562015110
562015110
    CURTISINDUSTRIES
    CONNBARRIERSTRP11CIRC0.563"
562015110 数据手册
Series 5600 .563" (14.29mm) Center-to-Center Spacing Features: Dual Row ‡ Durable, Hi-Temp, phenolic is self-extinguishing, resists breakage and conforms to UL94V-0 ‡ Terminal Flexibility is ideal for surface mount, sub-panel or chassis connections. One thru 22 terminals. 9/16" center-tocenter spacing. ‡ Economical Closed-Back Design does not require costly insulation strip ‡ Broad Wire Range using 8-32 or 10-32 external twin screws, UL recognized for No. 22 AWG to No. 10 AWG. Variations include double solder lug, single solder lug, wire wrap and printed circuit pin ‡ UL Electrical Ratings 50Amp up to 600VAC dependent on options ‡ Field Wiring to 40A ‡ Factory Wiring to 50A ‡ Recognition Various terminal types are UL recognized and CSA certified. Series 5600 Variations UL Standard 1059, Guide No. XCFR2 11/16" ±.032 0 = Flush Mount CSA Guide 22.2 No. 158 BARRIER STYLE 1 = Turret TType Solder Terminal Designed to meet IEC 947-7-1 Series 5600 Dimensions "A" OVERALL DIMENSION W/MTG ENDS .21 .563 1.311 6SeFL¿FatLoQs: "B" MOUNTING DIMENSION .563 .500 "C" OVERALL DIMENSION BARRIERS BOTH SIDES 4X Ø.208 MOUNTING HOLES .420 .810 .438 PC BOARD DRILLING DIMENSIONS .5625 Typ. 2-11 Terminals Ø.079 12-22 Terminals T Ø.093 36 www.curtisind.com Center-to-Center Spacing: .563" (14.29mm) Wire Range: No. 22AWG to No. 8AWG (No. 8 with ring lug for #10 screw only) No. of Terminals: 1 thru 22 Voltage Rating: 600V Tightening Torque: 16 in.-lbs. with #8 screws 20 in.-lbs. with #10 screws Current Rating: 50A with #8 or #10 screw and ring lug 40A with #10 screw 35A with #8 Screw (Options may affect current rating) Housing: Material Phenolic Continuous Use Temp. (UL Index) 150°C (302°F) Flammability Rating 94V-0 Water Absorption (24 hrs. % wt. gain) .1% Breakdown Voltage: Terminal - Terminal 7,500 Vrms Terminal - Ground 6,000 Vrms Curtis Industries A Division of Powers Holdings, Inc. 6SHci¿cDtionssuEMHcttocKDnJH. Dimensions are shown for reference purposes only. 56 0 0 0 0 00 ௘0 How to Order MOLDING DESIGN ] 1 = Barriers Both Sides 2 = w/ Mounting Ends 3 = Y Pin with Barriers 4 = Y Pin with Mounting Ends [ SPECIALS OR OPTIONAL DESIGNS 0 = None 1 = Double Tab, Flat (TB91) 2 = Double Tab, 45° Bend (TB92) 3 = Double Tab, 90° Bend (TB93) 7 = Single Tab, Flat (TB97) 8 = Single Tab, 45° Bend (TB98) 5 Thru 9 to be assigned. TERMINATION DESIGN ] Part No. Digit Terminal Plate Type Screw Type Approval *Field/ Factory 0= STEEL STEEL UR/cUR 2 1= STEEL **BRASS UR 1 ** SEMS NOT AVAILABLE IN BRASS *1 = FACTORY WIRING ONLY 2 = FACTORY & FIELD WIRING [ NUMBER OF