Terminal Blocks - Single Row
Series A5000 & Series CB5000
Single Row Terminal Blocks
* Max. rating shown; some options may be rated lower – consult factory.
EuroMag Series
SPECIFICATIONS
Rating: 10A, 300V*
Center Spacing: 0.250” (6.35mm)
Wire Range: #18-30 AWG Cu
Screw Size: #3-48 zinc-plated philslot SEMS screws, wire-ready
standard
Torque Rating: 4 lb-in.
Distance Between Barriers: 0.20” (5.08mm)
Recommended PCB Hole Diameter: 0.062” (1.57mm)
Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min.
Molded Material: Black, UL Rated 94V0 Thermoplastic
Breakdown Voltage: 1600V rms
Agency Information: UL File E62622; CE Certified
Terminal Blocks:
Single Row
A50110507
CB50220807
Edge Connectors,
One-Sided Boards
Dimensions - in (mm)
A5000 Series
Poles
0.75
1.00
1.25
1.50
1.75
2.00
2.25
2.50
2.75
3.00
3.25
3.50
3.75
4.00
4.25
4.50
4.75
5.00
5.25
5.50
5.75
6.00
6.25
6.50
6.75
7.00
7.25
1.06
1.31
1.56
1.81
2.06
2.31
2.56
2.81
3.06
3.31
3.56
3.81
4.06
4.31
4.56
4.81
5.06
5.31
5.56
5.81
6.06
6.31
6.56
6.81
7.06
7.31
7.56
BARRIER ENDS
A
B
Pole
Overall
Centers
Length
0.25
0.50
0.75
1.00
1.25
1.50
1.75
2.00
2.25
2.50
2.75
3.00
3.25
3.50
3.75
4.00
4.25
4.50
4.75
5.00
5.25
5.50
5.75
6.00
6.25
6.50
6.75
7.00
7.25
0.56
0.81
1.06
1.31
1.56
1.81
2.06
2.31
2.56
2.81
3.06
3.31
3.56
3.81
4.06
4.31
4.56
4.81
5.06
5.31
5.56
5.81
6.06
6.31
6.56
6.81
7.06
7.31
7.56
#3-48
screw
0.250
(6.35)
0.12
(3.0)
Ø
0.43
(10.9)
Mount End
B
Compliance
References
02
03
04
05
06
07
08
09
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
MOUNTING ENDS
A
B
Mounting
Overall
Centers
Length
Barrier End
0.50
(12.7)
0.25
(6.35)
0.025
(0.64)
A
Mount End
Barrier End
CB5000 Series
#3-48
screw
0.250
(6.35)
0.12
(3.0)
Ø
0.50
(12.7)
* Dimensions in inches. To convert to millimeters, multiply by 25.4.
Mount End
B
Barrier End
0.50
(12.7)
0.025
(0.64)
Mount End
A
For additional product information, visit www.eaton.com/connectors
Barrier End
4
Terminal Blocks:
Single Row
Part Numbering System Series
Terminal Style
Annn5
nBnCnn5
Base/End
nnn
nn
Screw Options
nnn
1 - mount end
2 - barrier end
01* - handwired
02 - printed circuit
04 - wire wrap tail
EuroMag Series
A5 - standard barrier
CB5 - closed back
Poles
*Only available with mount
Options
0nnn7
02 to 30
02 to 28 on mount
end base
07 - steel SEMS
std. wire ready
C1 to C8 - 0.110˝ QC
L1 to L6 marking options (pg 26)
MP - mounting plate 0.120˝ dia
OJ** - over barrier jumper
**Contact factory for configuration
end base style on A5 Series
Edge Connectors,
One-Sided Boards
Terminal Styles
Inches (Millimeters)
0.16
(4.1)
0.40
(10.2)
0.10
(2.54)
0.12
(3.0)
0.055
(1.40)
0.025
(.64)
0.14
(3.6)
01
Handwired
Compliance
References
0.50
(12.7)
0.032
(0.81)
0.045
(1.14)
02
Circuit Board
0.12
(3.0)
0.025
(0.64)
04
Wire Wrap Tail
CB5 Terminal Exit Options
0.12
(3.0)
Exit Rear (std.)
Screw Options
Wire ready screws standard on all terminal styles
07
Steel SEMS
Zinc-Plated
(B001-7035-J)
07
Standard
Wire Ready
Hardware Options
Jumpers
OJ (OJ12-J)
(Bulk ordering part numbers are in parentheses)
Quick Connects Blade Width 0.110” (For other orientations, contact factory.)
C1 (5C1-J)*
C2 (5C2-J)*
C7 (5C7-J)
C8 (5C8-J)
C4 (5C4-J)*
* N/A on CB5 Series.
5
很抱歉,暂时无法提供与“A50111007”相匹配的价格&库存,您可以联系我们找货
