Inc. Standard 1059, Guide No. XCFR2, File No. E62557. 3/4 ST single solder lug Guide No. 22.2 No. 158, Report No. LR39186-1. COMPLIES WITH IEC 947-7-1 Series 2000 Dimensions 30 www.curtisind.com ST double solder lug 1.125 (28,57) .875 (22,22) .234 (5,94) .062 (1,57) .180 (4,57) O.D. M.D. .437 Typ. (11,11) .185 Dia. Holes (4) (4,69) .422 (10,71) 1.60 (40,64) Y printer circuit terminal .031 (.787) .312 (7,93) 6-32 Terminal .120 Dia. Mtfg. Holes (4) Screw (3,05) .500 .375 Max. Lug Access (12,7) (9,52) Curtis Industries A Division of Powers Holdings, Inc. 6SHci¿cDtionssuEMHcttocKDnJH. Dimensions are shown for reference purposes only. How to Order Center-to-Center Spacing: .4375" (11.11mm) Wire Range: Up to No. 10AWG (CSA requires use of lugs on wire larger than No. 16AWG.) No. of Terminals: 1 thru 26 Voltage Rating: CSA – 300V UL – 150V – General Industrial 250V – Commercial Appliance 300V – Limited Energy Industrial Tightening Torque: Wire Clamp and Wire Binding Screw 12 in.-lbs. Current Rating: UL: 30 amps CSA: 20 amps Housing: Material Polyphenylene Oxide Continuous Use Temp. (UL Index) 110°C (230°F) Flammability Rating 94V-0 Water Absorption (24 hrs. % wt. gain) .06% Chemical Resistance Resistant to inorganic bases and acids. For organic substances contact factory for speci¿c resistance. Breakdown Voltage: Terminal - Terminal 4,400V Typ. Terminal - Ground 7,700V Typ. Note: Speci¿cations contained herein are subMect to change without notice 2000 Series terminal blocks are ordered by listing a composite number made up of the model designation in which the last two digits indicate the number of poles required for the application. Example: A 2000 10-terminal block becomes stock number 2010. Suffixes are used as follows: ST denotes double solder lug 3/4ST denotes single solder lug Y denotes printed circuit pin YSY solder pin YWY wire wrap W wire clamp The 2010 described above, with double solder lug mounting on 7/16" centers thus converts to stock number 2010-ST. To specify quick-connect terminals, simply add the style number required. (See accessories.) May be purchased factoryassembled or as customer-installed accessory. 2-11 Terminals .079 Dia. (No. 47 Drill) 12 T Terminals and Over .093 Dia. (No. 42 Drill) .437 Typ. (11,11) Mounting Dimensions Inches Metric (mm) Overall Dimensions Inches Metric (mm) 1 .875 22.22 1.235 2 1.312 33.33 1.672 42.48 3 1.750 44.45 2.110 53.59 4 2.187 55.56 2.547 64.70 5 2.625 66.67 2.985 75.81 6 3.062 77.78 3.422 86.93 7 3.500 88.90 3.860 98.04 8 3.937 100.01 4.297 109.15 9 4.375 111.12 4.735 120.26 10 4.812 122.23 5.172 131.38 11 5.250 133.35 5.610 142.49 12 5.687 144.46 6.047 153.60 13 6.125 155.57 6.485 164.71 14 6.562 166.68 6.922 175.83 15 7.000 177.80 7.360 186.94 16 7.437 188.91 7.797 198.05 17 7.875 200.02 8.235 209.16 18 8.312 8.672 220.28 19 8.750 222.25 9.110 231.39 20 9.187 233.36 9.547 242.50 9.625 244.47 9.985 253.61 21 211.13 31.36 22 10.062 255.58 10.422 264.73 23 10.500 266.70 10.860 275.84 24 10.938 277.83 11.299 286.77 25 11.376 288.95 11.736 298.09 26 11.814 300.08 12.174 309.22 BARRIER STYLE PC BOARD DRILLING DIMENSIONS Number of Terminals Dual Row 6SeFL¿FatLoQs: Dimensions Shown are ± 0.030" Dimensions are in inches and millimeters unless otherwise speci¿ed. Values in parentheses are metric equivalents. Curtis Industries A Division of Powers Holdings, Inc. 1-800-657-0853 31 Series 1500/2000 Accessories .806 (20,47) QUICK-CONNECT