DF36A-30S-0.4V(52)
DF36A-30S-0.4V(52)
    HRS(广濑)
DF36A-30S-0.4V(52) 数据手册
0.4mm Pitch, 1.5mm Mated Height, Board-to-Fine Coaxial Cable Connectors DF36 Series 1.5±0.15 (Mated height) High contact reliability – Effective mating length of 0.4mm Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. (0.4) (Effective mating length) Enhanced shielding (standard type) Plug ■Features 1. Small mated height and board occupied space Small pitch (0.4mm) and mated height (1.5mm) allows use in space-restricted areas. Standard type : mated height 1.5mm, depth 4.4mm Saving space type: mated height 1.5mm, depth 2.8mm Plug : Height 1.33mm, depth 2.8mm 2. Enhanced shielding and ground connections Metal covers on the plug and receptacle connect to each other with a reliable multi-point ground contacts, assuring reliable ground connection and EMC protection. Receptacle Ground contacts Fully mated Multi-point contacts Enhanced shielding (Space Saving type) 3. Reliable lock Fully mated condition is assured with reliable locks at 4 locations, confirming it with a distinct tactile click. 4. Reliable electrical and mechanical connection Despite it’s small mated height, unique contact configuration assures highly reliable connection, with effective mating length of 0.4mm. Fully mated 5. Solder wicking prevention Nickel barriers prevent solder wicking in the critical contact areas. 4-point lock: 2 points at each end 6. Durable plug construction Formed metal shells on the top and side surfaces form a strong and rigid assembly. 7. RoHS, Halogen-free* *As defined by IEC61249-2-21 Br-900 ppm maximum,Cl-900 ppm maximum, Cl+Br combined-1,500 ppm maximum ■Receptacle for conductivity tests We have a line-up of connectors for inspection, usable for electrical testing of both standard type and space saving type. Distinct tactile click In cases where the application will demand a high level of reliability, such as automotive, please contact a company representative for further information. 2017.6e 1 DF36 Series●0.4mm Pitch, 1.5mm Mated Height, Board-to-Fine Coaxial Cable Connectors ■Product Specifications 0.25A (42 AWG) 0.25A (44 AWG) (Note 3) 0.1A (46 AWG) Current rating Ratings Voltage rating 30V AC Item 1.Insulation resistance 50Mø min -35 to +85°C (Note 1) 20 to 80% Storage temperature range Storage humidity range -10 to +60°C (Note 2) 40 to 70% (Note 2) Specification Conditions 100V DC 2.Withstanding voltage No flashover or insulation breakdown 100V AC / 1 minute 3.Contact resistance Signal : 80mø max., Ground : 80mø max. 100mA (DC or 1,000Hz) 4.Vibration No electrical discontinuity of 1μs or longer No damage, cracks or parts dislocation. Frequency : 10 to 55Hz, single amplitude of 0.75 mm, 10 cycles in each of the 3 axial directions Contact resistance (Change from initial value) 50mø max. Insulation resistance : 25Mø min. No damage, cracks or parts dislocation. Contact resistance (Change from initial value) 50mø max. Insulation resistance : 25Mø min. No damage, cracks or parts dislocation. 