1.0mm Pitch, Board-to-Wire LCD Interface Connectors
MDF76 Series
■Increased Plug / Receptacle retention force
Receptacle
Plug
Crimped contact
Jan.1.2023 Copyright 2023 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
Protrusion
■Features
1. High-speed data transfer
Ground contacts opposite the signal contacts
(Receptacle) provide superior impedance matching.
2. EMI protection
Outer shell
Ground contact
■Incorrect insertion prevention
A vertically asymmetrical key form prevents
reverse insertion.
Metal shell provides shielding and ground connections.
3. Increased Plug / Receptacle retention
force
Unique configuration of the receptacle ground
contacts mating with the corresponding plug
increases the retention force between them.
(MDF76-30P-1 Plug mated with MDF76KBW or
MDF76LBRW Receptacles.)
Board side receptacle
4. Incorrect insertion prevention
Built-in polarizing features prevent reverse insertion
of the plug in the receptacle.
5. High board retention force
Metal shell is soldered directly to the PC board.
6. RoHS compliant
All components and materials comply with the
requirements of EU Directive 2002/95/EC.
■Applications
Cable side plug
Notebook computers, desktop computers, Liquid
Crystal Panels, LCD monitors and other devices
requiring discrete wire connections with a lowprofile high performance connectors.
2018.5②
1
MDF76 Series●1.0mm Pitch, Board-to-Wire LCD Interface Connectors
■Product Specifications
Ratings
Current rating
(Note 1)
Wire size
200V AC
Voltage rating
Item
28 to 30 AWG : 1.0A
32 AWG : 0.8A
36 AWG : 0.5A
Operating temperature range
Operating humidity range
-40ç to +85ç (Note 2)
RH 20% to 80%
Storage temperature range
Storage humidity range
-10ç to +60ç (Note 3)
RH 40% to 70% (Note 3)
Specification
Conditions
1. Insulation resistance 100Mø min.
100V DC
2. Withstanding voltage No flashover or insulation breakdown
500V AC / 1minute
3. Contact resistance
40mø max.
20mV max., at 1 mA.
4. Durability
Contact resistance : 80mø max.
50 cycles
No deformation of components affecting performance.
5. Vibration
No electrical discontinuity of 1μs or longer
No damage, cracks or parts dislocation.
Frequency : 10 to 55Hz, single amplitude of 0.75mm,
10 cycles in each of the 3 axial directions
6. Shock
Acceleration of 490m/s2, 11ms duration, sine half-wave,
3 cycles in each of the 3 axis
7. Humidity
Contact resistance : 80mø max.,
Insulation resistance : 50Mø min.
96 hours at 60 ±2ç, and humidity of 90% to 95%
8. Temperature cycle
9. Resistance to
soldering heat
-55ç → 5 to 35ç → 85ç → 5 to 35ç
Times : 30 min.→ 2 min. to 3 min. → 30 min. → 2min. to 3 min.
5 cycle
Reflow
: At the recommended temperature profile
Manual soldering : 300ç for 3 seconds
Note 1:The current rating will differ depending on the wire size used.
Note 2:Includes temperature rise caused by current flow.
Note 3:The term "storage" refers to products stored for a long period prior to mounting and use.
The operating temperature and humidity range covers the non-conducting condition of connectors after board mounting
and the temporary storage conditions of transportation, etc.
■Material / Finish
Plug
Part
Material
Finish
Remarks
Insulator
Polyamide
Color : Beige
UL94V-0
Ground plate
Stainless steel
Tin plated
Crimp contact
Phosphor bronze
Gold plated
Receptacle
Part
Material
Finish
Remarks
Insulator
Polyamide or LCP (Note 4)
Color : Beige or black (Note 5)
UL94V-0
Contacts
Phosphor bronze
Gold plated
Tin plated
Tin plated or gold plated (Note 6)
UL94V-0
Ground contact
Shell
Stainless steel
Note 4 : Low profile receptacles MDF76KBW and MDF76LBRW are polyamide.
High profile receptacles MDF76TW, and MDF76GW are LCP.
Note 5 : Low profile receptacles MDF76KBW, MDF76TW, and MDF76GW are beige.
Reverse mounting MDF76LBRW is black.
Note 6 : Low profile receptacles MDF76KBW and MDF76LBRW have tin plating on the solder leads.
High profile receptacles MDF76TW and MDF76GW have gold plating on the solder leads.
2
■Product Number Structure
Refer to the chart below when determining the product specifications from the product number.