TERMINALS 1500/2000 – Available with .187" x .202" quick-connect tabs for 1500 series; .250" x .032" for 2000 series. Nine styles . . . tin-plated brass tabs held in place by terminal screws. Up to six terminations per pole. To order, specify: 1500 Series: Part No. TB11-19 2000 Series: Part No. TB31-39 TB13 (1500) .125 (3,18) 1.570 45% Dual Row TB34 (2000) .589 (14,96) .250 (6,35) .187 (4,75) See Table A, Dim. 2 .156 (0) Dia. Hole Part No. TB11 P tN 2X ÿ .062 .125 .031 1.318 90% .300±.003 .150 .184 TB16 (1500) TB36 (2000) + .005 .367 - .003 1.197 .250 .031 .156 TB35 (2000) 90° .625 .312 .156 TB15 .994 (25,25) .088 .088 90% 45% TB15 (1500) .422 90° 45° 1.672 .312 1.224 1.049 (26,64) TB11 (1500) BARRIER STYLE 45° TB14 (1500) .031 (,787) .399 TB33 (2000) 1.392 (35,36) See Table A, Dim 1 1.00 (25,4) 90% 90° Last digit of part number corresponds to previous style numbers. See Table A, Dim. 3 (2) .250 (6,35) .960 .150 TB31 (2000) See Table A Dim. 4 .150 (3,81 TB37 (2000) 1.307 (33,2) TB12 (1500) 45° .243 (6,17 Part No. TB17 TB17 (1500) .826 (20,98) 1.099 .955 (24,26) 45% 45° TB18 (1500) TB38 (2000) 1.481 45% .727 (18,47) .960 .268 90° .831 90% Part No. TB19 TB32 (2000) 32 www.curtisind.com TB19 (1500) Curtis Industries A Division of Powers Holdings, Inc. TB39 (2000) Speci¿cations subMect to change. Dimensions are shown for reference purposes only. MARKING STRIPS 1500/2000 Pre-punched black ¿ber . . . mounts under block. May be imprinted to customer speci¿cations. To order, specify: 1500 Series – Part No. 247A10-1 thru 22 2000 Series – Part No. 247A11-1 thru 22 Dual Row WIRE CLAMP 1500/2000 – Wire clamp captivated to No. 6-32 screw eliminates need for lugs. 1500 Series – Part No. 058525700 2000 Series – Part No. 058526700 Part No. 68240100 Part No. 68245100 TERMINAL BLOCK JUMPERS COVERS 1500/2000 – Rigid .030" thick self-extinguishing vinyl. Complete with spring clips for attaching to mounting positions. To order, specify: 1500 Series – Part No. 247B24-1 thru 26 terminals 2000 Series – Part No. 247B25-1 thru 26 terminals Dimensions are in inches and millimeters unless otherwise speci¿ed. Values in parentheses are metric equivalents. 2000 – Plated brass in two styles. Types 267A28 is designed to Mump two adMacent terminals as it is channeled to cross over the barrier top. “Rooster comb” design of Type 267A42 permits connections of two to 18 poles. To order, specify: Part No. 267A42 (plus no. of poles) Example: 267A42-18 Curtis Industries A Division of Powers Holdings, Inc. 1-800-657-0853 BARRIER STYLE 1500 – Jumper is constructed of plated brass. “Rooster comb” design permits connections of two to 10 poles. To order, specify: Part No. 278-A11 (plus no. of poles) Example: 278A11-10 Part No. 68240100 (Holes) or 68245100 (slots) (2-pole Mumper for 1500 only) 33
1507-3/4ST
物料型号:文档中提到了两个系列的终端块,分别是Series 1500和Series 2000,它们具有不同的中心距和特性。
器件简介:这些终端块由Curtis Industries生产,属于Powers Holdings, Inc.的子公司。它们是灵活的高温热塑性终端块,具有自熄性,能够抵抗断裂和其他损害。
引脚分配:Series 1500的中心距为.375" (9.52mm),而Series 2000的中心距为.4375" (11.11mm)。1500系列可以从1到22个端子,2000系列可以从1到26个端子。
参数特性:这些终端块具有多种接线选项,包括双焊片、单焊片、绕线、焊针和印刷电路针。它们还具有UL/CSA电气额定值,例如UL 30A/1100V RMS和CSA 20A/300V。
功能详解:终端块设计用于电子/电气电路应用中的表面安装、子面板或底盘连接。它们具有经济的封闭式后部设计,无需昂贵的绝缘条。
应用信息:这些终端块适用于多种接线范围,从22AWG到10AWG,并具有UL认可和CSA认证。
封装信息:文档提供了详细的安装尺寸和整体尺寸,以及钻孔尺寸信息,以便于用户根据需要进行安装和设计。
1507-3/4ST 价格&库存
很抱歉,暂时无法提供与“1507-3/4ST”相匹配的价格&库存,您可以联系我们找货
1507-3/4ST
  • 200+48.61449200+6.28339