96 hours at 40 ±2°C, and humidity of 90 to 95% 5.Humidity Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Operating temperature range Operating humidity range 6.Temperature cycle Temperature : -55°C / 5 to 35°C / 85°C / 5 to 35°C Time : 30 min. / 2 to 3 min. / 30 min. / 2 to 3 min. 5 cycles 7.Durability Contact resistance (Change from initial value) 50mø max. 30 cycles No damage, cracks or parts dislocation. 8.Resistance to soldering heat No deformation of components affecting performance. Reflow : At the recommended temperature profile Manual soldering : 350°C for 3 seconds Note 1 : Includes temperature rise caused by current flow. Note 2 : The term "storage" refers to products stored for a long period prior to mounting and use. The operating temperature and humidity range covers the non-conducting condition of connectors after board mounting and the temporary storage conditions of transportation, etc. Note 3 : With only the connector portion at an elevated temperature level, the rated current value is set. ■Materials / Finish Item Receptacle (Standard) Plug (Standard) Item Receptacle (Space-saving) Plug (Space-saving) 2 Part Insulator Contacts Metal cover Insulator Contacts Metal shell Material LCP Phosphor bronze Phosphor bronze LCP Phosphor bronze Phosphor bronze Finish Color : Black Gold plating Tin plating Color : Natural (Beige), Black Gold plating Tin plating Remarks UL94V-0 ------------UL94V-0 ------------- Part Insulator Contacts Metal cover Insulator Contacts Metal shell Material LCP Phosphor bronze Phosphor bronze LCP Phosphor bronze Phosphor bronze Finish Color: Black Gold plating Gold plating Color : Natural (Beige), Black Gold plating Gold plating Remarks UL94V-0 ------------UL94V-0 ------------- DF36 Series●0.4mm Pitch, 1.5mm Mated Height, Board-to-Fine Coaxial Cable Connectors ■Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. ●Connector DF 36 A J – * S – 0.4 V (**) 1 2 3 4 5 6 7 8 9 DF 36 A J – * P – SHL Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1 1 2 3 2 3 4 5 6 10 4 Series name : DF Series No. : 36 Connector style Receptacle/shell A : Standard Blank : Space-saving Plug Blank : Standard 5 Insulator type J : Receptacles for conductivity tests Blank : Standard or space-saving P : Single-row plug Number of contacts Standard : 15 to 50 Space-saving : 15 to 25 Receptacles for conductivity tests : 15 to 50 6 7 8 9 10 Connector style S : Single-row receptacle P : Single-row plug Contact pitch: 0.4mm Termination type V : Straight SMT SD : Fine coaxial cable plug Packaging (51) : Embossed tape packaging Installation item (separate) SHL : Metal cover ■Combinations ●Standard use DF36(A)-*S-0.4V(**) + DF36(A)-*P-ASSY DF36-*P-0.4SD(**) DF36(A)-*P-SHL Note: The product specification of the above combination is shown on page 2. ( ) ●Receptacle test DF36(A)-*S-0.4V(**) + DF36(A)J-*P-ASSY • • Note DF36-*P-0.4SD(**) DF36(A)J-*P-SHL Note: This harness item is only usable for the receptacle test. For the product specification of the above combination, please contact our sales department. ( ) ●Plug test DF36(A)J-*S-0.4V(**) • • Note + DF36(A)-*P-ASSY DF36-*P-0.4SD(**) DF36(A)-*P-SHL Note : This harness item is only usable for the plug test. For the product specification of the above combination, please contact our sales