Please select from the product numbers listed in this catalog when placing orders.
●Connector
MDF 76 # – * P – 1 C
1
2
3
4
5
6
1
Series Name : MDF76
3
Number of contacts : 30
2
Form type
4
Connector type
Plug
Blank : Standard
P : Plug
Receptacle (Low profile)
S : Receptalce
KBW : Standard, mid-mount
5
Contact pitch : 1mm
LBRW : Reverse, mid-mount
6
Housing type
Receptacle (High profile)
C : Crimp
TW
GW
: Standard, top board
H : Right angle SMT
●Contacts
MDF 76 – 2836 PCF A
1
1
2
Applicable conductor
2836 : 28 to 36 AWG
2
3
3
Plating
A : Gold plated
Packaging
PCF : Male crimp contact / reel
3
■Plug (Discrete cable)
P=1
6.9
2.3
33.3
31.9
29
Contact No.1 indicator
1.5
34.9
Shown terminated
• Supplied in bag. (100 pieces/bag)
• Contacts supplied separate
All dimensions : mm
Part No.
HRS No.
No. of contacts
Insulator Color
MDF76-30P-1C
547-0918-1
30
Beige
■Crimp contact
Part No.
HRS No.
Packaging
Quantity
Finish
Reel
1 Reel / 30,000
Gold plated
MDF76-2836PCFA(41) 547-0919-4 41
0.75
0.7
●Applicable wire (Tin plated annealed copper wire)
Wire size (Stranded wire conductor)
Jacket diameter
0.6mm max.
30 AWG (7 / 0.10mm)
0.9
2.15
5.95
28 AWG (7 / 0.127mm)
32 AWG (7 / 0.08mm)
0.4mm max.
0.55
36 AWG (7 / 0.05mm)
Note : When using other than the recommended wire, contact nearest Hirose
sales representative.
●Tools
t=0.15
Part No.
HRS No.
Applicator
Type
AP105-MDF76-2836P
901-4613-1
Press
CM-105C
901-0001-0
Extraction tool
DF-C-PO(B)
550-0179-2
All dimensions : mm
4
■Receptacles (Low profile)
●Right angle, Standard, mid-mount, SMT
No.1 (Ground)
31
No.31 (Signal)
Lead pitch=1
No.2 (Signal)
No.32 (Ground)
1.55
Contact pitch = 1
29
3.3
1.9
All dimensions : mm
Part No.
HRS No.
MDF76KBW-30S-1H(55)
547-0606-9 55
No. of contacts
30
Insulator Color
Packaging
Above the mounting surface
Beige
3,000 pcs. / reel
1.0mm
●Right angle, Reverse, mid-mount, SMT
No.32 (Ground)
31
No.2 (Signal)
Lead pitch=1
No.31 (Signal)
No.1 (Ground)
0.2
37.35
0.15
2.8
1.2
0.4
Gold plated
1.55
1.1
40.05
Contact pitch = 1
29
1
3.3
1.9
All dimensions : mm
Part No.
HRS No.
No. of contacts
Insulator Color
Packaging
MDF76LBRW-30S-1H(55)
547-0607-1 55
30
Black
3,000 pcs. / reel
1.1mm
■Receptacles (High profile)
No.1 (Ground)
31
No.31 (Signal)
Lead pitch=1
No.2 (Signal)
No.32 (Ground)
0.2
Gold plated
Contact pitch = 1
1.5
2.3
37.35
40.05
1.2
3.25
0.4
0.8
Gold plated
1
1
37.35
40.05
1.2
0.2
0.15
2.8
0.4
3.45 1.9
29
All dimensions : mm
Part No.
HRS No.
No. of contacts
Insulator Color
Packaging
MDF76TW-30S-1H(55)
547-0912-5 55
30
Beige
2,500 pcs. / reel
1.5mm
5
●Right angle, Standard, top board, SMT
No.1 (Ground)
31
Lead pitch=1
0.4
No.31 (Signal)
No.2 (Signal)
No.32 (Ground)
0.8
1.2
3.25
0.4
Gold plated
2.35
37.35
40.05
3.45 1.3
Contact pitch = 1
29
All dimensions : mm
Part No.
HRS No.