POLES AVAILABLE Available 01-22 w/ Mounting Ends 01-22 w/ Barriers Both Ends SCREW SIZE ] 0 = 8-32 Thread 1 = 10-32 Thread “A” (Min-Max) Overall Dim. w/ Mounting Ends “B” (Min-Max) Mounting Dim. 1.551–1.539 1.131–1.119 2 2.116–2.100 1.694–1.682 3 2.680–2.660 2.258–2.242 4 3.245–3.221 2.823–2.803 5 3.809–3.781 3.387–3.363 6 4.374–4.342 3.952–3.924 7 4.938–4.902 4.516–4.484 8 5.503–5.463 5.081–5.045 9 6.067–6.023 5.645–5.605 10 6.632–6.584 6.210–6.166 11 7.196–7.144 6.774–6.726 12 7.761–7.705 7.339–7.287 13 8.325–8.265 7.903–7.847 QUICK CONNECT TERMINALS 14 8.888–8.828 8.468–8.408 15 9.452–9.388 9.030–8.970 .250" x .032" quick connect tabs available in 6 different styles. Tin-plated brass tabs are held in place by terminal screws. Terminal blocks can accommodate 1 to 6 terminations per pole. Factory assembled or shipped bulk. 1 Double Sided Single Sided TB91 TB97 TB92 TB98 TB93 TB99 Series 5600 Accessories 16 10.017–9.949 9.595–9.531 17 10.581–10.509 10.159–10.091 18 11.146–11.070 10.724–10.652 19 11.710–11.630 11.288–11.212 20 12.273–12.193 11.853–11.773 Wire clamp captivated screws eliminate the need for lugs. Available for both 8-32 & 10-32 thread options, these screws accept up to No. 10AWG wire and may be factory installed or shipped bulk. 21 12.837–12.753 12.415–12.335 TERMINAL BLOCK JUMPERS 22 13.402–13.314 12.978–12.898 Jumpers constructed of plated brass permit connections of 2 poles Dimensions shown are ± 0.030" Dimensions are in inches and millimeters unless otherwise speci¿ed. Values in parentheses are metric equivalents. BARRIER STYLE [ SCREW TYPE 0 = Binder Head, Combo Slot, Zinc Plated, Steel 2 = Binder Head, Combo Slot, Nickel Plated, Brass 4 = Wire Clamp Sems, Combo Slot, Zinc Plated, Steel 6 = Quick Connects Tabs Supplied w/ Binder Head (see special options) Dimensions Number of Terminals Dual Row 9 = Single Tab, 90° Bend (TB99) A thru Z to be assigned by engineering for special con¿gurations (optional Mumper available) WIRE CLAMPS Curtis Industries A Division of Powers Holdings, Inc. 1-800-657-0853 37
562015110
物料型号:Curtis Industries生产的Series 5600系列,具有36个双排端子,中心间距为.563" (14.29mm)。
器件简介:该系列端子采用屏障式设计,适用于表面贴装、子面板或机架连接。端子具有高度的灵活性,可使用8-32或10-32的外部双头螺丝,适用于22号至10号AWG的电线。
引脚分配:端子数量从1至22个不等,中心间距为9/16"。
参数特性: - 电压等级:600V - 电流等级:50A(使用8号或10号螺丝和环形端子),40A(仅使用10号螺丝),35A(仅使用8号螺丝) - 紧固扭矩:16 in.-lbs.(使用8号螺丝),20 in.-lbs.(使用10号螺丝) - 材料:酚醛塑料,连续使用温度为150°C (302°F),UL指数为0,符合UL94V-0的阻燃等级
功能详解:端子设计符合IEC 947-7-1标准,具有多种变体,包括双焊端子、单焊端子、绕线端子和印刷电路引脚。
应用信息:适用于需要高电流和高电压应用的场合,如工业自动化、电力系统等。
封装信息:端子块的尺寸和安装孔规格在文档中有详细说明,尺寸公差为±0.030",单位为英寸和毫米。
562015110 价格&库存
很抱歉,暂时无法提供与“562015110”相匹配的价格&库存,您可以联系我们找货
    • 200+142.80753200+18.47434