department. π : ASSY means a harness item. ( ) 3 DF36 Series●0.4mm Pitch, 1.5mm Mated Height, Board-to-Fine Coaxial Cable Connectors ■Receptacles - Standard, with metal cover B±0.2 A±0.15 P=0.4±0.1 0.15±0.05 (0.95) Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. (C) Lot No. 1.5±0.15 CAV No. Vacuum pick-up area 4.4±0.2 (0.87) Contact No.1 All dimensions : mm Part No. HRS No. No. of Contacts A DF36A-15S-0.4V(**) 662-4509-5-** 15 5.6 9.66 2.6 DF36A-25S-0.4V(**) 662-4011-4-** 25 9.6 13.66 2.6 DF36A-30S-0.4V(**) 662-4017-0-** 30 11.6 15.66 3.0 DF36A-40S-0.4V(**) 662-4003-6-** 40 15.6 19.66 3.0 DF36A-45S-0.4V(**) 662-4008-0-** 45 17.6 21.66 3.0 DF36A-50S-0.4V(**) 662-4043-0-** 50 19.6 23.66 3.0 B C [Specifications number] - * *, (* *) (51) : Embossed tape packaging (4,000 pcs/reel) Note 1 : Tape and reel packaging (4,000 pcs/reel). Order by number of reels. Note 2 : The 15 pos. does not have a lot stamp. BRecommended PCB mounting pattern 1.05±0.05 0.4±0.02 0.25±0.02 Contact No.15 3.85±0.05 3.2±0.05 2.7±0.05 2.1±0.05 0.7±0.05 0.3±0.05 1.05±0.05 Contact No.1 ●25 pos. 9.47±0.05 7.09±0.05 6±0.05 5.6±0.02 3.85±0.05 3.2±0.05 2.7±0.05 2.1±0.05 0.7±0.05 0.3±0.05 ●15 pos. Contact No.1 6.7±0.05 11.09±0.05 13.47±0.05 6±0.05 7.09±0.05 9.47±0.05 ●40 pos. 0. 25 ± 0. 05 Contact No.30 1.7±0.05 6.7±0.05 11.6±0.02 13.09±0.05 15.47±0.05 P=0.4±0.02 Contact No.1 19.47±0.05 17.09±0.05 16±0.05 15.6±0.02 11±0.05 7±0.05 2±0.05 3.85±0.05 3.2±0.05 0.25±0.02 2.7±0.05 2.1±0.05 0.7±0.05 0.3±0.05 1.05±0.05 Contact No.1 15.47±0.05 13.09±0.05 11.5±0.05 6.5±0.05 2.5±0.05 C 1.05±0.05 ●30 pos. 3.85±0.05 3.2±0.05 2.7±0.05 2.1±0.05 0.7±0.05 0.3±0.05 P=0.4±0.02 0.25±0.02 Contact No.25 1.7±0.05 1.3±0.05 Ground areas 4 13.47±0.05 11.09±0.05 10±0.05 9.6±0.02 5.6±0.05 2.2±0.05 1.7±0.05 6.4±0.05 10.4±0.05 15.1±0.05 17.09±0.05 19.47±0.05 P=0.4±0.02 0.25±0.02 Contact No.40 DF36 Series●0.4mm Pitch, 1.5mm Mated Height, Board-to-Fine Coaxial Cable Connectors BRecommended PCB mounting patterns ●50 pos. 21.47±0.05 19.09±0.05 18±0.05 17.6±0.02 13.4±0.05 10±0.05 5.6±0.05 2.2±0.05 23.47±0.05 21.09±0.05 20±0.05 19.6±0.02 16±0.05 12.8±0.05 8.8±0.05 5.6±0.05 1.6±0.05 Contact No.1 P=0.4±0.02 0.25±0.02 Contact No.45 3.85±0.05 3.2±0.05 2.7±0.05 2.1±0.05 0.7±0.05 0.3±0.05 1.05±0.05 Contact No.1 P=0.4±0.02 0.25±0.05 Contact No.50 1.7±0.05 1.7±0.05 6.7±0.05 12.1±0.05 17.1±0.05 19.09±0.05 21.47±0.05 6.7±0.05 14.1±0.05 19.1±0.05 21.09±0.05 23.47±0.05 Ground areas ■Receptacles - Space-saving B±0.2 A±0.15 P=0.4±0.1 0.15±0.05 (2.8) (0.87) Contact No.1 CAV No. Lot No. (C) 1.5±0.15 (0.95) Vacuum pick-up area All dimensions : mm HRS No. No. of Contacts A B C D DF36-15S-0.4V(**) 662-4031-1-** 15 5.6 9.66 2.6 8.28 DF36-20S-0.4V(**) 662-4039-3-** 20 7.6 11.66 2.6 10.28 DF36-25S-0.4V(**) 662-4005-1-** 25 9.6 13.66 2.6 12.28 Part No. [Specifications number] - * *, (* *) (51) : Embossed tape packaging (5,000 pcs/reel) Note 1 : Tape and reel packaging (5,000 pcs/reel). Order by number of reels. 