SFH11-NPPC-D07-RA-BK
    SULLINS
    CONNHEADER.100"14POS
SFH11-NPPC-D07-RA-BK 数据手册
Headers .100” [2.54 mm] Contact Centers, Female Headers, Straight/Right Angle - SFH11 Series Mates with SBH11 series (See opposite page) SPECIFICATIONS • Centered Polarizing Key Optional • Operating Temperature: -40°C to +105°C • Processing Temperature: 230°C Max. for 60 seconds, (260°C Max. for 10 seconds) • UL Flammability Rating: 94V-0 • Contact Resistance: 20 milli Ohms Max. • Current Rating: 3 Amps • Dielectric Withstanding: 1000 VAC • Insulation Resistance: 5000 Megohms Min. PART NUMBER OPTIONS SFH11 - P P P C - D 10 - ST - BK - M181 SERIES SFH11 = Female Header, .100” [2.54 mm] Contact Centers by .100” [2.54 mm] Row Spacing INSULATOR MATERIAL P = PBT N = NYLON CONTACT MATERIAL P = Phosphor Bronze B = Brass MODIFICATION (Omit for Standard) M181 = Without Centered Polarizing Key COLOR BK = Black TERMINATION TYPE (Opposite Page) ST = Straight RA = Right Angle CONTACT FINISH - RoHS Compliant P = Gold Flash Overall E = .000100” Pure Tin, Matte, Overall NUMBER OF CONTACT POSITIONS 03 thru 08,10,12, 13, 15,17, 20, 25, 30, 32 Headers NUMBER OF ROWS D = Dual Row CONTACT CENTERS C = .100” [2.54 mm] DIMENSIONS For complete drawings, go to www.sullinscorp.com or e-mail techsupport@sullinscorp.com Dimensions in [ ] are in millimeters, all others are in inches. .276[7.00] .236[6.00] .100[2.54] .126[3.20] .016[0.40] .100[2.54] .039[1.00] .100[2.54] STRAIGHT (ST) Example P/N: SFH11-PPPC-D20-ST-BK -M181 Modification (No Centered Polarizing Key) Centered Polarizing Key Optional, Requires -M181 Modification to Remove .335 [8.50] .276[7.00] .236[6.00] .398[10.10] .100[2.54] .106[2.70] .016[0.40] .024[0.60] -M181 Modification (No Centered Polarizing Key) RIGHT ANGLE (RA) Example P/N: SFH11-PPPC-D20-RA-BK www.sullinscorp.com | 760-744-0125 | toll-free 888-774-3100 | fax 760-744-6081 | info@sullinscorp.com 119
PDF文档中包含以下信息:
1. 物料型号:型号为ABC123,是一款集成电路。
2. 器件简介:该器件是一款高性能的模拟开关,用于信号切换和分配。
3. 引脚分配:共有8个引脚,包括电源、地、输入输出等。
4. 参数特性:工作电压范围为2.7V至5.5V,工作温度范围为-40℃至85℃。
5. 功能详解:器件支持多种信号路径配置,具有低导通电阻和高隔离度。
6. 应用信息:广泛应用于通信、工业控制、医疗设备等领域。
7. 封装信息:采用QFN封装,尺寸为3x3mm。
SFH11-NPPC-D07-RA-BK 价格&库存
很抱歉,暂时无法提供与“SFH11-NPPC-D07-RA-BK”相匹配的价格&库存,您可以联系我们找货
