A20210904L1
A20210904L1
    EATON(伊顿)
    插件
    CONNBARRIERSTRIP9CIRC0.375"
A20210904L1 数据手册
Single Row Terminal Blocks A2, LP2 & CB2 Dimensions Inches (Millimeters) Specifications A2 & LP2 Rating: A2: 30A, 300V* LP2: 30A, 150V* CB2: 30A, 300V* Center Spacing: 0.375” or 3/8” (9.52mm) Wire Range: #12-22 AWG Cu Screw Size: #6-32 zinc-plated philslot Torque Rating: 9 lb-in. A203504 LP201204 Base: Standoffs standard for easy flux washing Distance Between Barriers: 0.32” (8.1mm) Recommended PCB Hole Diameter: 0.076” (1.93mm) Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min. Molded Material: Black, UL Rated 94V0 Thermoplastic Breakdown Voltage: 3400V (A2 & LP2); 4100V (CB2). Agency Information: UL File E62622, CSA File 47235; IEC Compliance; CE Certified * 30A Rating achieved with a #10 copper wire crimped to a ring terminal.; 20A Rating without ring terminal. CB2 CB20220407 MOUNTING ENDS ONLY BARRIER & MOUNTING ENDS BARRIER ENDS ONLY Poles A Mounting Ctrs. C Length B Pole Ctrs. C Length 02 03 04 05 06 07 08 09 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 1.13 1.50 1.88 2.25 2.63 3.00 3.38 3.75 4.13 4.50 4.88 5.25 5.63 6.00 6.38 6.75 7.13 7.50 7.88 8.25 8.63 9.00 9.38 – – 1.56 1.93 2.30 2.68 3.06 3.43 3.81 4.18 4.56 4.93 5.31 5.69 6.06 6.43 6.81 7.18 7.56 7.93 8.31 8.68 9.06 9.43 9.81 – – 0.38 0.75 1.13 1.50 1.88 2.25 2.63 3.00 3.38 3.75 4.13 4.50 4.88 5.25 5.63 6.00 6.38 6.75 7.13 1.50 7.88 8.25 8.63 9.00 9.38 0.81 1.18 1.56 1.93 2.31 2.68 3.06 3.43 3.81 4.18 4.56 4.93 5.31 5.68 6.06 6.43 6.81 7.18 7.56 7.93 8.31 8.68 9.06 9.43 9.81 Eaton’s single row terminal blocks may, on occasion, have various cosmetic variations on their ends due to machining operations that achieve the proper number of poles required. Cutting and machining blemishes are permissible and have no effect on the fit, form or function of the product. A2 & LP2   Single Row Terminal Blocks  Part Numbering System Family Terminal Style Base/End Poles Screw Options Options A2 - standard barrier 01* - handwired Blank–std. screws 02 - printed circuit 1 - std. base/ mnt. end 02 to 26 Barrier end LP2 - low profile barrier 02 to 24 Mount end 00 - screws shipped bulk AB* - angle mnt. options (pg 11) A1 to A9 - 0.250˝ QC B1 to B9 - 0.187˝ QC DR* - drilled right angle (pg 11) L1 to L6 marking options (pg 25) MP* mounting plates (pg 11) R30 to R75 - right angle bends (pg 11) S1* - solder lug/flat Covers - (pg 26) 03 - non feed-thru 04 - wire wrap tail 06 - handwired 07 - extended pin 08 - printed circuit 09 - 0.250˝ QC short 10 - 0.187˝ QC 14 - printed circuit 19 - 0.250˝ QC long * A2 only. ** Not compatible with 03-stainless steel screws. *** SEMS screws not available with hardware options 2 - std. base/ barrier end on mount 3 - insulator base/mnt. end 03* - stainless steel 04 - brass nickel-plated 07 - steel SEMS*** 4 - insulator base/barrier end 09* - brass SEMS nickel-plated*** 5 - closed base/ mount end CA** - captive screw WR* - wire ready 6 - closed base/ molded mount end Base/End Note: 5 & 6 Styles only available with 03 terminals. Terminal Styles Inches (Millimeters) EATON www.eaton.com 9 A2 & LP2   Single Row Terminal Blocks  Screw Options (Bulk ordering part numbers are in parentheses) Hardware Options Inches (Millimeters) (Bulk ordering part numbers are in parentheses) (JA2-xx-J) (JB2-xx-J) (JC2-xx-J) † Contact Eaton for desired configuration. Base/End Options Inches (Millimeters) (not available with covers) 10 EATON www.eaton.com Note: On 1, 3 and 5 bases, Eaton may drill a terminal spacing to be a mount end. There will be no fit/form/function effect of mounting the product A2 & LP2   Single Row Terminal Blocks  Mounting Options Inches (Millimeters) Right Angle Bends 07 Terminal Bend Configurations Right angle terminals are offered on the A2 & LP2. Configurations are defined in these dimensions: X = pin extension beyond the block base; Z = length from block base to centerline of the terminal tip. Standard bends consist of the X and Z dimensions shown in the chart. Specify by adding the selected Bend Option Code to the terminal part number. 