A50110607L5
A50110607L5
    EATON(伊顿)
    CONNBARRIERSTRIP6CIRC0.25"
A50110607L5 数据手册
Terminal Blocks - Single Row Series A5000 & Series CB5000 Single Row Terminal Blocks * Max. rating shown; some options may be rated lower – consult factory. EuroMag Series SPECIFICATIONS Rating: 10A, 300V* Center Spacing: 0.250” (6.35mm) Wire Range: #18-30 AWG Cu Screw Size: #3-48 zinc-plated philslot SEMS screws, wire-ready standard Torque Rating: 4 lb-in. Distance Between Barriers: 0.20” (5.08mm) Recommended PCB Hole Diameter: 0.062” (1.57mm) Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min. Molded Material: Black, UL Rated 94V0 Thermoplastic Breakdown Voltage: 1600V rms Agency Information: UL File E62622; CE Certified Terminal Blocks: Single Row A50110507 CB50220807 Edge Connectors, One-Sided Boards Dimensions - in (mm) A5000 Series Poles 0.75 1.00 1.25 1.50 1.75 2.00 2.25 2.50 2.75 3.00 3.25 3.50 3.75 4.00 4.25 4.50 4.75 5.00 5.25 5.50 5.75 6.00 6.25 6.50 6.75 7.00 7.25 – – 1.06 1.31 1.56 1.81 2.06 2.31 2.56 2.81 3.06 3.31 3.56 3.81 4.06 4.31 4.56 4.81 5.06 5.31 5.56 5.81 6.06 6.31 6.56 6.81 7.06 7.31 7.56 – – BARRIER ENDS A B Pole Overall Centers Length 0.25 0.50 0.75 1.00 1.25 1.50 1.75 2.00 2.25 2.50 2.75 3.00 3.25 3.50 3.75 4.00 4.25 4.50 4.75 5.00 5.25 5.50 5.75 6.00 6.25 6.50 6.75 7.00 7.25 0.56 0.81 1.06 1.31 1.56 1.81 2.06 2.31 2.56 2.81 3.06 3.31 3.56 3.81 4.06 4.31 4.56 4.81 5.06 5.31 5.56 5.81 6.06 6.31 6.56 6.81 7.06 7.31 7.56 #3-48 screw 0.250 (6.35) 0.12 (3.0) Ø 0.43 (10.9) Mount End B Compliance References 02 03 04 05 06 07 08 09 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 MOUNTING ENDS A B Mounting Overall Centers Length Barrier End 0.50 (12.7) 0.25 (6.35) 0.025 (0.64) A Mount End Barrier End CB5000 Series #3-48 screw 0.250 (6.35) 0.12 (3.0) Ø 0.50 (12.7) * Dimensions in inches. To convert to millimeters, multiply by 25.4. Mount End B Barrier End 0.50 (12.7) 0.025 (0.64) Mount End A For additional product information, visit www.eaton.com/connectors Barrier End 4 Terminal Blocks: Single Row Terminal Blocks - Single Row Part Numbering System Series Terminal Style Annn5 nBnCnn5 Base/End nnn nn Screw Options nnn 1 - mount end 2 - barrier end 01* - handwired 02 - printed circuit 04 - wire wrap tail EuroMag Series A5 - standard barrier CB5 - closed back Poles *Only available with mount Options 0nnn7 02 to 30 02 to 28 on mount end base 07 - steel SEMS std. wire ready C1 to C8 - 0.110˝ QC L1 to L6 marking options (pg 26) MP - mounting plate 0.120˝ dia OJ** - over barrier jumper **Contact factory for configuration end base style on A5 Series Edge Connectors, One-Sided Boards Terminal Styles Inches (Millimeters) 0.16 (4.1) 0.40 (10.2) 0.10 (2.54) 0.12 (3.0) 0.055 (1.40) 0.025 (.64) 0.14 (3.6) 01 Handwired Compliance References 0.50 (12.7) 0.032 (0.81) 0.045 (1.14) 02 Circuit Board 0.12 (3.0) 0.025 (0.64) 04 Wire Wrap Tail CB5 Terminal Exit Options Inches (Millimeters) 0.12 (3.0) Exit Rear (std.) Screw Options Wire ready screws standard on all terminal styles 07 Steel SEMS Zinc-Plated (B001-7035-J) 07 Standard Wire Ready Hardware Options Jumpers OJ (OJ12-J) (Bulk ordering part numbers are in parentheses) Inches (Millimeters) (Bulk ordering part numbers are in parentheses) Quick Connects Blade Width 0.110” (For other orientations, contact factory.) C1 (5C1-J)* C2 (5C2-J)* C7 (5C7-J) C8 (5C8-J) C4 (5C4-J)* * N/A on CB5 Series. For additional product information, visit www.eaton.com/connectors 5
A50110607L5 价格&库存
很抱歉,暂时无法提供与“A50110607L5”相匹配的价格&库存,您可以联系我们找货