0.3±0.05 0.7±0.05 2.1±0.05 BRecommended PCB mounting pattern A±0.02 Contact No.1 3.1±0.05 Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 3.85±0.05 3.2±0.05 2.7±0.05 2.1±0.05 0.7±0.05 0.3±0.05 1.05±0.05 ●45 pos. P=0.4±0.02 0.25±0.02 1.19±0.05 D±0.05 Ground areas 5 DF36 Series●0.4mm Pitch, 1.5mm Mated Height, Board-to-Fine Coaxial Cable Connectors ■Plug ●Separate metal cover required '#-¤%#&* 6¤%#&* 8dciVXiCd#&  Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 86KCd# E2%#)¤%#& 7¤%#&* All dimensions : mm HRS No. No. of Contacts A B C D Packing DF36C-15P-0.4SD(**) Part No. 662-4035-2 ** 15 11.4 5.6 6.6 7.5 5,000 pcs./reel DF36-20P-0.4SD(**) 662-4040-2 ** 20 12.6 7.6 8.6 9.5 5,000 pcs./reel DF36-25P-0.4SD(**) 662-4006-4 ** 25 14.6 9.6 10.6 11.5 5,000 pcs./reel DF36-30P-0.4SD(**) 662-4018-3 ** 30 16.6 11.6 12.6 13.5 5,000 pcs./reel DF36-40P-0.4SD(**) 662-4002-3 ** 40 20.6 15.6 16.6 17.5 5,000 pcs./reel DF36-45P-0.4SD(**) 662-4009-2 ** 45 22.6 17.6 18.6 19.5 5,000 pcs./reel DF36-50P-0.4SD(**) 662-4044-3 ** 50 24.6 19.6 20.6 21.5 5,000 pcs./reel Note 1 : Tape and reel packaging(5,000 pcs/reel) order by number of reels. Note 2 : The metal cover is required for fine coaxial cable termination. B±0.15 Pitch maintaining tape Note 1 Laminated tape D MAX 0.33 MAX(Jacket) 0.47±0.03 (Ground bar) Note 1 : The pitch maintaining tape can be left in place during the termination process. Use high quality tape. Note 2 : Contact Hirose for Termination Procedures. 6 0.5 +0.1 0 2.5 MIN 0.2 MAX(Insulator) 5 MIN C±0.1 Inner conductor (Pre soldering required) 0.3±0.05 4 MIN 1.27±0.05(Cut dimension) 3 MIN 10±3 P=0.4±0.07 0.05 MAX Outer shield (for individual conductor) BRecommended Fine Coaxial Cable Preparation DF36 Series●0.4mm Pitch, 1.5mm Mated Height, Board-to-Fine Coaxial Cable Connectors ■Metal cover - Required for assembly and termination of the Plug 0.25±0.1 2.8±0.1 A±0.15 [ Standard ] All dimensions : mm HRS No. Plating No.of Contacts A DF36A-15P-SHL 662-4511-7 15 9.92 DF36A-25P-SHL 662-4007-7 25 13.92 DF36A-30P-SHL 662-4019-6 30 15.92 DF36A-40P-SHL 662-4013-0 40 19.92 DF36A-45P-SHL 662-4010-1 45 21.92 DF36A-50P-SHL 662-4045-6 50 23.92 Tin Note 1 : Reel packaging (10,000 pcs/reel). Order by number of reels. All dimensions : mm [ Space-saving ] Part No. HRS No. DF36-15P-SHL 662-4026-1 DF36-20P-SHL 662-4041-5 DF36-25P-SHL 662-4012-7 Plating No. of Contacts A 15 9.92 20 11.92 25 13.92 Gold Note 1 : Reel packaging (10,000 pcs/reel). Order by number of reels. BPackaging Specification ●Reel Dimensions &#,*¤%#& #* -¤%#& )¤%#& ¢& &#&(* KVXjjbe^X`"jeVgZVXZciZg % % #& ●Embossed Carrier Tape Dimensions – Standard Receptacle '#( EVgiCjbWZgAVWZa ¢'&¤%#- 8¤%#& '¤%#&* %#' ¢-% ¢(-%¤' '¤ %#* 7¤%#& 6¤%#( ¢&(¤ 9 '% :B6M % & %#'¤%#%* G% #,* %# Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Part No. Part No. JcgZZa^c\Y^gZXi^dc All dimensions : mm HRS No. No. of Contacts A B C D E DF36A-15S-0.4V(**) 662-4509-5 ** 15 32 28.4 14.2 32.4 38.4 DF36A-25S-0.4V(**) 662-4011-4 ** 25 32 28.4 14.2 32.4 38.4 DF36A-30S-0.4V(**) 662-4017-0 ** 30 32 28.4 14.2 32.4 38.4 DF36A-40S-0.4V(**) 662-4003-6 ** 40 44 40.4 20.2 44.4 50.4 DF36A-45S-0.4V(**) 662-4008-0 ** 45 44 40.4 20.2 44.4 50.4 DF36A-50S-0.4V(**) 662-4043-0 ** 50 44 40.4 20.2 44.4 50.4 Note 1 : Tape and reel packaging (4,000 pcs/reel). 