RM3216B-103/303-NWWP10
    SUSUMU
    SMD-4P,1.6x3.2mm
    排阻/电阻网络 SMD-4P,1.6x3.2mm 10kΩ ;30kΩ ±0.05% 63mW ±25ppm/℃
RM3216B-103/303-NWWP10 数据手册
Metal thin film chip resistor networks ■RM series AEC-Q200 Compliant Features Thin film surface mount resistors ・ Relative resistance tolerance and relative TCR definable among multiple resistors within package. ・ Relative resistance tolerance: ±0.01%, relative TCR: ±1ppm/°C ・ Number of resistors in package: 2 or higher, standard and custom circuits designs available ・ RG series equivalent reliability and long term stability: less than ±0.1% drift after 10000 hour stress test. ・ RoHS compliant, 100% lead free Applications RM series ・ Precision measurement instrumentation, medical electronics, automotive electronics ・ Voltage divider and amplification circuits that require very precise relative resistance tolerance and TCR ・ Multi step precision amplification circuits for minute signals ◆Part numbering system RM 2012 A - ***/*** - P W X L 10 Series code Size: RM2012, RM3216, RM3225 Packaging quantity: 10(1,000pcs), 50(5,000pcs), T4(4.000pcs) Relative resistance tolerance circuits Relative TCR Absolute TCR Nominal Resistance Value(R1/R2) Absolute resistance tolerance RM 3216 C - *** - 10 Packaging quantity: 10(1,000pcs), 50(5,000pcs),T4(4.000pcs) Series code Size: RM3216, RM3225, RM6432 Custom part number (e.g.)N10 circuits ※ Please contact our sales office regarding custom products including resistance, resistance combination, number of elements, circuit, and others. ※ Standard quantity / reel is 1000 and 5000. Please contact our sales office for custom product's quantity / reel. ※ Standard resistance value pairings are shown as below (Standard products are 2element circuit typeA & typeB only.) ◆Standard resistance value pairings Ratio R1(Ω)R2(Ω) Ratio R1(Ω)R2(Ω) Ratio R1(Ω)R2(Ω) Ratio R1(Ω)R2(Ω) Ratio R1(Ω)R2(Ω) Ratio R1(Ω)R2(Ω) 1:1 1: 2 ※ 37 1k 10k 100k 1k 10k 100k 1k 10k 100k 2k 20k 200k 1:3 1:4 1k 10k 100k 1k 10k 3k 30k 300k 4k 40k 1:5 1:6 1k 2k 10k 1k 10k 5k 10k 50k 6k 60k 1:9 1:10 1k 10k 1k 2k 10k 9k 90k 10k 20k 100k 1:20 1:25 1k 2k 5k 1k 2k 20k 40k 100k 25k 50k 1:50 1:100 : A combi na tio n th a t is in RM3216 but not i n R M 2 0 1 2 , P l ease cont act our sal es. 1K 2K 1K 2K 50k 100k 100k 200k ◆Electrical Specification ○ 4 terminal, 2 element Top view, terminal number ④ ③ Circuit diagram (circuit type A) ④ R1 ① Power ratings (85°C) ④ ① ① ② ② 100 ∼<300 ±0.1%(B) ±0.5%(D) ±0.05%(W) ±0.1%(B) RM3216 0.063W / Element Package RM3225 0.1W / Element 100 ∼<300 0.2W / Package *1 300 ∼ 500k 300 ∼ 500k ±1ppm/℃(X) ±2ppm/℃(W) ±5ppm/℃(V) ±0.05%(W) ±5ppm/℃(V) ±1ppm/℃(X) ±1ppm/℃(X) ±0.1%(B) ±0.5%(D) ±10ppm/℃(N) ±2ppm/℃(W) ±2ppm/℃(W) ±25ppm/℃(P) ±5ppm/℃(V) ±5ppm/℃(V) ±0.05%(W) ±0.1%(B) ±10ppm/℃(N) - ±25ppm/℃(P) ±0.5%(D) ±0.01%(L) ±0.02%(P) ±0.05%(W) ±5ppm/℃(V) ±1ppm/℃(X) ±1ppm/℃(X) ±0.1%(B) ±0.5%(D) ±0.05%(W) ±0.1%(B) ±0.5%(D) ±0.1%(B) ±0.5%(D) ±10ppm/℃(N) ±2ppm/℃(W) ±2ppm/℃(W) ±25ppm/℃(P) ±5ppm/℃(V) ±5ppm/℃(V) - ±1ppm/℃(X) ±10ppm/℃(N) ±2ppm/℃(W) ±2ppm/℃(W) ±25ppm/℃(P) ±5ppm/℃(V) ±5ppm/℃(V) ±0.5%(D) ±0.02%(P) ±0.05%(W) ±0.05%(W) ±0.1%(B) ±0.5%(D) ±0.1%(B) ±0.5%(D) ±2ppm/℃(W) ±5ppm/℃(V) ±1ppm/℃(X) ±2ppm/℃(W) ±2ppm/℃(W) ±5ppm/℃(V) ±5ppm/℃(V) ±0.05%(W) ±0.1%(B) - ±5ppm/℃(V) ±0.05%(W) ±0.1%(B) ±0.5%(D) ±0.05%(W) ±0.1%(B) (designation) ±2ppm/℃(W) ±0.01%(L) ±0.02%(P) ±0.1%(B) ±0.5%(D) Pakaging quantity *1 Resistance Resistance 1
1. 物料型号:文档提到了多种型号,例如RM2012、RM3216、RM3225和RM6432。
2. 器件简介:RM系列电阻是AEC-Q200合规的薄膜表面贴装电阻,具有多种特点,包括可定义的相对电阻容差和温度系数(TCR),适用于精密测量仪器、医疗电子、汽车电子等领域。
3. 引脚分配:文档提供了不同型号电阻的引脚分配图和电路图,例如4端子2元件、6端子3元件和8端子4元件的配置。
4. 参数特性:包括电阻范围、电阻容差、功率额定值、温度系数等。例如,RM2012型号在100~300欧姆范围内的绝对容差为±0.1%(B)或±0.5%(D),功率额定值为每个元件0.05W。
5. 功能详解:文档详细描述了电阻的功能,包括它们的可靠性和长期稳定性,以及在经过长时间应力测试后的漂移量。
6. 应用信息:适用于需要非常精确的相对电阻容差和TCR的电压分压和放大电路,以及微小信号的多步精密放大电路。
7. 封装信息:提供了不同型号的封装尺寸和包装数量,例如RM2012的尺寸为0805,标准包装数量为1000或5000件。
8. 可靠性规范和测试数据:包括短时间过载、寿命(偏置)、高温高湿、温度冲击、高温暴露和耐焊热性测试。
9. TCR线性和电阻随温度变化:提供了RM3216型号在不同条件下的电阻变化和TCR线性数据。
10. 降额曲线:展示了额定功率随环境温度变化的降额曲线。
RM3216B-103/303-NWWP10 价格&库存
很抱歉,暂时无法提供与“RM3216B-103/303-NWWP10”相匹配的价格&库存,您可以联系我们找货
    • 1+17.31240
    • 200+6.70680
    • 500+6.46920
    • 1000+6.35040
