NPPN022FJFN-RC
NPPN022FJFN-RC
    SULLINS
    CONNHEADER.079"4POS
NPPN022FJFN-RC 数据手册
8 7 4 5 6 1 2 3 REVISIONS F REV. ECO. NO DESCRIPTION DATE BY A 611 INITIAL RELEASE 6/15/2005 TT B 733 UPDATE SIDE VIEW 9/19/2005 TT C 1166 D 1811 ADDED NYLON MATL. OPTION 10/06/2006 MV 1/09/09 JH ADD POSI. 2 & 3, UPDATE P/N CODING, VIEWS, TOLERANCE BLOCK F E E .191 4.85 A±.004 [ .10] D .031±.002 0.80±0.05 D .079±.002 2.00±0.05 .079±.002 2.00±0.05 .079±.004 2.00±0.10 .020±.002 0.50±0.05 A±.008 [ .20] RECOMMENDED PCB LAYOUT 02-20, 0.20mm MAX. 21-40, 0.30mm MAX. C C .079±.002 2.00±0.05 B±.014 [ .35] .057±.002 1.45±0.05 .073±.008 1.85±0.20 .283 7.20 B A B NOTES: 1. INSULATOR MATERIAL: SEE PART NUMBER CODING. 2. CONTACT MATERIAL: PHOSPHOR BRONZE. 3. CONTACT PLATING: SEE PART NUMBER CODING. 4. CURRENT RATING: 1 AMP. 5. INSULATOR RESISTANCE: 5000 MEGOHMS MIN. 6. CONTACT RESISTANCE: 20 MILLIOHMS MAX. 7. DIELECTRIC WITHSTANDING: AC 500V. 8. OPERATING TEMPERATURE: -40° C TO +105° C. 9. *PROCESSING TEMP.: 260° C FOR 10 SECS MAX. .079±.004 2.00±0.10 .008±.002 0.20±0.05 UNLESS OTHERWISE SPECIFIED: Pb *INDICATED TEMPERATURE AND TIME IS FOR COMPONENT INSULATOR. HIGHER PROCESSING TEMPERATURES MAY BE USED, PROVIDED HEAT IS APPLIED FROM BACK SIDE OF PCB, AND INSULATOR DOES NOT EXCEED INDICATED TEMPERATURE AND TIME. 8 7 .118±.008 3.00±0.20 6 DIMENSIONS ARE IN INCHES[MM] TOLERANCES: ANGULAR: 5 .X= .012 [.30] .XX= .008 [.20] .XXX= .006 [.15] SURFACE FINISH: 63 Ra REMOVE ALL BURRS AND SHARP EDGES .010 MAX RoHS COMPLIANT 5 4 DRAWN NAME 1/10/09 JH THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT DESCRIPTION TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY PART NUMBER AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. HEADER, FEMALE 2mm CC, 2 ROWS, RA NPxNxx2FJFN-RC SIZE DWG. NO. C INTERPRET DIMENSIONS AND GEOMETRIC TOLERANCING PER: ANSI Y14.5M-1994 3 DATE REV 10461 SCALE: 12:1 2 D SHEET 1 OF 1 1 FILE NAME: Z:\COMPONENTS\Taiwan\10461, NPxNxx2FJFN-RC PRINT: 3/4/2009 A
NPPN022FJFN-RC 价格&库存
很抱歉,暂时无法提供与“NPPN022FJFN-RC”相匹配的价格&库存,您可以联系我们找货
