SFM230-NPPB-S04-SC-BK 数据手册
8
7
4
5
6
1
2
3
REVISIONS
REV.
ECO. NO
DESCRIPTION
DATE
BY
A
2399
INITIAL RELEASE
07/19/2011
LH
B
2688
REMOVE DIMPLE BUMP ON TAILS
10/12/2012
LH
F
F
PIN 1
E
E
.020 0.52
A
PIN 1
.063 1.60
.100 2.54
SFM230-NPPB-S_ _-SC-BK
(STANDARD)
.177 4.50
.020 0.52
D
.100 2.54
.028 0.70
.100 2.54
(NOT REQ'D FOR USE
AS TOP ENTRY)
.050 1.27
D
.030 0.76
RECOMMENDED PCB LAYOUT
.030 0.76
PIN
.050 1.27
SFM230-NPPB-S_ _-SD-BK
(OPPOSITE BEND, APPLICABLE ON EVEN PIN COUNTS)
.063 1.60
.028 0.70
(NOT REQ'D FOR USE
AS TOP ENTRY)
.177 4.50
C
C
.041 1.04
B
.012 0.30
PIN 1
.087 2.20
.091 2.30
.149 3.78
NOTES:
1. INSULATOR MATERIAL: NYLON 6T, UL 94V-0, BLACK.
2. CONTACT MATERIAL: PHOSPHOR BRONZE.
3. CONTACT PLATING: .000030" ~ .000050"NICKEL UNDERPLATE,
GOLD FLASH OVERALL.
4. CURRENT RATING: 1 AMP.
5. INSULATOR RESISTANCE: 5000 MEGOHMS MIN.
6. CONTACT RESISTANCE: 20 MILLIOHMS MAX.
7. DIELECTRIC WITHSTANDING: 500 V AC.
8. OPERATING TEMPERATURE: -40° C TO +105° C.
9. PROCESSING TEMP.: 230° C FOR 60 SECONDS MAX.
(260° C FOR 10 SECONDS MAX.)
(INDICATED TEMPERATURE AND TIME IS FOR COMPONENT INSULATOR.
HIGHER PROCESSING TEMPERATURES MAY BE USED, PROVIDED HEAT IS
APPLIED FROM BACK SIDE OF PCB, AND INSULATOR DOES NOT EXCEED
INDICATED TEMPERATURE AND TIME.)
10. FOR TOP/BOTTOM ENTRY.
11. CONSULT FACTORY FOR THE MATE IF BEING USED AS BOTTOM ENTRY.
8
7
6
.005 0.12
A
A
A
.004 [0.10]
.050 1.27
B
.100 2.54
B
+.006
+0.15
.091
2.30
- .000
0.00
DRAWN
UNLESS OTHERWISE SPECIFIED:
DIMENSIONS ARE IN INCHES [MM]
Pb
TOLERANCES:
.XX= .012 [0.30]
.XXX= .008 [0.20]
.XXXX= .0040 [0.100]
RoHS COMPLIANT
5
4
INTERPRET DIMENSIONS AND
TOLERANCING
PER: ASME Y14.5M-2009
3
DATE
NAME
07/19/11
GC
THE INFORMATION HEREIN CONTAINS
PROPIETARY INFORMATION OF
SULLINS ELECTRONICS AND IS NOT
TO BE REPRODUCED, USED OR
DISCLOSED TO OTHERS FOR ANY
PURPOSE EXCEPT AS SPECIFICALLY
AUTHORIZED IN WRITING BY AN
OFFICER OF SULLINS ELECTRONICS.
TITLE
HEADER FEMALE, .050 CC, T/B ENTRY
PART NUMBER
SIZE
C
54453
SCALE: 6:1
2
SFM230-NPPB-S_ _-S_-BK
CAGE CODE
DWG. NO.
11812
SHEET 1 OF 1
1
REV
B
FILE NAME: 11812, SFM230-NPPB-S_ _-S_-BK
A
SFM230-NPPB-S04-SC-BK 价格&库存
很抱歉,暂时无法提供与“SFM230-NPPB-S04-SC-BK”相匹配的价格&库存,您可以联系我们找货