7 DF36 Series●0.4mm Pitch, 1.5mm Mated Height, Board-to-Fine Coaxial Cable Connectors BPackaging Specification ●Reel Dimensions * % % #& -¤%#& )¤%#& ¢& # %#-(* KVXjjbe^X`"jeVgZVXZciZg &#,*¤%#& ●Embossed Carrier Tape Dimensions – Space saving Receptacle &#-* EVgiCjbWZgAVWZa %#' Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. '¤ %#* ¢-% ¢(-%¤' ¢&(¤ 7¤%#& 6¤%#( '¤%#&* 8¤%#& ¢'&¤%#- % & %#'¤%#%* G% #,* %# 9 '% :B6M JcgZZa^c\Y^gZXi^dc All dimensions : mm HRS No. No. of Contacts A B C D E DF36-15S-0.4V(**) 662-4031-1 ** 15 32 28.4 14.2 32.4 38.4 DF36-20S-0.4V(**) 662-4039-3 ** 20 32 28.4 14.2 32.4 38.4 DF36-25S-0.4V(**) 662-4005-1 ** 25 32 28.4 14.2 32.4 38.4 Part No. Note 1 : Tape and reel packaging (5,000 pcs/reel). BPackaging Specification #* ¢& -¤%#& )¤%#& % % #& ●Reel Dimensions &#,*¤%#& ●Plug &#- EVgiCjbWZgAVWZa ¢'&¤%#8¤%#& '¤%#&* %#' #,* ¢-% ¢(-%¤' %#* '¤ % % #& 9 '% :B6M G% %#'¤%#%* 7¤%#& 6¤%#( ¢&(¤ JcgZZa^c\Y^gZXi^dc All dimensions : mm Part No. HRS No. No. of Contacts A B C D E DF36C-15P-0.4SD(**) 662-4035-2 ** 15 32 28.4 14.2 32.4 32.4 DF36-20P-0.4SD(**) 662-4040-2 ** 20 32 28.4 14.2 32.4 32.4 DF36-25P-0.4SD(**) 662-4006-4 ** 25 32 28.4 14.2 32.4 32.4 DF36-30P-0.4SD(**) 662-4018-3 ** 30 32 28.4 14.2 32.4 32.4 DF36-40P-0.4SD(**) 662-4002-3 ** 40 44 40.4 20.2 44.4 44.4 DF36-45P-0.4SD(**) 662-4009-2 ** 45 44 40.4 20.2 44.4 44.4 DF36-50P-0.4SD(**) 662-4044-3 ** 50 44 40.4 20.2 44.4 44.4 Note 1 : Tape and reel packaging (5,000 pcs/reel). 8 DF36 Series●0.4mm Pitch, 1.5mm Mated Height, Board-to-Fine Coaxial Cable Connectors BExtraction tool For details about the extraction tool, please contact your Hirose sales representative. BUsage Recommendations 1.Recommended temperature profile Temperature (ç) 250ç 250 220ç 200 60sec max 180ç Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 150 150ç 90 to 120sec 100 50 Room temperature 0 50 100 150 200 250 300 Time (sec.) Solder composition : Paste, 96.5%Sn/3.0%Ag/0.5%Cu Note 1 : Up to 2 cycles of Reflow soldering are possible under the same conditions, provided that there is a return to normal temperature between the first and second cycle. Note 2 : The temperature profile indicates the board surface temperature at the point of contacts with the connector terminals. 2.Recommended manual soldering 3.Recommended screen thickness and open area ratio (Pattern area ratio) Manual soldering : 350ç for 3 seconds Do NOT use flux compound when manual soldering. Standard Thickness : 0.1mm Open area ratios : Lead terminal : 90% Ground terminal : 100% Space-saving Thickness : 0.1mm Open area ratios : Lead terminal : 90% Ground terminal : 90% 4.Board warpage Maximum of 0.02mm at the connector center, with both ends of the connector as reference points. 5.Cleaning conditions IPA (Isopropyl Alcohol) cleaning is permitted. (Cleaning is not recommended as it may change the feel of the mating and un-mating of the connector. Please contact your Hirose sales representative for information if you plan to use any other cleaning agents.) 