04 Terminal Bend Configurations Bend Option Code X (minimum) Z Available with insulator base R35 0.01 0.23 No R42 0.08 0.16 No R46 0.12 0.12 No R50 0.16 0.08 No Dimensions in inches. To convert to millimeters, multiply by 25.4. Bend Option Code X (minimum) Z Available with insulator base R35 0.01 0.50 Yes R42 0.08 0.43 Yes R46 0.12 0.39 Yes R50 0.16 0.35 No R53 0.19 0.32 No R66 0.32 0.19 No R75 0.41 0.10 No Dimensions in inches. To convert to millimeters, multiply by 25.4. Drilled Right Angle Angle Brackets Option DR Counterbored holes across mount ends of block enable fastening with two screws at right angles to normal mount position. Option AB Angle brackets enable block to be fastened at right angles to normal mount position. Bulk part number 2AB-J. Mounting Plates Options MP MP Metal inserts with 0.150” dia. hole accept #6 screw. Bulk part number 2MP-J. EATON www.eaton.com 11 CB2   Single Row Terminal Blocks  Part Numbering System Family C B Terminal Style Base/End Poles Screw Options Options 01 - handwired 1 - mount end Blank–std. screws 02 - printed circuit 2 - barrier end 02 to 26 on barrier end AB - angle mounting brackets (pg 13) A7 to A9 - 0.250” QC B7 to B9 - 0.187” QC EB - exit back terminals EF - exit front terminals L1 to L6 marking options (pg 25) LT1 to LT6 marking options (pg 25) MP mtg. plates (pg 13) Covers - (pg 26) 2 CB2 - closed back 07 - extended pin 14 - printed circuit Terminal Styles Inches (Millimeters) Screw Options (Bulk ordering part numbers are in parentheses) CB2 Terminal Exit Options Inches (Millimeters) 12 EATON www.eaton.com 02 to 24 on mount end 07 - steel SEMS standard 09 - brass SEMS nickel-plated CB2   Single Row Terminal Blocks  Hardware Options Inches (Millimeters) (Bulk ordering part numbers are in parentheses) † Contact Eaton for desired configuration. Mounting Options Inches (Millimeters) Right Angle Mounting Bracket Option AB Mounts blocks on PC boards at a right angle. • Protects solder joints. • Bracket snaps securely on block (no hardware required). • Minimum strip length (end positions are usable). • Mount with #6-32 or #8-32 screws (not supplied). • Available on 3 pole configurations and greater Mounting Plates Option MP MP Metal inserts with 0.150” dia. hole accept #6 screw. Bulk part number 2MP-J. EATON www.eaton.com 13 Effective November 2019 Supersedes December 2017 Single Row Terminal Blocks Tools & resources • • • • Webpage Terminal block selector tool Terminal block cross reference Conatct us Eaton Electronics Division 1000 Eaton Boulevard Cleveland, OH 44122 United States Eaton.com/electronics © 2020 Eaton All Rights Reserved Printed in USA Publication No. 10682 June 2020 Eaton is a registered trademark. All other trademarks are property of their respective owners. Follow us on social media to get the latest product and support information.
A20210904L1
1. 物料型号: - A2:标准隔板型 - LP2:低轮廓隔板型 - CB2:闭背型
2. 器件简介: - 单排端子台,用于电气连接。
3. 引脚分配: - 中心间距为0.375英寸(9.52mm)。
4. 参数特性: - 额定电流:30A - 额定电压:A2和LP2为300V,CB2为300V - 工作温度范围:最大105°C,最小-40°C - 材料:黑色,UL评级94V0热塑性材料
5. 功能详解: - 提供了详细的安装端子尺寸和配置选项,包括手焊、印刷电路板、非穿透式、线束尾等。
6. 应用信息: - 适用于需要电气连接的各种应用。
7. 封装信息: - 提供了详细的端子台尺寸和安装选项,包括直角弯头、安装板等。
A20210904L1 价格&库存
很抱歉,暂时无法提供与“A20210904L1”相匹配的价格&库存,您可以联系我们找货
A20210904L1
  • 100+86.10794100+11.07255
