A10221507CA
A10221507CA
    EATON(伊顿)
    插件
    CONNBARRIERSTRP15CIRC0.325"
A10221507CA 数据手册
Terminal Blocks - Single Row Poles 0.98 1.30 1.63 1.95 2.28 2.60 2.93 3.25 3.58 3.90 4.23 4.55 4.88 5.20 5.53 5.85 6.18 6.50 6.83 7.15 7.48 7.80 8.13 8.45 8.78 9.10 9.43 9.75 10.08 10.40 10.73 11.05 11.38 – – 1.37 1.69 2.02 2.34 2.67 2.99 3.32 3.64 3.97 4.29 4.62 4.94 5.27 5.59 5.92 6.24 6.57 6.89 7.22 7.54 7.87 8.19 8.52 8.84 9.17 9.49 9.82 10.14 10.47 10.79 11.12 11.44 11.77 – – BARRIER & MOUNTING ENDS B Pole Ctrs. 0.33 0.65 0.98 1.30 1.63 1.95 2.28 2.60 2.93 3.25 3.58 3.90 4.23 4.55 4.88 5.20 5.53 5.85 6.18 6.50 6.83 7.15 7.48 7.80 8.13 8.45 8.78 9.10 9.43 9.75 10.08 10.40 10.73 11.05 11.38 Dimensions - in (mm) A1000 Series 0.15 (3.8) Ø BARRIER ENDS ONLY C Length 0.72 1.04 1.37 1.69 2.02 2.34 2.67 2.99 3.32 3.64 3.97 4.29 4.62 4.94 5.27 5.59 5.92 6.24 6.57 6.89 7.22 7.54 7.87 8.19 8.52 8.84 9.17 9.49 9.82 10.14 10.47 10.79 11.12 11.44 11.77 0.325 (8.26) 0.50 (12.7) C Mount End Barrier End Compliance References 02 03 04 05 06 07 08 09 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 MOUNTING ENDS ONLY A C Mount Ctrs. Length A102206 Edge Connectors, One-Sided Boards *General industrial applications CB10210707 EuroMag Series SPECIFICATIONS Rating: 20A, 250V* Center Spacing: 0.325” (8.26mm) Wire Range: #14-22 AWG Cu Screw Size: #6-32 zinc-plated philslot wire-ready screws with a #2 driving recess. Torque Rating: 9 lb-in. Base: Standoffs are standard on CB1000 Series for easy flux washing. Distance Between Barriers: 0.26” (6.6mm) Recommended PCB Hole Diameter: 0.070” (1.78mm) Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min. Molded Material: Black, UL Rated 94V0 Thermoplastic Breakdown Voltage: 1600V Agency Information: UL/CSA; IEC Compliance; CE Certified; UL File: E62622, CSA File: 15364 Terminal Blocks: Single Row Series A1000 & Series CB1000 Single Row Terminal Blocks 0.50 (12.7) 0.25 (6.4) B Pole Centers A Mount Centers Mount End Barrier End CB1000 Series 0.325 (8.26) 0.15 (3.8) Ø 0.25 (6.4) 0.60 (15.2) C Mount End Barrier End 0.52 (13.2) 0.27 (6.9) 0.025 (0.64) B Pole Centers A Mount Centers Mount End Barrier End * Dimensions in inches. To convert to millimeters, multiply by 25.4. For additional product information, visit www.eaton.com/connectors 5 Terminal Blocks - Single Row Edge Connectors, One-Sided Boards EuroMag Series Terminal Blocks: Single Row Part Numbering System An 1 n Cn Bn 1 n Series Terminal Style qq A1 - standard barrier CB1 - closed back Covers - (pg 26) q 02 - printed circuit 03* - non feed-thru 04* - wire wrap tail 07 - extended pin Poles Screw Options qq 1 - mount end 2** - barrier end 02 to 36 02 to 34 on mount end base DR - angle mts. (A1 only-pg 7) B1 to B9 - 0.187” QC (all positions) EB - exit back terminals on CB1 w/07 screw option only L1 to L6 marking options (pg 25) LT1 to LT6 marking options (CB1 only-pg 25) MP & MT - mounting plates 0.150 dia (pg 7) R26 & R45 - right angle bends (A1 only-pg 7) †JA, JB & JC - barrier jumpers Inches (Millimeters) 0.35 (8.9) 0.16 (4.1) 0.14 (3.6) qqq Blank - std. screws 03 - stainless steel 07 - steel SEMS & washer (not available with hardware options) CA*** - standard captive screw Terminal Styles 0.055 (1.40) Options qqqq *A1 only **Not available with 03-non feed-thru terminal style ***Not compatible with 03-stainless steel screws †Contact factory for configuration 0.055 (1.40) 0.032 (0.81) 02 Printed Circuit 03 Non Feed-Thru Screw Options Compliance References Base/End 0.54 (13.7) 0.032 (0.81) 0.14 (3.6) 0.055 (1.40) 04 Wire Wrap Tail 0.14 (3.6) 0.032 (0.81) 07 Extended Pin Wire ready screws standard on all terminal styles (Bulk ordering part numbers are in parentheses) Standard Zinc-Plated Steel - (F508-J) 03 Stainless Steel - (F510-J) 07 Zinc-plated Steel Screws - (F522-J) CB1 Terminal Exit Options Inches (Millimeters) 0.275 (6.98) 0.12 (3.0) EB Exit Back Exit Rear (std.) Hardware Options Jumpers (Bulk ordering part numbers are in parentheses) Inches (Millimeters) Quick Connects Blade Width B = 0.187”. (For other orientations, contact factory.) 0.33 (8.4) 0.33 (8.4) JA (JA1-02)* JB (JB1-02)* B1 (1B1-J)** B2 (1B2-J)** B3 (1B3-J)** B4 (1B4-J)** B5 (1B5-J)** B6 (1B6-J)** B7 (1B7-J) B8 (1B8-J) 0.33 (8.4) JC (JC1-02)* *Contact factory for configuration B9 (1B9-J) **N/A on CB1 Series For additional product information, visit www.eaton.com/connectors 6 Terminal Blocks - Single Row Mounting Options Terminal Blocks: Single Row Series A1000 & CB1000 Single Row Terminal Blocks Continued Inches (Millimeters) Right Angle Bends (A1 only) EuroMag Series Right angle terminals are offered on the A1000 Series. Configurations are defined in these dimensions: X = pin extension beyond the block base; Z = length from block base to centerline of the terminal tip. Standard bends consist of the X and Z dimensions shown in the chart. Specify by adding the selected Bend Option Code to the terminal part number. Z Edge Connectors, One-Sided Boards X Bend Option Code X Z R26 (04 terminal only) R45 (07 terminal only) 0.14 (3.5) 0.33 (8.4) 0.09 (2.3) 0.09 (2.3) Dimensions: in (mm) Compliance References Drilled Right Angle (A1 only) (Dimensions in inches) 0.12 5 0.32 0.144 HOLE w/0.312 C' BORE Option DR Counterbored holes across mount ends of block enable fastening with two screws at right angles to normal mount position. Mounting Plates MOUNTING PLATE MP MT Options MP & MT MP Metal inserts with 0.150” (3.8) dia. hole accept #6 screw. MT Metal inserts with tapped hole accept #6-32 screw. Bulk part numbers 1MP-J & 1MT-J. For additional product information, visit www.eaton.com/connectors 7
A10221507CA
物料型号:EAT·N系列A1000和CB1000单排端子台
器件简介:这些端子台适用于一般工业应用,具有20A、250V的额定值,中心间距为0.325英寸(8.26mm),适用于#14-22 AWG铜线。螺丝规格为#6-32,采用锌镀的Philslot线准备螺丝,扭矩等级为9磅英寸。CB1000系列的标准配件包括用于简易清洗的支架。
引脚分配:表格列出了从2到36个端子的不同配置,包括仅安装端、带障碍的安装端和仅障碍端。
参数特性:操作温度范围为-40°C至105°C,模制材料为黑色、UL等级94V0热塑性材料,击穿电压为1600V。
功能详解:文档提供了端子台的详细尺寸、安装选项、端子退出选项和硬件选项。
应用信息:适用于一般工业应用。
封装信息:提供了端子台的尺寸和安装板选项。
A10221507CA 价格&库存
很抱歉,暂时无法提供与“A10221507CA”相匹配的价格&库存,您可以联系我们找货