9 DF36 Series●0.4mm Pitch, 1.5mm Mated Height, Board-to-Fine Coaxial Cable Connectors BPrecautions Precautions ■Mating / un-mating [ Standard ] Mate the plug with the receptacle by pressing straight against the entire plug surface. Do NOT mate the plug while holding by the terminated cable. Use a dedicated extraction tool to un-mate the plug. Insert the tool under either end of the plug (clearance) and pull straight up as illustrated below. Please refrain from removing by holding the electrical cable, otherwise this may result in cable disconnection, connector breakage and so on. Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Extraction tool Plug End side (clearance) [ Space-saving ] Mate the plug with the receptacle by pressing straight against the entire plug surface, the same as the standard. Use a dedicated extraction tool to un-mate the plug. Insert the tool under the plug at the front side (clearance) and pull straight up, as illustrated below. Do NOT mate / un-mate the connectors when receptacle is not mounted on the board. Please refrain from removing by holding the electrical cable, otherwise this may result in cable disconnection, connector breakage and so on. Extraction tool Extraction tool Front side Plug End side (clearance) ■Do not mate / un-mate the connectors when receptacle is not mounted on the board. ■In the manual soldering process, don't carry out the flux coating which will cause a flux blister on the connector. ■Different production lots may exhibit different shades of the insulator materials. No affect on form, fit or function of the connectors. ■Excessive scoop insertion or extraction may result in damage. 10 DF36 Series●0.4mm Pitch, 1.5mm Mated Height, Board-to-Fine Coaxial Cable Connectors Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. MEMO : 11 Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. DF36 Series●0.4mm Pitch, 1.5mm Mated Height, Board-to-Fine Coaxial Cable Connectors USA: HIROSE ELECTRIC (U.S.A.), INC. HEADQUARTERS CHICAGO OFFICE 2300 Warrenville Road, Suite 150, Downers Grove, IL 60515 Phone : +1-630-282-6700 http://www.hirose.com/us/ USA: HIROSE ELECTRIC (U.S.A.), INC. SAN JOSE OFFICE 2841 Junction Ave, Suite 200 San Jose, CA. 95134 Phone : +1-408-253-9640 Fax : +1-408-253-9641 http://www.hirose.com/us/ USA: HIROSE ELECTRIC (U.S.A.), INC. DETROIT OFFICE (AUTOMOTIVE) 17197 N. Laurel Park Drive, Suite 253, Livonia, MI 48152 Phone : +1-734-542-9963 Fax : +1-734-542-9964 http://www.hirose.com/us/ USA: HIROSE ELECTRIC (U.S.A.), INC. BOSTON OFFICE 300 Brickstone Square Suite 201, Andover, MA 01810 Phone : +1-978-662-5255 THE NETHERLANDS: HIROSE ELECTRIC EUROPE B.V. Hogehillweg #8 1101 CC Amsterdam Z-O Phone : +31-20-6557460 Fax : +31-20-6557469 http://www.hirose.com/eu/ GERMANY: HIROSE ELECTRIC EUROPE B.V. GERMAN BRANCH Schoenbergstr. 20, 73760 ostfildern Phone : +49-711-456002-1 Fax : +49-711-456002-299 http://www.hirose.com/eu/ GERMANY: HIROSE ELECTRIC EUROPE B.V. NUREMBERG OFFICE Neumeyerstrasse 22-26, 90411 Nurnberg Phone : +49-911 32 68 89 63 Fax : +49-911 32 68 89 69 http://www.hirose.com/eu/ GERMANY: HIROSE ELECTRIC EUROPE B.V. HANOVER OFFICE Bayernstr. 