No. of contacts
Insulator Color
Packaging
MDF76GW-30S-1H(55)
547-0916-6 55
30
Beige
2,500 pcs. / reel
2.35mm
■Recommended PCB mounting pattern
●Mid-mount
No.1(Ground) (Note)
31±0.05
For receptacles :
(1)
0.6±0.05
No.2(Signal) (Note)
(0.3)
3.5±0.05
1.5±0.1
(0.5)
3±0.1
MDF76TW-30S-1H(**)
No.32
(Ground)
No.31(Signal)
P=1±0.03
1±0.1
MDF76LBRW-30S-1H(**)
0.8±0.08
29±0.05
2.2±0.05
0.5±0.05
MDF76KBW-30S-1H(**)
37.65±0.05
1.2±0.1
40.65±0.1
Note : For MDF76LBRW, No.32 (Ground and No.31 (Signal) are on left side.
●Top board
31±0.05
For receptacles :
No.1(Ground)
3.25±0.1
MDF76GW-30S-1H(**)
1.5±0.05
P=1±0.05
No.31(Signal)
No.2(Signal)
0.6±0.05
0.8±0.1
No.32
(Ground)
1.8±0.1
(3.9)
0.3±0.15
1.8±0.1
No conductive traces
36.85±0.1
(37.35±0.3)
(40.45)
All dimensions : mm
6
BPackaging Specifications
◆MDF76TW-30S-1H(55)
MDF76GW-30S-1H(55)
2
12
1.95
Ø1
.5 +
Unreeling direction
1.75
Part Number Label
(Ø80)
(42)
56
52.4
Ø13
A
A
0.4
0.2
Unreeling direction
A
2.95
(56.5)
(1.6)
.75
R0
(2)
All dimensions : mm
◆MDF76KBW-30S-1H(55)
2
12
1.8
4
Unreeling direction
1.75
.5
Ø1
A-A
Part Number Label
26.2
A
(Ø80)
(Ø380)
(42)
A
.75
R0
(2)
Unreeling direction
56
52.4
Ø13
0.2
26.2
A-A
(Ø380)
A
0 .1
t=0.4
(56.5)
(2)
2.3
All dimensions : mm
7
BUsage Recommendations
1.Recommended temperature profile
Temperature (ç)
10sMAX
255çMAX
250
220ç
200
30 to 60sec
180ç
150
60 to 120sec
100
Time (Seconds)
Note 1 : Up to 2 cycles of Reflow soldering is possible under the same
conditions, provided that there is a return to normal
temperature between the first and second cycle.
Note 2 : The temperature profile indicates the board surface
temperature at the point of contacts with the connector
terminals.
2.Recommended manual soldering
3.Recommended screen thickness
and open area ratio
4.Board warpage
300±10ç for 3 seconds
5.Cleaning conditions
6.Wire preparation and contact crimping
Refer to "Nylon Connector Use Handbook".
7.Crimped contact extraction
■ Insert the contact retention tool in the insulator body and carefully lift the
molded-in retention tab while pulling on the wire at the same time (Fig. 1).
Do not deflect the molded-in retention tab more than is needed to release
the contact. The tab should return to its initial position after the contact is
removed.
Note : If the tab is not returning to it’s initial position carefully push I back
before inserting the crimped contact.
Permanent breakage of the molded-in retention tab will require
replacement of the entire plug.
Thickness : 0.15mm
Open area ratio : 100%
Maximum of 0.03mm at the connector center, with both ends of the
connector as reference points.
Refer to “Nylon Connector Use Handbook”.
The crimp contact termination must be performed using specified tools.
All dimensions and crimp conditions are listed in applicable Crimp
Condition Table and Crimping Quality Standards Manual.
Contact extraction tool
Plug
Molded-in contact retention tab
Pull-out
Contact
Figure 1. Contact Extraction
8
8.Crimped contact insertion
Contact must be inserted horizontally oriented as shown on Fig. 2
Do NOT attempt to insert crimped contact in any other direction.
Horizontal insertion !
Insert
MDF76-30P-1C
Plug
MDF76-2836PCFA(41)
Crimped contact
Figure 2. Crimped Contact Insertion
9.Connector mating / unmating
Mating / unmating of the connectors should be done in the direction
parallel to the receptacle’s mounting surface. Do not attempt to
mate/unmate in any other direction.
Note : The connectors will self-guide themselves within the 20° angle,
as shown in Fig. 3.
MDF76 # W-30S-1H(**)
Receptacle
20° Max.
MDF76-30P-1C
PCB
Figure 3. Angular mating / unmating
10.Precautions
Do not mate / unmate the connectors when the receptacle is NOT
mounted on the PC board.
Differences in color shade of molded components will not affect form, fit
or function.
Contact HRS if additional information is required.
9
MEMO:
10
MEMO:
11
12