3, Haus C 30855 Langenhagen, Germany Phone : +49-511 97 82 61 30 Fax : +49-511 97 82 61 35 http://www.hirose.com/eu/ FRANCE: HIROSE ELECTRIC EUROPE B.V. PARIS OFFICE Regus La Garenne Colombes,Place de La Belgique, 71 Boulevard National La Garenne Colombes, 92250, France Phone : +33 (0) 1 7082 3170 Fax : +33 (1) 7082 3101 http://www.hirose.com/eu/ UNITED KINGDOM: HIROSE ELECTRIC EUROPE BV (UK BRANCH) 4 Newton Court, Kelvin Drive, Knowlhill, Milton Keynes, MK5 8NH Phone : +44-1908 202050 Fax : +44-1908 202058 http://www.hirose.com/eu/ CHINA: HIROSE ELECTRIC (SHANGHAI) CO., LTD. 18, Enterprise Center Tower 2, 209# Gong He Road, Jing’an District, Shanghai, CHINA 200070 Phone : +86-21-6391-3355 Fax : +86-21-6391-3335 http://www.hirose.com/cn/ CHINA: HIROSE ELECTRIC (SHANGHAI) CO.,LTD. BEIJING BRANCH A1001, Ocean International Center, Building 56# East 4th Ring Middle Road, ChaoYang District, Beijing, 100025 Phone : +86-10-5165-9332 Fax : +86-10-5908-1381 http://www.hirose.com/cn/ CHINA: HIROSE ELECTRIC TECHNOLOGIES (SHENZHEN) CO., LTD. Room 09-13, 19/F, Office Tower Shun Hing Square, Di Wang Commercial Centre, 5002 Shen Nan Dong Road, Shenzhen City, Guangdong Province, 518008 Phone : +86-755-8207-0851 Fax : +86-755-8207-0873 http://www.hirose.com/cn/ HONG KONG: HIROSE ELECTRIC HONGKONG TRADING CO., LTD. Room 1001, West Wing, Tsim Sha Tsui Centre, 66 Mody Road, Tsim Sha Tsui East, Kowloon, Hong Kong Phone : +852-2803-5338 Fax : +852-2591-6560 http://www.hirose.com/hk/ TAIWAN: HIROSE ELECTRIC TAIWAN CO., LTD. 103 8F, No.87, Zhengzhou Rd., Taipei Phone : +886-2-2555-7377 Fax : +886-2-2555-7350 http://www.hirose.com/tw/ KOREA: HIROSE KOREA CO.,LTD. 143, Gongdan 1-daero, Siheung-si, Gyeonggi-do, 15084, Korea Phone : +82-31-496-7000 Fax : +82-31-496-7100 http://www.hirose.co.kr/ SINGAPORE: INDIA: HIROSE ELECTRIC SINGAPORE PTE. LTD. DELHI LIAISON OFFICE HIROSE ELECTRIC SINGAPORE PTE. LTD. 03, Anson Road, #20-01, Springleaf Tower, Office NO.552, Regus-Green Boulevard, Level5, Tower C, Sec62, Plot B-9A, Block B, Noida, 201301, Uttar Pradesh, India Singapore 079909 Phone : +91-12-660-8018 Phone : +65-6324-6113 Fax : +91-120-4804949 Fax : +65-6324-6123 http://www.hirose.com/sg/ http://www.hirose.com/sg/ INDIA: HIROSE ELECTRIC SINGAPORE PTE. LTD. BANGALORE LIAISON OFFICE Unit No-403, 4th Floor, No-84, Barton Centre, Mahatma Gandhi (MG) Road, Bangalore 560 001, Karnataka, India Phone : +91-80-4120 1907 Fax : +91-80-4120 9908 http://www.hirose.com/sg/ MALAYSIA: THAILAND: PENANG REPRESENTATIVE OFFICE BANGKOK OFFICE (REPRESENTATIVE OFFICE) 73-3-1, Ideal@The One, Jalan Mahsuri, Bayan Unit 4703, 47th FL., 1 Empire Tower, South Sathorn Road, Yannawa, Sathorn, Bangkok 10120 Thailand Lepas Penang, 11950, Malaysia Phone : +66-2-686-1255 Phone : +604-648-5536 Fax : +66-2-686-3433 http://www.hirose.com/sg/ http://www.hirose.com/sg/ ® 12 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN TEL: +81-45-620-3526 Fax: +81-45-591-3726 http://www.hirose.com http://www.hirose-connectors.com The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use. The contents of this catalog are current as of date of 06/2017. Contents are subject to change without notice for the purpose of improvements.
DF36A-30S-0.4V(52) 价格&库存
很抱歉,暂时无法提供与“DF36A-30S-0.4V(52)”相匹配的价格&库存,您可以联系我们找货
